MCU Subsystem
BLE_FERP_CTL
- Name: BLE_FERP_CTL Register
- Description: BLE_FERP_CTL Register
- Base Address: 0x4000E000
- Offset: 0x224
31:1 |
Reserved bits |
0 |
FERP_EN |
Enable ferp memory clock & ferp memory access on SoC side by configuring this register to 1 before starting a 2.4G spec use. |
SECURITY_RESET
- Name: SECURITY_RESET Register
- Description: SECURITY_RESET Register
- Offset: 0x22C
- Reset Value: 0x00000028
31:6 |
Reserved bits |
5 |
TRNG |
0x1 |
TRNG soft reset, low active Value:
4 |
Reserved bit |
3 |
EFUSE |
0x1 |
eFuse controller soft reset, low active Value:
2:0 |
Reserved bits |
PMU_ID
- Name: PMU_ID Register
- Description: PMU_ID Register
- Offset: 0x230
- Reset Value: 0x000000B0
31:8 |
Reserved bits |
7:0 |
PMU_ID |
0xB0 |
PMU chip ID |
PWR_AVG_CTL_REG0
- Name: PWR_AVG_CTL_REG0 Register
- Description: PWR_AVG_CTL_REG0 Register
- Offset: 0x234
- Reset Value: 0x00000004
31:24 |
TPA_ADC_OUT |
Real-time value |
18 |
AVG_PWR_ERR |
Indicate ble_tx_en going off before outputting the result. |
17 |
Reserved bit |
16 |
AVG_PWR_RDY |
Indicate that the average value is ready to read. |
15:8 |
AVG_PWR |
Average power data |
7:4 |
SAMPL_PWR |
Take 2 ^ n samples for averaging (0–15). |
3 |
BLE_F_TX_EN |
Forcibly enable internal ble_tx_en. |
2 |
ONESHOT_EN |
0x1 |
Enable one shot mode. |
1 |
Reserved bit |
0 |
PWR_AVG_EN |
Enable the power average calculation block. |
TIMER2BLE_PLUSE_CTRL
- Name: TIMER2BLE_PLUSE_CTRL Register
- Description: TIMER2BLE_PLUSE_CTRL Register
- Offset: 0x238
31:2 |
Reserved bits |
1:0 |
TIMER2BLE_PLUSE_CTRL |
Bluetooth LE pulse selection control: Value:
EFUSE_PWR_DELTA_0
- Name: EFUSE_PWR_DELTA_0 Register
- Description: EFUSE_PWR_DELTA_0 Register
- Offset: 0x254
- Reset Value: 0x0FFF00B4
31:16 |
DELTA1 |
0xFFF |
About 250 μs; an eFuse power controller timing parameter; based on 16 MHz clock |
15:0 |
DELTA0 |
0xB4 |
About 10 μs; an eFuse power controller timing parameter; based on 16 MHz clock |
EFUSE_PWR_DELTA_1
- Name: EFUSE_PWR_DELTA_1 Register
- Description: EFUSE_PWR_DELTA_1 Register
- Offset: 0x258
- Reset Value: 0x000000B4
31:16 |
Reserved bits |
15:0 |
DELTA2 |
0xB4 |
EFUSE_PWR_CTRL_0
- Name: EFUSE_PWR_CTRL_0 Register
- Description: EFUSE_PWR_CTRL_0 Register
- Offset: 0x260
31:5 |
Reserved bits |
4 |
STP |
Write 1 to stop the power sequencer. |
3 |
Reserved bit |
2 |
BGN |
Write 1 to begin the power sequencer. |
1 |
Reserved bit |
0 |
EN |
Enable the eFuse controller. |
EFUSE_PWR_CTRL_1
- Name: EFUSE_PWR_CTRL_1 Register
- Description: EFUSE_PWR_CTRL_1 Register
- Offset: 0x264
31:5 |
Reserved bits |
4 |
DIS_DONE |
eFuse power disable done. Clear on read. |
3:1 |
Reserved bits |
0 |
EN_DONE |
eFuse power enable done. Clear on read. |
MCU_BOOT_DBG
- Name: MCU_BOOT_DBG Register
- Description: MCU_BOOT_DBG Register
- Offset: 0x27C
31:0 |
MCU_BOOT_DBG |
MCU boot debug register; record the boot status. |
MCU_SUB_REG
- Name: MCU_SUB_REG Register
- Description: MCU_SUB_REG Register
- Offset: 0x280
31:14 |
Reserved bits |
13:12 |
GDX_REG_WAIT_STATE |
ROM AHB wait state number |
11:6 |
Reserved bits |
5:4 |
MEM_BOND_OPT |
3:0 |
Reserved bits |
MCU_NMI_CFG
- Name: MCU_NMI_CFG Register
- Description: MCU_NMI_CFG Register
- Offset: 0x284
31:10 |
Reserved bits |
9:0 |
MCU_NMI_SEL |
Select MCU NMI. bit9: aon_irq_sts[IRQ_BLE_PWR_DN_DONE] bit8: aon_irq_sts[IRQ_BLE_PWR_UP_DONE] bit7: timer0_irq bit6: aon_evts[EVT_CLDR_TIMER_EVT_0] bit5: aon_evts[EVT_WD_TIMER_ALMOST_EXP] bit4: aon_evts[EVT_SMC_OSC_EN] bit3: aon_irq_sts[IRQ_PMU_BOD_REDGA] bit2: aon_evts[EVT_BLE_MAC_IRQ] bit1: gpio_1_irq bit0: gpio_0_irq |
CPLL_IRQ_CFG
- Name: CPLL_IRQ_CFG Register
- Description: CPLL_IRQ_CFG Register
- Offset: 0x288
31:1 |
Reserved bits |
0 |
DRIFT_IRQ_EN |
Enable CPLL drift IRQ. |
AON_SW_RST
- Name: AON_SW_RST Register
- Description: AON_SW_RST Register
- Offset: 0x28C
- Reset Value: 0xC5A10000
31:16 |
SET |
W |
0xC5A1 |
Reserved bits |
15:9 |
Always-on software reset magic word for enabling configuration. |
8 |
FULL |
W |
Always-on software reset for full logic |
7:1 |
Reserved bits |
0 |
PARTIAL |
W |
Always-on software reset for partial logic |
MCU_SUBSYS_CG_CTRL[0]
- Name: MCU_SUBSYS_CG_CTRL[0] Register
- Description: MCU_SUBSYS_CG_CTRL[0] Register
- Offset: 0x2C0
31:11 |
Reserved bits |
10 |
WFI_SERIAL_HCLK |
HCLK for serial blocks including I2C, UART, QSPI, and SPI (M & S) Value:
9 |
WFI_APB_SUB_HCLK |
HCLK for APB subsystem including watchdog and timer Value:
8 |
WFI_BLE_BRG_HCLK |
HCLK for Bluetooth LE MCU bridge Value:
7 |
Reserved bits |
6 |
WFI_GPIO_HCLK |
HCLK for GPIOs Value:
5 |
WFI_SNSADC_HCLK |
HCLK for sense ADC Value:
4 |
WFI_ROM_HCLK |
HCLK for ROM Value:
3 |
Reserved bits |
2 |
WFI_HTB_HCLK |
HCLK for hopping table Value:
1 |
Reserved bits |
0 |
WFI_SECU_HCLK |
HCLK for all security blocks including eFuse and TRNG Value:
MCU_SUBSYS_CG_CTRL[1]
- Name: MCU_SUBSYS_CG_CTRL[1] Register
- Description: MCU_SUBSYS_CG_CTRL[1] Register
- Offset: 0x2C4
- Reset Value: 0x0000FFEF
31:11 |
Reserved bits |
10 |
FORCE_SERIAL_HCLK |
0x1 |
9 |
FORCE_APB_SUB_HCLK |
0x1 |
8 |
FORCE_BLE_BRG_HCLK |
0x1 |
7 |
Reserved bits |
6 |
FORCE_GPIO_HCLK |
0x1 |
5 |
FORCE_SNSADC_HCLK |
0x1 |
4 |
FORCE_ROM_HCLK |
HCLK for ROM Value:
3 |
Reserved bits |
2 |
FORCE_HTB_HCLK |
0x1 |
1 |
0x1 |
Reserved bits |
0 |
FORCE_SECU_HCLK |
0x1 |
MCU_SUBSYS_CG_CTRL[2]
- Name: MCU_SUBSYS_CG_CTRL[2] Register
- Description: MCU_SUBSYS_CG_CTRL[2] Register
- Offset: 0x2C8
- Reset Value: 0x00020000
31:19 |
Reserved bits |
18 |
FORCE_SRAM_HCLK |
SRAM HCLK clock Value:
17 |
FORCE_XF_XQSPI_HCLK |
0x1 |
Cache HCLK clock Value:
16:3 |
Reserved bits |
2 |
WFI_SRAM_HCLK |
SRAM HCLK clock during WFI Value:
1 |
WFI_XF_XQSPI_HCLK |
Cache HCLK clock during WFI Value:
0 |
WFI_AON_MCUSUB_HCLK |
mcu_reg_hclk clock during WFI Value:
MCU_PERIPH_PCLK_OFF
- Name: MCU_PERIPH_PCLK_OFF Register
- Description: MCU_PERIPH_PCLK_OFF Register
- Offset: 0x2CC
- Reset Value: 0x30063005
31:30 |
Reserved bits |
29 |
FORCE_PWM_1_PCLK |
0x1 |
pwm_1 CLK Value:
28 |
FORCE_PWM_0_PCLK |
0x1 |
pwm_0 CLK Value:
27:19 |
Reserved bits |
18 |
FORCE_SPI_S_PCLK |
0x1 |
spi_s CLK Value:
17 |
FORCE_SPI_M_PCLK |
0x1 |
spi_m CLK Value:
16:4 |
Reserved bits |
13 |
FORCE_I2C1_PCLK |
0x1 |
i2c_1 CLK Value:
12 |
FORCE_I2C0_PCLK |
0x1 |
i2c_0 CLK Value:
11:3 |
Reserved bits |
2 |
FORCE_UART1_PCLK |
0x1 |
uart_1 CLK Value:
1 |
Reserved bit |
0 |
FORCE_UART0_PCLK |
0x1 |
uart_0 CLK Value:
MCU_PERIPH_CG_LP_EN
- Name: MCU_PERIPH_CG_LP_EN Register
- Description: MCU_PERIPH_CG_LP_EN Register
- Offset: 0x2D0
- Reset Value: 0x000007FF
31:12 |
Reserved bits |
10 |
AHB2APB_ASYNC_BRG_LP_EN |
0x1 |
Enable apb2apb async bridge low-power feature. |
9 |
AHB2APB_BRG_LP_EN |
0x1 |
Enable ahb2apb bridge low-power feature. |
8 |
AHB_BUS_LP_EN |
0x1 |
Enable AHB bus low-power feature. |
7 |
I2C1_LP_SCLK_EN |
0x1 |
Enable i2c1 SCLK low-power feature. |
6 |
I2C0_LP_SCLK_EN |
0x1 |
Enable i2c0 SCLK low-power feature. |
5 |
SPIS_LP_SCLK_EN |
0x1 |
Enable SPIS SCLK low-power feature. |
4 |
SPIM_LP_SCLK_EN |
0x1 |
Enable SPIM SCLK low-power feature. |
3 |
UART1_LP_PCLK_EN |
0x1 |
Enable uart1 PCLK low-power feature. |
2 |
UART1_LP_SCLK_EN |
0x1 |
Enable uart1 SCLK low-power feature. |
1 |
UART0_LP_PCLK_EN |
0x1 |
Enable uart0 PCLK low-power feature. |
0 |
UART0_LP_SCLK_EN |
0x1 |
Enable uart0 SCLK low-power feature. |
MCU_PERIPH_CLK_SLP_OFF
- Name: MCU_PERIPH_CLK_SLP_OFF Register
- Description: MCU_PERIPH_CLK_SLP_OFF Register
- Offset: 0x2D4
31:14 |
Reserved bits |
13 |
PWM1 |
Enable pwm_1 PCLK auto off when CPU is in sleep state. |
12 |
PWM0 |
Enable pwm_0 PCLK auto off when CPU is in sleep state. |
11 |
SPIS |
Enable spi_s PCLK auto off when CPU is in sleep state. |
10 |
SPIM |
Enable spi_m PCLK auto off when CPU is in sleep state. |
9:8 |
Reserved bits |
7 |
I2C1 |
Enable i2c_1 PCLK auto off when CPU is in sleep state. |
6 |
I2C0 |
Enable i2c_0 PCLK auto off when CPU is in sleep state. |
5:2 |
Reserved bits |
1 |
UART1 |
Enable uart_1 PCLK auto off when CPU is in sleep state. |
0 |
UART0 |
Enable uart_0 PCLK auto off when CPU is in sleep state. |
SECU_CLK_CTRL
- Name: SECU_CLK_CTRL Register
- Description: SECU_CLK_CTRL Register
- Offset: 0x2D8
- Reset Value: 0x00003C00
31:14 |
Reserved bits |
13 |
EFUSE_HCLK_SLP_OFF |
0x1 |
Enable eFuse PCLK auto off when CPU is in sleep state. |
12 |
EFUSE_HCLK_FORCE_OFF |
0x1 |
eFuse PCLK Value:
11 |
RNG_HCLK_SLP_OFF |
0x1 |
Enable RNG PCLK auto off when CPU is in sleep state. |
10 |
RNG_HCLK_FORCE_OFF |
0x1 |
RNG PCLK Value:
9:0 |
Reserved bits |
MCU_MISC_CLK
- Name: MCU_MISC_CLK Register
- Description: MCU_MISC_CLK Register
- Offset: 0x2E8
- Reset Value: 0x0000000C
31:4 |
Reserved bits |
3 |
DMA0_HCLK_OFF |
0x1 |
2 |
XQSPI_SCK_OFF |
0x1 |
1:0 |
Reserved bits |
HFOSC_CLK_EN
- Name: HFOSC_CLK_EN Register
- Description: HFOSC_CLK_EN Register
- Offset: 0x2F4
- Reset Value: 0x00000001
31:1 |
Reserved bits |
0 |
EN |
0x1 |
APB_TIMER_DBG
- Name: APB_TIMER_DBG Register
- Description: APB_TIMER_DBG Register
- Offset: 0x340
- Reset Value: 0x0000000F
31:4 |
Reserved bits |
3 |
WDT |
Write 1 to stop the watchdog timer during CPU HALT. |
2 |
DUAL_TIMER |
Write 1 to stop the dual timer during CPU HALT. |
1 |
TIMER1 |
Write 1 to stop the timer1 during CPU HALT. |
0 |
TIMER0 |
Write 1 to stop the timer0 during CPU HALT. |
APB_MON_DBG
- Name: APB_MON_DBG Register
- Description: APB_MON_DBG Register
- Offset: 0x344
31:1 |
Reserved bits |
0 |
BYPASS |
Write 1 to bypass AHB2APB bridge monitor. |
MCU_RELEASE
- Name: MCU_RELEASE Register
- Description: MCU_RELEASE Register
- Offset: 0x380
- Reset Value: 0x20220710
31:0 |
MCU_RELEASE |
0x20220710 |
Contain the RTL release date. |
FPGA_CTRL
- Name: FPGA_CTRL Register
- Description: FPGA_CTRL Register
- Offset: 0x384
31:5 |
Reserved bits |
4 |
EXIST |
This HW is 0: ASIC, 1: FPGA. |
3:2 |
Reserved bits |
1:0 |
MUX_SEL |
Select FPGA debug port signals. |
ST_CALIB
- Name: ST_CALIB Register
- Description: ST_CALIB Register
- Offset: 0x388
- Reset Value: 0x0000013F
31:29 |
Reserved bits |
28 |
STCALIB_CLK |
mcu_stclk_sel Value:
27:26 |
Reserved bits |
25:0 |
STCALIB |
0x13F |
STCAILIB to ARM Core STCLK = 32 KHz by default STCALIB[25] = 0, use STCLK. STCALIB[24] = 0, exact multiple 10 ms STCALIB[23:0] = 13F, 10 ms/(1/32 KHz) -1 = 319 = 0x13F |
TESTBUS_CTRL
- Name: TESTBUS_CTRL Register
- Description: TESTBUS_CTRL Register
- Offset: 0x38C
| 31:20 | RSVD | R | 0x0 | Reserved bits |
| 19:17 | SEL_PL_LO | RW | 0x0 |
Select testbus pad low bank low bits[07:00]. val | subsystem 000 | comm testbus[7:0] 001 | aon testbus[7:0] 010 | xf cache testbus[7:0] 011 | clk testbus[7:0] 100 | mcu testbus[7:0] 101 | htable testbus[7:0] |
| 16:14 | SEL_PL_HI | RW | 0x0 |
Select testbus pad low bank high bits[15:08]. val | subsystem 000 | comm testbus[15:8] 001 | aon testbus[15:8] 010 | xf cache testbus[15:8] 011 | clk testbus[15:8] 100 | mcu testbus[15:8] 101 | htable testbus[15:8] |
| 13:11 | SEL_PH_LO | RW | 0x0 |
Select testbus pad high bank low bits[23:16]. val | subsystem 000 | comm testbus[7:0] 001 | aon testbus[7:0] 010 | xf cache testbus[7:0] 011 | clk testbus[7:0] 100 | mcu testbus[7:0] 101 | htable testbus[7:0] |
| 10:8 | SEL_PH_HI | RW | 0x0 |
Select testbus pad high bank high bits[31:24]. val | subsystem 000 | comm testbus[15:8] 001 | aon testbus[15:8] 010 | xf cache testbus[15:8] 011 | clk testbus[15:8] 100 | mcu testbus[15:8] 101 | htable testbus[15:8] |
| 7:5 | SEL_LO | RW | 0x0 |
Select MCU testbus low bits[07:00]. val | ip 00 | dma testbus[7:0] 01 | bus_matrix testbus[7:0] 10 | apb_serial testbus[7:0] |
| 4:2 | SEL_HI | RW | 0x0 |
Select MCU testbus high bits[15:08]. val | ip 00 | dma testbus[15:8] 01 | bus_matrix testbus[15:8] 10 | apb_serial testbus[15:8] |
| 1:0 | ORDER | RW | 0x0 |
Testbus order val | order 00 | testbus[31:16] = bits[31:28] [27:24] [23:20] [19:16] 01 | testbus[31:16] = bits[19:16] [31:28] [27:24] [23:20] 10 | testbus[31:16] = bits[23:20] [19:16] [31:28] [27:24] 11 | testbus[31:16] = bits[27:24] [23:20] [19:16] [31:28]
00 | testbus[15:00] = bits[15:12] [11:08] [07:04] [03:00] 01 | testbus[15:00] = bits[03:00] [15:12] [11:08] [07:04] 10 | testbus[15:00] = bits[07:04] [03:00] [15:12] [11:08] 11 | testbus[15:00] = bits[11:08] [07:04] [03:00] [15:12] |
