文档中心 > GR533x Datasheet/ System/ Registers/ Always-on RF Control Copy URL
RF5
  • Name: RF5 Register
  • Description: RF5 Register
  • Base Address: 0x4000A900
  • Offset: 0x0
表 149 RF5 Register
31:24
23:16
RF_MUX_REG2
[7] if 0 --> 1 MHz clock; if 1 --> 2 MHz
[6] 0: TPP; 1: TPN (if tpc_ena = 0); if tpc_ena = 1 --> dda_out
[5] ADC MUX en (Need to disable original MUX: RF_MUX_REG1[7] = 0)
[4:1] NC
[0] ADCMUX_en
15:8
7:0
RF_MUX_REG1
[7] 1: Enable test MUX; 0: tri-state
[6:4] block selection
[3] 1: TPP; 0: TPN
[2:0] signal selection inside block
RF6
  • Name: RF6 Register
  • Description: RF6 Register
  • Offset: 0x4
  • Reset Value: 0x38C6A8B0
表 150 RF6 Register
31:0
RF_CPLL_REG1
0x38C6A8B0
[30] NC
[29:28] Pre division before CP (00: no division;11: divided by 16); default: div 16
[27:23] CPLL loop filter third capacitor control - 2.4 pF max
[22:18] CPLL loop filter second capacitor control - 4.8 pF max
[17:13] CPLL loop filter first capacitor control – 56 pF max
[12:8] CPLL loop filter resistor control – 160 kohm max
[7:6] Control clock freq. doubler delay, to attain 50% duty cycle.
[5] Select current source. 1 = from bandgap; 0 = from GM bias cell
[4] Select current source. 1 = from bandgap; 0 = from GM bias cell
[3] Enable clock freq. doubler.
[2] Enable CPLL VCO.
[1] 1: cpll_rst_n = 0, reset DPLL; 0: cpll_rst_n follows sequencer.
[0] Select MUX control (0 = CPLL CLK out; 1 = doubler CLK out)
RF7
  • Name: RF7 Register
  • Description: RF7 Register
  • Offset: 0x8
  • Reset Value: 0x05808492
表 151 RF7 Register
31:0
RF_CPLL_REG2
0x05808492
[31:30] TH
[29:28] TL
[27:26] extra divider after the "m_div", to increase DPLL counting accuracy
[25:18] DPLL ideal count
[17] MUX control to select the source of the KVCO word (0 = DPLL engine; 1 = external word)
[16:12] coarse tuning bits for VCO to set the mid frequency near the locking frequency
[11:9] charge pump code programmability (000-5 μA to 111-40 μA); default: 15 μA
[8:6] CPLL VCO KVCO control; default: 96 MHz/V
[5:0] feedback divider; default: divided by 48
RF8
  • Name: RF8 Register
  • Description: RF8 Register
  • Offset: 0xC
  • Reset Value: 0x4F261008
表 152 RF8 Register
31:0
RF_XO_REG1
0x4F261008
[31:28] comparator reference to disable the chirp noise injection
[27:24] Control the strength of chirp buffers to limit over drive of crystal; LSB must be 1.
[23:20] chirp oscillator KVCO and center frequency control; 1111 = highest frequency and KVCO
[19:17] chirp oscillator ramp control; 111 - slowest; 000- fastest
[16] Double the current of the biasing circuit.
[15] noise injection to be enabled in SU sequence
[14] Negative cap generator to be enabled in SU sequence
[13] Need to transition to high with xo_enable for fast SU.
[12:8] CK_LDO trimming control bits
[7] Use the CK_LDO as a switch (bypass regulation).
[6] Enable internal load for stability.
[5] Double the current of the biasing circuit.
[4:0] XO core current programmability; 32 μA (00001) to 992 μA (11111), unit: 32 μA
RF9
  • Name: RF9 Register
  • Description: RF9 Register
  • Offset: 0x10
  • Reset Value: 0x25B40094
表 153 RF9 Register
31:0
RF_XO_REG2
0x25B40094
[31] rc_cal_ena
[30] rc_cal_reset_b
[29:28] rc_cal_prediv
[27:20] rc_cal_n_ideal_count
[19] rc_cal_override
[18:10] Cload programmability from 50 fF to 26 pF on each side
[9:5] number of Xtal cycles for frequency settling after all SU sequences are done
<11>: 128 μs; <10>: 64 μs; <9>: 32 μs; <8>: 16 μs; <7>: 8 μs; default: 32 μs
[4:0] number of Xtal cycles before disconnecting negative cap
<11>: 128 μs; <10>: 64 μs; <9>: 32 μs; <8>: 16 μs; <7>: 8 μs; default: 160 μs
RF_RD_REG_0
  • Name: RF_RD_REG_0 Register
  • Description: RF_RD_REG_0 Register
  • Offset: 0x40
表 154 RF_RD_REG_0 Register
31:21
20:16
CPLL_CRSCDE
PLL frequency value
15:8
7:0
RF_ID
RF ID number
RF_XO_BIAS_VAL
  • Name: RF_XO_BIAS_VAL Register
  • Description: RF_XO_BIAS_VAL Register
  • Offset: 0x68
  • Reset Value: 0x40284028
表 155 RF_XO_BIAS_VAL Register
31
Reserved bit
30:22
CAP_LO
0x100
XO capacitance parameter
21:16
BIAS_LO
0x28
XO bias parameter
15
Reserved bit
14:6
CAP_HI
0x100
5:0
BIAS_HI
0x28
XO bias parameter
RF_INTF_OVR_EN_0
  • Name: RF_INTF_OVR_EN_0 Register
  • Description: RF_INTF_OVR_EN_0 Register
  • Offset: 0xC0
表 156 RF_INTF_OVR_EN_0 Register
31:24
3
RST_N
Value for rst_n overwrite interface
2
CPLL_EN
Value for cpll_en overwrite interface
TUNE_EN
Value for tune_en overwrite interface
XO_EN
Value for xo_en overwrite interface
RF_INTF_OVR_VAL_0
  • Name: RF_INTF_OVR_VAL_0 Register
  • Description: RF_INTF_OVR_VAL_0 Register
  • Offset: 0xC4
表 157 RF_INTF_OVR_VAL_0 Register
31:24
3
RST_N
2
CPLL_EN
TUNE_EN
XO_EN
RF_INTF_OVR_RD_0
  • Name: RF_INTF_OVR_RD_0 Register
  • Description: RF_INTF_OVR_RD_0 Register
  • Offset: 0xC8
表 158 RF_INTF_OVR_RD_0 Register
31:24
3
RST_N
Current rst_n value. When RF_INTF_OVR_EN_0[3] = 0x1, the value equals RF_INTF_OVR_VAl_0[3]; when RF_INTF_OVR_EN_0[3] = 0x0, the value is controlled by software.
2
CPLL_EN
Current cpll_en value
TUNE_EN
Current tune_en value
XO_EN
Current xo_en value
RF_INTF_OVR_EN_1
  • Name: RF_INTF_OVR_EN_1 Register
  • Description: RF_INTF_OVR_EN_1 Register
  • Offset: 0xCC
表 159 RF_INTF_OVR_EN_1 Register
31:1
XO_BIAS_SW
Value for xo_bias overwrite interface
RF_INTF_OVR_VAL_1
  • Name: RF_INTF_OVR_VAL_1 Register
  • Description: RF_INTF_OVR_VAL_1 Register
  • Offset: 0xD0
表 160 RF_INTF_OVR_VAL_1 Register
31:1
XO_BIAS_SW
RF_INTF_OVR_RD_1
  • Name: RF_INTF_OVR_RD_1 Register
  • Description: RF_INTF_OVR_RD_1 Register
  • Offset: 0xD4
表 161 RF_INTF_OVR_RD_1 Register
31:1
XO_BIAS_SW
