Transfer Type Flow Control
The device supports DMA as flow controller only. There are four transfer types:
- Memory to memory
- Memory to peripheral
- Peripheral to memory
- Peripheral to peripheral
Transfer Width
For memory, the source transfer width must be less than or equal to the data bus width of AHB master interface, normally 8, 16, or 32 bits. For a non-memory, the source transfer width is equal to the peripheral FIFO width.
For memory, the destination transfer width must be less than or equal to the data bus width of AHB master interface, normally 8, 16, or 32 bits. For a non-memory, the destination transfer width is equal to the peripheral FIFO width.
- Source address increment: It indicates whether to increase, decrease, or remain the source address on every source transfer. If the device is fetching data from a source peripheral FIFO with a fixed address, then set this field to No change.
- Destination address increment: This decides whether to increase, decrease, or remain the destination address on every source transfer. If the device is fetching data from a destination peripheral FIFO with a fixed address, then set this field to No change.
Channel Priority
Each channel has a programmable priority in the range of 0–5, from lowest to highest. Channel priority applies to most scenarios except those on master bus. It is worth noting that a request for the master bus interface can be made at any time, but the request is granted only after the current AHB transfer (burst or single) completes. Therefore, when the master interface is transferring data for a low-priority channel while a high priority channel requests service, it completes the current AHB transfer (burst or single) for the low-priority channel before switching to data transfer for the high one.
DMA Transfers
DMA has five channels in total; each channel has a FIFO and is independent from each other. The FIFO of each channel is 32-bit wide. After the DMA channel is enabled, the DMA obtains data from the source according to the bit width configured for the source and stores the data into the DMA FIFO.
The DMA takes out the data from the DMA FIFO according to the bit width configured for the target and sends the data to the destination. Regardless of the configured transmission bit width, the data obtained from the source is compactly stored (this helps maximize the use of DAM FIFO storage space).
For example, the transmission bit width is 16 bits, and the FIFO bit width is 32 bits, so one depth of DMA FIFO will store two 16-bit data entries. It is worth mentioning that when DMA is used as flow control, the total number of bytes (blk_size_bytes_dma) transmitted by DMA in a single transmission depends on the product of the source transmission bit width (src_single_size_bytes) and the block size (CTL_HIx.BLOCK_TS). The detailed calculation methods are as follows:
Source Interface Width | Destination Interface Width | Block Size (DMA as Flow Control) | Source Content: Address/Data | Transfer Operations | Destination Content: Address/Data |
8 | 8 | 4 | @0x0/B0 @0x1/B1 @0x2/B2 @0x3/B3 |
8 | 16 | 4 | @0x0/B0 @0x1/B1 @0x2/B2 @0x3/B3 |
@0x0/B1B0 @0x2/B3B2 |
8 | 32 | 4 | @0x0/B0 @0x1/B1 @0x2/B2 @0x3/B3 |
@0x0/B3B2B1B0 |
16 | 8 | 2 | @0x0/B1B0 @0x2/B3B2 |
16 | 16 | 2 | @0x0/B1B0 @0x2/B3B2 |
16 | 32 | 2 | @0x0/B1B0 @0x2/B3B2 |
@0x0/B3B2B1B0 |
32 | 8 | 1 | @0x0/B3B2B1B0 |
32 | 16 | 1 | @0x0/B3B2B1B0 |
32 | 32 | 1 | @0x0/B3B2B1B0 |
@0x0/B3B2B1B0 |
DMA Interrupt
For each channel, there are three types of interrupt sources:
- IntTfr: DMA Transfer Complete Interrupt
- IntBlock: Block Transfer Complete Interrupt. This interrupt is generated on DMA block transfer completion to the destination peripheral.
- IntErr: Error Interrupt. This interrupt is generated when an ERROR response is received from an AHB slave on the HRESP bus during a DMA transfer. In addition, the DMA transfer is cancelled, and the channel is disabled.
The DMA_RAW_x, DMA_STAT_x, DMA_MASK_x, and DMA_CLR_x registers are provided to manage interrupts. The DMA_MASK_x registers is used to enable or disable the block transfer complete interrupt, DMA transfer complete interrupt, and error interrupt. By reading the DMA_STAT_x registers or DMA_RAW_x registers, you can check whether the interruption have occurred. To clear interrupts, write 1 to the DMA_CLR_x registers.
- DMA_MASK_x registers: Used to enable or disable the block transfer complete interrupt, DMA transfer complete interrupt, and error interrupt.
- DMA_STAT_x or DMA_RAW_x registers: Used to reply whether the interruption have occurred.
- DMA_CLR_x registers: Write 1 to DMA_CLR_x to clear interrupts.
Each channel of DMA can communicate with designated peripheral devices through the assigned hardware handshaking interface. The hardware handshaking interfaces are assigned as shown in the following table. The developer can program the CFG_HIx.DEST_PER or CFG_HIx.SRC_PER to assign a handshaking interface for each channel source and destination.
DMA0 Request | Peripheral Name | Peripheral Description |
0x0 | BLE CTE | BLE Constant Tone Extension |
0x1 | PWM | PWM Coding |
0x2 | SPIM TX | SPI Master Transmit |
0x3 | SPIM RX | SPI Master Receive |
0x4 | SPIS TX | SPI Slave Transmit |
0x5 | SPIS RX | SPI Slave Receive |
0x6 | UART0 TX | UART0 Transmit |
0x7 | UART0 RX | UART0 Receive |
0x8 | UART1 TX | UART1 Transmit |
0x9 | UART1 RX | UART1 Receive |
0xA | SNSADC | Sense ADC |
0xB | NC | / |
0xC | I2C0 TX | I2C0 Transmit |
0xD | I2C0 RX | I2C0 Receive |
0xE | I2C1 TX | I2C1 Transmit |
0xF | I2C1 RX | I2C1 Receive |
