Real-Time Counter (RTC/Calendar)
The Real-time Counter (RTC) modules provide a generic, low-power timer running on a low-frequency clock source. Because the RTC modules are in the AON domain, the timer can keep running when the MCU is off. The modules can also wake up the system from sleep mode.
The RTC tick event interrupt module enables low-power "tick-less" RTOS implementation as it optionally provides a regular interrupt source for an RTOS without the need to use the ARM® SysTick feature. Using the RTC tick event rather than the SysTick allows the CPU to be powered down while still keeping RTOS scheduling active.
- One ordinary compare interrupt
- One tick event, supporting one-time counting and auto loading mode
- 32-bit up-counter register, supporting reading and writing
- 32-bit compare register, supporting reading and writing
- 32-bit down-tick register, supporting reading and writing
- One clock divider, supporting NO_DIV, DIV_2, DIV_4, DIV_8, DIV_16, DIV_32, DIV_64, and DIV_128
- Flexible clock source selections from LFRC_32K or LFXO_32K
- An independent interrupt entry
- The software has to enable RTC PMU LPD (GFG0.EN = 1) before using the RTC.
- The CFG1 register is a read/write register when the RTC is disabled, and it is read only when the RTC is enabled. Writing to the CFG1 register when the RTC is enabled has no effect.
- The OVERFLOW, ALARM, and tick event interrupts are enabled by default.
- When RTC is enabled, the TIMER_R register starts to count. When users set the values of the TIMER_W register and the VAL bit to 1, the calendar module synchronizes the count value to the TIMER_R register and starts timing.
- When RTC is disabled, all register values must be cleared to restore the default values.
- When the value of the TIMER_R register is equal to that of the ALARM_R register, the ordinary compare interrupt is triggered.
- RTC tick event interrupt register is a value-decreasing register. When the auto reloading mode is set (CFG0.TICK_MDOE = 1), the value of the counter (TICK_W) is automatically reloaded (TICK_R) when the interrupt is triggered.
- When the count value of the TIMER_R register overflows, the overflow interrupt is triggered, and the TIMER_R register continues counting from 0.
The AON_WDT, RTC, and SLP TIMER share the same clock source selection. The clock source can be LFRC_32K or LFXO_32K which are described in "Clocks".
CFG0
- Name: CFG0 Register
- Description: This register sets RTC configurations.
- Base Address: 0x4000A600
- Offset: 0x00
Bits | Field Name | RW | Reset | Description |
31:25 |
Reserved bits |
24 |
CFG |
W |
Writing 1 to this register triggers the calendar timer configuration. |
23:11 |
Reserved bits |
10 |
TICK_MDOE |
Set the RTC tick event mode.
9 |
TICK_SET |
Set the RTC tick event timer value. |
8 |
TICK_EN |
Enable RTC tick event. |
7:5 |
Reserved bits |
4 |
WRAP_CLR |
Clear the wrap counter. |
3 |
ALARM_SET |
Set the RTC ALARM timer value. |
2 |
ALARM_EN |
Enable RTC ALARM timer. |
1 |
TIME_SET |
Set the RTC initial timer value. |
0 |
EN |
Enable RTC timer. |
CFG1
- Name: CFG1 Register
- Description: This register is used to set the frequency division coefficient.
- Offset: 0x4
31:3 |
Reserved bits |
2:0 |
DIV |
INT_EN
- Name: INT_EN Register
- Description: This register is used to enable RTC interrupts.
- Offset: 0x14
- Reset Value: 0x00000007
31:3 |
Reserved bits |
2 |
TICK |
0x1 |
RTC tick event interrupt. Write 1 to enable the interrupt. |
1 |
WRAP |
0x1 |
RTC overflow interrupt. Write 1 to enable the interrupt. |
0 |
ALARM |
0x1 |
RTC COMPARE interrupt. Write 1 to enable the interrupt. |
INT_STAT
- Name: IRQ_STAT Register
- Description: This register is used to get interrupt status of the RTC.
- Offset: 0x18
31:3 |
Reserved bits |
2 |
TICK |
RTC tick event interrupt. Write 1 to clear the interrupt. |
1 |
WRAP |
RTC overflow interrupt. Write 1 to clear the interrupt. |
0 |
ALARM |
RTC COMPARE interrupt. Write 1 to clear the interrupt. |
STAT
- Name: STAT Register
- Description: This register is used to get the RTC status.
- Offset: 0x38
31:12 |
Reserved bits |
11:8 |
WRAP_CNT |
Calendar timer wrap counter |
7:5 |
Reserved bits |
4 |
BUSY |
Calendar timer is busy. The application layer can perform other operations until this bit is set is 0. |
3:1 |
Reserved bits |
0 |
STAT |
RTC timer is running. |
ALARM_W
- Name: ALARM_W Register
- Description: This register is used to set the ALARM timer value.
- Offset: 0x40
31:0 |
VAL |
TIMER_W
- Name: TIMER_W Register
- Description: This register is used to set the RTC timer value.
- Offset: 0x44
31:0 |
VAL |
TICK_W
- Name: TICK_W Register
- Description: This register is used to set the tick event timer value.
- Offset: 0x48
31:0 |
VAL |
TIMER_R
- Name: TIMER_R Register
- Description: This register is used to get the internal value of the RTC timer.
- Offset: 0x50
31:0 |
VAL |
Current internal value of the RTC timer |
ALARM_R
- Name: ALARM Register
- Description: This register is used to get the value of the RTC ALARM timer.
- Offset: 0x54
31:0 |
VAL |
Current internal value of the RTC ALARM timer |
TICK_R
- Name: TICK_RD Register
- Description: This register is used to get the value of the RTC tick event timer.
- Offset: 0x58
31:0 |
VAL |
Current internal value of the RTC tick event timer. |
