文档中心 > GR533x Datasheet/ System/ Registers/ Clock Calibration Copy URL
Clock Calibration
SL_CLK_CTRL
  • Name: SL_CLK_CTRL Register
  • Description: This register enables SL clock calibration.
  • Base Address: 0x4000E400
  • Offset: 0x0
表 226 SL_CLK_CTRL Register
31:1
EN
Enable clock calibration block.
  • 0x1: Enable the block.
  • 0x0: Disable the block.
SL_CLK_CNT
  • Name: SL_CLK_CNT Register
  • Description: This register sets the number of cycles of the slow clock.
  • Offset: 0x4
表 227 SL_CLK_CNT Register
31:12
11:0
COUNT
Number of cycles of the slow clock
SL_CLK_STAT
  • Name: SL_CLK_STAT Register
  • Description: This register indicates the calibration status.
  • Offset: 0x8
表 228 SL_CLK_STAT Register
31:2
OVER
Fast clock counter overflow. Need to reduce slow clock cnt_val.
DONE
Calibration done status
SL_CLK_CNT0
  • Name: SL_CLK_CNT0 Register
  • Description: This register sets the fast clock counter value.
  • Offset: 0xC
表 229 SL_CLK_CNT0 Register
31:24
23:0
VAL
Fast clock counter value
SL_CLK_CNT1
  • Name: SL_CLK_CNT1 Register
  • Description: This register reads the current counter value of the slow clock.
  • Offset: 0x10
表 230 SL_CLK_CNT1 Register
31:12
11:0
VAL
Read the current counter value of the slow clock.
SL_CLK_INT_EN
  • Name: SL_CLK_INT_EN Register
  • Description: This register enables the clock interrupt.
  • Offset: 0x14
  • Reset Value: 0x00000003
表 231 SL_CLK_INT_EN Register
31:2
OVER
0x1
Interrupt Enable ONLY. The status in CLK_STAT can be read no matter whether the interrupt is enabled.
DONE
0x1
SL_CLK_INT_CLR
  • Name: SL_CLK_INT_CLR Register
  • Description: This register clears the clock interrupt.
  • Offset: 0x18
表 232 SL_CLK_INT_CLR Register
31:2
OVER
W
Write the corresponding bit to clear the interrupt.
DONE
W
SL_CLK_SEL
  • Name: SL_CLK_SEL Register
  • Description: This register selects the slow clock source.
  • Offset: 0x20
表 233 SL_CLK_SEL Register
31:2
1:0
SLOW_CLK_SEL
Select slow clock source. Only valid for the defined source value
  • 0x0: LFXO_32K
  • 0x1: LFRC_32K
  • 0x2: RNG_32K from RNG_OSC
HS_CLK_CTRL
  • Name: HS_CLK_CTRL Register
  • Description: This register enables HS clock calibration.
  • Offset: 0x100
表 234 HS_CLK_CTRL Register
31:1
EN
HS_CLK_CNT
  • Name: HS_CLK_CNT Register
  • Offset: 0x104
表 235 HS_CLK_CNT Register
31:12
11:0
COUNT
HS_CLK_STAT
  • Name: HS_CLK_STAT Register
  • Offset: 0x108
表 236 HS_CLK_STAT Register
31:2
OVER
DONE
HS_CLK_CNT0
  • Name: HS_CLK_CNT0 Register
  • Offset: 0x10C
表 237 HS_CLK_CNT0 Register
31:24
23:0
VAL
HS_CLK_CNT1
  • Name: HS_CLK_CNT1 Register
  • Offset: 0x110
表 238 HS_CLK_CNT1 Register
31:12
11:0
VAL
HS_CLK_INT_EN
  • Name: HS_CLK_INT_EN Register
  • Offset: 0x114
表 239 HS_CLK_INT_EN Register
31:2
OVER
0x1
DONE
0x1
HS_CLK_INT_CLR
  • Name: HS_CLK_INT_CLR Register
  • Offset: 0x118
表 240 HS_CLK_INT_CLR Register
31:2
OVER
W
DONE
W
HS_CLK_SEL
  • Name: HS_CLK_SEL Register
  • Offset: 0x120
表 241 HS_CLK_SEL Register
31:2
1:0
SLOW_CLK_SEL
  • 0x0: LFXO_32K
  • 0x1: LFRC_32K
  • 0x2: XO_32K from XO_32M
