Cache
CACHE_REGS
CTRL0
  • Name: CTRL0 Register
  • Description: CTRL0 Register
  • Base Address: 0x4000D000
  • Offset: 0x0
  • Reset Value: 0x00000013
表 162 CTRL0 Register
31:12 RSVD R 0x0 Reserved bits
11 DIRECT_MAP_EN RW 0x0
Enable direct map.
  • 0x0: Enable 4-way associative map.
  • 0x1: Enable direct map (no effect for sequential access).
10 CLK_FORCE_EN_3 RW 0x0
Cache_FSM and cache memory clock gating
  • 0x0: Forcibly disable gating.
  • 0x1: Enable gating dynamically.
9 CLK_FORCE_EN_2 RW 0x0
APB clock gating control
8 CLK_FORCE_EN_1 RW 0x0
Cache CLK_96 gating control
7 CLK_FORCE_EN_0 RW 0x0
XQSPI and cache HCLK gating control
6 BUF_DIS RW 0x0
Disable cache buffer preloading.
  • 0x0: Enable cache preloading.
  • 0x1: Disable cache preloading.
5 DIS_SEQ RW 0x0
Disable sequential cache access.
  • 0x0: Enable cache sequential access.
  • 0x1: Disable cache sequential access.
4 HITMISS RW 0x1
Clear hit/miss counters.
  • 0x0: hit and miss counters in normal mode
  • 0x1: hit and miss counters in clear mode (default)
3 FIFO RW 0x0
Clear LFU FIFO.
  • 0x0: FIFO in normal mode (default)
  • 0x1: FIFO in clear mode
1 FLUSH RW 0x1
Enable tag memory flushing.
Out of resetting tag memory will get flushed unless tag memory retention is enabled (tag_ret signal lives in CPU register space).
  • 0x0: Tag memory flushing is disabled.
  • 0x1: Tag memory flushing is enabled.
0 DIS RW 0x1
Disable cache.
  • 0x0: Enable cache.
  • 0x1: Disable cache disabled (default).
HIT_COUNT
  • Name: HIT_COUNT Register
  • Description: HIT_COUNT Register
  • Offset: 0x8
表 163 HIT_COUNT Register
31:0
HITCOUNT
Read cache hit count (if bit[4] of CTRL0 is 0).
MISS_COUNT
  • Name: MISS_COUNT Register
  • Description: MISS_COUNT Register
  • Offset: 0xC
表 164 MISS_COUNT Register
31:0
MISSCOUNT
Read cache miss count (if bit[4] of CTRL0 is 0).
STAT
  • Name: STAT Register
  • Description: STAT Register
  • Offset: 0x10
表 165 STAT Register
31:1
STAT
  • 0x0: tag flushing not busy
  • 0x1: tag flushing busy
QSPI_REGS
TX_DATA
  • Name: TX_DATA Register
  • Description: TX_DATA Register
  • Base Address: 0x4000D400
  • Offset: 0x0
表 166 TX_DATA Register
31:0
TX
W
Serial transmit data register
No packing of transmit data is attempted. That is, the number of bits transmitted per FIFO element is determined by the “bitsize” value in the Control Register (e.g. bitsize = 010 means only 12 bits are used). In addition, the “msb1st” value in the Control Register determines whether the least-significant bits or the most-significant bits of the FIFO element are used.
RX_DATA
  • Name: RX_DATA Register
  • Description: RX_DATA Register
  • Offset: 0x4
表 167 RX_DATA Register
31:0
RX
Serial receive data register
No packing of receive data is attempted. That is, the number of bits stored per FIFO element is determined by the “bitsize” value in the Control Register (e.g. bitsize = 011 means only 16 bits are used).
CTRL
  • Name: CTRL Register
  • Description: CTRL Register
  • Offset: 0xC
  • Reset Value: 0x00000021
表 168 CTRL Register
31:16
15:14
TXWMARK
  • 0x0: QSPI_FIFO_DEPTH/8
  • 0x1: QSPI_FIFO_DEPTH/4
  • 0x2: QSPI_FIFO_DEPTH/2
  • 0x3: QSPI_FIFO_DEPTH/2 + QSPI_FIFO_DEPTH/4
13:12
RXWMARK
11
MWAITEN
  • 0x0: Disable delay (full speed).
  • 0x1: Enable delay.
10
DMA
Not used
  • 0x0: Disable DMA mode.
  • 0x1: Enable DMA mode.
9:6
5
MASTER
0x1
qspi_master flag
4
CPOL
  • 0x0: SPI clock rests low.
  • 0x1: SPI clock rests high.
3
CPHA
  • 0x0: First bit(s) of sdataOut occur as SS is asserted.
  • 0x1: sdataOut occurs on first SPI clock edge after SS
2
MSB1ST
MSB/LSB
  • 0x1: MSB first
  • 0x0: LSB first
CONTXFER
0x1
Continuous Transfer bit. This is relevant for Master operation only.
Note that this setting also affects the timing of the master output enable signal, sdataOutEnMN.
  • 0x0: ssOut goes inactive between successive transfers.
  • 0x1: ssOut stays active until the TX FIFO is empty AND the contXferExtend bit (in the Auxiliary Control Register) is low.
AUX_CTRL
  • Name: AUX_CTRL Register
  • Description: AUX_CTRL Register
  • Offset: 0x10
  • Reset Value: 0x00000070
表 169 AUX_CTRL Register
31:8
7
CONTXFERX
Continuous Transfer Extend Bit. This is relevant for Master operation only. Further, this bit has no effect if the contXfer bit is 0. This register bit is synchronized to the SCLK domain for use there. Note that this setting also affects the timing of the master output enable signal, sdataOutEnMN.
  • 0x0: Set to 0 to have ssOut[x] become inactive when the TX FIFO is empty.
  • 0x1: Set to 1 to have ssOut[x] remain active even when the TX FIFO is empty.
6:4
BITSIZE
0x7
  • 0x0: 4-bit serial mode
  • 0x1: 8-bit serial mode
  • 0x2: 12-bit serial mode
  • 0x3: 16-bit serial mode
  • 0x4: 20-bit serial mode
  • 0x5: 24-bit serial mode
  • 0x6: 28-bit serial mode
  • 0x7: 32-bit serial mode
3
INHIBITDIN
Set to 1 to inhibit the SPI serializers from writing to the Read Data FIFO.
2
INHIBITDOUT
Set to 1 to inhibit the SPI serializers from reading the Transmit FIFO.
Note that this is intended to be used as a Slave mode configuration. In many cases, a Slave simply receives data from a Master; in these cases, setting this bit will allow the Slave to receive data without causing a TX FIFO underflow condition.
1:0
QMODE
  • 0x0: normal SPI
  • 0x1: reserved
  • 0x2: dual SPI
  • 0x3: quad SPI
STAT
  • Offset: 0x14
  • Reset Value: 0x0000002C
表 170 STAT Register
31:8
7
RXFULL
  • 0x0: RX FIFO is not full.
  • 0x1: RX FIFO is full.
6
RXWMARK
  • 0x0: The received data is less than the watermark.
  • 0x1: The received data is more than or equal to the watermark.
5
RXEMPTY
0x1
  • 0x0: RX FIFO is not empty.
  • 0x1: RX FIFO is empty.
4
TXFULL
  • 0x0: TX FIFO is not full.
  • 0x1: TX FIFO is full.
3
TXWMARK
0x1
  • 0x0: The data in TX FIFO is more than the watermark.
  • 0x1: The data in TX FIFO is less than or equal to the watermark.
2
TXEMPTY
0x1
  • 0x0: TX FIFO is not empty.
  • 0x1: TX FIFO is empty.
XFERIP
Transfer is in progress (ssOut/ssIn is active).
  • 0x0: CS is inactive.
  • 0x1: CS is active.
SLAVE_SEL
  • Name: SLAVE_SEL Register
  • Description: SLAVE_SEL Register
  • Offset: 0x18
表 171 SLAVE_SEL Register
31:4
3
OUT3
  • 0x0: Do not select slave 1 for TX/RX.
  • 0x1: Select Slave 1 for TX/RX.
Only bit0 is used.
2
OUT2
Only bit0 is used.
OUT1
Only bit0 is used.
OUT0
Only bit0 is used.
SLAVE_SEL_POL
  • Name: SLAVE_SEL_POL Register
  • Description: SLAVE_SEL_POL Register
  • Offset: 0x1C
表 172 SLAVE_SEL_POL Register
31:4
3
POL3
  • 0x0: CS is an active low signal.
  • 0x1: CS is an active high signal.
Only bit0 is used.
2
POL2
Only bit0 is used.
POL1
Only bit0 is used.
POL0
Only bit0 is used.
INTEN
  • Name: INTEN Register
  • Description: INTEN Register
  • Offset: 0x20
表 173 INTEN Register
31:7
6:0
INT_EN
[0] TX FIFO empty interrupt
[1] TX FIFO watermark interrupt
[2] RX FIFO watermark interrupt
[3] RX FIFO full interrupt
[4] ro_xferip from high to low
[5] no use
[6] no use
  • 0x0: Disable
  • 0x1: Enable
INTSTAT
  • Name: INTSTAT Register
  • Description: INTSTAT Register
  • Offset: 0x24
表 174 INTSTAT Register
31:5
4:0
INT_STAT
[0] TX FIFO empty flag interrupt
[4] CS done interrupt
  • 0x0: no interrupt
  • 0x1: Interrupt source is active.
INTCLR
  • Name: INTCLR Register
  • Description: INTCLR Register
  • Offset: 0x28
表 175 INTCLR Register
31:5
4:0
INT_CLR
W
[0] Clear the TX FIFO empty flag interrupt.
[1] Clear the TX FIFO watermark interrupt.
[2] Clear the RX FIFO watermark interrupt.
[3] Clear the RX FIFO full interrupt.
[4] Clear the CS done interrupt.
  • 0x0: no effect
  • 0x1: Clear the interrupt,
TX_FIFO_LVL
  • Name: TX_FIFO_LVL Register
  • Description: TX_FIFO_LVL Register
  • Offset: 0x2C
表 176 TX_FIFO_LVL Register
31:5
4:0
TXFIFOLVL
Read the transmit FIFO current level (0–16).
RX_FIFO_LVL
  • Name: RX_FIFO_LVL Register
  • Description: RX_FIFO_LVL Register
  • Offset: 0x30
表 177 RX_FIFO_LVL Register
31:5
4:0
RXFIFOLVL
MSTR_IT_DELAY
  • Name: MSTR_IT_DELAY Register
  • Description: MSTR_IT_DELAY Register
  • Offset: 0x38
表 178 MSTR_IT_DELAY Register
31:8
7:0
MWAIT
If master (Control Register) is 1, this register sets the inter-transfer delay for the master serializer. The delay is (mwait + 1) SCLK cycles.
SPIEN
  • Name: SPIEN Register
  • Description: SPIEN Register
  • Offset: 0x3C
表 179 SPIEN Register
31:1
EN
Enable SPI.
  • 0x0: Disable SPI TX and RX; reset RX and TX FIFOs on the transition from 1 to 0 of this bit. Although SPI can be disabled at any time, it is recommended to disable SPI when FIFOs are empty. After writing 0 to the enable bit, read the enable bit back; only after the enable bit is read to be 0, should any further register configurations be performed.
  • 0x1: Enable SPI TX and RX.
RX_DATA0_31
  • Name: RX_DATA0_31 Register
  • Description: RX_DATA0_31 Register
  • Offset: 0x48
表 180 RX_DATA0_31 Register
31:0
RX_DATA0
32-bit LSB word in RX 128-bit read mode, rx_data[31:0]
RX_DATA32_63
  • Name: RX_DATA32_63 Register
  • Description: RX_DATA32_63 Register
  • Offset: 0x4C
表 181 RX_DATA32_63 Register
31:0
RX_DATA1
32-bit 2nd LSB word in RX 128-bit read mode, rx_data[63:32]
RX_DATA64_95
  • Name: RX_DATA64_95 Register
  • Description: RX_DATA64_95 Register
  • Offset: 0x50
表 182 RX_DATA64_95 Register
31:0
RX_DATA2
32-bit 3rd LSB word in RX 128-bit read mode, rx_data[95:64]
RX_DATA96_127
  • Name: RX_DATA96_127 Register
  • Description: RX_DATA96_127 Register
  • Offset: 0x54
表 183 RX_DATA96_127 Register
31:0
RX_DATA3
32-bit 4th LSB word in RX 128-bit read mode, rx_data[127:96]
FLASH_WRITE
  • Name: FLASH_WRITE Register
  • Description: FLASH_WRITE Register
  • Offset: 0x5C
表 184 FLASH_WRITE Register
31:1
FLASH_WRITE
  • 0x0: 128-bit mode
  • 0x1: 32-bit mode (used for Flash programming/write operation)
CS_IDLE_UNVLD_EN
  • Name: CS_IDLE_UNVLD_EN Register
  • Description: CS_IDLE_UNVLD_EN Register
  • Offset: 0x78
  • Reset Value: 0x00000001
表 185 CS_IDLE_UNVLD_EN Register
31:3
2
KEY_PULSE_DIS
When CPU reads Flash alias address and Flash address, access to Flash alias address will flush XQSPI FIFO, thus resulting in low performance.
  • 0x0: Enable key_pulse to interrupt rd_data state.
  • 0x1: Disable key_pulse to interrupt rd_data state.
1ST_PRETETCH_DIS
When XIP_EN_REQ is set, XQSPI will prefetch 256 bytes of data from Flash. Clear this bit to disable this function.
  • 0x0: Enable 1st prefecth function.
  • 0x1: Disable 1st prefetch function.
CS_IDLE_UNVLD_EN
0x1
  • 0x0: CS keeps valid when the device is not reading data.
  • 0x1: CS keeps invalid when the device is not reading data.
XIP_REGS
CTRL0
  • Base Address: 0x4000DC00
  • Offset: 0x0
  • Reset Value: 0x00000003
表 186 CTRL0 Register
31:8
7:0
CMD
0x3
XIP configuration read command
  • 0x03: read
  • 0x0B: fast read
  • 0x3B: fast dual out read
  • 0x6B: fast quad out read
  • 0xBB: fast dual I/O read
  • 0xEB: fast quad I/O read
  • All others: reserved
CTRL1
  • Name: CTRL1 Register
  • Description: CTRL1 Register
  • Offset: 0x4
  • Reset Value: 0x00000108
表 187 CTRL1 Register
31:9
8
LE32
0x1
XIP configuration 128-bit little endian arrangement of read data
  • 0x0: The read data is in big endian mode.
  • 0x1: The read data is in 128-bit little endian mode.
7
ADDR4
XIP configuration 4-byte address mode
  • 0x0: XIP issues 3-byte address
  • 0x1: XIP issues 4-byte SPI address
6
CPOL
XIP configuration CPOL mode
  • 0x0: CPOL mode 0
  • 0x1: CPOL mode 1
5
CPHA
XIP configuration CPHA mode
  • 0x0: CPHA mode 0
  • 0x1: CPHA mode 1
4:1
SS
0x4
XIP configuration slave select
  • 0x1: slave select 0
  • 0x2: slave select 1
  • 0x4: slave select 2
  • 0x8: slave select 3
HPEN
XIP configuration high performance mode
  • 0x0: Disable HP mode.
  • 0x1: Enable HP mode.
CTRL2
  • Name: CTRL2 Register
  • Description: CTRL2 Register
  • Offset: 0x8
  • Reset Value: 0x000000A3
表 188 CTRL2 Register
31:14
13:12
ENDDUMMY
Configure the number of dummy cycles necessary to terminate high performance mode. This is used by the core when exiting XIP mode after performing high-performance transfers to ensure that FLASH device is not still in HP mode. For Quad mode, this value is multiplied by 2 to get the actual number of dummy cycles.
11:8
DUMMYCYCLES
Used to configure the number of dummy cycles used by the core for Fast Read, Fast Read Dual Output, and Fast Read Quad Output.
Fast Read Dual I/O: 4 x value + 4
Fast Read Quad I/O: 2 x value + 2
Fast Read Quad Output: 8 x value
7:0
HPMODE
0xA3
XIP mode command byte. This byte is transferred from core to QSPI Flash memory. It is the value specified by different QSPI Flash memory vendors to enter into its status register to activate HP mode in dual I/O and Quad I/O accesses.
CTRL3
  • Name: CTRL3 Register
  • Description: CTRL3 Register
  • Offset: 0xC
表 189 CTRL3 Register
31:1
XIP_EN_REQ
XIP enable request
  • 0x0: Disable XIP mode.
  • 0x1: Enable XIP mode.
When it is set to 1’b1, do not access QSPI address space. Wait until XIP_EN_OUT is 1’b1. When it is set to 1’b0, do not access QSPI address space. Wait until XIP_EN_OUT is 1’b0.
STAT
  • Offset: 0x10
表 190 STAT Register
31:1
XIP_EN_OUT
XIP enable status
  • 0x0: XIP mode is disabled.
  • 0x1: XIP mode is enabled.
INTEN
  • Offset: 0x14
表 191 INTEN Register
31:1
XIP_INT_EN
Enable interrupt.
  • 0x0: Disable interrupt.
  • 0x1: Enable interrupt.
INTSTAT
  • Offset: 0x18
表 192 INTSTAT Register
31:1
XIP_INT_STAT
Interrupt status
  • 0x0: No interrupt occurred.
  • 0x1: An interrupt occurred.
INTREQ
  • Name: INTREQ Register
  • Description: INTREQ Register
  • Offset: 0x1C
表 193 INTREQ Register
31:1
XIP_INT_REQ
Output interrupt.
  • 0x0: No interrupt occurred or interrupt is disabled.
  • 0x1: An interrupt occurred and interrupt is enabled.
INTSET
  • Name: INTSET Register
  • Description: INTSET Register
  • Offset: 0x20
表 194 INTSET Register
31:1
XIP_INT_SET
W
Interrupt enable set
  • 0x0: no action
  • 0x1: Set the related bit to 1.
INTCLR
  • Offset: 0x24
表 195 INTCLR Register
31:1
XIP_INT_CLR
W
Interrupt enable clear
  • 0x0: no action
  • 0x1: Clear the related bit to 0.
SOFT_RST
  • Name: SOFT_RST Register
  • Description: SOFT_RST Register
  • Offset: 0x28
表 196 SOFT_RST Register
31:1
XIP_SOFT_RST
Soft reset IP by writing 1’b0, and then internal logic generates active low reset for one HCLK cycle.
