Always-on Power Control
A_TIMING_CTRL0
- Name: A_TIMING_CTRL0 Register
- Description: A_TIMING_CTRL0 Register
- Base Address: 0x4000A400
- Offset: 0x0
- Reset Value: 0x0009001E
31:20 |
Reserved bits |
19:16 |
DIG_LDO |
0x9 |
CORE_LDO timing required for power-on |
15:5 |
Reserved bits |
4:0 |
DCDC |
0x1E |
DC-DC timing required for power-on |
A_TIMING_CTRL1
- Name: A_TIMING_CTRL1 Register
- Description: A_TIMING_CTRL1 Register
- Offset: 0x4
- Reset Value: 0x00070009
31:20 |
Reserved bits |
19:16 |
HF_OSC |
0x7 |
HF_OSC timing required for stability |
15:4 |
Reserved bits |
3:0 |
FAST_LDO |
0x9 |
FAST_LDO timing required for power-on |
A_TIMING_CTRL2
- Name: A_TIMING_CTRL2 Register
- Description: A_TIMING_CTRL2 Register
- Offset: 0x8
- Reset Value: 0x0003003B
31:21 |
Reserved bits |
20:16 |
PLL |
0x3 |
PLL timing required for stability |
15:6 |
Reserved bits |
5:0 |
PLL_LOCK |
0x3B |
PLL lock timing required for stability |
A_TIMING_CTRL3
- Name: A_TIMING_CTRL3 Register
- Description: A_TIMING_CTRL3 Register
- Offset: 0xC
- Reset Value: 0x00F90009
31:24 |
Reserved bits |
23:16 |
XO |
0xF9 |
XO timing required for stability |
15:4 |
Reserved bits |
3:0 |
PWR_SWITCH |
0x9 |
IO LDO or standard IO LDO power switch timing required for stability |
A_TIMING_CTRL4
- Name: A_TIMING_CTRL4 Register
- Description: A_TIMING_CTRL4 Register
- Offset: 0x10
- Reset Value: 0x000E0095
31:20 |
Reserved bits |
19:16 |
RF_TUNE |
0xE |
RF_TUNE timing required for stability |
15:8 |
Reserved bits |
7:0 |
XO_BIAS_SW |
0x95 |
XO bias timing required for stability |
A_SLP_CFG
- Name: A_SLP_CFG Register
- Description: A_SLP_CFG Register
- Offset: 0x20
- Reset Value: 0x00070017
31:19 |
Reserved bits |
18 |
TRN_ON_STB_LDO |
0x1 |
17 |
TRN_OFF_PLL |
0x1 |
PLL status in sleep mode Value:
16 |
TRN_OFF_XO |
0x1 |
XO status in sleep mode Value:
15:5 |
Reserved bits |
4 |
TRN_OFF_FAST_LDO |
0x1 |
FAST_LDO status in sleep mode Value:
3 |
TRN_OFF_IO_LDO |
IO_LDO status in sleep mode Value:
2 |
TRN_OFF_HF_OSC |
0x1 |
HF_OSC status in sleep mode Value:
1 |
TRN_OFF_DIG_LDO |
0x1 |
CORE_LDO status in sleep mode Value:
0 |
TRN_OFF_DCDC |
0x1 |
DC-DC status in sleep mode Value:
AON_START_CFG
- Name: AON_START_CFG Register
- Description: AON_START_CFG Register
- Offset: 0x24
- Reset Value: 0x00000056
31:7 |
Reserved bits |
6 |
PLL_EN_PWR |
0x1 |
1: Enable PLL after DC-DC gets ready. |
5 |
Reserved bit |
4 |
XO_EN_PWR |
0x1 |
1: Enable XO after DC-DC gets ready. |
3 |
Reserved bit |
2:1 |
POWER_MODE |
0x3 |
Power mode: Value:
0 |
Reserved bit |
DPAD_LE_CTRL
- Name: DPAD_LE_CTRL Register
- Description: DPAD_LE_CTRL Register
- Offset: 0x28
- Reset Value: 0x00040100
31:19 |
Reserved bits |
18 |
WAKEUP |
0x1 |
Set HW controlled dpad_le value after waking up. |
17 |
Reserved bit |
16 |
SLEEP |
Set HW controlled dpad_le value during sleep. |
15:11 |
Reserved bits |
10 |
BUSY |
DPAD_LE_CTRL is applying a value. Do not apply a value again. |
9 |
Reserved bit |
8 |
READ |
0x1 |
The current DPAD Latch value |
7:3 |
Reserved bits |
2 |
APPLY_WR |
W |
Write 1 to apply the value of WR to control signal. |
1 |
Reserved bit |
0 |
WR |
Enable DPAD Latch. Value:
AON_SLP_CTRL
- Name: AON_SLP_CTRL Register
- Description: AON_SLP_CTRL Register
- Offset: 0x3C
31:9 |
Reserved bits |
8 |
PRO |
The power controller is processing a deep-sleep request. |
7:1 |
Reserved bits |
0 |
REQ |
W |
Write 1 to send a sleep request. |
XO_PLL_SET
- Name: XO_PLL_SET Register
- Description: XO_PLL_SET Register
- Offset: 0x40
31:3 |
Reserved bits |
2 |
HF_OSC_SET |
W |
Write 1 to enable HFOSC. This operation will turn DC-DC on if it is not. |
1 |
XO_SET |
W |
Write 1 to enable HFXO. This operation will turn DC-DC on if it is not. |
0 |
PLL_SET |
W |
Write 1 to enable CPLL. This operation will turn DC-DC on if it is not. |
XO_PLL_CLR
- Name: XO_PLL_CLR Register
- Description: XO_PLL_CLR Register
- Offset: 0x44
31:3 |
Reserved bits |
2 |
HF_OSC_CLR |
W |
Write 1 to disable HFOSC. |
1 |
XO_CLR |
W |
Write 1 to disable HFXO. |
0 |
PLL_CLR |
W |
Write 1 to disable CPLL. |
XO_PLL_STAT
- Name: XO_PLL_STAT Register
- Description: XO_PLL_STAT Register
- Offset: 0x48
- Reset Value: 0x00000007
31:3 |
Reserved bits |
2 |
HF_STAT |
0x1 |
HF_OSC stable state |
1 |
XO_STAT |
0x1 |
XO stable state |
0 |
PLL_STAT |
0x1 |
PLL stable state |
PWR_SET
- Name: PWR_SET Register
- Description: PWR_SET Register
- Offset: 0x4C
31:6 |
Reserved bits |
5 |
STB_IO_LDO_SET |
W |
Write '1' to enable STB_IO_LDO. |
4 |
IO_LDO_SET |
W |
Write '1' to enable IO_LDO. |
3 |
Reserved bit |
2 |
FAST_LDO_SET |
W |
Fast LDO power request |
1 |
DIG_LDO_SET |
W |
CORE_LDO power request |
0 |
DCDC_SET |
W |
DC-DC power request |
PWR_CLR
- Name: PWR_CLR Register
- Description: PWR_CLR Register
- Offset: 0x50
31:6 |
Reserved bits |
5 |
STD_IO_LDO_CLR |
W |
Write '1' to disable STB_IO_LDO. |
4 |
IO_LDO_CLR |
W |
Write '1' to disable IO_LDO. |
3 |
Reserved bit |
2 |
FAST_LDO_CLR |
W |
Disable Fast LDO power. |
1 |
DIG_LDO_CLR |
W |
Disable CORE_LDO power. |
0 |
DCDC_CLR |
W |
Disable DC-DC power. |
PWR_STAT
- Name: PWR_STAT Register
- Description: PWR_STAT Register
- Offset: 0x54
| 31:3 | RSVD | R | 0x0 | Reserved bitS |
| 2 | FAST_LDO_AVL | R | 0x1 |
Fast LDO power is available. The status is NOT valid if analog interface overriding is used. |
| 1 | DIG_LDO_AVL | R | 0x1 |
CORE_LDO power is available. The status is NOT valid if analog interface overriding is used. |
| 0 | DCDC_AVL | R | 0x1 |
DC-DC power is available. The status is NOT valid if analog interface overriding is used. |
MEM_PWR_SLP0
- Name: MEM_PWR_SLP0 Register
- Description: MEM_PWR_SLP0 Register
- Offset: 0x80
- Reset Value: 0x00000FFF
31:12 |
Reserved bits |
11:10 |
SET05 |
0x3 |
Memory power states that is loaded in sleep phase Value:
9:8 |
SET04 |
0x3 |
7:6 |
SET03 |
0x3 |
5:4 |
SET02 |
0x3 |
3:2 |
SET01 |
0x3 |
1:0 |
SET00 |
0x3 |
MEM_PWR_SLP1
- Name: MEM_PWR_SLP1 Register
- Description: MEM_PWR_SLP1 Register
- Offset: 0x84
- Reset Value: 0x0000003C
31:6 |
Reserved bits |
5:4 |
ICACHE_SET |
0x3 |
Cache memory sleep power Memory power states that is loaded in sleep phase Value:
3:2 |
HTM_DM_SET |
0x3 |
Hopping table DM memory sleep power Memory power states that is loaded in sleep phase Value:
1:0 |
Reserved bits |
MEM_PWR_WKUP0
- Name: MEM_PWR_WKUP0 Register
- Description: MEM_PWR_WKUP0 Register
- Offset: 0x88
- Reset Value: 0x00000AAA
31:12 |
Reserved bits |
11:10 |
SET05 |
0x2 |
Memory power states that is loaded in wakeup phase Value:
9:8 |
SET04 |
0x2 |
7:6 |
SET03 |
0x2 |
5:4 |
SET02 |
0x2 |
3:2 |
SET01 |
0x2 |
1:0 |
SET00 |
0x2 |
MEM_PWR_WKUP1
- Name: MEM_PWR_WKUP1 Register
- Description: MEM_PWR_WKUP1 Register
- Offset: 0x8C
- Reset Value: 0x00000020
31:6 |
Reserved bits |
5:4 |
ICACHE |
0x2 |
Cache memory sleep power Memory power states that is loaded on wakeup Value:
3:2 |
HTM_DM |
Hopping table DM memory sleep power Memory power states that is loaded on wakeup Value:
1:0 |
Reserved bits |
MEM_PWR_APPLY
- Name: MEM_PWR_APPLY Register
- Description: MEM_PWR_APPLY Register
- Offset: 0x90
31:17 |
Reserved bits |
16 |
BUSY |
During the bit being 1, writing APPLY would not take any effect. |
15:1 |
Reserved bits |
0 |
APPLY |
W |
Write 1 to apply the memory settings in MEM_PWR_WKUP manually. |
MEM_PWR_STAT0
- Name: MEM_PWR_STAT0 Register
- Description: MEM_PWR_STAT0 Register
- Offset: 0x98
31:12 |
Reserved bits |
11:10 |
SET05 |
0x2 |
Memory power states. **Do NOT** read when MEM_PWR_APPLY_BUSY is high. Value:
9:8 |
SET04 |
0x2 |
7:6 |
SET03 |
0x2 |
5:4 |
SET02 |
0x2 |
3:2 |
SET01 |
0x2 |
1:0 |
SET00 |
0x2 |
MEM_PWR_STAT1
- Name: MEM_PWR_STAT1 Register
- Description: MEM_PWR_STAT1 Register
- Offset: 0x9C
31:6 |
Reserved bits |
5:4 |
ICACHE_SET |
0x2 |
Memory power states. Do not read when MEM_PWR_APPLY_BUSY is high. Value:
3:2 |
HTM_DM_SET |
1:0 |
Reserved bits |
MEM_PWR_DBG
- Name: MEM_PWR_DBG Register
- Description: MEM_PWR_DBG Register
- Offset: 0xBC
31:1 |
Reserved bits |
0 |
RESET_ON_SRAM |
1: When MCU issues a system-reset request, turn ON all SRAM power. Do not change this register when system-reset is ongoing. |
COMM_CORE_PWR_CTRL_SW
- Name: COMM_CORE_PWR_CTRL_SW Register
- Description: COMM_CORE_PWR_CTRL_SW Register
- Offset: 0xC0
- Reset Value: 0x00000002
31:3 |
Reserved bits |
2 |
RST_N |
Comm proc reset active low When this bit is 0, Bluetooth LE is held in reset. |
1 |
ISO_EN |
0x1 |
Enable comm_core power domain isolation. Value:
0 |
CORE_EN |
Enable comm_core power domain power. Value:
COMM_CORE_PWR_CTRL_HW_CFG
- Name: COMM_CORE_PWR_CTRL_HW_CFG Register
- Description: COMM_CORE_PWR_CTRL_HW_CFG Register
- Offset: 0xC4
- Reset Value: 0x00020200
31:19 |
Reserved bits |
18 |
PD_HOLD_EN_RD |
Real-time status of PD_HOLD_EN |
17 |
AUTO_EN_RD |
0x1 |
Real-time status of AUTO_ON |
16 |
HW_EN_RD |
Real-time status of HW_EN |
15:12 |
Reserved bits |
11 |
PLL_AUTO_ON |
Waking Bluetooth LE timer up will enable PLL automatically. |
10 |
PD_HOLD_EN |
Wait the Bluetooth LE timer flag and the delay counter before powering off Bluetooth LE. |
9 |
AUTO_EN |
0x1 |
1: If HW sequencer is selected, set 1 to let HW automatically request power-on when a COMM Timer wakeup signal is received. Please allow 6 μs–12 μs for the configuration to be applied. |
8 |
HW_EN |
Enable the hardware sequencer block. Please allow 6 μs–12 μs for the configuration to be applied. |
7:1 |
Reserved bits |
0 |
CTRL_SEL |
COMM_CORE_PWR_CTRL_HW_CTRL
- Name: COMM_CORE_PWR_CTRL_HW_CTRL Register
- Description: COMM_CORE_PWR_CTRL_HW_CTRL Register
- Offset: 0xC8
31:9 |
Reserved bits |
8 |
DIS |
W |
Write 1 to start comm_core power-off sequence. Writing it to 0 will take no effect. |
7:1 |
Reserved bits |
0 |
REQ |
W |
Write 1 to start comm_core power-on sequence. Writing it to 0 will take no effect. |
COMM_CORE_PWR_CTRL_HW_STAT
- Name: COMM_CORE_PWR_CTRL_HW_STAT Register
- Description: COMM_CORE_PWR_CTRL_HW_STAT Register
- Offset: 0xCC
31:3 |
Reserved bits |
2 |
HW_PD_WAIT |
1: Power-off command received, waiting for PD condition |
1 |
HW_PWR |
0 |
BUSY |
COMM_CORE_PWR_CTRL_PD_DLY
- Name: COMM_CORE_PWR_CTRL_PD_DLY Register
- Description: COMM_CORE_PWR_CTRL_PD_DLY Register
- Offset: 0xD0
31:17 |
Reserved bits |
16 |
PD_FLAG |
1: Do not wait for Bluetooth LE timer flag to power off the Bluetooth LE. |
15:8 |
Reserved bits |
7:0 |
PD_DLY |
Delay after receiving Bluetooth LE timer flag
COMM_CORE_PWR_STAT
- Name: COMM_CORE_PWR_STAT Register
- Description: COMM_CORE_PWR_STAT Register
- Offset: 0xD4
31:3 |
Reserved bits |
2 |
RST_N_RD |
1 |
ISO_EN_RD |
0x1 |
0 |
CORE_EN_RD |
COMM_TIMER_PWR_CTRL
- Name: COMM_TIMER_PWR_CTRL Register
- Description: COMM_TIMER_PWR_CTRL Register
- Offset: 0xE0
31:3 |
Reserved bits |
2 |
RST_N |
Comm timer reset This bit is used to reset the Comm timer after it has been powered on. Value:
1 |
ISO_EN |
0x1 |
Enable comm_timer power domain isolation. Value:
0 |
EN |
Enable comm_timer power domain power. Value:
SOFTWARE_REG_3
- Name: SOFTWARE_REG_3 Register
- Description: SOFTWARE_REG_3 Register
- Offset: 0xE8
31:0 |
SOFTWARE_REG3 |
Software can use this register to save data. It will not be reset by NVIC or in sleep. |
