Power Reset
Power-on Reset
The Power-on Reset (POR) initializes the system when the supply voltage is above the power-on threshold. The system will be held in the reset phase until the supply voltage has reached the minimum operating voltage. The power-on threshold Vwork of the device is about 1.75 V.
Brown-out Reset
Brown-out Reset is dependent on the Brown-out detector (BOD). BOD reset circuit puts the system into reset state when the supply falls below the Brown-Out Reset threshold.
For detailed description of the BOD reset, refer to "Brown-out Detector (BOD)".
