Timer
The device has two instances of Timer module. Each Timer module features a 32-bit down counter and 4-channel I/O capture registers. Because the Timer is in the MCU subsystem domain, Timer interrupt is not available during sleep, and the running Timer will not prevent MCU from sleeping. In active mode, when the Timer is restarted after being stopped, it will continue to count down from the stop time.
- Generate an interrupt when the 32-bit down counter reaches 0.
- The 4-channel I/O capture function contains rising edge capture, falling edge capture, and both edge capture.
- The clock source of the Timer follows the system clock.
- Each Timer module has an independent interrupt entry.
- Timer pauses when the MCU is suspended.
Counter
- The Timer can generate a COUNTDONE interrupt request signal when the 32-bit down counter reaches 0. The COUNTDONE interrupt request is held until it is cleared by writing 1 to the COUNTDONE_INT_STAT bit in the INTSTAT register.
- If the Timer count reaches 0 and, at the same time, the software clears the previous COUNTDONE interrupt status, the COUNTDONE_INT_STAT bit is set to 1.
- When the value of the RELOAD register is configured to 0, no COUNTDONE interrupt are generated.
- The RELOAD value only represents the count-down number of timers. If you want to configure a specific duration (for example, µs, ms, or s), you need to use the following formula:
- When the CTRL.EN bit is set to 1, the timer is running. Changing the value in the RELOAD register will take effect immediately, and the timer will count down from the new RELOAD value.
I/O Capture
- I/O should be set to input mode for Timer I/O capture function.
- I/O capture function supports falling edge capture, rising edge capture and both edge capture which can be configured the CHx_EDGE_DET bit in the CTRL register.
- Each Timer module can capture GPIO_0 to GPIO_13, AON_GPIO_0 to AON_GPIO_7, and MSIO_0 to MSIO_9. The CHx interrupt request is held until it is cleared by writing 1 to the CHx_INT_STAT bit in the INTSTAT register.
- The captured value of each channel will be put into the corresponding CHANNELx_VAL register. When multiple values are captured continuously by the same channel, only the last value is retained in CHANNELx_VAL register.
CTRL
- Name: Timer Control Register
- Description: The CTRL register configures capture channel parameters and enables the software to control the Timer.
- Base Address: 0x40000000 + x*0x1000
- Offset: 0x00
- Reset Value: 0x00
*x is used to identify the Timer Module. The “x” can be 0 or 1.
31:29 |
Reserved bits |
28:24 |
CH3_PIN_SELECT |
GPIO PIN select of channel3 Value:
23:19 |
CH2_PIN_SELECT |
GPIO PIN select of channel2 Value:
18:14 |
CH1_PIN_SELECT |
GPIO PIN select of channel1 Value:
13:9 |
CH0_PIN_SELECT |
GPIO PIN select of channel0 Value:
8:7 |
CH3_EDGE_DET |
Capture type of channel3 Value:
6:5 |
CH2_EDGE_DET |
Capture type of channel2 Value:
4:3 |
CH1_EDGE_DET |
Capture type of channel1 Value:
2:1 |
CH0_EDGE_DET |
Capture type of channel0 Value:
0 |
EN |
Timer enable bit Value:
VALUE
- Name: Timer Value Register
- Description: The VALUE register indicates the current value of the decrementing counter.
- Offset: 0x04
- Reset Value: 0x00
31:0 |
VALUE |
Current value |
RELOAD
- Name: Timer Reload Register
- Description: When this register is written to, the count value takes effect immediately from a new RELAOD value.
- Offset: 0x08
- Reset Value: 0x00
31:0 |
RELOAD |
Sets reload value. |
INTEN
- Name: Timer Interrupt Enable Register
- Description: The INTEN register indicates interrupt enable configuration of COUNTDONE, CHANNEL0 capture, CHANNEL1 capture, CHANNEL2 capture, or CHANNEL3 capture.
- Offset: 0x0C
31:5 |
Reserved bits |
4 |
CH3_INT_EN |
Channel 3 I/O capture interrupt enable bit |
3 |
CH2_INT_EN |
Channel 2 I/O capture interrupt enable bit |
2 |
CH1_INT_EN |
Channel 1 I/O capture interrupt enable bit |
1 |
CH0_INT_EN |
Channel 0 I/O capture interrupt enable bit |
0 |
COUNTDONE_INT_EN |
Count done interrupt enable bit |
INTSTAT
- Name: Timer Interrupt Status Register
- Description: The INTSTAT register indicates the interrupt status from the counter. Writing one to each bit of INTSTAT register clears the corresponding interrupt.
- Offset: 0x10
31:5 |
Reserved bits |
4 |
CH3_INT_STAT |
WC |
Channel 3 captured; write 1 to clear. |
3 |
CH2_INT_STAT |
WC |
Channel 2 captured; write 1 to clear. |
2 |
CH1_INT_STAT |
WC |
Channel 1 captured; write 1 to clear. |
1 |
CH0_INT_STAT |
WC |
Channel 0 captured; write 1 to clear. |
0 |
COUNTDONE_INT_STAT |
WC |
Count done; write 1 to clear. |
CHANNEL0_VAL
- Name: CHANNEL0 Capture Value
- Description: The CHANNEL0_VAL register indicates the edge capture value.
- Offset: 0x14
31:0 |
CH0_VAL |
When the desired I/O edge is captured, the value of the current counter is stored. |
CHANNEL1_VAL
- Name: CHANNEL1 Capture Value
- Description: The CHANNEL1_VAL register indicates the edge capture value.
- Offset: 0x18
31:0 |
CH1_VAL |
CHANNEL2_VAL
- Name: CHANNEL2 Capture Value
- Description: The CHANNEL2_VAL register indicates the edge capture value.
- Offset: 0x1C
31:0 |
CH2_VAL |
CHANNEL3_VAL
- Name: CHANNEL3 Capture Value
- Description: The CHANNEL3_VAL register indicates the edge capture value.
- Offset: 0x20
31:0 |
CH3_VAL |
