eFuse
TPGM
  • Name: TPGM Register
  • Description: TPGM Register
  • Base Address: 0x40018400
  • Offset: 0x0
  • Reset Value: 0x00010281
Table 245 TPGM Register
31:20
19:12
WRITE_INTERVAL
0x10
Interval between two bits in eFuse, number of APB CLK cycles.
11:0
TIME
0x281
eFuse programming time, tpro = TIME*T, where T is clock period; typically tpro = 10000 ns, and 9000 ns < tpro < 11000 ns
PGENB
  • Name: PGENB Register
  • Description: PGENB Register
  • Offset: 0x4
  • Reset Value: 0x00000001
Table 246 PGENB Register
31:1
SIG
0x1
eFuse programming enable signal control (active low)
  • 0x0: Program eFuse.
  • 0x1: Read eFuse.
OPERATION
  • Name: OPERATION Register
  • Description: OPERATION Register
  • Offset: 0x8
Table 247 OPERATION Register
31:1
INIT_CHECK
W
Writing "1" to this bit enables eFuse ctrl to start to read the whole eFuse value; at the same time, check this value with "0".
STAT
  • Name: STAT Register
  • Description: STAT Register
  • Offset: 0xC
Table 248 STAT Register
31:3
2
WRITE_DONE
RC
eFuse one word write done
Reading this register enables hardware to clear this bit.
INIT_SUCCESS
RC
eFuse initial value check success means the eFuse values are all "0".
INIT_DONE
RC
eFuse initial value check done
