Clock Calibration
SL_CLK_CTRL
- Name: SL_CLK_CTRL Register
- Description: This register enables SL clock calibration.
- Base Address: 0x4000E400
- Offset: 0x0
31:1 |
Reserved bits |
0 |
EN |
Enable clock calibration block. Value:
SL_CLK_CNT
- Name: SL_CLK_CNT Register
- Description: This register sets the number of cycles of the slow clock.
- Offset: 0x4
31:12 |
Reserved bits |
11:0 |
COUNT |
Number of cycles of the slow clock |
SL_CLK_STAT
- Name: SL_CLK_STAT Register
- Description: This register indicates the calibration status.
- Offset: 0x8
31:2 |
Reserved bits |
1 |
OVER |
Fast clock counter overflow. Need to reduce slow clock cnt_val. |
0 |
DONE |
Calibration done status |
SL_CLK_CNT0
- Name: SL_CLK_CNT0 Register
- Description: This register sets the fast clock counter value.
- Offset: 0xC
31:24 |
Reserved bits |
23:0 |
VAL |
Fast clock counter value |
SL_CLK_CNT1
- Name: SL_CLK_CNT1 Register
- Description: This register reads the current counter value of the slow clock.
- Offset: 0x10
31:12 |
Reserved bits |
11:0 |
VAL |
Read the current counter value of the slow clock. |
SL_CLK_INT_EN
- Name: SL_CLK_INT_EN Register
- Description: This register enables the clock interrupt.
- Offset: 0x14
- Reset Value: 0x00000003
31:2 |
Reserved bits |
1 |
OVER |
0x1 |
Interrupt Enable ONLY. The status in CLK_STAT can be read no matter whether the interrupt is enabled. |
0 |
DONE |
0x1 |
SL_CLK_INT_CLR
- Name: SL_CLK_INT_CLR Register
- Description: This register clears the clock interrupt.
- Offset: 0x18
31:2 |
Reserved bits |
1 |
OVER |
W |
Write the corresponding bit to clear the interrupt. |
0 |
DONE |
W |
SL_CLK_SEL
- Name: SL_CLK_SEL Register
- Description: This register selects the slow clock source.
- Offset: 0x20
31:2 |
Reserved bits |
1:0 |
SLOW_CLK_SEL |
Select slow clock source. Only valid for the defined source value Value:
HS_CLK_CTRL
- Name: HS_CLK_CTRL Register
- Description: This register enables HS clock calibration.
- Offset: 0x100
31:1 |
Reserved bits |
0 |
EN |
HS_CLK_CNT
- Name: HS_CLK_CNT Register
- Offset: 0x104
31:12 |
Reserved bits |
11:0 |
COUNT |
HS_CLK_STAT
- Name: HS_CLK_STAT Register
- Offset: 0x108
31:2 |
Reserved bits |
1 |
OVER |
0 |
DONE |
HS_CLK_CNT0
- Name: HS_CLK_CNT0 Register
- Offset: 0x10C
31:24 |
Reserved bits |
23:0 |
VAL |
HS_CLK_CNT1
- Name: HS_CLK_CNT1 Register
- Offset: 0x110
31:12 |
Reserved bits |
11:0 |
VAL |
HS_CLK_INT_EN
- Name: HS_CLK_INT_EN Register
- Offset: 0x114
31:2 |
Reserved bits |
1 |
OVER |
0x1 |
0 |
DONE |
0x1 |
HS_CLK_INT_CLR
- Name: HS_CLK_INT_CLR Register
- Offset: 0x118
31:2 |
Reserved bits |
1 |
OVER |
W |
0 |
DONE |
W |
HS_CLK_SEL
- Name: HS_CLK_SEL Register
- Offset: 0x120
31:2 |
Reserved bits |
1:0 |
SLOW_CLK_SEL |
