GPIO
The device has up to 14 individually configurable GPIOs that can serve as peripherals or digital input/output.
  • All I/Os can retain their output levels when the system enters sleep mode.
  • I/O default state is input mode with pull-down.
  • All I/Os (except MSIO_0–MSIO_9) can be configured as being triggered by high level, low level, rising edge, falling edge, or both edges.
  • Configurable output drive strength: four drive strengths and two slew rate options. The fast slew rate should be used when speed or timing is a concern; the slow slew rate is used to reduce the switching noise.
  • All pins can be individually mapped to interface blocks for layout flexibility.
The 14 digital GPIOs can be used:
  • For general-purpose input/output.
  • To multiplex different peripherals on different output pins of the package.
  • To multiplex debug signals from different blocks of the SoC.
A functional drawing of the GPIO pads is provided in the following figure. The digital GPIO pads can be configured to set direction, enable pull-up/pull-down resistors, and enable output retention. GPIOs can also be read or written by firmware for applications that need direct access through the GPIO registers.
Figure 40 GPIO pad diagram
The general rule for enabling the on-chip pull-up/pull-down resistors is as follows:
  • If a GPIO is unused, enable the pull-down resistor.
  • If a GPIO is configured as an output, disable the pull-up/pull-down resistor. However, if disabling the output causes a high impedance state, enable the pull-up or pull-down resistor during this period.
  • If a GPIO is used as an input and is being actively driven high or low by an external device, disable the pull-up/pull-down resistor (the same applies when there is an external pull-up/pull-down resistor on the board. In this case, the on-chip resistor should always be disabled). However, if the external device driving the input ever goes to a high impedance state, a pull-up or pull-down resistor must be enabled during this period.
PAD_IE_AUTO_EN
  • Name: Pad auto Input Enable Control Register
  • Description: This register enables/disables auto pad input.
  • Base Address: 0x4000E900
  • Offset: 0x28
  • Reset Value: 0x0000000
Table 259 PAD_IE_AUTO_EN Register
31:20
2
MSIO_IE_AUTO_EN
Enable/Disable DPAD auto input.
  • 0x0: Disabled
  • 0x1: Enabled
AON_IE_AUTO_EN
Enable/Disable AON pad auto input.
  • 0x0: Disabled
  • 0x1: Enabled
DPAD_IE_AUTO_EN
Enable/Disable MSIO auto input.
  • 0x0: Disabled
  • 0x1: Enabled
DPAD_IE_BUS
  • Name: GPIO Input Enable Register
  • Description: This register enables a GPIO as input.
  • Offset: 0x2C
  • Reset Value: 0x000FFFFF
Table 260 DPAD_IE_BUS Register
31:20
19:0
IE
0xFFFFF
Enable l/O inputs to GPIO_0–GPIO_13
  • 0x0: Disable inputs to pad.
  • 0x1: Enable inputs to pad.
DPAD_PE_BUS
  • Name: GPIO Pull-Up/Down Resistor Enable Register
  • Description: This register decides whether to use pull-up/down resistors.
  • Offset: 0x30
  • Reset Value: 0x00003FFF
Table 261 DPAD_RE_BUS
31:20
19:0
PE
0x3FFF
Resistor enable control of GPIO_0–GPIO_13
  • 0x0: Disable pull-up/down resistor.
  • 0x1: Enable pull-up/down resistor.
DPAD_PS_BUS
  • Name: GPIO Resistor Type Control Register
  • Description: This register sets the resistor type to either pull-up or pull-down.
  • Offset: 0x34
Table 262 DPAD_RTYP_BUS
31:20
19:0
PS
Resistor type of GPIO_0–GPIO_13
  • 0x0: Pull-down.
  • 0x1: Pull-up.
DPAD_IS_BUS
  • Name: GPIO Input Type Control Register
  • Description: This register sets the input type.
  • Offset: 0x38
Table 263 DPAD_IS_BUS
31:20
19:0
IS
Input type of GPIO_0–GPIO_13
  • 0x0: CMOS input.
  • 0x1: Schmitt input
DPAD_SR_BUS
  • Name: GPIO Slew Rate Control Register
  • Description: This register sets the slew rate of GPIOs.
  • Offset: 0x3C
Table 264 DPAD_RTYP_BUS
31:20
19:0
SR
  • 0x0: Fast slew rate
  • 0x1: Slow slew rate
DPAD_DS0_BUS
  • Name: GPIO Output Driver Strength Type Control Register
  • Description: This register sets the output driver strength.
  • Offset: 0x40
Table 265 DPAD_DS0_BUS
31:20
19:0
DS0
Output drive strength (high bit)
  • 0x0: Weak mode
  • 0x1: Strong mode
DPAD_DS1_BUS
  • Offset: 0x44
Table 266 DPAD_DS1_BUS
31:20
19:0
DS1
0xFFFFF
Output drive strength (low bit)
  • 0x0: Weak mode
  • 0x1: Strong mode
The drive strengths of GPIO0 can be configured as follows:
  • DPAD_DS0_BUS[0]: DPAD_DS1_BUS[0] = 1:1, output drive strength is 12 mA.
  • DPAD_DS0_BUS[0]: DPAD_DS1_BUS[0] = 1:0, output drive strength is 8 mA.
  • DPAD_DS0_BUS[0]: DPAD_DS1_BUS[0] = 0:1, output drive strength is 4 mA.
  • DPAD_DS0_BUS[0]: DPAD_DS1_BUS[0] = 0:0, output drive strength is 2 mA.
DATA
  • Name: GPIO Data Value Register
  • Description: This register contains the input data and can write it to the data output register.
  • Base Address: 0x40010000
  • Offset: 0x0000
Table 267 DATA
31:16
15:0
DATA
Data value [15:0]:
Read: Read the value that is sampled at pin.
Write: Write the field to the DATA_OUT register.
GPIO includes GPIOA (GPIO_0–GPIO_13) in SDK.
DATA_OUT
  • Name: GPIO Data Output Register
  • Description: This register contains the output data.
  • Offset: 0x0004
Table 268 DATA_OUT
31:16
15:0
DATA_OUT
Data output register value [15:0]:
Read: current value of data output register
Write: to data output register
OUTENSET
  • Name: GPIO Output Enable Register
  • Description: This register is used to enable the GPIO as output.
  • Offset: 0x0010
Table 269 OUTENSET
31:16
15:0
EN
Output enable set [15:0]:
Read:
  • 0x0: Indicate the signal direction as input.
  • 0x1: Indicate the signal direction as output.
Write:
  • 0x0: No effect
  • 0x1: Set the output enable bit.
OUTENCLR
  • Name: GPIO Output Enable Clear Register
  • Description: This register is used to disable output bit.
  • Offset: 0x0014
Table 270 OUTENCLR
31:16
15:0
CLR
Output enable clear [15:0]:
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the output enable bit.
INTENSET
  • Name: GPIO Interrupt Enable Register
  • Description: This register is used to enable GPIO interrupt.
  • Offset: 0x0020
Table 271 INTENSET
31:16
15:0
EN
Interrupt enable set [15:0]:
Read:
  • 0x0: Interrupt disabled
  • 0x1: Interrupt enabled
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt enable bit.
INTENCLR
  • Name: GPIO Interrupt Enable Clear Register
  • Description: This register is used to disable GPIO interrupt.
  • Offset: 0x0024
Table 272 INTENCLR
31:16
15:0
CLR
Interrupt enable clear [15:0]:
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt enable bit.
INTTYPESET
  • Name: GPIO Interrupt Type Enable Register
  • Description: This register is used to set GPIO interrupt type.
    • Interrupt type is 0 and interrupt polarity is 0: low-level trigger interrupt
    • Interrupt type is 0 and interrupt polarity is 1: high-level trigger interrupt
    • Interrupt type is 1 and interrupt polarity is 0: falling edge trigger interrupt
    • Interrupt type is 1 and interrupt polarity is 1: rising edge trigger interrupt
  • Offset: 0x0028
Table 273 INTTYPESET
31:16
15:0
EN
Interrupt type set [15:0]:
Read:
  • 0x0: Low or high level
  • 0x1: Falling edge or rising edge
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt type bit.
INTTYPECLR
  • Name: GPIO Interrupt Type Clear Register
  • Description: This register is used to disable GPIO interrupt type.
  • Offset: 0x002C
Table 274 INTTYPECLR
31:16
15:0
CLR
Interrupt type clear [15:0]:
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt type bit.
INTPOLSET
  • Name: GPIO Interrupt Polarity Enable Register
  • Description: This register is used to enable GPIO interrupt polarity.
  • Offset: 0x0030
Table 275 INTPOLSET
31:16
15:0
EN
Polarity configuration [15:0]:
Read:
  • 0x0: Low level or falling edge
  • 0x1: High level or rising edge
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt polarity bit.
INTPOLCLR
  • Name: GPIO Interrupt Polarity Disable Register
  • Description: This register is used to disable GPIO interrupt polarity.
  • Offset: 0x0034
Table 276 GPIO_INT_POL_CLR
31:16
15:0
CLR
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt polarity bit.
INTSTAT
  • Name: GPIO IRQ Status Register
  • Description: This register contains GPIO interrupt status and is used to clear the interrupt request.
  • Offset: 0x0038
Table 277 GPIO_INT_STAT
31:16
15:0
STAT_CLR
Write one to clear interrupt request:
Read:
[15:0] IRQ status register
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt request.
INTDBESET
  • Name: GPIO_REG_INTDBESET Register
  • Description: This register is used to set the double-edge interrupt enable bit (which means that both falling edge and rising edge will get the interrupt).
  • Offset: 0x0040
Table 278 INTDBESET
31:16
15:0
EN
Read:
  • Read back 1: Enable the double-edge interrupt.
  • Read back 0: Disable the double-edge interrupt.
Write:
  • 0x0: No effect
  • 0x1: Set the double-edge interrupt enable bit (which means that both falling edge and rising edge will get the interrupt).
INTDBECLR
  • Name: GPIO_REG_INTDBECLR Register
  • Description: This register is used to clear the double-edge interrupt enable bit (which means that both falling edge and rising edge will get the interrupt).
  • Offset: 0x0044
Table 279 INTDBECLR
31:16
15:0
CLR
Write 1: Clear the double-edge interrupt enable bit (which means that both falling edge and rising edge will get the interrupt).
Write 0: No effect
The electrical parameters for the GPIO_0–GPIO_13 are as follows:
Table 280 GPIO electrical specifications
VIH Input high voltage VDDIO x 0.7 VDDIO V
VIL Input low voltage VSS VDDIO x 0.3 V
VOH,L Output high voltage, 4 mA, VDDIO ≥ 2.0 V VDDIO - 0.4 VDDIO V
VOH,M Output high voltage, 4 mA, VDDIO ≥ 2.5 V VDDIO - 0.4 VDDIO V
VOH,H Output high voltage, 4 mA, VDDIO ≥ 3 V VDDIO - 0.4 VDDIO V
VOL,L Output low voltage, 4 mA, VDDIO ≥ 2.0 V VSS VSS + 0.4 V
VOL,M Output low voltage, 4 mA, VDDIO ≥ 2.5 V VSS VSS + 0.4 V
VOL,H Output low voltage, 4 mA, VDDIO ≥ 3 V VSS VSS + 0.4 V
IOL,L Current at VSS+0.4 V, output set low, VDDIO ≥ 2.0 V 2 12 mA
IOL,M Current at VSS+0.4 V, output set low, VDDIO ≥ 2.5 V 2 12 mA
IOH,L Current at VDDIO-0.4 V, output set high, VDDIO ≥ 2.0 V 2 12 mA
IOH,M Current at VDDIO-0.4 V, output set high, VDDIO ≥ 2.5 V 2 12 mA
tRF,9pF Rise time, 10%–90%, 9 pF load 1.6 13 ns
tRF,9pF Fall time, 10%–90%, 9 pF load 1.9 14.2 ns
RPU Pull-up resistance 12 20 32
RPD Pull-down resistance 12 20 32
CPAD Pad capacitance 5 pF
