Dual Timer
The Dual Timer module consists of two programmable down counters (32-bit or 16-bit) that can generate interrupts when they reach 0. I/O control function without going through interrupt handler is supported in order to meet the requirements of application scenarios that demand low latency response.
Because the Dual-Timer is in the MCU Subsystem domain, Dual-Timer interrupt is not available during sleep, and the running Dual-Timer will not prevent the MCU from sleeping.
- Two 32-bit or 16-bit counters
- One of the following timer modes:
- Periodic
- One-shot
- Free-running
- 3-channel I/O control interface for each dual timer instance supports I/O set, reset and toggle.
- One I/O control channel supports up to five compare events, including START, STOP, PERIOD and two custom COUNT events.
- Flexible and configurable interrupts for all compare events in I/O control function.
- The clock source of the Dual Timer follows the system clock
- Dual Timer has a prescaler that can divide down the enabled timer clock rate by a factor of 1, 16, or 256.
- Dual Timer supports the specified number of cycles to stop counting.
- Dual Timer pauses when the MCU is suspended.
Counter
In Dual Timer, both of the counters are defined by default, and they can be defined as either 16-bit or 32-bit down counter. For each counter, the following operational modes are available:
- Free-running mode
The counter wraps after reaching zero, and continues to count down from the maximum value (0xFFFFFFFF). This is the default mode.
- Periodic mode
The counter generates an interrupt at a fixed interval, reloading the original value after wrapping past zero values.
- One-shot mode
The counter generates an interrupt once. When the counter reaches 0, it halts until you reprogram it.
The RELOAD value only represents the count-down number of timers. To configure a specific duration (for example, µs, ms, or s), use the following formula:
where PRE stands for prescaled coefficient.
When the value of the RELOAD register is configured to 0, no count and no interrupt are generated.
Dual timer supports background reload function in periodic mode. If the BG_LOAD register is configured with a value, the Dual Timer will restart counting down with the BG_LOAD value after the current counting cycle is completed. If BG_LOAD value is set before Dual Timer is initialized, the BG_LOAD value will become invalid after the Dual Timer is initialized with the RELOAD value.
Dual timer supports one-time background reload function in periodic mode. If the TP_LOAD register is configured with a value, the Dual Timer will start counting down one-time with the TP_LOAD value after the current counting cycle is completed. When the BG_LOAD and TP_LOAD registers are configured at the same time, the dual timer will respond to the TP_LOAD register first.
Dual Timer supports the specified number of cycles to stop counting in periodic mode. If the PERIOD_COUNT register is configured with a value, the Dual Timer will stop counting after the specified number of cycles are completed. The value is valid when it is greater than 1. The PERIOD_COUNT register is only valid when one of the I/O control channels is enabled.
I/O Control
The dual timer supports I/O control function without going through interrupt handler. Each of the instance supports three channels with up to five compare events.
- I/O is muxed to dual timer in order to implement I/O control function.
- I/O initial state can be defined through the IO_INIT_SET register before the I/O control channel is enabled.
- There are up to five compare events for I/O control. When the dual timer starts counting, the start event will trigger the channel I/O action. When the counter value reaches zero, the PERIOD event will trigger the channel I/O action. When the dual timer stops counting, the STOP event will trigger the channel I/O action. Each channel has two custom compare values which can be configured in COUNT_x1IO and COUNT_x2IO registers. When the counter value reaches the compare value, the IOx_C1 and IOx_C2 events will trigger the channel I/O action. Compare value greater than reload value will not trigger an interrupt or IO control action.
- I/O action supports I/O set, reset and toggle.
- Channel I/O will trigger a PERIOD event action and a STOP event action in sequence at the end of the counting in one-shot mode.
For example, the I/O action timing diagram of I/O control function using dual timer is shown in the figure below.
RELOAD
- Name: Dual Timer Reload Register
- Description: This register contains the value from which the counter is to decrease. The count is immediately restarted from the new RELOAD value.
- Base Address: 0x40002000
- Offset: 0x00 + x*0x80
- Reset Value: 0x00
*x is used to identify the counter of the Dual Timer Module. The “x” can be 0 or 1.
Bits | Field Name | RW | Reset | Description |
31:0 |
RELOAD |
Reload value. Write to this register sets the current value. |
VALUE
- Name: Dual Timer Current Value Register
- Description: This register provides the current count value of the decrementing counter.
- Offset: 0x04 + x*0x80
- Reset Value: 0xFFFFFFFF
31:0 |
VALUE |
RO |
0xFFFFFFFF |
Current count value |
CTRL
- Name: Dual Timer Control Register
- Description: This register enables the software to control the Dual Timer.
- Offset: 0x08 + x*0x80
- Reset Value: 0x20
31:21 | RSVD | R | Reserved bits | |
20 | IOC_ACT_C2_INTEN | RW | 0x0 | Interrupt when timer value meets COUNT_C2IO Value:
19 | IOC_ACT_C1_INTEN | RW | 0x0 | Interrupt when timer value meets COUNT_C1IO Value:
18 | IOB_ACT_C2_INTEN | RW | 0x0 | Interrupt when timer value meets COUNT_B2IO Value:
17 | IOB_ACT_C1_INTEN | RW | 0x0 | Interrupt when timer value meets COUNT_B1IO Value:
16 | ACT_STOP_INTEN | RW | 0x0 | Interrupt when timer stop Value:
15 | ACT_PERIOD_INTEN | RW | 0x0 | Interrupt when timer value meets 0 Value:
14 | IOA_ACT_C2_INTEN | RW | 0x0 | Interrupt when timer value meets COUNT_A2IO Value:
13 | IOA_ACT_C1_INTEN | RW | 0x0 | Interrupt when timer value meets COUNT_A1IO Value:
12 | ACT_START_INTEN | RW | 0x0 | Interrupt when timer start Value:
11 | RSVD | R | Reserved bits | |
10 | IOC | RW | 0x0 | Channel C I/O Control enable Value:
9 | IOB | RW | 0x0 | Channel B I/O Control enable Value:
8 | IOA | RW | 0x0 | Channel A I/O Control enable Value:
7 | EN | RW | 0x0 | Timer enable Value:
6 | MODE | RW | 0x0 | Timer mode Value:
5 | INTEN | RW | 0x1 | Interrupt enable Value:
4 | RSVD | R | Reserved bits | |
3:2 | PRE | RW | 0x0 | Prescale bits Value:
1 | SIZE | RW | 0x0 | Select 16-bit or 32-bit counter operation: Value:
0 | ONESHOT | RW | 0x0 | Select wrap mode or one-shot mode: Value:
INTCLR
- Name: Dual Timer Interrupt Clear Register
- Description: Any write to the INTCLR register clears the interrupt output from the counter.
- Offset: 0x0C + x*0x80
- Reset Value: 0x00
31:0 |
CLR |
WO |
Clear the Dual-Timer interrupt event. |
RAW_INTSTAT
- Name: Dual Timer Raw Interrupt Status Register
- Description: The RAW_INTSTAT register indicates the raw interrupt status from the counter.
- Offset: 0x10 + x*0x80
- Reset Value: 0x00
31:1 |
Reserved bits |
0 |
RIS_RTI |
RO |
Raw interrupt status from the counter |
INTSTAT
- Name: Dual-Timer interrupt enable status register
- Description: The INTSTAT register indicates the masked interrupt status from the counter.
- Offset: 0x14 + x*0x80
- Reset Value: 0x00
31:10 |
Reserved bits |
9 |
IOC_ACT_C2 |
Interrupt status when timer value meets to COUNT_C2IO |
8 |
IOC_ACT_C1 |
Interrupt status when timer value meets to COUNT_C1IO |
7 |
IOB_ACT_C2 |
Interrupt status when timer value meets to COUNT_B2IO |
6 |
IOB_ACT_C1 |
Interrupt status when timer value meets to COUNT_B1IO |
5 |
ACT_STOP |
Interrupt status when timer stop. |
4 |
ACT_PERIOD |
Interrupt status when timer value meets to 0 |
3 |
IOA_ACT_C2 |
Interrupt status when timer value meets to COUNT_A2IO |
2 |
IOA_ACT_C1 |
Interrupt status when timer value meets to COUNT_A1IO |
1 |
ACT_START |
Interrupt status when timer start. |
0 |
ISR_TI |
RO |
Enable interrupt status from the counter. |
BG_LOAD
- Name: Dual-Timer background reload register
- Description: When the BG_LOAD value is set, the counter will count down again from the BG_LOAD value after completing the current counting cycle.
- Offset: 0x18 + x*0x80
- Reset Value: 0x00
31:0 |
BL |
The BG_LOAD does not cause the counter to immediately restart from the new value. |
COUNT_A1IO
- Name: Dual-Timer Channel A Count 1 register
- Description: This register indicates the count 1 value for channel A I/O Control.
- Offset: 0x1C + x*0x80
31:0 |
COUNT_A1IO |
0xFFFFFFFF |
When timer value meet this value, the channel A will act. |
COUNT_A2IO
- Name: Dual-Timer Channel A Count 2 register
- Description: This register indicates the count 2 value for channel A I/O Control.
- Offset: 0x20 + x*0x80
31:0 |
COUNT_A2IO |
0xFFFFFFFF |
COUNT_B1IO
- Name: Dual-Timer Channel B Count 1 register
- Description: This register indicates the count 1 value for channel B I/O Control.
- Offset: 0x24 + x*0x80
31:0 |
COUNT_B1IO |
0xFFFFFFFF |
When timer value meet this value, the channel B will act. |
COUNT_B2IO
- Name: Dual-Timer Channel B Count 2 register
- Description: This register indicates the count 2 value for channel B I/O Control.
- Offset: 0x28 + x*0x80
31:0 |
COUNT_B2IO |
0xFFFFFFFF |
COUNT_C1IO
- Name: Dual-Timer Channel C Count 1 register
- Description: This register indicates the count 1 value for channel C I/O Control.
- Offset: 0x2C + x*0x80
31:0 |
COUNT_C1IO |
0xFFFFFFFF |
When timer value meet this value, the channel C will act. |
COUNT_C2IO
- Name: Dual-Timer Channel C Count 2 register
- Description: This register indicates the count 2 value for channel C I/O Control.
- Offset: 0x30 + x*0x80
31:0 |
COUNT_C2IO |
0xFFFFFFFF |
IO_ACT_CTRL
- Name: Dual-Timer I/O action control register
- Description: This register enables the software to control I/O action.
- Offset: 0x34 + x*0x80
- Reset Value: 0x00
31:30 |
Reserved bits |
29:28 |
IOC_ACT_CTRL_STOP |
Channel C action when timer stop Value:
27:26 |
IOC_ACT_CTRL_PERIOD |
Channel C action when timer meets 0 Value:
25:24 |
IOC_ACT_CTRL_C2 |
Channel C action when timer meets COUNT_C2IO Value:
23:22 |
IOC_ACT_CTRL_C1 |
Channel C action when timer meets COUNT_C1IO Value:
21:20 |
IOC_ACT_CTRL_START |
Channel C action when timer start Value:
19:18 |
IOB_ACT_CTRL_STOP |
Channel B action when timer stop Value:
17:16 |
IOB_ACT_CTRL_PERIOD |
Channel B action when timer meets 0 Value:
15:14 |
IOB_ACT_CTRL_C2 |
Channel B action when timer meets COUNT_B2IO Value:
13:12 |
IOB_ACT_CTRL_C1 |
Channel B action when timer meets COUNT_B1IO Value:
11:10 |
IOB_ACT_CTRL_START |
Channel B action when timer start Value:
9:8 |
IOA_ACT_CTRL_STOP |
Channel A action when timer stop Value:
7:6 |
IOA_ACT_CTRL_PERIOD |
Channel A action when timer meets 0 Value:
5:4 |
IOA_ACT_CTRL_C2 |
Channel A action when timer meets COUNT_A2IO Value:
3:2 |
IOA_ACT_CTRL_C1 |
Channel A action when timer meets COUNT_A1IO Value:
1:0 |
IOA_ACT_CTRL_START |
Channel A action when timer start Value:
IO_INIT_SET
- Name: Dual-Timer I/O initial control register
- Description: This register enables the software to control I/O initial state.
- Offset: 0x38 + x*0x80
- Reset Value: 0x00
31:3 |
Reserved bits |
2 |
IOC_ACT_INIT |
Set channel C initial value when CTRL_IOC is disabled. Value:
1 |
IOB_ACT_INIT |
Set channel B initial value when CTRL_IOB is disabled. Value:
0 |
IOA_ACT_INIT |
Set channel A initial value when CTRL_IOA is disabled. Value:
TP_LOAD
- Name: Dual-Timer one-time reload register
- Description: When the TP_LOAD value is set, the counter will count down again from the TP_LOAD value after completing the current counting cycle for one cycle.
- Offset: 0x3C + x*0x80
- Reset Value: 0x00
31:0 |
TP_LOAD |
Used to reload the counter when Periodic mode/io action mode is enabled, and the current count reaches 0. The value is only invalid one time. When the timer reloads the value, the register will be cleared automatically. |
PERIOD_COUNT
- Name: Dual-Timer period count register
- Description: This register indicates the period count in period mode.
- Offset: 0x4C + x*0x80
- Reset Value: 0x00
31:16 |
Reserved bits |
15:0 |
PERIOD_COUNT |
Set dual timer's period count in period mode. The value is valid when the value is greater than 1. |
IO_BLE_INTCLR
- Name: Dual Timer I/O Control Interrupt Clear Register
- Description: Any write to the IO_BLE_INTCLR register clears the interrupt of I/O control function.
- Offset: 0x50 + x*0x80
- Reset Value: 0x00
31:12 |
Reserved bits |
11 |
IO_ACT_ALL_INTCLR |
W |
Write 1 to clear all I/O interrupt status. |
10:9 |
Reserved bits |
8 |
IOC_ACT_C2_INTCLR |
W |
Write 1 to clear IOC_ACT_C2. |
7 |
IOC_ACT_C1_INTCLR |
W |
Write 1 to clear IOC_ACT_C1. |
6 |
IOB_ACT_C2_INTCLR |
W |
Write 1 to clear IOB_ACT_C2. |
5 |
IOB_ACT_C1_INTCLR |
W |
Write 1 to clear IOB_ACT_C1. |
4 |
ACT_STOP_INTCLR |
W |
Write 1 to clear ACT_STOP. |
3 |
ACT_PERIOD_INTCLR |
W |
Write 1 to clear ACT_PERIOD. |
2 |
IOA_ACT_C2_INTCLR |
W |
Write 1 to clear IOA_ACT_C2. |
1 |
IOA_ACT_C1_INTCLR |
W |
Write 1 to clear IOA_ACT_C1. |
0 |
ACT_START_INTCLR |
W |
Write 1 to clear ACT_START. |
