Always-on Watchdog (AON_WDT)
The Always-on Watchdog (AON_WDT) is a 32-bit countdown hardware timer. When the AON_WDT counter counts to 0, a system reset signal is sent, and when the counter value decreases to the set warning value, an interrupt signal is generated. Because the AON_WDT timer is in the AON domain, it can keep running when the MCU is off.
- The MCU_CLK_CTRL register is a read/write register which controls clock source selections.
- 32-bit down counter running with a low-power clock
- Generate an interrupt to warn the MCU when the 32-bit down counter reaches the alarm values
- 16-bit alarm register, supporting reading and writing
- Flexible clock source selections from LFRC_32K or LFXO_32K
- An independent interrupt entry
- Support write access protection
- The LOCK register enables or disables write accesses to all other registers. This is to prevent malicious software from disabling the watchdog functionality. Writing a value of 0x15CC5A51 (LOCK.LOCK_SET[31:1]) enables write accesses to all other registers. Writing any other value to the LOCK register disables the write accesses.
- When the AON_WDT is disabled, all register values must be cleared to restore the default values.
- When the CFG0.EN bit is set to 1, the value of the TIMER_W register is automatically loaded into the TIMER_R register, and the value starts to decrease.
- The AON_WDT alarm interrupt is triggered when the value of the TIMER_R register decrements to the value of the ALARM_R register.
- When the TIMER_R count value decrements to 0, the system restarts.
MCU_CLK_CTRL
- Name: MCU_CLK_CTRL Register
- Description: This register sets AON_WDT CLK configurations.
- Base Address: 0x4000A000
- Offset: 0x0
- Reset Value: 0x42040202
5:4 |
WDT_CLK_SEL |
WO |
3:0 |
RO |
Reserved bits |
CFG_0
- Name: CFG_0 Register
- Description: This register sets AON_WDT configurations.
- Base Address: 0x4000A700
- Offset: 0x0
31:25 |
Reserved bits |
24 |
CFG |
WO |
Writing 1 to this bit triggers the watchdog timer configuration. |
23:5 |
Reserved bits |
4 |
ESD_PROTECT |
WR |
3 |
ALARM_SET |
Set the timer alarm value. |
2 |
ALARM_EN |
Enable AON WDT alarm. |
1 |
TIMER_SET |
WO |
Enable AON WDT timer reload (feed). |
0 |
EN |
Enable AON WDT. |
LOCK
- Name: LOCK Register
- Description: This register can prevent other registers of AON_WDT from being overwritten.
- Offset: 0x4
31:1 |
LOCK_SET |
WO |
Enable write access to all other registers by writing 0x15CC5A51. Disable write accesses by writing any other value to the LOCK register. |
0 |
STAT |
RO |
0 |
STAT
- Name: STAT Register
- Description: This register can be used to get status of AON_WDT.
- Offset: 0x38
31:2 |
Reserved bits |
1 |
BUSY |
Watchdog timer is busy. The application layer can perform other operations until this bit is set to 0. |
0 |
STAT |
AON WDT is running. |
TIMER_W
- Name: TIMER_W Register
- Description: This register is used to configure the initial AON_WDT value.
- Offset: 0x40
31:0 |
VAL |
Write: Write the initial AON WDT value to the register. Read: Read the initial AON WDT value that users have configured. Read TIMER_R to get the current internal value. |
ALARM_W
- Name: ALARM_W Register
- Description: This register is used to configure the AON_WDT alarm value.
- Offset: 0x44
- Reset Value: 0x64
31:16 |
Reserved bits |
15:0 |
VAL |
0x64 |
Write: Write an AON WDT alarm value to the register. Read: Read the AON WDT alarm value that users have configured. Read ALARM_R to get the current internal alarm value of AON WDT. |
TIMER_R
- Name: TIMER_R Register
- Description: This register is used to get the current value of AON_WDT.
- Offset: 0x4C
31:0 |
VAL |
RO |
Current internal value of AON WDT |
ALARM_R
- Name: ALARM_R Register
- Description: This register reads the current alarm value of AON_WDT.
- Offset: 0x50
31:16 |
Reserved bits |
15:0 |
VAL |
RO |
Current internal alarm value of the AON WDT |
