DDVS
DDVS_EN
  • Name: DDVS_EN Register
  • Description: DDVS_EN Register
  • Base Address: 0x4000E800
  • Offset: 0x0
Table 238 DDVS_EN Register
31:1
DDVS_EN
Enable DDVS.
  • 0x0: Disable DDVS (default).
  • 0x1: Enable DDVS.
DDVS_CFG_1
  • Name: DDVS_CFG_1 Register
  • Description: DDVS_CFG_1 Register
  • Offset: 0x4
Table 239 DDVS_CFG_1 Register
31 CONF_DDVS_MODE RW 0x0
DDVS mode
  • 0x0: DDVS automatic mode (default)
  • 0x1: DDVS manual mode
30:29 CONF_DIV_FACTOR RW 0x0
Ringo frequency division factor
  • 0x0: 8K (default)
  • 0x1: 4K
  • 0x2: 16K
  • 0x3: reserved
28:25 CONF_RINGO_EN RW 0x0
Enable each ringo.
  • 0x0: Disable all 4 ringos (default).
  • Others: Enable corresponding ringos.
24 CONF_INT_EN RW 0x0
Enable error interrupt.
  • 0x0: Disable error interrupt.
  • 0x1: Enable error interrupt.
23 ERR_INT WC 0x0
Error interrupt
  • 0x0: no error
  • 0x1: error interrupt
CPU writes 1 to clear, and writing 0 is invalid.
22:17 CONF_VREF_MANUAL RW 0x0
Manual vref
In manual mode, MCU writes this register to set vref.
16 RSVD R 0x0 Reserved bit
15:4 CONF_THRESHOLD_SLOW RW 0x0 Drift slow threshold that changes lock state to re-adjust vref
3:0 RSVD R 0x0 Reserved bits
DDVS_CFG_2
  • Name: DDVS_CFG_2 Register
  • Description: DDVS_CFG_2 Register
  • Offset: 0x8
Table 240 DDVS_CFG_2 Register
31:20
CONF_TARGET_CNT
Target counter number
19:16
15:4
CONF_THRESHOLD_FAST
Drift threshold that changes lock state to re-adjust vref
3:0
DDVS_RINGO_CNT_01
  • Name: DDVS_RINGO_CNT_01 Register
  • Description: DDVS_RINGO_CNT_01 Register
  • Offset: 0xC
Table 241 DDVS_RINGO_CNT_01 Register
31:20
RINGO_0_CNT
Ringo 0 counter
19:16
15:4
RINGO_1_CNT
Ringo 1 counter
3:0
DDVS_RINGO_CNT_23
  • Name: DDVS_RINGO_CNT_23 Register
  • Description: DDVS_RINGO_CNT_23 Register
  • Offset: 0x10
Table 242 DDVS_RINGO_CNT_23 Register
31:20
RINGO_2_CNT
Ringo 2 counter
19:16
15:4
RINGO_3_CNT
Ringo 3 counter
3:0
DDVS_FSM
  • Name: DDVS_FSM Register
  • Description: DDVS_FSM Register
  • Offset: 0x14
Table 243 DDVS_FSM Register
31:29
CURR
FSM current state
  • 0x0: initial state
  • 0x1: vref plus 1
  • 0x2: vref minus 1
  • 0x3: lock
  • 0x4: An error occurs when vref reaches the maximum but still does not meet the system requirement.
  • Others: not used
28:0
DDVS_CLK_CTRL
  • Name: DDVS_CLK_CTRL Register
  • Description: DDVS_CLK_CTRL Register
  • Offset: 0x40
Table 244 DDVS_CLK_CTRL Register
31:10
9:8
CLK_SEL
  • 0x0: xo_32MHz
  • 0x1: xo_16MHz
  • 0x2: sys_32MHz
  • 0x3: sys_16MHz
7:1
CLK_EN
  • 0x0: Disable CLK.
  • 0x1: Enable CLK.
