Timer
The device has two instances of Timer module. Each Timer module features a 32-bit down counter and 4-channel I/O capture registers. Because the Timer is in the MCU subsystem domain, Timer interrupt is not available during sleep, and the running Timer will not prevent MCU from sleeping. In active mode, when the Timer is restarted after being stopped, it will continue to count down from the stop time.
  • Generate an interrupt when the 32-bit down counter reaches 0.
  • The 4-channel I/O capture function contains rising edge capture, falling edge capture, and both edge capture.
  • The clock source of the Timer follows the system clock.
  • Each Timer module has an independent interrupt entry.
  • Timer pauses when the MCU is suspended.
Counter
  • The Timer can generate a COUNTDONE interrupt request signal when the 32-bit down counter reaches 0. The COUNTDONE interrupt request is held until it is cleared by writing 1 to the COUNTDONE_INT_STAT bit in the INTSTAT register.
  • If the Timer count reaches 0 and, at the same time, the software clears the previous COUNTDONE interrupt status, the COUNTDONE_INT_STAT bit is set to 1.
  • When the value of the RELOAD register is configured to 0, no COUNTDONE interrupt are generated.
  • The RELOAD value only represents the count-down number of timers. If you want to configure a specific duration (for example, µs, ms, or s), you need to use the following formula:
  • When the CTRL.EN bit is set to 1, the timer is running. Changing the value in the RELOAD register will take effect immediately, and the timer will count down from the new RELOAD value.
I/O Capture
  • I/O should be set to input mode for Timer I/O capture function.
  • I/O capture function supports falling edge capture, rising edge capture and both edge capture which can be configured the CHx_EDGE_DET bit in the CTRL register.
  • Each Timer module can capture GPIO_0 to GPIO_13, AON_GPIO_0 to AON_GPIO_7, and MSIO_0 to MSIO_9. The CHx interrupt request is held until it is cleared by writing 1 to the CHx_INT_STAT bit in the INTSTAT register.
  • The captured value of each channel will be put into the corresponding CHANNELx_VAL register. When multiple values are captured continuously by the same channel, only the last value is retained in CHANNELx_VAL register.
Figure 42 Timing diagram – I/O capture both edge
CTRL
  • Name: Timer Control Register
  • Description: The CTRL register configures capture channel parameters and enables the software to control the Timer.
  • Base Address: 0x40000000 + x*0x1000
  • Offset: 0x00
  • Reset Value: 0x00
*x is used to identify the Timer Module. The “x” can be 0 or 1.
Table 296 CTRL
31:29
28:24
CH3_PIN_SELECT
GPIO PIN select of channel3
  • 0x0–0xC: GPIO_0 to GPIO_13
  • 0xD–0x14: AON_GPIO_0 to AON_GPIO_ 7
  • 0x15–0x1E: MSIO_0 to MSIO_9
23:19
CH2_PIN_SELECT
GPIO PIN select of channel2
18:14
CH1_PIN_SELECT
GPIO PIN select of channel1
13:9
CH0_PIN_SELECT
GPIO PIN select of channel0
8:7
CH3_EDGE_DET
Capture type of channel3
  • 0x0: None
  • 0x1: Falling edge capture
  • 0x2: Rising edge capture
  • 0x3: Both edge capture
6:5
CH2_EDGE_DET
Capture type of channel2
  • 0x0: None
4:3
CH1_EDGE_DET
Capture type of channel1
  • 0x0: None
2:1
CH0_EDGE_DET
Capture type of channel0
  • 0x0: None
EN
Timer enable bit
  • 0x0: Disable the Timer.
  • 0x1: Enable the Timer.
VALUE
  • Name: Timer Value Register
  • Description: The VALUE register indicates the current value of the decrementing counter.
  • Offset: 0x04
  • Reset Value: 0x00
Table 297 VALUE
31:0
VALUE
Current value
RELOAD
  • Name: Timer Reload Register
  • Description: When this register is written to, the count value takes effect immediately from a new RELAOD value.
  • Offset: 0x08
  • Reset Value: 0x00
Table 298 RELOAD
31:0
RELOAD
Sets reload value.
INTEN
  • Name: Timer Interrupt Enable Register
  • Description: The INTEN register indicates interrupt enable configuration of COUNTDONE, CHANNEL0 capture, CHANNEL1 capture, CHANNEL2 capture, or CHANNEL3 capture.
  • Offset: 0x0C
Table 299 INTEN
31:5
4
CH3_INT_EN
Channel 3 I/O capture interrupt enable bit
3
CH2_INT_EN
Channel 2 I/O capture interrupt enable bit
2
CH1_INT_EN
Channel 1 I/O capture interrupt enable bit
CH0_INT_EN
Channel 0 I/O capture interrupt enable bit
COUNTDONE_INT_EN
Count done interrupt enable bit
INTSTAT
  • Name: Timer Interrupt Status Register
  • Description: The INTSTAT register indicates the interrupt status from the counter. Writing one to each bit of INTSTAT register clears the corresponding interrupt.
  • Offset: 0x10
Table 300 INTSTAT
31:5
4
CH3_INT_STAT
WC
Channel 3 captured; write 1 to clear.
3
CH2_INT_STAT
WC
Channel 2 captured; write 1 to clear.
2
CH1_INT_STAT
WC
Channel 1 captured; write 1 to clear.
CH0_INT_STAT
WC
Channel 0 captured; write 1 to clear.
COUNTDONE_INT_STAT
WC
Count done; write 1 to clear.
CHANNEL0_VAL
  • Name: CHANNEL0 Capture Value
  • Description: The CHANNEL0_VAL register indicates the edge capture value.
  • Offset: 0x14
Table 301 CHANNEL0_VAL
31:0
CH0_VAL
When the desired I/O edge is captured, the value of the current counter is stored.
CHANNEL1_VAL
  • Name: CHANNEL1 Capture Value
  • Description: The CHANNEL1_VAL register indicates the edge capture value.
  • Offset: 0x18
Table 302 CHANNEL1_VAL
31:0
CH1_VAL
CHANNEL2_VAL
  • Name: CHANNEL2 Capture Value
  • Description: The CHANNEL2_VAL register indicates the edge capture value.
  • Offset: 0x1C
Table 303 CHANNEL2_VAL
31:0
CH2_VAL
CHANNEL3_VAL
  • Name: CHANNEL3 Capture Value
  • Description: The CHANNEL3_VAL register indicates the edge capture value.
  • Offset: 0x20
Table 304 CHANNEL3_VAL
31:0
CH3_VAL
