文档中心 > GR533x Datasheet/ System/ Registers/ Always-on Power Control Copy URL
A_TIMING_CTRL0
  • Name: A_TIMING_CTRL0 Register
  • Description: A_TIMING_CTRL0 Register
  • Base Address: 0x4000A400
  • Offset: 0x0
  • Reset Value: 0x0009001E
Table 101 A_TIMING_CTRL0 Register
31:20
19:16
DIG_LDO
0x9
CORE_LDO timing required for power-on
15:5
4:0
DCDC
0x1E
DC-DC timing required for power-on
A_TIMING_CTRL1
  • Name: A_TIMING_CTRL1 Register
  • Description: A_TIMING_CTRL1 Register
  • Offset: 0x4
  • Reset Value: 0x00070009
Table 102 A_TIMING_CTRL1 Register
31:20
19:16
HF_OSC
0x7
HF_OSC timing required for stability
15:4
3:0
FAST_LDO
0x9
FAST_LDO timing required for power-on
A_TIMING_CTRL2
  • Name: A_TIMING_CTRL2 Register
  • Description: A_TIMING_CTRL2 Register
  • Offset: 0x8
  • Reset Value: 0x0003003B
Table 103 A_TIMING_CTRL2 Register
31:21
20:16
PLL
0x3
PLL timing required for stability
15:6
5:0
PLL_LOCK
0x3B
PLL lock timing required for stability
A_TIMING_CTRL3
  • Name: A_TIMING_CTRL3 Register
  • Description: A_TIMING_CTRL3 Register
  • Offset: 0xC
  • Reset Value: 0x00F90009
Table 104 A_TIMING_CTRL3 Register
31:24
23:16
XO
0xF9
XO timing required for stability
15:4
3:0
PWR_SWITCH
0x9
IO LDO or standard IO LDO power switch timing required for stability
A_TIMING_CTRL4
  • Name: A_TIMING_CTRL4 Register
  • Description: A_TIMING_CTRL4 Register
  • Offset: 0x10
  • Reset Value: 0x000E0095
Table 105 A_TIMING_CTRL4 Register
31:20
19:16
RF_TUNE
0xE
RF_TUNE timing required for stability
15:8
7:0
XO_BIAS_SW
0x95
XO bias timing required for stability
A_SLP_CFG
  • Name: A_SLP_CFG Register
  • Description: A_SLP_CFG Register
  • Offset: 0x20
  • Reset Value: 0x00070017
Table 106 A_SLP_CFG Register
31:19
18
TRN_ON_STB_LDO
0x1
  • 0x0: Keep the current status.
  • 0x1: Turn on the standby IO_LDO power switch in sleep mode.
17
TRN_OFF_PLL
0x1
PLL status in sleep mode
  • 0x1: Turn off
16
TRN_OFF_XO
0x1
XO status in sleep mode
  • 0x1: Turn off
15:5
4
TRN_OFF_FAST_LDO
0x1
FAST_LDO status in sleep mode
  • 0x1: Turn off
3
TRN_OFF_IO_LDO
IO_LDO status in sleep mode
  • 0x1: Turn off
2
TRN_OFF_HF_OSC
0x1
HF_OSC status in sleep mode
  • 0x1: Turn off
TRN_OFF_DIG_LDO
0x1
CORE_LDO status in sleep mode
  • 0x1: Turn off
TRN_OFF_DCDC
0x1
DC-DC status in sleep mode
  • 0x1: Turn off
AON_START_CFG
  • Name: AON_START_CFG Register
  • Description: AON_START_CFG Register
  • Offset: 0x24
  • Reset Value: 0x00000056
Table 107 AON_START_CFG Register
31:7
6
PLL_EN_PWR
0x1
1: Enable PLL after DC-DC gets ready.
5
Reserved bit
4
XO_EN_PWR
0x1
1: Enable XO after DC-DC gets ready.
3
Reserved bit
2:1
POWER_MODE
0x3
Power mode:
  • 0x0: Start with DC-DC only.
  • 0x1: Boot with SYS_LDO only.
  • 0x2: Start DC-DC and SYS_LDO at the same time, and the hardware closes SYS_LDO after completion.
  • 0x3: Start DC-DC and SYS_LDO at the same time, both of which remain on after completion.
Reserved bit
DPAD_LE_CTRL
  • Name: DPAD_LE_CTRL Register
  • Description: DPAD_LE_CTRL Register
  • Offset: 0x28
  • Reset Value: 0x00040100
Table 108 DPAD_LE_CTRL Register
31:19
18
WAKEUP
0x1
Set HW controlled dpad_le value after waking up.
17
Reserved bit
16
SLEEP
Set HW controlled dpad_le value during sleep.
15:11
10
BUSY
DPAD_LE_CTRL is applying a value. Do not apply a value again.
9
Reserved bit
8
READ
0x1
The current DPAD Latch value
7:3
2
APPLY_WR
W
Write 1 to apply the value of WR to control signal.
Reserved bit
WR
Enable DPAD Latch.
  • 0x0: Latch the pad configurations.
  • 0x1: The DPAD latch is transparent.
AON_SLP_CTRL
  • Name: AON_SLP_CTRL Register
  • Description: AON_SLP_CTRL Register
  • Offset: 0x3C
Table 109 AON_SLP_CTRL Register
31:9
8
PRO
The power controller is processing a deep-sleep request.
7:1
REQ
W
Write 1 to send a sleep request.
XO_PLL_SET
  • Name: XO_PLL_SET Register
  • Description: XO_PLL_SET Register
  • Offset: 0x40
Table 110 XO_PLL_SET Register
31:3
2
HF_OSC_SET
W
Write 1 to enable HFOSC. This operation will turn DC-DC on if it is not.
XO_SET
W
Write 1 to enable HFXO. This operation will turn DC-DC on if it is not.
PLL_SET
W
Write 1 to enable CPLL. This operation will turn DC-DC on if it is not.
XO_PLL_CLR
  • Name: XO_PLL_CLR Register
  • Description: XO_PLL_CLR Register
  • Offset: 0x44
Table 111 XO_PLL_CLR Register
31:3
2
HF_OSC_CLR
W
Write 1 to disable HFOSC.
XO_CLR
W
Write 1 to disable HFXO.
PLL_CLR
W
Write 1 to disable CPLL.
XO_PLL_STAT
  • Name: XO_PLL_STAT Register
  • Description: XO_PLL_STAT Register
  • Offset: 0x48
  • Reset Value: 0x00000007
Table 112 XO_PLL_STAT Register
31:3
2
HF_STAT
0x1
HF_OSC stable state
XO_STAT
0x1
XO stable state
PLL_STAT
0x1
PLL stable state
PWR_SET
  • Name: PWR_SET Register
  • Description: PWR_SET Register
  • Offset: 0x4C
Table 113 PWR_SET Register
31:6
5
STB_IO_LDO_SET
W
Write '1' to enable STB_IO_LDO.
4
IO_LDO_SET
W
Write '1' to enable IO_LDO.
3
Reserved bit
2
FAST_LDO_SET
W
Fast LDO power request
DIG_LDO_SET
W
CORE_LDO power request
DCDC_SET
W
DC-DC power request
PWR_CLR
  • Name: PWR_CLR Register
  • Description: PWR_CLR Register
  • Offset: 0x50
Table 114 PWR_CLR Register
31:6
5
STD_IO_LDO_CLR
W
Write '1' to disable STB_IO_LDO.
4
IO_LDO_CLR
W
Write '1' to disable IO_LDO.
3
Reserved bit
2
FAST_LDO_CLR
W
Disable Fast LDO power.
DIG_LDO_CLR
W
Disable CORE_LDO power.
DCDC_CLR
W
Disable DC-DC power.
PWR_STAT
  • Name: PWR_STAT Register
  • Description: PWR_STAT Register
  • Offset: 0x54
Table 115 PWR_STAT Register
31:3 RSVD R 0x0 Reserved bits
2 FAST_LDO_AVL R 0x1
Fast LDO power is available.
The status is NOT valid if analog interface overriding is used.
1 DIG_LDO_AVL R 0x1
CORE_LDO power is available.
0 DCDC_AVL R 0x1
DC-DC power is available.
MEM_PWR_SLP0
  • Name: MEM_PWR_SLP0 Register
  • Description: MEM_PWR_SLP0 Register
  • Offset: 0x80
  • Reset Value: 0x00000FFF
Table 116 MEM_PWR_SLP0 Register
31:12
11:10
SET05
0x3
Memory power states that is loaded in sleep phase
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
9:8
SET04
0x3
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
7:6
SET03
0x3
  • 0x0: OFF
  • 0x1: Reserved
  • 0x2: full power
  • 0x3: retention
5:4
SET02
0x3
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
3:2
SET01
0x3
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
1:0
SET00
0x3
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
MEM_PWR_SLP1
  • Name: MEM_PWR_SLP1 Register
  • Description: MEM_PWR_SLP1 Register
  • Offset: 0x84
  • Reset Value: 0x0000003C
Table 117 MEM_PWR_SLP1 Register
31:6
5:4
ICACHE_SET
0x3
Cache memory sleep power
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
3:2
HTM_DM_SET
0x3
Hopping table DM memory sleep power
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
1:0
MEM_PWR_WKUP0
  • Name: MEM_PWR_WKUP0 Register
  • Description: MEM_PWR_WKUP0 Register
  • Offset: 0x88
  • Reset Value: 0x00000AAA
Table 118 MEM_PWR_WKUP0 Register
31:12
11:10
SET05
0x2
Memory power states that is loaded in wakeup phase
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
9:8
SET04
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
7:6
SET03
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
5:4
SET02
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
3:2
SET01
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
1:0
SET00
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
MEM_PWR_WKUP1
  • Name: MEM_PWR_WKUP1 Register
  • Description: MEM_PWR_WKUP1 Register
  • Offset: 0x8C
  • Reset Value: 0x00000020
Table 119 MEM_PWR_WKUP1 Register
31:6
5:4
ICACHE
0x2
Memory power states that is loaded on wakeup
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
3:2
HTM_DM
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
1:0
MEM_PWR_APPLY
  • Name: MEM_PWR_APPLY Register
  • Description: MEM_PWR_APPLY Register
  • Offset: 0x90
Table 120 MEM_PWR_APPLY Register
31:17
16
BUSY
During the bit being 1, writing APPLY would not take any effect.
15:1
APPLY
W
Write 1 to apply the memory settings in MEM_PWR_WKUP manually.
MEM_PWR_STAT0
  • Name: MEM_PWR_STAT0 Register
  • Description: MEM_PWR_STAT0 Register
  • Offset: 0x98
Table 121 MEM_PWR_STAT0 Register
31:12
11:10
SET05
0x2
Memory power states. **Do NOT** read when MEM_PWR_APPLY_BUSY is high.
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
9:8
SET04
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
7:6
SET03
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
5:4
SET02
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
3:2
SET01
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
1:0
SET00
0x2
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
MEM_PWR_STAT1
  • Name: MEM_PWR_STAT1 Register
  • Description: MEM_PWR_STAT1 Register
  • Offset: 0x9C
Table 122 MEM_PWR_STAT1 Register
31:6
5:4
ICACHE_SET
0x2
Memory power states. Do not read when MEM_PWR_APPLY_BUSY is high.
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
3:2
HTM_DM_SET
  • 0x0: OFF
  • 0x1: reserved
  • 0x2: full power
  • 0x3: retention
1:0
MEM_PWR_DBG
  • Name: MEM_PWR_DBG Register
  • Description: MEM_PWR_DBG Register
  • Offset: 0xBC
Table 123 MEM_PWR_DBG Register
31:1
RESET_ON_SRAM
1: When MCU issues a system-reset request, turn ON all SRAM power.
Do not change this register when system-reset is ongoing.
COMM_CORE_PWR_CTRL_SW
  • Name: COMM_CORE_PWR_CTRL_SW Register
  • Description: COMM_CORE_PWR_CTRL_SW Register
  • Offset: 0xC0
  • Reset Value: 0x00000002
Table 124 COMM_CORE_PWR_CTRL_SW Register
31:3
2
RST_N
Comm proc reset active low
When this bit is 0, Bluetooth LE is held in reset.
ISO_EN
0x1
Enable comm_core power domain isolation.
  • 0x0: NO isolation
  • 0x1: isolated
CORE_EN
Enable comm_core power domain power.
  • 0x0: OFF
  • 0x1: ON
COMM_CORE_PWR_CTRL_HW_CFG
  • Name: COMM_CORE_PWR_CTRL_HW_CFG Register
  • Description: COMM_CORE_PWR_CTRL_HW_CFG Register
  • Offset: 0xC4
  • Reset Value: 0x00020200
Table 125 COMM_CORE_PWR_CTRL_HW_CFG Register
31:19
18
PD_HOLD_EN_RD
Real-time status of PD_HOLD_EN
17
AUTO_EN_RD
0x1
Real-time status of AUTO_ON
16
HW_EN_RD
Real-time status of HW_EN
15:12
11
PLL_AUTO_ON
Waking Bluetooth LE timer up will enable PLL automatically.
10
PD_HOLD_EN
Wait the Bluetooth LE timer flag and the delay counter before powering off Bluetooth LE.
9
AUTO_EN
0x1
1: If HW sequencer is selected, set 1 to let HW automatically request power-on when a COMM Timer wakeup signal is received. Please allow 6 μs–12 μs for the configuration to be applied.
8
HW_EN
Enable the hardware sequencer block. Please allow 6 μs–12 μs for the configuration to be applied.
7:1
CTRL_SEL
  • 0x0: Use the register (`COMM_CORE_PWR_CTRL_SW`) to control comm_core power sequence.
  • 0x1: Use Hardware power sequencer.
COMM_CORE_PWR_CTRL_HW_CTRL
  • Name: COMM_CORE_PWR_CTRL_HW_CTRL Register
  • Description: COMM_CORE_PWR_CTRL_HW_CTRL Register
  • Offset: 0xC8
Table 126 COMM_CORE_PWR_CTRL_HW_CTRL Register
31:9
8
DIS
W
Write 1 to start comm_core power-off sequence. Writing it to 0 will take no effect.
7:1
REQ
W
Write 1 to start comm_core power-on sequence. Writing it to 0 will take no effect.
COMM_CORE_PWR_CTRL_HW_STAT
  • Name: COMM_CORE_PWR_CTRL_HW_STAT Register
  • Description: COMM_CORE_PWR_CTRL_HW_STAT Register
  • Offset: 0xCC
Table 127 COMM_CORE_PWR_CTRL_HW_STAT Register
31:3
2
HW_PD_WAIT
1: Power-off command received, waiting for PD condition
HW_PWR
  • 0x0: OFF state or going to be OFF state
  • 0x1: ON state or going to be ON state
BUSY
  • 0x0: HW power controller is ready to receive a command.
  • 0x1: HW power controller is working.
COMM_CORE_PWR_CTRL_PD_DLY
  • Name: COMM_CORE_PWR_CTRL_PD_DLY Register
  • Description: COMM_CORE_PWR_CTRL_PD_DLY Register
  • Offset: 0xD0
Table 128 COMM_CORE_PWR_CTRL_PD_DLY Register
31:17
16
PD_FLAG
1: Do not wait for Bluetooth LE timer flag to power off the Bluetooth LE.
15:8
7:0
PD_DLY
Delay after receiving Bluetooth LE timer flag
  • 0: no delay
  • > 0: N x 4 μs
COMM_CORE_PWR_STAT
  • Name: COMM_CORE_PWR_STAT Register
  • Description: COMM_CORE_PWR_STAT Register
  • Offset: 0xD4
Table 129 COMM_CORE_PWR_STAT Register
31:3
2
RST_N_RD
ISO_EN_RD
0x1
  • 0x0: NO isolation
  • 0x1: isolated
CORE_EN_RD
  • 0x0: OFF
  • 0x1: ON
COMM_TIMER_PWR_CTRL
  • Name: COMM_TIMER_PWR_CTRL Register
  • Description: COMM_TIMER_PWR_CTRL Register
  • Offset: 0xE0
Table 130 COMM_TIMER_PWR_CTRL Register
31:3
2
RST_N
Comm timer reset
This bit is used to reset the Comm timer after it has been powered on.
  • 0x0: Comm timer reset
  • 0x1: Comm timer reset released
ISO_EN
0x1
Enable comm_timer power domain isolation.
  • 0x0: NO isolation
  • 0x1: isolated
EN
Enable comm_timer power domain power.
  • 0x0: OFF
  • 0x1: ON
SOFTWARE_REG_3
  • Name: SOFTWARE_REG_3 Register
  • Description: SOFTWARE_REG_3 Register
  • Offset: 0xE8
Table 131 SOFTWARE_REG_3 Register
31:0
SOFTWARE_REG3
Software can use this register to save data. It will not be reset by NVIC or in sleep.
