Comparator
The comparator compares two analog signals: V1 (input voltage) and V2 (reference voltage), and generates an interrupt when V1 exceeds V2. The interrupt can be used to wake the system up from sleep state. These two signals can be derived from any of the eight MSIOs (MSIO_0–MSIO_7). Additionally, the comparator can be used to compare an external signal with one of the following:
  • An internal programmable reference voltage
  • A programmable divided version of VBATL
  • GND
The comparator accepts rail-to-rail inputs.
  • Input voltage (V1)
    • Internal reference voltage (Vref)
    • VBAT-based reference voltage (Vbatt_ref), internal reference based on VBAT
    • GND
    • Eight MSIOs (MSIO_0–MSIO_7)
  • Reference voltage (V2)
    • GND
  • Configurable 26 mV hysteresis
    • No hysteresis
    • –26 mV negative side of hysteresis
    • + 26 mV positive side of hysteresis
    • Fully hysteresis 52 mV (±26 mV)
  • Res degeneration is set for calibration. The default value is 0x8 and is always kept unchanged.
    • Negative side calibration of comparator
    • Positive side calibration of comparator
  • CascRes Half. This bit is used when the current is set to low.
  • Current set (COMP_REG_0.ICOMP_CTRL).
  • Comparator channel selection
Overview
The following figure shows the block diagram of the wakeup comparator module.
Figure 86 COMP block diagram
Once enabled by configuring the COMP_REG_0.WAKE_COMP_EN bit, the comparator starts to work. When the wakeup comparator module is started, V1 starts to be compared with V2 continuously. When V1 exceeds V2, the wakeup comparator will be triggered. The CHANNEL_SEL_P and CHANNEL_SEL_N fields are used to select the input of V1 and V2. When Vbatt_ref is selected in the CHANNEL_SEL_N or CHANNEL_SEL_P field. The COMP_BATT_LVL_CTRL field is used to select a level value. The following figure shows the settings of VBAT control level. The COMP_BATT_LVL_CTRL level value ranges from 0 to 7, and the calculation formula of Vbatt_ref is shown below:
Figure 87 Set of VBATT control level
When Vref is selected in the CHANNEL_SEL_P or CHANNEL_SEL_N field. The COMP_REF_CTR field is used to select a level value. The settings of Vref control level is showed in the following figure. The COMP_REF_CTRL level value ranges from 0 to 255, and the calculation formula of Vref is shown below:
When the Vref voltage is within the range of 30 mV to 1.7 V, the actual output voltage of the Vref can closely approximate the calculated value derived from the formula above.
Figure 88 Set of Vref control level
The selected analog pins will be acquired by the comparator once it is enabled.
Hysteresis
The configurable 52 mV (±26 mV) hysteresis could be added into the wakeup comparator, which helps ensure the slowly changing voltage or a slightly noisy voltage that will cause the comparator not to output to oscillate frequently when the two input voltages are almost close. This could increase the anti-interference ability of the comparator.
The hysteresis mode can be configured by the COMP_REG_1.NEGATIVE_HYS_EN bit and COMP_REG_1.POSITIVE_HYS_EN bit. The hysteresis on both sides mode is illustrated in the following figure. The comparator will trigger a falling edge interrupt when V1 becomes lower than V2- (VHYST/2). It will also trigger a rising edge interrupt when V1 becomes higher than V2+ (VHYST/2), VHYST is 52 mV. Here it is assumed that V1 is connected to the positive side of the comparator, and V2 is connected to the negative side of the comparator.
Figure 89 Both sides Hysteresis enabled in wakeup comparator
Res Degeneration
Res degeneration is set for calibration. The default values of the COMP_REG_1.NEGATIVE_RES_DEGENERATION field and the COMP_REG_1.POSITIVE_RES_DEGENERATION field are 0x8 and are always kept unchanged.
The COMP module obtains positive and negative res degeneration which means users can calibrate the comparator by adjusting positive and negative sides. For example, when the comparator outputs a valid signal, the voltage values at N and P sides of the comparator should be approximately equal; if it is found that the actual voltage at P side is too much higher than that at N side, you can set the value of COMP_REG_1.NEGATIVE_RES_DEGENERATION smaller, or set the value of COMP_REG_1.POSITIVE_RES_DEGENERATION larger.
CascRes Half
The COMP_REG_1.CASCRES_HALF_CTRL bit is used to ensure that the comparator is in proper operation at different bias currents.
  • The COMP_REG_0.CASCRES_HALF_CTRL is set to 1 for half resistor when COMP_REG_0.ICOMP_CTRL is set to 0000.
  • The COMP_REG_0.CASCRES_HALF_CTRL is set to 0 for full resistor when COMP_REG_0.ICOMP_CTRL is set to 1111.
Bias Current Set
The COMP_REG_0. ICOMP_CTRL field is used to configure the bias current. Higher bias currents will reduce the response time of the comparator, but with a corresponding increase in power consumption. Lower bias currents will increase the response time of the comparator, but with a corresponding reduce in power consumption. It is worth noting that this bias current is also from bandgap module, but this current and Iref are independent of each other and will not interfere with each other.
Glitch Remove
When the voltage reaches the threshold, the signal from the comp output will jitter because of noise interference. In order to eliminate jitter, users can specify a time by configuring the PMU_COMP_GLITCH_REMOVE.GLITCH_REMOV E_CYCLE field and the signal is considered valid if it does not change within this period of time. As the following figure shows, if the duration of the signal is less than the user set time Glitch_t, then the probability of triggering the interrupt will be greatly reduced. If the duration of the signal is larger than the user set time Glitch_t, then the interrupt will definitely be triggered.
Figure 90 Glitch removing of comp
COMP_REG_0
  • Name: Comparator Register 0
  • Description: This register includes REF_VALUE setting, COMP enablement, and channel selection.
  • Base Address: 0x4000A800
  • Offset: 0x40
Table 506 Comparator Register 0
23:20
CHANNEL_SEL_N
WR
Wakeup comparator channel N selection:
  • 0–7: MSIO_0–MSIO_7
  • 8: GND
  • 9: Vbatl_ref
  • 10: Vref
19:16
CHANNEL_SEL_P
WR
Wakeup comparator channel P selection:
  • 8: GND
  • 9: Vbatl_ref
  • 10: Vref
15
14:12
COMP_BATT_LVL_CTRL
WR
Changes the Vbatl based ref (Vbatl_vref):
  • 000: Vbatl/10
  • 001: 2* Vbatl/10
  • 111 :8*Vbatl/10
11:8
ICOMP_CTRL
WR
  • 0000: Max current (1 μA)
  • 1111: Min current (50 nA)
7
WAKE_COMP_EN
WR
Enables or disables wakeup comparator.
  • 0: Disable
  • 1: Enable
6
CASCRES_HALF_CTRL
WR
CascRes Half:
  • 1: Half resistor (high power when ICOMP_CTRL is close to 0000)
  • 0: Full resistor (low power when ICOMP_CTRL is close to 1111)
5:2
NEGATIVE_HYS_EN
WR
  • 0: No Negative hysteresis
  • 1: Negative Hysteresis
Hysteresis = 26 mV
POSITIVE_HYS_EN
WR
  • 0: No Positive hysteresis
  • 1: Positive Hysteresis
Hysteresis = 26 mV
COMP_REG_1
  • Name: Comparator Register 1
  • Description: This register includes res degeneration, reference source enable, CascRes Half, and Hysteresis.
  • Offset: 0x44
  • Reset Value: 0x00000088
Table 507 Comparator Register 1
15:8
COMP_REF_CTRL
WR
COMP REF CTRL (Vref)
Changes the BG-based reference: Min = 0 V, Max =1.9 V (step = 7.5 mV).
  • 11111111: 1.9 V
  • 00000000: 0 V
7:4
WR
0x8
Res degeneration N, for calibration only
3:0
WR
0x8
Res degeneration P, for calibration only
MCU_WAKEUP_CTRL
  • Name: MCU Wakeup Control Register of COMP
  • Description: For each bit, 0 indicates IRQ is disabled, and 1 indicates IRQ is enabled.
  • Base Address: 0x4000A000
  • Offset: 0x80
  • Reset Value: 0x0000FFFF
Table 508 MCU Wakeup Control Register of COMP
6
COMP_FALL
  • 1: Enable the wakeup function of the comp falling edge.
  • 0: Disable the wakeup function of the comp falling edge.
4
COMP_RISE
WR
0x1
  • 1: Enable the wakeup function of the comp rising edge.
  • 0: Disable the wakeup function of the comp rising edge.
AON_SLP_EVENT
  • Name: AON Sleep Event Register of COMP
  • Description: Events that happen in sleep or active mode, controlled by MCU_WAKE_UP_CTRL.
    When clearing the individual event, do not use read-mask-write but simply write ~ (1<< EVENT_BIT) to AON_SLP_EVENT.
  • Offset: 0x84
Table 509 AON Sleep Event Register of COMP
6
COMP_FALL
WR
Write 0 to this bit to clear comp event.
4
COMP_RISE
WR
  • Name: COMP Glitch Remove Register
  • Description: To remove voltage jitter, add deglitch circuit on comparator output (glitch: from 4 μs to 28 μs at a 4 μs step).
  • Offset: 0x2C0
Table 510 COMP Glitch Remove Register
31:3
2:0
GLITCH_REMOVE_CYCLE
WR
  • 0: No glitch removal
  • 1–7: 4 μs*N glitch removal
In the table below, the typical values are measured at 25°C, and the minimum and maximum values are measured at the worst process and temperature conditions.
Table 511 Electrical specifications
V_hyst Optional hysteresis in wakeup comparator 0 52 52 mV
VREF Optional VREF voltage in wakeup comparator 0 1.89 V
VBAT_REF Optional VBAT voltage in wakeup comparator 0.1 * VBATL 0.8 * VBATL V
Error_VBAT The trigger error rate when the reference source is Vbat 5 %
Error_VREF The trigger error rate when the reference source is Vref 5 %
Error_MSIO The trigger error rate when the reference source is MSIO_0–MSIO_7 10 mV
P_HYS Positive hysteresis voltage in wakeup comparator 22 23 26 mV
N_HYS Negative hysteresis voltage in wakeup comparator 21 23 26 mV
