文档中心 > GR533x Datasheet/ System/ MCU Core/ Interrupt Copy URL
Interrupt
In addition to supporting 16 system exceptions within the Arm®Cortex®-M4F, the device also supports 35 external interrupts with 256 programmable priority levels. In some cases, a single peripheral can generate multiple different interrupts (such as BOD/Bluetooth LE interrupt). Most interrupts are connected directly to the NVIC, but all wakeup sources on the always-on domain are connected to the Power State Controller (PSC) outside of the Arm®Cortex®-M4F, allowing the interrupt sources to wake up the Arm®Cortex®-M4F core from the sleep mode. In most cases, developers do not need to change the interrupt source.
The Cortex®-M4F allows developers to assign various interrupts to different priority levels based on the application requirements. To maintain the stability of Bluetooth connection, it is recommended that the priority of Bluetooth interrupt should be set to the highest. In most cases, developers do not need to change priority levels, and the SoC has been configured with default priorities to meet most application requirements.
One additional feature of the Cortex®-M4F interrupt architecture is the ability to relocate the vector table to different addresses. The software can move the vector table into SRAM and reassign the interrupt service routine entry addresses on demand, but it should be noted that the remapping start address of the interrupt vector table should be aligned with 0x200. For example, the vector table base address should be set as 0x00000000, 0x00000200, or 0x00000400.
All non-programmable and programmable interrupts including those that can wake up the MCU from sleep mode are shown in Table 10 and Table 11. The width of interrupt priority control register is 8 bits, in which bit 7–bit 4 are used for preemption priority and bit 3–bit 0 are used for subpriority. A higher level corresponds to a lower priority, so level 0 is the highest interrupt priority.
Table 10 Non-programmable interrupts
No. Name Default Priority Wake up MCU Description
Reset_IRQ
-3
Reset exception
2
NMI_IRQn
-2
Non-maskable interrupt
3
HardFault_IRQ
-1
All classes of fault. This interrupt occurs when the corresponding fault handler cannot be activated because it is disabled or masked by exception masking.
Table 11 Programmable interrupts
No. Name Default Preemption Priority Default Subpriority Wake up MCU Description
4
MemManage_IRQ
Memory management fault; caused by MPU violation or invalid accesses
5
BusFault_IRQ
Error response received from the bus system
6
UsageFault_IRQ
Usage fault; typical causes are invalid instructions or invalid state transition attempts.
7–10
Reserved
Unused
11
SVCall_IRQ
Supervisor call via SVC instruction
12
DebugMonitor_IRQ
Debug monitor – for software-based debugging
13
Reserved
Unused
14
PendSV_IRQ
15
15
Pendable request for system service
15
SysTick_IRQ
15
15
System tick timer interrupt
16
WDT_IRQ
8
System watchdog timer interrupt
17
BLE_SDK_IRQ
15
15
Bluetooth LE software development kit (SDK) schedule interrupt
18
BLE_IRQ
2
19
DMA0_IRQ
6
DMA0 interrupt
20
SPI_M_IRQ
8
SPI master interrupt
21
SPI_S_IRQ
8
SPI slave interrupt
22
EXT0_IRQ
8
GPIO_0 interrupt
23
EXT1_IRQ
8
GPIO_1 interrupt
24
TIMER0_IRQ
12
TIMER0 interrupt
25
TIMER1_IRQ
12
TIMER1 interrupt
26
DUAL_TIMER_IRQ
12
DUAL_TIMER interrupt
27
DDVS_ERR_IRQ
8
DDVS error interrupt
28
UART0_IRQ
10
UART0 interrupt
29
UART1_IRQ
10
UART1 interrupt
30
I2C0_IRQ
8
I2C0 interrupt
31
I2C1_IRQ
8
I2C1 interrupt
32
RNG_IRQ
8
TRNG interrupt
33
BOD_ASSERT_IRQ
8
Brown-out detection interrupt
34
XQSPI_IRQ
8
XQSPI interrupt
35
BLESLP_IRQ
2
Bluetooth LE timer done interrupt
36
SLPTIMER_IRQ
12
Sleep timer done interrupt
37
AON_EXT_IRQ
8
AON GPIO interrupt
38
AON_WDT_IRQ
8
AON watchdog timer interrupt
39
RTC1_IRQ
8
Real-Timer counter interrupt
40
COMM_CORE_IRQ
8
AHB/APB timeout interrupt
41
SLP_FAIL_IRQ
8
Sleep failure interrupt
42
CTE_FULL_IRQ
8
CTE full interrupt
43
BOD_DEASSERT_IRQ
8
Brown out detection deassert interrupt
44
COMP_IRQ
8
Comparator interrupt
45
CPLL_DRIFT_IRQ
8
CPLL drift interrupt
46
CLK_CALIB_IRQ
8
Clock calibration_0/1 interrupt
47
BLE_PWR_ON_IRQ
2
Bluetooth LE sequencer power on done interrupt
48
BLE_PWR_DN_IRQ
8
Bluetooth LE sequencer power off done interrupt
49
PLL_STATE_IRQ
8
PLL state interrupt
50
PWM0_DONE_IRQ
8
PWM0 coding mode done interrupt
