Dual Timer
The Dual Timer module consists of two programmable down counters (32-bit or 16-bit) that can generate interrupts when they reach 0. I/O control function without going through interrupt handler is supported in order to meet the requirements of application scenarios that demand low latency response.
Because the Dual-Timer is in the MCU Subsystem domain, Dual-Timer interrupt is not available during sleep, and the running Dual-Timer will not prevent the MCU from sleeping.
  • Two 32-bit or 16-bit counters
  • One of the following timer modes:
    • Periodic
    • One-shot
    • Free-running
  • 3-channel I/O control interface for each dual timer instance supports I/O set, reset and toggle.
  • One I/O control channel supports up to five compare events, including START, STOP, PERIOD and two custom COUNT events.
  • Flexible and configurable interrupts for all compare events in I/O control function.
  • The clock source of the Dual Timer follows the system clock
  • Dual Timer has a prescaler that can divide down the enabled timer clock rate by a factor of 1, 16, or 256.
  • Dual Timer supports the specified number of cycles to stop counting.
  • Dual Timer pauses when the MCU is suspended.
Counter
In Dual Timer, both of the counters are defined by default, and they can be defined as either 16-bit or 32-bit down counter. For each counter, the following operational modes are available:
  • Free-running mode
    The counter wraps after reaching zero, and continues to count down from the maximum value (0xFFFFFFFF). This is the default mode.
  • Periodic mode
    The counter generates an interrupt at a fixed interval, reloading the original value after wrapping past zero values.
  • One-shot mode
    The counter generates an interrupt once. When the counter reaches 0, it halts until you reprogram it.
The RELOAD value only represents the count-down number of timers. To configure a specific duration (for example, µs, ms, or s), use the following formula:
where PRE stands for prescaled coefficient.
When the value of the RELOAD register is configured to 0, no count and no interrupt are generated.
Dual timer supports background reload function in periodic mode. If the BG_LOAD register is configured with a value, the Dual Timer will restart counting down with the BG_LOAD value after the current counting cycle is completed. If BG_LOAD value is set before Dual Timer is initialized, the BG_LOAD value will become invalid after the Dual Timer is initialized with the RELOAD value.
Dual timer supports one-time background reload function in periodic mode. If the TP_LOAD register is configured with a value, the Dual Timer will start counting down one-time with the TP_LOAD value after the current counting cycle is completed. When the BG_LOAD and TP_LOAD registers are configured at the same time, the dual timer will respond to the TP_LOAD register first.
Dual Timer supports the specified number of cycles to stop counting in periodic mode. If the PERIOD_COUNT register is configured with a value, the Dual Timer will stop counting after the specified number of cycles are completed. The value is valid when it is greater than 1. The PERIOD_COUNT register is only valid when one of the I/O control channels is enabled.
I/O Control
The dual timer supports I/O control function without going through interrupt handler. Each of the instance supports three channels with up to five compare events.
  • I/O is muxed to dual timer in order to implement I/O control function.
  • I/O initial state can be defined through the IO_INIT_SET register before the I/O control channel is enabled.
  • There are up to five compare events for I/O control. When the dual timer starts counting, the start event will trigger the channel I/O action. When the counter value reaches zero, the PERIOD event will trigger the channel I/O action. When the dual timer stops counting, the STOP event will trigger the channel I/O action. Each channel has two custom compare values which can be configured in COUNT_x1IO and COUNT_x2IO registers. When the counter value reaches the compare value, the IOx_C1 and IOx_C2 events will trigger the channel I/O action. Compare value greater than reload value will not trigger an interrupt or IO control action.
  • I/O action supports I/O set, reset and toggle.
  • Channel I/O will trigger a PERIOD event action and a STOP event action in sequence at the end of the counting in one-shot mode.
For example, the I/O action timing diagram of I/O control function using dual timer is shown in the figure below.
Figure 43 I/O action timing diagram
RELOAD
  • Name: Dual Timer Reload Register
  • Description: This register contains the value from which the counter is to decrease. The count is immediately restarted from the new RELOAD value.
  • Base Address: 0x40002000
  • Offset: 0x00 + x*0x80
  • Reset Value: 0x00
*x is used to identify the counter of the Dual Timer Module. The “x” can be 0 or 1.
Table 305 RELOAD
31:0
RELOAD
Reload value. Write to this register sets the current value.
VALUE
  • Name: Dual Timer Current Value Register
  • Description: This register provides the current count value of the decrementing counter.
  • Offset: 0x04 + x*0x80
  • Reset Value: 0xFFFFFFFF
Table 306 VALUE
31:0
VALUE
RO
0xFFFFFFFF
Current count value
CTRL
  • Name: Dual Timer Control Register
  • Description: This register enables the software to control the Dual Timer.
  • Offset: 0x08 + x*0x80
  • Reset Value: 0x20
Table 307 CTRL
31:21 RSVD R Reserved bits
20 IOC_ACT_C2_INTEN RW 0x0
Interrupt when timer value meets COUNT_C2IO
  • 0x0: disabled
  • 0x1: enabled
19 IOC_ACT_C1_INTEN RW 0x0
Interrupt when timer value meets COUNT_C1IO
  • 0x0: disabled
  • 0x1: enabled
18 IOB_ACT_C2_INTEN RW 0x0
Interrupt when timer value meets COUNT_B2IO
  • 0x0: disabled
  • 0x1: enabled
17 IOB_ACT_C1_INTEN RW 0x0
Interrupt when timer value meets COUNT_B1IO
  • 0x0: disabled
  • 0x1: enabled
16 ACT_STOP_INTEN RW 0x0
Interrupt when timer stop
  • 0x0: disabled
  • 0x1: enabled
15 ACT_PERIOD_INTEN RW 0x0
Interrupt when timer value meets 0
  • 0x0: disabled
  • 0x1: enabled
14 IOA_ACT_C2_INTEN RW 0x0
Interrupt when timer value meets COUNT_A2IO
  • 0x0: disabled
  • 0x1: enabled
13 IOA_ACT_C1_INTEN RW 0x0
Interrupt when timer value meets COUNT_A1IO
  • 0x0: disabled
  • 0x1: enabled
12 ACT_START_INTEN RW 0x0
Interrupt when timer start
  • 0x0: disabled
  • 0x1: enabled
11 RSVD R Reserved bits
10 IOC RW 0x0
Channel C I/O Control enable
  • 0x0: disabled
  • 0x1: enabled
9 IOB RW 0x0
Channel B I/O Control enable
  • 0x0: disabled
  • 0x1: enabled
8 IOA RW 0x0
Channel A I/O Control enable
  • 0x0: disabled
  • 0x1: enabled
7 EN RW 0x0
Timer enable
  • 0x0: Timer disabled; default
  • 0x1: Timer enabled
6 MODE RW 0x0
Timer mode
  • 0x0: Timer is in free-running mode; default
  • 0x1: Timer is in periodic mode
5 INTEN RW 0x1
Interrupt enable
  • 0x0: Timer interrupt disabled
  • 0x1: Timer interrupt enabled; default
4 RSVD R Reserved bits
3:2 PRE RW 0x0
Prescale bits
  • 0x00: 0 stage of prescale, clock is divided by 1; default
  • 0x01: 4 stages of prescale, clock is divided by 16
  • 0x10: 8 stages of prescale, clock is divided by 256
  • 0x11: Undefined. Do not use this value.
1 SIZE RW 0x0
Select 16-bit or 32-bit counter operation:
  • 0x0: 16-bit counter; default
  • 0x1: 32-bit counter
0 ONESHOT RW 0x0
Select wrap mode or one-shot mode:
  • 0x0: Wrap mode; default
  • 0x1: One-shot mode
INTCLR
  • Name: Dual Timer Interrupt Clear Register
  • Description: Any write to the INTCLR register clears the interrupt output from the counter.
  • Offset: 0x0C + x*0x80
  • Reset Value: 0x00
Table 308 INTCLR
31:0
CLR
WO
Clear the Dual-Timer interrupt event.
RAW_INTSTAT
  • Name: Dual Timer Raw Interrupt Status Register
  • Description: The RAW_INTSTAT register indicates the raw interrupt status from the counter.
  • Offset: 0x10 + x*0x80
  • Reset Value: 0x00
Table 309 RAW_INTSTAT
31:1
RIS_RTI
RO
Raw interrupt status from the counter
INTSTAT
  • Name: Dual-Timer interrupt enable status register
  • Description: The INTSTAT register indicates the masked interrupt status from the counter.
  • Offset: 0x14 + x*0x80
  • Reset Value: 0x00
Table 310 INTSTAT
31:10
9
IOC_ACT_C2
Interrupt status when timer value meets to COUNT_C2IO
8
IOC_ACT_C1
Interrupt status when timer value meets to COUNT_C1IO
7
IOB_ACT_C2
Interrupt status when timer value meets to COUNT_B2IO
6
IOB_ACT_C1
Interrupt status when timer value meets to COUNT_B1IO
5
ACT_STOP
Interrupt status when timer stop.
4
ACT_PERIOD
Interrupt status when timer value meets to 0
3
IOA_ACT_C2
Interrupt status when timer value meets to COUNT_A2IO
2
IOA_ACT_C1
Interrupt status when timer value meets to COUNT_A1IO
ACT_START
Interrupt status when timer start.
ISR_TI
RO
Enable interrupt status from the counter.
BG_LOAD
  • Name: Dual-Timer background reload register
  • Description: When the BG_LOAD value is set, the counter will count down again from the BG_LOAD value after completing the current counting cycle.
  • Offset: 0x18 + x*0x80
  • Reset Value: 0x00
Table 311 BG_LOAD
31:0
BL
The BG_LOAD does not cause the counter to immediately restart from the new value.
COUNT_A1IO
  • Name: Dual-Timer Channel A Count 1 register
  • Description: This register indicates the count 1 value for channel A I/O Control.
  • Offset: 0x1C + x*0x80
Table 312 COUNT_A1IO
31:0
COUNT_A1IO
0xFFFFFFFF
When timer value meet this value, the channel A will act.
COUNT_A2IO
  • Name: Dual-Timer Channel A Count 2 register
  • Description: This register indicates the count 2 value for channel A I/O Control.
  • Offset: 0x20 + x*0x80
Table 313 COUNT_A2IO
31:0
COUNT_A2IO
0xFFFFFFFF
COUNT_B1IO
  • Name: Dual-Timer Channel B Count 1 register
  • Description: This register indicates the count 1 value for channel B I/O Control.
  • Offset: 0x24 + x*0x80
Table 314 COUNT_B1IO
31:0
COUNT_B1IO
0xFFFFFFFF
When timer value meet this value, the channel B will act.
COUNT_B2IO
  • Name: Dual-Timer Channel B Count 2 register
  • Description: This register indicates the count 2 value for channel B I/O Control.
  • Offset: 0x28 + x*0x80
Table 315 COUNT_B2IO
31:0
COUNT_B2IO
0xFFFFFFFF
COUNT_C1IO
  • Name: Dual-Timer Channel C Count 1 register
  • Description: This register indicates the count 1 value for channel C I/O Control.
  • Offset: 0x2C + x*0x80
Table 316 COUNT_C1IO
31:0
COUNT_C1IO
0xFFFFFFFF
When timer value meet this value, the channel C will act.
COUNT_C2IO
  • Name: Dual-Timer Channel C Count 2 register
  • Description: This register indicates the count 2 value for channel C I/O Control.
  • Offset: 0x30 + x*0x80
Table 317 COUNT_C2IO
31:0
COUNT_C2IO
0xFFFFFFFF
IO_ACT_CTRL
  • Name: Dual-Timer I/O action control register
  • Description: This register enables the software to control I/O action.
  • Offset: 0x34 + x*0x80
  • Reset Value: 0x00
Table 318 IO_ACT_CTRL
31:30
29:28
IOC_ACT_CTRL_STOP
Channel C action when timer stop
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
27:26
IOC_ACT_CTRL_PERIOD
Channel C action when timer meets 0
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
25:24
IOC_ACT_CTRL_C2
Channel C action when timer meets COUNT_C2IO
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
23:22
IOC_ACT_CTRL_C1
Channel C action when timer meets COUNT_C1IO
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
21:20
IOC_ACT_CTRL_START
Channel C action when timer start
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
19:18
IOB_ACT_CTRL_STOP
Channel B action when timer stop
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
17:16
IOB_ACT_CTRL_PERIOD
Channel B action when timer meets 0
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
15:14
IOB_ACT_CTRL_C2
Channel B action when timer meets COUNT_B2IO
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
13:12
IOB_ACT_CTRL_C1
Channel B action when timer meets COUNT_B1IO
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
11:10
IOB_ACT_CTRL_START
Channel B action when timer start
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
9:8
IOA_ACT_CTRL_STOP
Channel A action when timer stop
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
7:6
IOA_ACT_CTRL_PERIOD
Channel A action when timer meets 0
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
5:4
IOA_ACT_CTRL_C2
Channel A action when timer meets COUNT_A2IO
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
3:2
IOA_ACT_CTRL_C1
Channel A action when timer meets COUNT_A1IO
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
1:0
IOA_ACT_CTRL_START
Channel A action when timer start
  • 0x0: Do nothing
  • 0x1: I/O set
  • 0x2: I/O reset
  • 0x3: I/O toggle
IO_INIT_SET
  • Name: Dual-Timer I/O initial control register
  • Description: This register enables the software to control I/O initial state.
  • Offset: 0x38 + x*0x80
  • Reset Value: 0x00
Table 319 IO_INIT_SET
31:3
2
IOC_ACT_INIT
Set channel C initial value when CTRL_IOC is disabled.
  • 0x0: Reset
  • 0x1: Set
IOB_ACT_INIT
Set channel B initial value when CTRL_IOB is disabled.
  • 0x0: Reset
  • 0x1: Set
IOA_ACT_INIT
Set channel A initial value when CTRL_IOA is disabled.
  • 0x0: Reset
  • 0x1: Set
TP_LOAD
  • Name: Dual-Timer one-time reload register
  • Description: When the TP_LOAD value is set, the counter will count down again from the TP_LOAD value after completing the current counting cycle for one cycle.
  • Offset: 0x3C + x*0x80
  • Reset Value: 0x00
Table 320 TP_LOAD
31:0
TP_LOAD
Used to reload the counter when Periodic mode/io action mode is enabled, and the current count reaches 0. The value is only invalid one time. When the timer reloads the value, the register will be cleared automatically.
PERIOD_COUNT
  • Name: Dual-Timer period count register
  • Description: This register indicates the period count in period mode.
  • Offset: 0x4C + x*0x80
  • Reset Value: 0x00
Table 321 PERIOD_COUNT
31:16
15:0
PERIOD_COUNT
Set dual timer's period count in period mode. The value is valid when the value is greater than 1.
IO_BLE_INTCLR
  • Name: Dual Timer I/O Control Interrupt Clear Register
  • Description: Any write to the IO_BLE_INTCLR register clears the interrupt of I/O control function.
  • Offset: 0x50 + x*0x80
  • Reset Value: 0x00
Table 322 IO_BLE_INTCLR
31:12
11
IO_ACT_ALL_INTCLR
W
Write 1 to clear all I/O interrupt status.
10:9
8
IOC_ACT_C2_INTCLR
W
Write 1 to clear IOC_ACT_C2.
7
IOC_ACT_C1_INTCLR
W
Write 1 to clear IOC_ACT_C1.
6
IOB_ACT_C2_INTCLR
W
Write 1 to clear IOB_ACT_C2.
5
IOB_ACT_C1_INTCLR
W
Write 1 to clear IOB_ACT_C1.
4
ACT_STOP_INTCLR
W
Write 1 to clear ACT_STOP.
3
ACT_PERIOD_INTCLR
W
Write 1 to clear ACT_PERIOD.
2
IOA_ACT_C2_INTCLR
W
Write 1 to clear IOA_ACT_C2.
IOA_ACT_C1_INTCLR
W
Write 1 to clear IOA_ACT_C1.
ACT_START_INTCLR
W
Write 1 to clear ACT_START.
