文档中心 > GR533x Datasheet/ System/ Registers/ MCU Subsystem Copy URL
MCU Subsystem
BLE_FERP_CTL
  • Name: BLE_FERP_CTL Register
  • Description: BLE_FERP_CTL Register
  • Base Address: 0x4000E000
  • Offset: 0x224
Table 194 BLE_FERP_CTL Register
31:1
FERP_EN
Enable ferp memory clock & ferp memory access on SoC side by configuring this register to 1 before starting a 2.4G spec use.
SECURITY_RESET
  • Name: SECURITY_RESET Register
  • Description: SECURITY_RESET Register
  • Offset: 0x22C
  • Reset Value: 0x00000028
Table 195 SECURITY_RESET Register
31:6
5
TRNG
0x1
TRNG soft reset, low active
  • 0x0: reset module
  • 0x1: normal work mode
4
Reserved bit
3
EFUSE
0x1
eFuse controller soft reset, low active
  • 0x0: reset module
2:0
PMU_ID
  • Name: PMU_ID Register
  • Description: PMU_ID Register
  • Offset: 0x230
  • Reset Value: 0x000000B0
Table 196 PMU_ID Register
31:8
7:0
PMU_ID
0xB0
PMU chip ID
PWR_AVG_CTL_REG0
  • Name: PWR_AVG_CTL_REG0 Register
  • Description: PWR_AVG_CTL_REG0 Register
  • Offset: 0x234
  • Reset Value: 0x00000004
Table 197 PWR_AVG_CTL_REG0 Register
31:24
TPA_ADC_OUT
Real-time value
18
AVG_PWR_ERR
Indicate ble_tx_en going off before outputting the result.
17
Reserved bit
16
AVG_PWR_RDY
Indicate that the average value is ready to read.
15:8
AVG_PWR
Average power data
7:4
SAMPL_PWR
Take 2 ^ n samples for averaging (0–15).
3
BLE_F_TX_EN
Forcibly enable internal ble_tx_en.
2
ONESHOT_EN
0x1
Enable one shot mode.
Reserved bit
PWR_AVG_EN
Enable the power average calculation block.
TIMER2BLE_PLUSE_CTRL
  • Name: TIMER2BLE_PLUSE_CTRL Register
  • Description: TIMER2BLE_PLUSE_CTRL Register
  • Offset: 0x238
Table 198 TIMER2BLE_PLUSE_CTRL Register
31:2
1:0
Bluetooth LE pulse selection control:
  • 0x0: timer1
  • 0x1: timer2
  • 0x2: dual timer fr1
  • 0x3: dual timer fr2
EFUSE_PWR_DELTA_0
  • Name: EFUSE_PWR_DELTA_0 Register
  • Description: EFUSE_PWR_DELTA_0 Register
  • Offset: 0x254
  • Reset Value: 0x0FFF00B4
Table 199 EFUSE_PWR_DELTA_0 Register
31:16
DELTA1
0xFFF
About 250 μs; an eFuse power controller timing parameter; based on 16 MHz clock
15:0
DELTA0
0xB4
About 10 μs; an eFuse power controller timing parameter; based on 16 MHz clock
EFUSE_PWR_DELTA_1
  • Name: EFUSE_PWR_DELTA_1 Register
  • Description: EFUSE_PWR_DELTA_1 Register
  • Offset: 0x258
  • Reset Value: 0x000000B4
Table 200 EFUSE_PWR_DELTA_1 Register
31:16
15:0
DELTA2
0xB4
EFUSE_PWR_CTRL_0
  • Name: EFUSE_PWR_CTRL_0 Register
  • Description: EFUSE_PWR_CTRL_0 Register
  • Offset: 0x260
Table 201 EFUSE_PWR_CTRL_0 Register
31:5
4
STP
Write 1 to stop the power sequencer.
3
Reserved bit
2
BGN
Write 1 to begin the power sequencer.
Reserved bit
EN
Enable the eFuse controller.
EFUSE_PWR_CTRL_1
  • Name: EFUSE_PWR_CTRL_1 Register
  • Description: EFUSE_PWR_CTRL_1 Register
  • Offset: 0x264
Table 202 EFUSE_PWR_CTRL_1 Register
31:5
4
DIS_DONE
eFuse power disable done. Clear on read.
3:1
EN_DONE
eFuse power enable done. Clear on read.
MCU_BOOT_DBG
  • Name: MCU_BOOT_DBG Register
  • Description: MCU_BOOT_DBG Register
  • Offset: 0x27C
Table 203 MCU_BOOT_DBG Register
31:0
MCU_BOOT_DBG
MCU boot debug register; record the boot status.
MCU_SUB_REG
  • Name: MCU_SUB_REG Register
  • Description: MCU_SUB_REG Register
  • Offset: 0x280
Table 204 MCU_SUB_REG Register
31:14
13:12
GDX_REG_WAIT_STATE
ROM AHB wait state number
11:6
5:4
MEM_BOND_OPT
  • 0x0: 80 KB (SRAMs 0–4 ON)
  • 0x1: 64 KB (SRAMs 0–3 ON; SRAM 4 OFF)
  • 0x2: 48 KB (SRAMs 0–2 ON; SRAMs 3–4 OFF)
  • 0x3: 32 KB (SRAMs 0–1 ON; SRAMs 2–4 OFF)
3:0
MCU_NMI_CFG
  • Name: MCU_NMI_CFG Register
  • Description: MCU_NMI_CFG Register
  • Offset: 0x284
Table 205 MCU_NMI_CFG Register
31:10
9:0
MCU_NMI_SEL
Select MCU NMI.
bit9: aon_irq_sts[IRQ_BLE_PWR_DN_DONE]
bit8: aon_irq_sts[IRQ_BLE_PWR_UP_DONE]
bit7: timer0_irq
bit6: aon_evts[EVT_CLDR_TIMER_EVT_0]
bit5: aon_evts[EVT_WD_TIMER_ALMOST_EXP]
bit4: aon_evts[EVT_SMC_OSC_EN]
bit3: aon_irq_sts[IRQ_PMU_BOD_REDGA]
bit2: aon_evts[EVT_BLE_MAC_IRQ]
bit1: gpio_1_irq
bit0: gpio_0_irq
CPLL_IRQ_CFG
  • Name: CPLL_IRQ_CFG Register
  • Description: CPLL_IRQ_CFG Register
  • Offset: 0x288
Table 206 CPLL_IRQ_CFG Register
31:1
DRIFT_IRQ_EN
Enable CPLL drift IRQ.
AON_SW_RST
  • Name: AON_SW_RST Register
  • Description: AON_SW_RST Register
  • Offset: 0x28C
  • Reset Value: 0xC5A10000
Table 207 AON_SW_RST Register
31:16
SET
W
0xC5A1
15:9
Always-on software reset magic word for enabling configuration.
8
FULL
W
Always-on software reset for full logic
7:1
PARTIAL
W
Always-on software reset for partial logic
MCU_SUBSYS_CG_CTRL[0]
  • Name: MCU_SUBSYS_CG_CTRL[0] Register
  • Description: MCU_SUBSYS_CG_CTRL[0] Register
  • Offset: 0x2C0
Table 208 MCU_SUBSYS_CG_CTRL[0] Register
31:11
10
WFI_SERIAL_HCLK
HCLK for serial blocks including I2C, UART, QSPI, and SPI (M & S)
  • 0x0: HCLK is always on.
  • 0x1: HCLK is gated during WFI/WFE.
9
WFI_APB_SUB_HCLK
HCLK for APB subsystem including watchdog and timer
8
WFI_BLE_BRG_HCLK
HCLK for Bluetooth LE MCU bridge
7
6
WFI_GPIO_HCLK
HCLK for GPIOs
5
WFI_SNSADC_HCLK
HCLK for sense ADC
4
WFI_ROM_HCLK
HCLK for ROM
3
2
WFI_HTB_HCLK
HCLK for hopping table
WFI_SECU_HCLK
HCLK for all security blocks including eFuse and TRNG
MCU_SUBSYS_CG_CTRL[1]
  • Name: MCU_SUBSYS_CG_CTRL[1] Register
  • Description: MCU_SUBSYS_CG_CTRL[1] Register
  • Offset: 0x2C4
  • Reset Value: 0x0000FFEF
Table 209 MCU_SUBSYS_CG_CTRL[1] Register
31:11
10
FORCE_SERIAL_HCLK
0x1
  • 0x0: Force the clock to be ON.
  • 0x1: Force the clock to be OFF.
9
FORCE_APB_SUB_HCLK
0x1
8
FORCE_BLE_BRG_HCLK
0x1
7
6
FORCE_GPIO_HCLK
0x1
HCLK for GPIOs
5
FORCE_SNSADC_HCLK
0x1
HCLK for sense ADC
4
FORCE_ROM_HCLK
HCLK for ROM
3
2
FORCE_HTB_HCLK
0x1
0x1
FORCE_SECU_HCLK
0x1
MCU_SUBSYS_CG_CTRL[2]
  • Name: MCU_SUBSYS_CG_CTRL[2] Register
  • Description: MCU_SUBSYS_CG_CTRL[2] Register
  • Offset: 0x2C8
  • Reset Value: 0x00020000
Table 210 MCU_SUBSYS_CG_CTRL[2] Register
31:19
18
FORCE_SRAM_HCLK
SRAM HCLK clock
17
FORCE_XF_XQSPI_HCLK
0x1
Cache HCLK clock
16:3
2
WFI_SRAM_HCLK
SRAM HCLK clock during WFI
WFI_XF_XQSPI_HCLK
Cache HCLK clock during WFI
WFI_AON_MCUSUB_HCLK
mcu_reg_hclk clock during WFI
MCU_PERIPH_PCLK_OFF
  • Name: MCU_PERIPH_PCLK_OFF Register
  • Description: MCU_PERIPH_PCLK_OFF Register
  • Offset: 0x2CC
  • Reset Value: 0x30063005
Table 211 MCU_PERIPH_PCLK_OFF Register
31:30
29
FORCE_PWM_1_PCLK
0x1
pwm_1 CLK
28
FORCE_PWM_0_PCLK
0x1
pwm_0 CLK
27:19
18
FORCE_SPI_S_PCLK
0x1
spi_s CLK
17
FORCE_SPI_M_PCLK
0x1
spi_m CLK
16:4
13
FORCE_I2C1_PCLK
0x1
i2c_1 CLK
12
FORCE_I2C0_PCLK
0x1
i2c_0 CLK
11:3
2
FORCE_UART1_PCLK
0x1
uart_1 CLK
Reserved bit
FORCE_UART0_PCLK
0x1
uart_0 CLK
MCU_PERIPH_CG_LP_EN
  • Name: MCU_PERIPH_CG_LP_EN Register
  • Description: MCU_PERIPH_CG_LP_EN Register
  • Offset: 0x2D0
  • Reset Value: 0x000007FF
Table 212 MCU_PERIPH_CG_LP_EN Register
31:12
10
AHB2APB_ASYNC_BRG_LP_EN
0x1
Enable apb2apb async bridge low-power feature.
9
AHB2APB_BRG_LP_EN
0x1
Enable ahb2apb bridge low-power feature.
8
AHB_BUS_LP_EN
0x1
Enable AHB bus low-power feature.
7
I2C1_LP_SCLK_EN
0x1
Enable i2c1 SCLK low-power feature.
6
I2C0_LP_SCLK_EN
0x1
Enable i2c0 SCLK low-power feature.
5
SPIS_LP_SCLK_EN
0x1
Enable SPIS SCLK low-power feature.
4
SPIM_LP_SCLK_EN
0x1
Enable SPIM SCLK low-power feature.
3
UART1_LP_PCLK_EN
0x1
Enable uart1 PCLK low-power feature.
2
UART1_LP_SCLK_EN
0x1
Enable uart1 SCLK low-power feature.
UART0_LP_PCLK_EN
0x1
Enable uart0 PCLK low-power feature.
UART0_LP_SCLK_EN
0x1
Enable uart0 SCLK low-power feature.
MCU_PERIPH_CLK_SLP_OFF
  • Name: MCU_PERIPH_CLK_SLP_OFF Register
  • Description: MCU_PERIPH_CLK_SLP_OFF Register
  • Offset: 0x2D4
Table 213 MCU_PERIPH_CLK_SLP_OFF Register
31:14
13
PWM1
Enable pwm_1 PCLK auto off when CPU is in sleep state.
12
PWM0
Enable pwm_0 PCLK auto off when CPU is in sleep state.
11
SPIS
Enable spi_s PCLK auto off when CPU is in sleep state.
10
SPIM
Enable spi_m PCLK auto off when CPU is in sleep state.
9:8
7
I2C1
Enable i2c_1 PCLK auto off when CPU is in sleep state.
6
I2C0
Enable i2c_0 PCLK auto off when CPU is in sleep state.
5:2
UART1
Enable uart_1 PCLK auto off when CPU is in sleep state.
UART0
Enable uart_0 PCLK auto off when CPU is in sleep state.
SECU_CLK_CTRL
  • Name: SECU_CLK_CTRL Register
  • Description: SECU_CLK_CTRL Register
  • Offset: 0x2D8
  • Reset Value: 0x00003C00
Table 214 SECU_CLK_CTRL Register
31:14
13
EFUSE_HCLK_SLP_OFF
0x1
Enable eFuse PCLK auto off when CPU is in sleep state.
12
EFUSE_HCLK_FORCE_OFF
0x1
eFuse PCLK
11
RNG_HCLK_SLP_OFF
0x1
Enable RNG PCLK auto off when CPU is in sleep state.
10
RNG_HCLK_FORCE_OFF
0x1
RNG PCLK
9:0
MCU_MISC_CLK
  • Name: MCU_MISC_CLK Register
  • Description: MCU_MISC_CLK Register
  • Offset: 0x2E8
  • Reset Value: 0x0000000C
Table 215 MCU_MISC_CLK Register
31:4
3
DMA0_HCLK_OFF
0x1
  • 0x0: Turn on DMA CLK.
  • 0x1: Turn off DMA CLK.
2
XQSPI_SCK_OFF
0x1
  • 0x0: Turn on XQSPI SPI CLK.
  • 0x1: Turn off XQSPI SPI CLK.
1:0
HFOSC_CLK_EN
  • Name: HFOSC_CLK_EN Register
  • Description: HFOSC_CLK_EN Register
  • Offset: 0x2F4
  • Reset Value: 0x00000001
Table 216 HFOSC_CLK_EN Register
31:1
EN
0x1
  • 0x0: Turn off HFOSC CLK.
  • 0x1: Turn on HFOSC CLK.
APB_TIMER_DBG
  • Name: APB_TIMER_DBG Register
  • Description: APB_TIMER_DBG Register
  • Offset: 0x340
  • Reset Value: 0x0000000F
Table 217 APB_TIMER_DBG Register
31:4
3
WDT
Write 1 to stop the watchdog timer during CPU HALT.
2
DUAL_TIMER
Write 1 to stop the dual timer during CPU HALT.
TIMER1
Write 1 to stop the timer1 during CPU HALT.
TIMER0
Write 1 to stop the timer0 during CPU HALT.
APB_MON_DBG
  • Name: APB_MON_DBG Register
  • Description: APB_MON_DBG Register
  • Offset: 0x344
Table 218 APB_MON_DBG Register
31:1
BYPASS
Write 1 to bypass AHB2APB bridge monitor.
MCU_RELEASE
  • Name: MCU_RELEASE Register
  • Description: MCU_RELEASE Register
  • Offset: 0x380
  • Reset Value: 0x20220710
Table 219 MCU_RELEASE Register
31:0
MCU_RELEASE
0x20220710
Contain the RTL release date.
FPGA_CTRL
  • Name: FPGA_CTRL Register
  • Description: FPGA_CTRL Register
  • Offset: 0x384
Table 220 FPGA_CTRL Register
31:5
4
EXIST
This HW is 0: ASIC, 1: FPGA.
3:2
1:0
MUX_SEL
Select FPGA debug port signals.
ST_CALIB
  • Name: ST_CALIB Register
  • Description: ST_CALIB Register
  • Offset: 0x388
  • Reset Value: 0x0000013F
Table 221 ST_CALIB Register
31:29
28
STCALIB_CLK
mcu_stclk_sel
  • 0x0: rng_clk
  • 0x1: xo_clk
27:26
25:0
STCALIB
0x13F
STCAILIB to ARM Core
STCLK = 32 KHz by default
STCALIB[25] = 0, use STCLK.
STCALIB[24] = 0, exact multiple 10 ms
STCALIB[23:0] = 13F, 10 ms/(1/32 KHz) -1 = 319 = 0x13F
TESTBUS_CTRL
  • Name: TESTBUS_CTRL Register
  • Description: TESTBUS_CTRL Register
  • Offset: 0x38C
Table 222 TESTBUS_CTRL Register
31:20 RSVD R 0x0 Reserved bits
19:17 SEL_PL_LO RW 0x0
Select testbus pad low bank low bits[07:00].
val | subsystem
000 | comm testbus[7:0]
001 | aon testbus[7:0]
010 | xf cache testbus[7:0]
011 | clk testbus[7:0]
100 | mcu testbus[7:0]
101 | htable testbus[7:0]
16:14 SEL_PL_HI RW 0x0
Select testbus pad low bank high bits[15:08].
val | subsystem
000 | comm testbus[15:8]
001 | aon testbus[15:8]
010 | xf cache testbus[15:8]
011 | clk testbus[15:8]
100 | mcu testbus[15:8]
101 | htable testbus[15:8]
13:11 SEL_PH_LO RW 0x0
Select testbus pad high bank low bits[23:16].
val | subsystem
10:8 SEL_PH_HI RW 0x0
Select testbus pad high bank high bits[31:24].
val | subsystem
7:5 SEL_LO RW 0x0
Select MCU testbus low bits[07:00].
val | ip
00 | dma testbus[7:0]
01 | bus_matrix testbus[7:0]
10 | apb_serial testbus[7:0]
4:2 SEL_HI RW 0x0
Select MCU testbus high bits[15:08].
val | ip
00 | dma testbus[15:8]
01 | bus_matrix testbus[15:8]
10 | apb_serial testbus[15:8]
1:0 ORDER RW 0x0
Testbus order
val | order
00 | testbus[31:16] = bits[31:28] [27:24] [23:20] [19:16]
01 | testbus[31:16] = bits[19:16] [31:28] [27:24] [23:20]
10 | testbus[31:16] = bits[23:20] [19:16] [31:28] [27:24]
11 | testbus[31:16] = bits[27:24] [23:20] [19:16] [31:28]
00 | testbus[15:00] = bits[15:12] [11:08] [07:04] [03:00]
01 | testbus[15:00] = bits[03:00] [15:12] [11:08] [07:04]
10 | testbus[15:00] = bits[07:04] [03:00] [15:12] [11:08]
11 | testbus[15:00] = bits[11:08] [07:04] [03:00] [15:12]
