文档中心 > GR5405 Datasheet/ Peripherals/ Timer Interfaces/ Sleep Timer (SLP TIMER) Copy URL
The Sleep Timer is a 32-bit hardware timer that can wake the SoC up from sleep state. It can also be used when the SoC is awake.
  • 32-bit down counter running with two different clock sources: LFXO_32K clock (32.768 kHz) and LFRC_32K clock (about 32 KHz).
  • Three operation modes: Basic Sleep Timer, Single-load Sleep Timer, and Auto-reload Sleep Timer
The Sleep Timer supports three operation modes:
  • Mode 0 – Basic Sleep Timer: This is the original mode of the Sleep Timer. It only counts down when the SoC is in sleep state and is not activated when the SoC is awake.
  • Mode 1 – Single-load Sleep Timer: In this mode, the timer starts counting as soon as it is put in this mode and it continues to count down even when the SoC is awake. The timer stops when the counter hits zero. The time-out signal is saved as a timeout event.
  • Mode 2 – Auto-reload Sleep Timer: Similar to Single-load Sleep Timer mode, the timer does not stop counting down even when the SoC is awake. However, the timer can automatically reload to a value that is the same as that before automatic reload until it is disabled by the MCU.
The AON_WDT, RTC, and SLP TIMER share the same clock source selection. The clock source can be LFRC_32K or LFXO_32K which are described in Clocks.
CFG_0
  • Base Address: 0x4000A500
  • Offset: 0x00
Table 353 CFG_0
31:25
24
CFG
W
Write:
  • Writing 1 to this register triggers the Sleep Timer configuration.
  • Writing to this bit during sleep timer configuration will generate a configuration failure interrupt.
Read:
The read value is always 0.
23:4
3
COUNT_MODE
  • 0x1: Count during sleep only.
  • 0x0: Count in any condition.
2
MODE
  • 0x1: Single-load mode
  • 0x0: Auto-reload mode
VAL_SET
Set the timer value; write 1 to make the timer value effective.
EN
Enable Sleep Timer.
  • 0x1: Enable Sleep Timer.
  • 0x0: Disable Sleep Timer.
STS
  • Offset: 0x38
Table 354 STS
31:2
BUSY
Sleep Timer is running.
STAT
Sleep Timer is busy. Do not configure this bit if the signal is 1.
TIMER_W
  • Offset: 0x40
Table 355 TIMER_W
31:0
VAL_SET
Write:
Write the Sleep Timer value to the VAL_W register.
Read:
The set value. Read SLP_TIMER_VAL_RD in the VAL_R register for the current interval value.
TIMER_R
  • Offset: 0x48
Table 356 TIMER_R
31:0
VAL_READ
Read internal value of the Sleep Timer.
