文档中心 > GR5405 Datasheet/ Peripherals/ Timer Interfaces/ Always-on Watchdog (AON_WDT) Copy URL
The Always-on Watchdog (AON_WDT) is a 32-bit countdown hardware timer. When the AON_WDT counter counts to 0, a system reset signal is sent, and when the counter value decreases to the set warning value, an interrupt signal is generated. Because the AON_WDT timer is in the AON domain, it can keep running when the MCU is off.
  • The MCU_CLK_CTRL register is a read/write register which controls clock source selections.
  • 32-bit down counter running with a low-power clock
  • Generate an interrupt to warn the MCU when the 32-bit down counter reaches the alarm values
  • 16-bit alarm register, supporting reading and writing
  • Flexible clock source selections from LFRC_32K or LFXO_32K
  • An independent interrupt entry
  • Support write access protection
  • The LOCK register enables or disables write accesses to all other registers. This is to prevent malicious software from disabling the watchdog functionality. Writing a value of 0x15CC5A51 (LOCK.LOCK_SET[31:1]) enables write accesses to all other registers. Writing any other value to the LOCK register disables the write accesses.
  • When the AON_WDT is disabled, all register values must be cleared to restore the default values.
  • When the CFG0.EN bit is set to 1, the value of the TIMER_W register is automatically loaded into the TIMER_R register, and the value starts to decrease.
  • The AON_WDT alarm interrupt is triggered when the value of the TIMER_R register decrements to the value of the ALARM_R register.
  • When the TIMER_R count value decrements to 0, the system restarts.
MCU_CLK_CTRL
  • Name: MCU_CLK_CTRL Register
  • Description: This register sets AON_WDT CLK configurations.
  • Base Address: 0x4000A000
  • Offset: 0x0
  • Reset Value: 0x42040202
Table 334 MCU_CLK_CTRL
5:4
WDT_CLK_SEL
WO
  • 0x02: LFRC_32K (LFRC 32 kHz clock)
  • 0x03: LFXO_32K (LF_XO 32 kHz clock)
3:0
RO
CFG_0
  • Name: CFG_0 Register
  • Description: This register sets AON_WDT configurations.
  • Base Address: 0x4000A700
  • Offset: 0x0
Table 335 CFG_0
31:25
24
CFG
WO
Writing 1 to this bit triggers the watchdog timer configuration.
23:5
4
ESD_PROTECT
WR
  • 0x0: The backup counter does not take effect.
  • 0x1: When there is difference between the working counter and the backup counter, a watchdog reset will be generated.
3
ALARM_SET
Set the timer alarm value.
2
ALARM_EN
Enable AON WDT alarm.
TIMER_SET
WO
Enable AON WDT timer reload (feed).
EN
Enable AON WDT.
LOCK
  • Name: LOCK Register
  • Description: This register can prevent other registers of AON_WDT from being overwritten.
  • Offset: 0x4
Table 336 LOCK
31:1
LOCK_SET
WO
Enable write access to all other registers by writing 0x15CC5A51. Disable write accesses by writing any other value to the LOCK register.
STAT
RO
  • 0x0: Unlocked. Writing to other watchdog registers is enabled.
  • 0x1: Locked. Writing to other watchdog registers is disabled.
STAT
  • Name: STAT Register
  • Description: This register can be used to get status of AON_WDT.
  • Offset: 0x38
Table 337 STAT
31:2
BUSY
Watchdog timer is busy. The application layer can perform other operations until this bit is set to 0.
STAT
AON WDT is running.
TIMER_W
  • Name: TIMER_W Register
  • Description: This register is used to configure the initial AON_WDT value.
  • Offset: 0x40
Table 338 TIMER_W
31:0
VAL
Write:
Write the initial AON WDT value to the register.
Read:
Read the initial AON WDT value that users have configured. Read TIMER_R to get the current internal value.
ALARM_W
  • Name: ALARM_W Register
  • Description: This register is used to configure the AON_WDT alarm value.
  • Offset: 0x44
  • Reset Value: 0x64
Table 339 ALARM_W
31:16
15:0
VAL
0x64
Write:
Write an AON WDT alarm value to the register.
Read:
Read the AON WDT alarm value that users have configured. Read ALARM_R to get the current internal alarm value of AON WDT.
TIMER_R
  • Name: TIMER_R Register
  • Description: This register is used to get the current value of AON_WDT.
  • Offset: 0x4C
Table 340 TIMER_R
31:0
VAL
RO
Current internal value of AON WDT
ALARM_R
  • Name: ALARM_R Register
  • Description: This register reads the current alarm value of AON_WDT.
  • Offset: 0x50
Table 341 ALARM_R
31:16
15:0
VAL
RO
Current internal alarm value of the AON WDT
