文档中心 > GR5405 Datasheet/ Peripherals/ I/O/ Always-On I/O Copy URL
Always-On I/O
The device has eight individually configurable AON_GPIOs that can be applied by peripherals or digital input/output.
  • I/O default state is input mode with pull-down.
  • Can be configured as being triggered by high level, low level, rising edge, falling edge, or both edges.
  • As wakeup sources from sleep
  • Output some slow-speed clocks.
  • As digital GPIOs for input/output
  • To multiplex some different peripherals
AON_PAD_CTRL0
  • Name: Always-on Pad Control Register
  • Description: This register contains the AON_GPIO configurations.
  • Base Address: 0x4000AA14
  • Offset: 0x0
  • Reset Value: 0x00FF00FF
Table 262 AON_PAD_CTRL_0
31:24
23:16
IE
0xFF
Always-on PAD input enable
  • 0x0: Disable input.
  • 0x1: Enable input.
15:8
PS
Always-on PAD resistor type
  • 0x0: Pull-down.
  • 0x1: Pull-up.
7:0
PE
0xFF
Always-on PAD pull up/down resister enable
  • 0x0: Disable AONx resistor.
  • 0x1: Enable AONx resistor.
AON_PAD_CTRL1
  • Offset: 0x4
Table 263 AON_PAD_CTRL_1
31:24
23:16
IN_VAL
RO
AON pad input value
  • 0x0: Input AONx low.
  • 0x1: Input AONx high.
15:8
OUT_VAL
AON PAD output value
  • 0x0: Drive AONx low.
  • 0x1: Drive AONx high.
7:0
OE
0x00
Always-on pad output enable
  • 0x0: Enable AONx output.
  • 0x1: Disable AONx output.
AON_PAD_CTRL2
  • Offset: 0x8
Table 264 AON_PAD_CTRL_2
31:24
23:16
POE
RO
AON pad input value
15:8
SR
AON PAD slew rate
  • 0x0: Fast slew rate
  • 0x1: Slow slew rate
7:0
IS
0x00
AON pad input type
  • 0x0: CMOS input
  • 0x1: Schmitt input
AON_PAD_CTRL3
  • Offset: 0xC
  • Reset Value: 0x0000FF00
Table 265 AON_PAD_CTRL_3
31:24
15:8
DS1
0xFF
Always-on pad output drive strength (low bit)
  • 0x0: Weak mode
  • 0x1: Strong mode
7:0
DS0
0x00
Always-on pad output drive strength (high bit)
  • 0x0: Weak mode
  • 0x1: Strong mode
ANO_PAD_CLK
  • Name: Always-on PAD output clock controls register
  • Description: This register controls inner clock output from AON_GPIO_4.
  • Offset: 0x10
Table 266 AON_PAD_CLK
31:5
4:2
AON_GPIO4_CLK__SEL
Clock out selection
  • 0x0: RNG_256K div8
  • 0x1: RNG_OSC
  • 0x2: LFRC_32K
  • 0x3: LFXO_32K
AON_GPIO4_OUT_EN
Enable clock out via AON_GPIO_4.
  • 0x0: Disable selected clock out via AON_GPIO_4.
  • 0x1: Enable selected clock out via AON_GPIO_4.
AON_PAD_MCU_OVR
  • Description: This register controls the MCU domain setting of always-on pads.
  • Offset: 0x14
Table 267 AON_PAD_MCU_OVR
31:17
23:16
OVR
Use the settings from MCU domain; only valid when MCU domain is ON.
  • 0x0: Disable AONx digital setting.
  • 0x1: Enable AONx digital setting.
15:0
The electrical parameters for the AON_GPIO_0–AON_GPIO_7 are as follows:
Table 268 AON GPIO electrical specifications
VIH Input high voltage VDDIO x 0.7 VDDIO V
VIL Input low voltage VSS VDDIO x 0.3 V
VOH Output high voltage, 4 mA, VDDIO ≥ 3 V VDDIO - 0.4 VDDIO V
VOL,H Output low voltage, 4 mA, VDDIO ≥ 3 V VSS VSS + 0.4 V
IOL Current at VSS+0.4 V, output set low, VDDIO ≥ 3 V 2 12 mA
IOH Current at VDDIO-0.4 V, output set high, VDDIO ≥ 3 V 2 15 mA
tRF,9pF Rise time, 10%–90%, 9 pF load 1.6 13 ns
tRF,9pF Fall time, 10%–90%, 9 pF load 1.9 14.2 ns
RPU Pull-up resistance 12 20 32
RPD Pull-down resistance 12 20 32
CPAD Pad capacitance 5 pF
