文档中心 > GR5405 Datasheet/ System/ Reset/ Functional Overview Copy URL
Functional Overview
A reset is triggered by power, hardware or software in the SoC.
  • Power reset includes power-on reset and brown- out reset.
  • Hardware reset includes external reset pin (CHIP_EN) and watchdog reset.
  • Software reset refers to the NVIC System Reset Register (AIRCR) as defined in Cortex®-M4.
The reset structure of this SoC is illustrated in the figure below.
The PMU, triggered by CHIP_EN pad, POR circuit or BOD reset circuit, generates an active low por_rst_n reset signal. The watchdog reset by the watchdog timer in the always-on power domain generates an active low aon_wdog_rst_n reset signal. Either of these two reset signals will cause an active low pwr_rst_n reset signal to the power state controller, resulting in generating a reset signal of the SoC.
The power state controller generates an active low MCU Core Reset (mcu_core_rst_n), which goes directly to Cortex®-M4F core reset input. In order to support CPU-initiated system reset, the System Reset Request output of Cortex®-M4F is combined with mcu_core_rst_n, and the resulting System Reset (sys_rst_n) is connected to MCU peripherals as well as the XF Cache and always-on peripherals.
Figure 30 Reset structure
The reset sources are illustrated as below:
Table 40 Impact of reset sources on modules
Reset Source POR BOD Watchdog SYSRESETREQ
Power state controller Impacted Impacted Impacted Not impacted
Always-on power control Impacted Impacted Impacted Not impacted
Always-on peripherals Impacted Impacted Impacted Impacted
Always-on memory control Impacted Impacted Impacted Impacted
Always-on others Impacted Impacted Impacted Impacted
Bluetooth LE timer Impacted Impacted Impacted Impacted
Bluetooth LE core Impacted Impacted Impacted Impacted
MCU subsystem Impacted Impacted Impacted Impacted
Cortex®-M4 core Impacted Impacted Impacted Impacted
Cortex®-M4 debug Impacted Impacted Impacted Not impacted
