文档中心 > GR5405 Datasheet/ Peripherals/ Timer Interfaces/ Real-Time Counter (RTC/Calendar) Copy URL
The Real-time Counter (RTC) modules provide a generic, low-power timer running on a low-frequency clock source. Because the RTC modules are in the AON domain, the timer can keep running when the MCU is off. The modules can also wake up the system from sleep mode.
The RTC tick event interrupt module enables low-power "tick-less" RTOS implementation as it optionally provides a regular interrupt source for an RTOS without the need to use the ARM® SysTick feature. Using the RTC tick event rather than the SysTick allows the CPU to be powered down while still keeping RTOS scheduling active.
  • One ordinary compare interrupt
  • One tick event, supporting one-time counting and auto loading mode
  • 32-bit up-counter register, supporting reading and writing
  • 32-bit compare register, supporting reading and writing
  • 32-bit down-tick register, supporting reading and writing
  • One clock divider, supporting NO_DIV, DIV_2, DIV_4, DIV_8, DIV_16, DIV_32, DIV_64, and DIV_128
  • Flexible clock source selections from LFRC_32K or LFXO_32K
  • An independent interrupt entry
  • The software has to enable RTC PMU LPD (GFG0.EN = 1) before using the RTC.
  • The CFG1 register is a read/write register when the RTC is disabled, and it is read only when the RTC is enabled. Writing to the CFG1 register when the RTC is enabled has no effect.
  • The OVERFLOW, ALARM, and tick event interrupts are enabled by default.
  • When RTC is enabled, the TIMER_R register starts to count. When users set the values of the TIMER_W register and the VAL bit to 1, the calendar module synchronizes the count value to the TIMER_R register and starts timing.
  • When RTC is disabled, all register values must be cleared to restore the default values.
  • When the value of the TIMER_R register is equal to that of the ALARM_R register, the ordinary compare interrupt is triggered.
  • RTC tick event interrupt register is a value-decreasing register. When the auto reloading mode is set (CFG0.TICK_MDOE = 1), the value of the counter (TICK_W) is automatically reloaded (TICK_R) when the interrupt is triggered.
  • When the count value of the TIMER_R register overflows, the overflow interrupt is triggered, and the TIMER_R register continues counting from 0.
The AON_WDT, RTC, and SLP TIMER share the same clock source selection. The clock source can be LFRC_32K or LFXO_32K which are described in "Clocks".
CFG0
  • Name: CFG0 Register
  • Description: This register sets RTC configurations.
  • Base Address: 0x4000A600
  • Offset: 0x00
Table 342 CFG0
31:25
24
CFG
W
Writing 1 to this register triggers the calendar timer configuration.
23:11
10
TICK_MDOE
Set the RTC tick event mode.
  • 0: One-time
  • 1: Auto reloading
9
TICK_SET
Set the RTC tick event timer value.
8
TICK_EN
Enable RTC tick event.
7:5
4
WRAP_CLR
Clear the wrap counter.
3
ALARM_SET
Set the RTC ALARM timer value.
2
ALARM_EN
Enable RTC ALARM timer.
TIME_SET
Set the RTC initial timer value.
EN
Enable RTC timer.
CFG1
  • Name: CFG1 Register
  • Description: This register is used to set the frequency division coefficient.
  • Offset: 0x4
Table 343 CFG1
31:3
2:0
DIV
  • 0x0: NO_DIV. No division; counting at SLP_CLK
  • 0x1: DIV_2. Counting at 1/2 of SLP_CLK
  • 0x2: DIV_4. Counting at 1/4 of SLP_CLK
  • 0x3: DIV_8. Counting at 1/8 of SLP_CLK
  • 0x4: DIV_16. Counting at 1/16 of SLP_CLK
  • 0x5: DIV_32. Counting at 1/32 of SLP_CLK
  • 0x6: DIV_64. Counting at 1/64 of SLP_CLK
  • 0x7: DIV_128. Counting at 1/128 of SLP_CLK
INT_EN
  • Name: INT_EN Register
  • Description: This register is used to enable RTC interrupts.
  • Offset: 0x14
  • Reset Value: 0x00000007
Table 344 INT_EN
31:3
2
TICK
0x1
RTC tick event interrupt. Write 1 to enable the interrupt.
WRAP
0x1
RTC overflow interrupt. Write 1 to enable the interrupt.
ALARM
0x1
RTC COMPARE interrupt. Write 1 to enable the interrupt.
INT_STAT
  • Name: IRQ_STAT Register
  • Description: This register is used to get interrupt status of the RTC.
  • Offset: 0x18
Table 345 IRQ_STAT
31:3
2
TICK
RTC tick event interrupt. Write 1 to clear the interrupt.
WRAP
RTC overflow interrupt. Write 1 to clear the interrupt.
ALARM
RTC COMPARE interrupt. Write 1 to clear the interrupt.
STAT
  • Name: STAT Register
  • Description: This register is used to get the RTC status.
  • Offset: 0x38
Table 346 STAT
31:12
11:8
WRAP_CNT
Calendar timer wrap counter
7:5
4
BUSY
Calendar timer is busy. The application layer can perform other operations until this bit is set is 0.
3:1
STAT
RTC timer is running.
ALARM_W
  • Name: ALARM_W Register
  • Description: This register is used to set the ALARM timer value.
  • Offset: 0x40
Table 347 ALARM_W
31:0
VAL
  • W: RTC ALARM timer value to configure
  • R: The set value. Read ALARM_R to get the current internal value.
TIMER_W
  • Name: TIMER_W Register
  • Description: This register is used to set the RTC timer value.
  • Offset: 0x44
Table 348 TIMER_W
31:0
VAL
  • W: RTC timer value to configure
  • R: The set value. Read TIMER_R to get the current internal value.
TICK_W
  • Name: TICK_W Register
  • Description: This register is used to set the tick event timer value.
  • Offset: 0x48
Table 349 TICK_W
31:0
VAL
  • W: RTC tick event timer value to configure
  • R: The set value. Read TICK_R to get the current internal value.
TIMER_R
  • Name: TIMER_R Register
  • Description: This register is used to get the internal value of the RTC timer.
  • Offset: 0x50
Table 350 TIMER_R
31:0
VAL
Current internal value of the RTC timer
ALARM_R
  • Name: ALARM Register
  • Description: This register is used to get the value of the RTC ALARM timer.
  • Offset: 0x54
Table 351 ALARM
31:0
VAL
Current internal value of the RTC ALARM timer
TICK_R
  • Name: TICK_RD Register
  • Description: This register is used to get the value of the RTC tick event timer.
  • Offset: 0x58
Table 352 TICK_RD
31:0
VAL
Current internal value of the RTC tick event timer.
