文档中心 > GR5405 Datasheet/ System/ Registers/ Always-on PMU Control Copy URL
RF_REG_0
  • Name: RF_REG_0 Register
  • Description: RF_REG_0 Register
  • Base Address: 0x4000A800
  • Offset: 0x4
  • Reset Value: 0x08588E70
Table 120 RF_REG_0 Register
31:24
IO_LDO_REG1
0x8
[7] IO_LDO bypass mode
[6:0] Default is 1.8 V.
23:16
LPD_REG2
0x58
[7] NC
[6:4] AON_LDO vref trimming/output options (0.75/0.80/0.85/0.90/0.95/1.0/1.05/1.1)
[3] Enable LPD BG static mode.
[2:0] LPD dynamic mode period option (frequency for clk_ph1/clk_ph2/clk_ph3)
15:8
LPD_REG1
0x8E
[7:5] Temperature coefficient (Tempco) trimming
[4:2] RET_LDO vref trimming/output options (0.6/0.65/0.7/0.75/0.8/0.9/1.0/1.1)
[1] Enable Vret, which can be turned off during ultra deep sleep mode.
[0] NC
7:0
RTC_REG1
0x70
[7] Enable RTC.
[6] NC. Enable Constant GM mode.
[5] NC
[4:0] GM control
RF_REG_1
  • Name: RF_REG_1 Register
  • Description: RF_REG_1 Register
  • Offset: 0x8
  • Reset Value: 0x919A6F0F
Table 121 RF_REG_1 Register
31:24 DCDC_REG4 RW 0x91
[7] Enable ZCS skip function.
[6:4] Change BUCK ZCS offset to positive.
[3:1] Change BUCK ZCS offset to negative.
[0] Enable ZCS skip function; NC
23:16 DCDC_REG3 RW 0x9A
[7:3] hi-bit = 0, 769 mV–1035 mV, 18 mV/step; hi-bit = 1, 1053 mV–1436 mV, 25 mV/step
[2:1] Control low limit of DC-DC switching frequency. 00/01: 842 kHz; 10:640 kHz; 11:516 kHz
[0] Enable frequency limit function.
15:8 DCDC_REG2 RW 0x6F
[7:3] Trim the internal OSC to 32M.
[2:0] Change the length of driver deadtime; the optimized value is 010.
7:0 DCDC_REG1 RW 0xF
[7] Enable BUCK state machine. 0: DC-DC pause working
[6] Select CLK source. 1: external; 0: internal. Warning: Do not switch before XO32M works normally.
[5] Enable BUCK test mode.
[4] 1: Use Vreg to operate DC-DC. 0: Use LDO to operate DC-DC.
[3:2] Change the number of BUCK NMOS driver.
[1:0] Change the number of BUCK PMOS driver.
RF_REG_2
  • Name: RF_REG_2 Register
  • Description: RF_REG_2 Register
  • Offset: 0xC
  • Reset Value: 0x0084A0C0
Table 122 RF_REG_2 Register
31:24 RSVD R 0x0 Reserved bits
23:16 PMU_BG_REG RW 0x84
[7:5] bandgap TC fine trimming. 3b'000: most negative
[4] NC
[3] Forcibly enable main BG when DC-DC and SYS are off.
[2:0] bandgap TC coarse trimming. 3b'000: most negative
15:8 GP_REG1 RW 0xA0
[7:5] reference control - default 101
[4] delayed enable signal for efuse_vddq (2.5 V)
[3] Enable eFuse 2.5 V.
[2] Enable eFuse 1.1 V.
[1] Bypass vddq to VBATL (when EN = 1).
[0] NC
7:0 MUX1_REG1 RW 0xC0
[7] en_mux_msio
[6] mux_en
[5:3] mux_a
[2:0] Block selection. 000 - Sense ADC; 001:
RF_REG_3
  • Name: RF_REG_3 Register
  • Description: RF_REG_3 Register
  • Offset: 0x10
  • Reset Value: 0x11924729
Table 123 RF_REG_3 Register
31:30
29
BOD2_PWR_CTRL_POST
Real power state of BOD2
  • 0x0: OFF
  • 0x1: ON
28
BOD2_BYPASS
0x1
Bypass the power-on and power-off of BOD2 automatically.
27
26
COMP_INT
COMP interrupt
25
BOD2_INT
BOD interrupt
24
BOD2_OK
0x1
BOD works normally.
23:16
LPD_REG61
0x92
[4:3] 1.1 V LDO Vref trimming/output options (1.05/1.1/1.15/1.2)
[2:0] prebias IPAT current trimming
15:8
LPD_REG60
0x47
[3:1] 1.2 V Vref (for SIDO) trimming
[0] NC
7:6
5
BOD_STATIC_EN
0x1
The dynamic mode has lower power but lower accuracy.
  • 0x0: Enable dynamic mode.
  • 0x1: Enable static mode.
4:2
BOD2_LVL_CTRL_LV
0x2
BOD2 level control bits
BOD2_EN
  • 0x0: Disable BOD interrupt.
  • 0x1: Enable BOD interrupt.
BOD_EN
0x1
  • 0x0: Disable BOD reset.
  • 0x1: Enable BOD reset.
RF_REG_4
  • Name: RF_REG_4 Register
  • Description: RF_REG_4 Register
  • Offset: 0x14
  • Reset Value: 0x00230000
Table 124 RF_REG_4 Register
31:24
23:16
ANACORE_LDO_REG1
0x23
[7] en_bleed
[6] Enable bypass mode.
[5:4] digcore_ldo_out, 0.8/0.9/1.0/(soft bypass)
[3] Bypass VDDaon to VDDcore.
[2] NC; test function; slowly start to prevent VBAT drop.
[1:0] NC; digcore_ldo_out trimming; defaulted to +10%, have been moved to overwrite register
15:0
RC_RTC_REG_0
  • Name: RC_RTC_REG_0 Register
  • Description: RC_RTC_REG_0 Register
  • Offset: 0x48
  • Reset Value: 0x900ADD8B
Table 125 RC_RTC_REG_0 Register
31:24
RTC_CAP
0x90
[7] FBresistor
[6] FBresistor
[5:0] cap control
23:16
RTC_CS
0xA
[7] NC
[6] NC
[5] NC
[4:0] CS
15:8
RC_REG2
0xDD
[7] Enable RCOSC.
[6] Enable RCOSC delay.
[5:3] RCOSC rdiv_delay_ctrl
[2:0] RCOSC resn_ctrl
7:0
RC_REG1
0x8B
[7:6] RCOSC bias control
[5] cgm_byp
[4:3] NC
[2:0] NC
FS_REG_0
  • Name: FS_REG_0 Register
  • Description: FS_REG_0 Register
  • Offset: 0x50
Table 126 FS_REG_0 Register
31:24
23:16
FINE_CODE
Fine code
15:0
FS_REG_1
  • Name: FS_REG_1 Register
  • Description: FS_REG_1 Register
  • Offset: 0x54
  • Reset Value: 0x00000A60
Table 127 FS_REG_1 Register
31:16 RSVD R 0x0 Reserved bits
15:8 FS_REG5 RW 0xA
[7:5] NC
[4] test function; add zero in feedback loop.
[3:0] Control input reference voltage.
7:0 FS_REG4 RW 0x60
[7:6] ctrl_osc_fin
[5:4] NC
[3:0] coarse code that controls hf_clk frequency. Use the default: 0000 (Need one-time calibration using the on-chip frequency calibration).
PMU_TON_CFG
  • Name: PMU_TON_CFG Register
  • Description: PMU_TON_CFG Register
  • Offset: 0x94
  • Reset Value: 0x00000606
Table 128 PMU_TON_CFG Register
31:12
11:8
OFF
0x6
TON_CTRL value when TXEN = 0
7:4
3:0
ON
0x6
TON_CTRL value when TXEN = 1
PMU_INTF_OVR_EN_0
  • Name: PMU_INTF_OVR_EN_0 Register
  • Description: PMU_INTF_OVR_EN_0 Register
  • Offset: 0xC0
Table 129 PMU_INTF_OVR_EN_0 Register
31:9
8
AVS_CTL_REF_EN
Value for AVS_CTL_REF overwrite interface
7
RNG_OSC_CLK_EN
Value for RNG_OSC_CLK overwrite interface
6
5
IO_LDO_EN
Value for IO_LDO overwrite interface
4
3
DIG_LDO_EN
Value for CORE_LDO overwrite interface
2
HF_OSC_EN
Value for HF_OSC overwrite interface
SYS_LDO_EN
Value for SYS_LDO overwrite interface
DCDC_EN
Value for DC-DC overwrite interface
PMU_INTF_OVR_VAL_0
  • Name: PMU_INTF_OVR_VAL_0 Register
  • Description: PMU_INTF_OVR_VAL_0 Register
  • Offset: 0xC4
  • Reset Value: 0x00003F00
Table 130 PMU_INTF_OVR_VAL_0 Register
31:14
13:8
AVS_CTL_REF
0x3F
7
RNG_OSC_CLK_EN
6
5
IO_LDO_EN
4
Reserved bit
3
DIG_LDO_EN
2
HF_OSC_EN
SYS_LDO_EN
DCDC_EN
PMU_DVS_CFG_0
  • Name: PMU_DVS_CFG_0 Register
  • Description: PMU_DVS_CFG_0 Register
  • Offset: 0xC8
  • Reset Value: 0x00000088
Table 131 PMU_DVS_CFG_0 Register
31:8
7:0
DVS_LPD_REG2
0x88
[7]: 0x0: low BOD hysteresis; 0x1: high BOD hysteresis
[6:5]: not used
[4]: Select BOD hysteresis mode. 0x0: HW mode; 0x1: SW mode
[3:0]: BOD trimming value
MPX_CFG
  • Name: MPX_CFG Register
  • Description: MPX_CFG Register
  • Offset: 0xD4
Table 132 MPX_CFG Register
31:8
7:0
MPX_REG1
[7] When rg_efuse_mpx_sel = 1, select the eFuse power from MPX pad. When rg_efuse_mpx_sel = 0, do not use eFuse LDO; instead, use MPX as the analog test pad.
[6] rg_en_mpx_dig
[5:3] rg_efuse_mpx_sel
[2] rg_en_bypass
[1:0] NC
PMU_INTF_OVR_RD0
  • Name: PMU_INTF_OVR_RD0 Register
  • Description: PMU_INTF_OVR_RD0 Register
  • Offset: 0xE0
  • Reset Value: 0x00003FAF
Table 133 PMU_INTF_OVR_RD0 Register
31:14
13:8
AVS_CTL_REF
0x3F
Current AVS_CTL_REF value
When PMU_ INTF_OVR_EN_0[8] = 1, the value equals PMU_ INTF_OVR_EN_0[13:8]; when PMU_ INTF_OVR_EN_0[8] = 0, the value equals avs_ctl value.
7
RNG_OSC_CLK_EN
0x1
Current RNG_OSC_CLK_EN value
6
5
IO_LDO_EN
0x1
Current IO_LDO value
4
Reserved bit
3
DIG_LDO_EN
0x1
Current CORE_LDO value
2
HF_OSC_EN
0x1
Current HF_OSC_EN value
SYS_LDO_EN
0x1
Current SYS_LDO value
DCDC_EN
0x1
Current DC-DC value
