文档中心 > GR5405 Datasheet/ System/ MCU Core/ Performance Copy URL
Performance
Benefiting from the efficient design of each module, the device can easily reach a high level of operating efficiency. The CoreMark scores are shown in the table below.
Table 7 MCU CoreMark scores
CMFLASH,Direct
CoreMark, running from Flash, 64 MHz, direct map cache
212
CoreMark
CMFLASH/MHz,Direct
CoreMark per MHz, running from Flash, 64 MHz, direct map cache
3.3
CoreMark/MHz
CMFLASH,4-Way
CoreMark, running from Flash, 64 MHz, 4-way associative cache
168
CoreMark
CMFLASH/MHz, 4-Way
CoreMark per MHz, running from Flash, 64 MHz, 4-way associative cache
2.7
CoreMark/MHz
