文档中心 > GR5405 Datasheet/ System/ Registers/ Always-on Control Copy URL
Always-on Control
MCU_CLK_CTRL
  • Name: MCU_CLK_CTRL Register
  • Description: MCU_CLK_CTRL Register
  • Base Address: 0x4000A000
  • Offset: 0x0
  • Reset Value: 0x42040202
Table 54 MCU_CLK_CTRL Register
31
Reserved bit
30
RNG_2MHZ_CLK_EN
0x1
Enable/Disable RNG 256 KHz OSC CLK in PMU.
29
Reserved bit
28:27
SLOW_CLK_SEL
Select the source of aon_slow CLK. Please allow about 10 μs for switching.
  • 0x0: 256K RNG OSC CLK
  • 0x1: Reserved
  • 0x2: RC OSC 32K CLK
  • 0x3: RTC OSC 32K CLK
26:24
SYS_CLK_RD
0x2
Current MCU_CLK_CTRL_SEL value
23:19
18:16
SER_CLK_SEL
0x4
Select the clock for serial modules (UART, I2C, SPI_M, and SPI_S).
  • 0x0: 64M_clk PLL/HF_OSC 64 MHz CLK
  • 0x1: 32M_clk PLL/HF_OSC 32 MHz CLK
  • 0x2: 16M_clk PLL/HF_OSC 16 MHz CLK
  • 0x3: 8M_clk PLL/HF_OSC 8 MHz CLK
  • 0x4: XO_16M_clk XO 16 MHz CLK
15:13
12
WKUP_CLK_EN
Apply WKUP_CLK_SEL to MCU_CLK_CTRL_SEL on wakeup.
11
Reserved bit
10:8
WKUP_CLK_SEL
0x2
Select system clock on wakeup.
  • 0x2: XO_16M_clk XO 16 MHz CLK
  • 0x3: 16M_clk PLL/HF_OSC 16 MHz CLK
  • 0x4: 8M_clk PLL/HF_OSC 8 MHz CLK
  • 0x5: 2M_clk PLL/HF_OSC 2 MHz CLK
7:6
5:4
SLOW_CLK_CTRL_SEL
Select WD timer, sleep timer, and RTC clock.
  • 0x0: RNG 256 kHz CLK div8
  • 0x1: Reserved
  • 0x2: RC 32 kHz CLK
  • 0x3: RTC 32 kHz CLK
3
Reserved bit
2:0
MCU_CLK_CTRL_SEL
0x2
Select the system clock for MCU subsystem.
MCU_MISC_CFG
  • Name: MCU_MISC_CFG Register
  • Description: MCU_MISC_CFG Register
  • Offset: 0x4
Table 55 MCU_MISC_CFG Register
31:9
8
SWD_ENABLE
Enable SWD debugging.
7:0
XO_CTRL
  • Name: XO_CTRL Register
  • Description: XO_CTRL Register
  • Offset: 0x8
  • Reset Value: 0x00000100
Table 56 XO_CTRL Register
31:25
24
BYP
RF control register. Keep the default setting in test mode.
  • 0x0: Use the analog XO module.
  • 0x1: Bypass the analog XO module. If the system uses XO or CPLL clock, an external oscillator shall be used.
23:9
8
2MHZ_ENA
0x1
Enable XO 2 MHz from RF.
7:1
2MHZ_OUT
  • 0x0: normal aon_gpio[5]
  • 0x1: aon_gpio[5] becomes xo_2mhz output.
FLASH_CACHE_CTRL0
  • Name: FLASH_CACHE_CTRL0 Register
  • Description: FLASH_CACHE_CTRL0 Register
  • Offset: 0xC
  • Reset Value: 0x00000014
Table 57 FLASH_CACHE_CTRL0 Register
31:9
8
XF_TAG_RET
This signal controls and disables flushing of the tag memory on power-on:
  • 0x0: The tag memory will be flushed when mcu core is powered on.
  • 0x1: Disable flushing the tag memory on mcu core power-on.
7:5
4
XF_XO_DIV1
0x1
Always need to be set to 1.
3
Reserved bit
2:0
XF_SCK_CLK_SEL
0x4
XQSPI clock
  • 0x0: PLL 64 MHz
  • 0x1: PLL 48 MHz
  • 0x2: PLL 32 MHz
  • 0x3: PLL 16 MHz
  • 0x4: XO 16 MHz
FLASH_CACHE_CTRL1
  • Name: FLASH_CACHE_CTRL1 Register
  • Description: FLASH_CACHE_CTRL1 Register
  • Offset: 0x10
  • Reset Value: 0x00000006
Table 58 FLASH_CACHE_CTRL1 Register
31:3
2
PAD_BYPASS
0x1
  • 0x0: the power of external Flash is controlled by HW automatically.
  • 0x1: the power of external Flash is controlled by software.
0x1
Reserved bit
PAD_EN
External Flash pad is enabled by SW. This configuration takes effect only when the bypass_pwr_req signal is equal to 1'b1. Enable it to provide POWER to External Flash.
DIGIO_FST_CLK
  • Name: DIGIO_FST_CLK Register
  • Description: DIGIO_FST_CLK Register
  • Offset: 0x14
Table 59 DIGIO_FST_CLK Register
31:9
8
SEL
Clock for digital IO LDO
  • 0x0: 8 MHz
  • 0x1: 16 MHz
7:1
EN
Enable digital IO LDO fast CLK.
AON_CLK
  • Name: AON_CLK Register
  • Description: AON_CLK Register
  • Offset: 0x18
Table 60 AON_CLK Register
31:9
8
WAKUP_FAST_CLK_SEL
Select the source of the 192 MHz clock:
  • 0x0: cpll_clk
  • 0x1: hf_osc_clk
7:5
4
WAKUP_CLK_EN
Apply WAKUP_FAST_CLK_SEL value to CAL_FST_CLK on wakeup.
3:1
CAL_FST_CLK
  • 0x0: cpll_clk
  • 0x1: hf_osc_clk
TPP_ANA
  • Name: TPP_ANA Register
  • Description: TPP_ANA Register
  • Offset: 0x20
  • Reset Value: 0x00000101
Table 61 TPP_ANA Register
31:9
8
EN_N_RD
0x1
Actual value of EN_N
7:1
EN_N
0x1
This register only gets reset through POR.
AON_PWR_SAVING
  • Name: AON_PWR_SAVING Register
  • Description: AON_PWR_SAVING Register
  • Offset: 0x24
Table 62 AON_PWR_SAVING Register
31:1
EN
Set it to 1 to save more AON power.
MCU_WAKEUP_CTRL
  • Name: MCU_WAKEUP_CTRL Register
  • Description: MCU_WAKEUP_CTRL Register
  • Offset: 0x80
  • Reset Value: 0x0000007F
Table 63 MCU_WAKEUP_CTRL Register
31:7
6
COMP_FALL
0x1
Select COMP_FALL IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
5
AON_WDT
0x1
Select AON_WDT IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
4
COMP_RISE
0x1
Select COMP_RISE IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
3
RTC0
0x1
Select RTC0 IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
2
SMS_OSC
0x1
Select SMS_OSC IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
EXT
0x1
Select EXT IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
SLP_TIMER
0x1
Select SLP_TIMER IRQ as the wakeup event.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
AON_SLP_EVENT
  • Name: AON_SLP_EVENT Register
  • Description: AON_SLP_EVENT Register
  • Offset: 0x84
Table 64 AON_SLP_EVENT Register
31:7
6
COMP_FALL
WC
COMP_FALL event that happened during sleeping or in functional mode. Write 0 to clear.
5
AON_WDT
WC
AON_WDT event that happened during sleeping or in functional mode. Write 0 to clear.
4
COMP_RISE
WC
COMP_RISE event that happened during sleeping or in functional mode. Write 0 to clear.
3
RTC0
WC
RTC0 event that happened during sleeping or in functional mode. Write 0 to clear.
2
SMS_OSC
WC
SMS_OSC event that happened during sleeping or in functional mode. Write 0 to clear.
EXT
WC
EXT event that happened during sleeping or in functional mode. Write 0 to clear.
SLP_TIMER
WC
SLP_TIMER event that happened during sleeping or in functional mode. Write 0 to clear.
AON_SLP_EVENT_RAW
  • Name: AON_SLP_EVENT_RAW Register
  • Description: AON_SLP_EVENT_RAW Register
  • Offset: 0x8C
Table 65 AON_SLP_EVENT_RAW Register
31:7 RSVD R 0x0 Reserved bits
6 PMU_COMP R 0x0 AON sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
5 AON_WDT R 0x0 AON Sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
4 PMU_MSIO R 0x0 AON Sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
3 RTC0 R 0x0 AON Sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
2 SMS_OSC R 0x0 AON Sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
1 EXT R 0x0 AON Sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
0 SLP_TIMER R 0x0 AON Sleep event status before masking (MCU_WAKEUP_CTRL). The bit order matches the AON_SLP_EVT register.
AON_IRQ
  • Name: AON_IRQ Register
  • Description: AON_IRQ Register
  • Offset: 0x98
  • Reset Value: 0x00000008
Table 66 AON_IRQ Register
31:7
6
SLP_FAIL_IRQ
WC
0x1
Sleep failure status. Write 0 to clear.
5
BLE_MAC_IRQ
WC
0x1
Bluetooth LE MAC IRQ status. Write 0 to clear.
4
PMU_BOD_FALL
WC
0x1
PMU BOD falling edge IRQ status. Write 0 to clear.
3
AONPLL_CHG
WC
0x1
PLL power-on done IRQ status. Write 0 to clear.
2
PMU_BOD_RISE
WC
0x1
BOD rising edge IRQ status. Write 0 to clear.
BLE_PWR_DN
WC
0x1
Bluetooth LE power-off done IRQ status. Write 0 to clear.
BLE_PWR
WC
0x1
Bluetooth LE power-on done IRQ status. Write 0 to clear.
AON_IRQ_EN
  • Name: AON_IRQ_EN Register
  • Description: AON_IRQ_EN Register
  • Offset: 0x9C
  • Reset Value: 0x000000FF
Table 67 AON_IRQ_EN Register
31:7
6
SLP_FAIL_IRQ
0x1
Enable sleep failure status.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
5
BLE_MAC_IRQ
0x1
Enable Bluetooth LE MAC IRQ.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
4
PMU_BOD_FALL
0x1
Enable PMU BOD falling edge IRQ.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
3
AONPLL_CHG
0x1
Enable PLL power-on done IRQ.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
2
PMU_BOD_RISE
0x1
Enable BOD rising edge IRQ.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
BLE_PWR_DN
0x1
Enable Bluetooth LE power-off done IRQ.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
BLE_PWR_ON
0x1
Enable Bluetooth LE power-on done IRQ.
  • 0x0: Disable IRQ.
  • 0x1: Enable IRQ.
AON_DBG_CTRL
  • Name: AON_DBG_CTRL Register
  • Description: AON_DBG_CTRL Register
  • Offset: 0xA8
  • Reset Value: 0x00000007
Table 68 AON_DBG_CTRL Register
31:17
16
DBG_SLP
Prevent sleep when JLINK is attached.
15:3
2
AON_WDT
0x1
Set to stop the watchdog timer when MCU halts.
RTC
0x1
Set to stop the calendar timer when MCU halts.
SLP_TIMER
0x1
Set to stop the sleep timer when MCU halts.
MEM_MARGIN
  • Name: MEM_MARGIN Register
  • Description: MEM_MARGIN Register
  • Offset: 0x1C0
  • Reset Value: 0x000000CC
Table 69 MEM_MARGIN Register
31:8
7:6
NON_CRITICAL_MEM_RWM
0x3
Control of non-critical memory margin adjustment
5
NON_CRITICAL_MEM_WM
Write margin adjustment of non-critical memory
4
NON_CRITICAL_MEM_RM
Read margin adjustment of non-critical memory
3:2
CRITICAL_MEM_RWM
0x3
Control of critical memory margin adjustment
CRITICAL_MEM_WM
Write margin adjustment of critical memory
CRITICAL_MEM_RM
Read margin adjustment of critical memory
MEM_PARAM
  • Name: MEM_PARAM Register
  • Description: MEM_PARAM Register
  • Offset: 0x1C4
Table 70 MEM_PARAM Register
31:4
3:0
MEM_BTRM
0x8
Source Bias Trim Adjustment for all SRAMs
EXT_WAKEUP_CTRL0
  • Name: EXT_WAKEUP_CTRL0 Register
  • Description: EXT_WAKEUP_CTRL0 Register
  • Offset: 0x200
Table 71 EXT_WAKEUP_CTRL0 Register
31:16
15:8
INVERT
Invert external wakeup.
  • bit7: aon_gpio7
  • bit6: aon_gpio6
  • bit5: aon_gpio5
  • bit4: aon_gpio4
  • bit3: aon_gpio3
  • bit2: aon_gpio2
  • bit1: aon_gpio1
  • bit0: aon_gpio0
  • 0x0: Do not invert
  • 0x1: Invert
7:0
SRC_EN
Enable external wakeup source.
  • bit7: aon_gpio7
  • bit6: aon_gpio6
  • bit5: aon_gpio5
  • bit4: aon_gpio4
  • bit3: aon_gpio3
  • bit2: aon_gpio2
  • bit1: aon_gpio1
  • bit0: aon_gpio0
  • 0x0: Disable
  • 0x1: Enable
EXT_WAKEUP_CTRL1
  • Name: EXT_WAKEUP_CTRL1 Register
  • Description: EXT_WAKEUP_CTRL1 Register
  • Offset: 0x204
Table 72 EXT_WAKEUP_CTRL1 Register
31:24
23:16
EDGE_BOTH
Valid when EDGE_EN = 1
  • bit7: aon_gpio7
  • bit6: aon_gpio6
  • bit5: aon_gpio5
  • bit4: aon_gpio4
  • bit3: aon_gpio3
  • bit2: aon_gpio2
  • bit1: aon_gpio1
  • bit0: aon_gpio0
  • 0x0: single edge
  • 0x1: both edges
15:8
EDGE_TYPE
Valid when EDGE_EN = 1 & EDGE_BOTH = 0
  • bit7: aon_gpio7
  • bit6: aon_gpio6
  • bit5: aon_gpio5
  • bit4: aon_gpio4
  • bit3: aon_gpio3
  • bit2: aon_gpio2
  • bit1: aon_gpio1
  • bit0: aon_gpio0
  • 0x0: rising edge
  • 0x1: falling edge
7:0
EDGE_EN
Enable edge detecting.
  • bit7: aon_gpio7
  • bit6: aon_gpio6
  • bit5: aon_gpio5
  • bit4: aon_gpio4
  • bit3: aon_gpio3
  • bit2: aon_gpio2
  • bit1: aon_gpio1
  • bit0: aon_gpio0
  • 0x0: level signal
  • 0x1: Detect the edge.
EXT_WAKEUP_STAT
  • Name: EXT_WAKEUP_STAT Register
  • Description: EXT_WAKEUP_STAT Register
  • Offset: 0x20C
Table 73 EXT_WAKEUP_STAT Register
31:8
7:0
STAT
WC
External wakeup status (after masking). Write 0 to clear the wakeup status (both level and pulse).
  • bit7: aon_gpio7
  • bit6: aon_gpio6
  • bit5: aon_gpio5
  • bit4: aon_gpio4
  • bit3: aon_gpio3
  • bit2: aon_gpio2
  • bit1: aon_gpio1
  • bit0: aon_gpio0
  • 0x0: not triggered
  • 0x1: triggered
COMM_CTRL
  • Name: COMM_CTRL Register
  • Description: COMM_CTRL Register
  • Offset: 0x280
  • Reset Value: 0x00020000
Table 74 COMM_CTRL Register
31:18
17:16
TIMER_CLK_SEL
0x2
Select Comm timer clock.
  • 0x0: rtc_osc_clk
  • 0x1: rng_2_osc_clk (rc32k)
  • 0x2: rng_osc_clk
15:10
9
DEEPSLCNTL_EXTWKUPDSB
Comm timer register
8
DEEPSLCNTL_SOFT_WAKEUP_REQ
Comm timer register
7
Reserved bit
6
DEEPSLCNTL_DEEP_SLEEP_ON
Comm timer register
5
DEEPSLCNTL_RADIO_SLEEP_EN
Comm timer register
4
DEEPSLCNTL_OSC_SLEEP_EN
Comm timer register
3
Reserved bit
2
DEEPSLCNTL_DEEP_SLEEP_STAT
Comm timer register
1:0
BLE_MISC
  • Name: BLE_MISC Register
  • Description: BLE_MISC Register
  • Offset: 0x284
Table 75 BLE_MISC Register
31:1
SMC_WAKEUP_REQ
Wake up SMC by MCU; it needs to be cleared by MCU as well.
COMM_TIMER_CFG0
  • Name: COMM_TIMER_CFG0 Register
  • Description: COMM_TIMER_CFG0 Register
  • Offset: 0x288
Table 76 COMM_TIMER_CFG0 Register
31:0
DEEPSLWKUP
Used for Comm timer
COMM_TIMER_CFG1
  • Name: COMM_TIMER_CFG1 Register
  • Description: COMM_TIMER_CFG1 Register
  • Offset: 0x28C
Table 77 COMM_TIMER_CFG1 Register
31:0
ENBPRESET
Used for Comm timer
BLE_DEEP_SLP_CORR_EN
  • Name: BLE_DEEP_SLP_CORR_EN Register
  • Description: BLE_DEEP_SLP_CORR_EN Register
  • Offset: 0x290
  • Reset Value: 0x00000001
Table 78 BLE_DEEP_SLP_CORR_EN Register
31:2
HW_EN
Enable HW Timer Correction Operation.
FW_EN
0x1
Enable FW Timer Correction Operation.
BLE_DEEP_SLP_HW_TIMER_CORR
  • Name: BLE_DEEP_SLP_HW_TIMER_CORR Register
  • Description: BLE_DEEP_SLP_HW_TIMER_CORR Register
  • Offset: 0x294
  • Reset Value: 0x0F424000
Table 79 BLE_DEEP_SLP_HW_TIMER_CORR Register
31:30
29:12
RTC_TOSC
0XF424
Period of RTC clock in μs
11:10
9:0
WAIT
Wait time in μs after wakeup before correction begins
COMM_TIMER_STAT
  • Name: COMM_TIMER_STAT Register
  • Description: COMM_TIMER_STAT Register
  • Offset: 0x298
Table 80 COMM_TIMER_STAT Register
31:0
DEEPSLSTAT
Sleep status
PMU_COMP_GLITCH_REMOVE
  • Name: PMU_COMP_GLITCH_REMOVE Register
  • Description: PMU_COMP_GLITCH_REMOVE Register
  • Offset: 0x2C0
Table 81 PMU_COMP_GLITCH_REMOVE Register
31:3
2:0
CYCLE
  • 0x0: no digital de-glitch
  • Others: The de-glitch step is the clock cycle of aon_slow_clk (32K/256K).
SOFTWARE_REG0
  • Name: SOFTWARE_REG0 Register
  • Description: SOFTWARE_REG0 Register
  • Offset: 0x340
Table 82 SOFTWARE_REG0 Register
31:0
SOFTWARE_REG0
Used to save some values which can be used after waking up
SOFTWARE_REG1
  • Name: SOFTWARE_REG1 Register
  • Description: SOFTWARE_REG1 Register
  • Offset: 0x344
Table 83 SOFTWARE_REG1 Register
31:0
SOFTWARE_REG1
SLP_BUSY_STAT
  • Name: SLP_BUSY_STAT Register
  • Description: SLP_BUSY_STAT Register
  • Offset: 0x348
Table 84 SLP_BUSY_STAT Register
31:17
16:0
SLP_BUSY_STS
Sleep busy status, which is updated when sleep fails
  • bit16: rng_busy
  • bit15: uart_0_busy
  • bit14: uart_1_busy
  • bit13: spi_m_busy
  • bit12: spi_s_busy
  • bit11: i2c_0_busy
  • bit10: i2c_1_busy
  • bit9: pwm_0_busy
  • bit8: pwm_1_busy
  • bit7: mcu_dualtimer_busy
  • bit6: mcu_apb_timer_0_busy
  • bit5: mcu_apb_timer_1_busy
  • bit4: snadc_busy
  • bit3: dma_busy
  • bit2: clk_calib_0_busy
  • bit1: clk_calib_1_busy
  • bit0: ble_pwr_off_busy
SLP_BUSY_BYPASS
  • Name: SLP_BUSY_BYPASS Register
  • Description: SLP_BUSY_BYPASS Register
  • Offset: 0x34C
  • Reset Value: 0x0001FFFF
Table 85 SLP_BUSY_BYPASS Register
31:17
16:0
SLP_BUSY_BYPASS
0x1FFFF
0x1: Bypass HW auto goto sleep function.
  • bit16: Bypass the rng_busy.
  • bit15: Bypass the uart_0_busy.
  • bit14: Bypass the uart_1_busy.
  • bit13: Bypass the spi_m_busy.
  • bit12: Bypass the spi_s_busy.
  • bit11: Bypass the i2c_0_busy.
  • bit10: Bypass the i2c_1_busy.
  • bit9: Bypass the pwm_0_busy.
  • bit8: Bypass the pwm_1_busy.
  • bit7: Bypass the mcu_dualtimer_busy.
  • bit6: Bypass the mcu_apb_timer_0_busy.
  • bit5: Bypass the mcu_apb_timer_1_busy.
  • bit4: Bypass the snadc_busy.
  • bit3: Bypass the dma_busy.
  • bit2: Bypass the clk_calib_0_busy.
  • bit1: Bypass the clk_calib_1_busy.
  • bit0: Bypass the ble_pwr_off_busy.
DBG_REG0
  • Name: DBG_REG0 Register
  • Description: DBG_REG0 Register
  • Offset: 0x380
Table 86 DBG_REG0 Register
31:15
14:13
DBG_FLAGSELH
  • 0x0: Output high 8 bits tie to 8'h0.
  • 0x1: Select flag_in01 high 8 bits.
  • 0x2: Select flag_in02 high 8 bits.
12
DBG_FLAGH_EN
  • 0x0: Disable high block of debug bus.
  • 0x1: Enable high block of debug bus.
11
Reserved bit
10:9
DBG_FLAGSELL
  • 0x0: Output low 8 bits tie to 8'h0.
  • 0x1: Select flag_in01 low 8 bits.
  • 0x2: Select flag_in02 low 8 bits.
8
DBG_FLAGL_EN
  • 0x0: Disable low block of debug bus.
  • 0x1: Enable low block of debug bus.
7:4
DBG_BUS_SEL
bit0: debug bus to AON pads
  • 0x0: Disable debug bus.
  • 0x1: Enable debug bus.
bit1:
  • 0x0: Select low 8 bits to AON pads.
  • 0x1: Select high 8 bits connected to AON pads.
bit2: debug bus to MISO pads
bit3:
  • 0x0: Select low 10 bits to MSIO pads.
  • 0x1: Select high 10 bits connected to MSIO pads.
3:1
DBG_SYS_CLK_SEL
0x1: Use the test logic to generate the final MCU_CLK_CTRL_SEL.
DBG_REG_RST_SRC
  • Name: DBG_REG_RST_SRC Register
  • Description: DBG_REG_RST_SRC Register
  • Offset: 0x384
  • Reset Value: 0x01010030
Table 87 DBG_REG_RST_SRC Register
31
CFG
W
Write 1 to apply the bit [25:24].
30
CFG_BUSY
0x1: The block is being configured. Do not perform any write operation.
29:25
24
EN
0x1
1: Enable reset source record.
23:15
16
RDY
0x1
  • 0x0: The block is not ready to record.
  • 0x1: The block is ready to record.
15:6
5:0
STS
WC
0x30
Reset season status:
  • Bit 0: System reset. Clear the bit by writing 1 to it.
  • Bit 1: System watchdog reset. Clear the bit by writing 1 to it.
  • Bit 2: AON watchdog reset. Clear the bit by writing 1 to it.
  • Bit 3: System full reset. Clear the bit by writing 1 to it.
  • Bit 4: POR reset. Clear the bit by writing 1 to it.
  • Bit 5: Sleep reset. Clear the bit by 1" to it.
MEM_BOND_OPT_REG
  • Name: MEM_BOND_OPT_REG Register
  • Description: MEM_BOND_OPT_REG Register
  • Offset: 0x3A0
Table 88 MEM_BOND_OPT_REG Register
31:16
REG_MAGIC_WORD
W
The valid magic word is 16h5A5A.
BOND_OPT cannot be written except when the magic word is valid.
15:2
1:0
BOND_OPT
  • 0x0: 96 KB (SRAMs 0–5 ON)
  • 0x1: 80 KB (SRAMs 0–4 ON; SRAM 5 OFF)
  • 0x2: 64 KB (SRAMs 0–3 ON; SRAMs 4–5 OFF)
  • 0x3: 48 KB (SRAMs 0–2 ON; SRAMs 3–5 OFF)
