文档中心 > GR5405 Datasheet/ Peripherals/ I/O/ Mixed Signal I/O Copy URL
Mixed Signal I/O
The device has seven individually configurable MSIOs that can be applied by peripherals, digital input/output or analog input.
  • I/O default state is high impendence mode.
  • As analog input for sense ADC or comparator.
  • As digital GPIOs for input/output, no interrupt.
  • To multiplex some different peripherals.
MSIO_A_PAD_CFG0
  • Name: MSIO Pad Control Register
  • Description: This register contains the input and output data.
  • Base Address: 0x4000AA00
  • Offset: 0x00
Table 269 MSIO_A_PAD_CFG0
31:30
29:20
IN_VAL
MSIO input digital value
19:10
OE
MSIO output enable (active low)
  • 0x1: Enable MSIO_x output.
  • 0x0: Disable MSIO_x output.
9:0
OUT_VAL
MSIO output value (valid in output mode)
MSIO_A_PAD_CFG1
  • Description: This register contains the MSIO configurations.
  • Offset: 0x04
Table 270 MSIO_A_PAD_CFG1
31:30
29:20
IE
MSIO input enabled
  • 0x0: Disable input.
  • 0x1: Enable input.
19:10
PS
MSIO resistor type
  • 0x0: Pull-down.
  • 0x1: Pull-up.
9:0
PE
Pull up/down enable control for MSIO pad
  • 0x0: Disabled
  • 0x1: Enabled
MSIO_A_PAD_CFG2
  • Offset: 0x08
Table 271 MSIO_A_PAD_CFG2
31:30
29:20
POE
MSIO parametric output enable
  • 0x0: Disabled
  • 0x1: Enabled
19:10
SR
MSIO slew rate
  • 0x0: Fast slew rate.
  • 0x1: Slow slew rate.
9:0
IS
MSIO input type
  • 0x0: CMOS input
  • 0x1: Schmitt input
MSIO_A_PAD_CFG3
  • Offset: 0x0C
  • Reset Value: 0x3FFFFC00
Table 272 MSIO_A_PAD_CFG3
31:30
29:20
AE
0x3FF
Analog enable control for MSIO pad
  • 0x0: Digital mode
  • 0x1: Analog mode
19:10
DS1
0x3FF
MSIO output drive strength (low bit)
  • 0x0: Weak mode
  • 0x1: Strong mode
9:0
DS0
MSIO output drive strength (high bit)
  • 0x0: Weak mode
  • 0x1: Strong mode
MSIO_MCU_OVR
  • Name: MSIO Using MCU Domain Setting Control Register
  • Description: This register controls MSIO using the settings from the MCU domain.
  • Offset: 0x10
  • Reset Value:0x00000000
Table 273 MSIO_A_PAD_MCU_OVR
31:10
9:0
OVR
Use the settings from MCU domain, only valid when MCU domain is ON
  • 0: Use settings in MSIO_A_PAD_CFG as GPIO.
  • 1: Use PAD MUX settings in MCU.
The electrical parameters for the MSIO_3–MSIO_7 are as follows:
Table 274 MSIO_3 – MSIO_7 electrical specifications
VIH Input high voltage VBATL x 0.7 VBATL V
VIL Input low voltage VSS VBATL x 0.3 V
VOH Output high voltage, 2.5 mA, VDDIO ≥ 3 V VBATL - 0.4 VBATL V
VOL Output low voltage, 2.5 mA, VDDIO ≥ 3 V VSS VSS + 0.4 V
IOL Current at VSS + 0.4 V, output set low, VDDIO ≥ 3 V 2 12 mA
IOH Current at VDDIO - 0.4 V, output set high, VDDIO ≥ 3 V 2 12 mA
tRF,9pF Rise time, 10%–90%, 9 pF load 1.6 13 ns
tRF,9pF Fall time, 10%–90%, 9 pF load 1.9 14.2 ns
RPU Pull-up resistance 12 20 32
RPD Pull-down resistance 12 20 32
CPAD Pad capacitance 5 pF
The electrical parameters for the MSIO_8–MSIO_9 are as follows:
Table 275 MSIO_8 – MSIO_9 electrical specifications
VIH Input high voltage VDDIO x 0.7 VDDIO V
VIL Input low voltage VSS VDDIO x 0.3 V
VOH Output high voltage, 4 mA, VDDIO ≥ 3 V VDDIO - 0.4 VDDIO V
VOL Output low voltage, 4 mA, VDDIO ≥ 3 V VSS VSS + 0.4 V
IOL Current at VSS+0.4 V, output set low, VDDIO ≥ 3 V 2 12 mA
IOH Current at VDDIO-0.4 V, output set high, VDDIO ≥ 3 V 2 12 mA
