Advanced Encryption Standard (AES)
Advanced Encryption Standard (AES), also known as Rijndael encryption method in cryptography, is a block encryption standard adopted by the U.S. federal government. This standard is used to replace the Data Encryption Standard (DES). The block length of AES is fixed at 128 bits. The basic processes of AES include SubBytes, ShiftRows, MixColumns, and AddRoundKey.
- Compliance with NIST “Advanced Encryption Standard (AES), FIPS Publication 197” from November 2001
- Supports 128-bit key.
- Supports encryption mode and decryption mode.
- Supports Electronic Codebook (ECB) mode and Cipher Block chaining (CBC) mode.
- Supports interrupt mode.
Standard
| Document Code | Name of Standard |
FIPS PUB 197 |
Advanced Encryption Standard (AES) |
Module Overview
The AES co-processor encrypts or decrypts data, using an algorithm and implementation fully compliant with the AES defined in Federal Information Processing Standards (FIPS) publication 197. In the SoC, the AES module is a crypto engine inside the Bluetooth LE Core, so that its operation should comply with the rules of the Bluetooth LE Core.
Electronic Codebook (ECB) and Cipher Block Chaining (CBC) are supported for key size of 128 bits. Due to the feature of block cipher of AES, the data to be encrypted or decrypted requires an integer multiple of 16 bytes. AES calculation process needs to be performed in interrupt mode.
It should be noticed that the ECB mode and the CBC mode are mutually exclusive so that the two modes cannot be used at the same time. When an Encrypted Link Layer event has to be processed, it is possible that Event Controller /Packet Controller may require AES to respond to the event while the calculation is in process. In this case, the current encryption/decryption process will stop if the processing of the event has a higher priority.
Usage
AES-128 can be used by software which stores the block to cipher/decipher at AESPTR address in the exchange memory. The block size to cipher/decipher is always considered equal to 16 bytes.
The AES can be switched into ECB or CBC mode by configuring AESCNTL.AES_ALG_MODE.
The 128-bit symmetric key needs to be set in the AESKEYx_x registers. If the AES works in CBC mode, the initialization vector needs to be set in the CBC_AES_IV_x registers. AESCNTL.CBC_AES_FIRST_BLOCK_IND is used to configure whether the block is the first block in CBC mode.
Once the settings complete, the AES can be started with the cipher/decipher mode set in AESCNTL.AES_MODE, and a 1 written in AESCNTL.AES_START.
Upon normal termination, the software will receive a ble_crypt_irq interrupt. The ciphered/deciphered data can be found at AESPTR+16 address. When the encryption/decryption process is till normal termination, the AES will automatically reset the AESCNTL.AES_START bit.
AESCNTL
Name: AES Controller Register
Description: This register acts as a controller register for AES.
Base Address: 0x400E0000
Offset: 0xB0
Reset Value: 0x00000000
31:2 |
Reserved bits |
3 |
CBC_AES_FIRST_BLOCK_IND |
Indicate AES-CBC mode first block; first block is set to 1, and others set to 0. |
2 |
AES_ALG_MODE |
AES algorithm mode Value:
1 |
AES_MODE |
AES operation mode Value:
0 |
AES_START |
Writing a 1 starts AES-128 ciphering/deciphering process. This bit is reset once the process is finished. |
AESKEY31_0
Name: AES Key 31_0 Register
Description: This register is a 32-bit buffer for the key[31:0] for AES.
Offset: 0xB4
31:0 |
AESKEY31_0 |
AES encryption 128-bit key. Bit 31 down to 0 |
AESKEY63_32
Name: AES Key 63_32 Register
Description: This register is a 32-bit buffer for the key[63:32] for AES.
Offset: 0xB8
31:0 |
AESKEY63_32 |
AES encryption 128-bit key. Bit 63 down to 32 |
AESKEY95_64
Name: AES Key 95_64 Register
Description: This register is a 32-bit buffer for the key[95:64] for AES.
Offset: 0xBC
31:0 |
AESKEY95_64 |
AES encryption 128-bit key. Bit 95 down to 64 |
AESKEY127_96
Name: AES Key 127_96 Register
Description: This register is a 32-bit buffer for the key[127:96] for AES.
Offset: 0xC0
31:0 |
AESKEY127_96 |
AES encryption 128-bit key. Bit 127 down to 96 |
AESPTR
Name: AES Pointer Register
Description: This register acts as a memory offset pointer register for AES.
Offset: 0xC4
31:14 |
Reserved bits |
13:0 |
AESPTR |
Pointer to the memory zone where the block to cipher/decipher using AES-128 is stored. |
CBC_AES_IV_0
Name: AES CBC IV 0 Register
Description: This register is a 32-bit buffer for the Initialization Vector (IV) [31:0] for AES CBC mode.
Offset: 0x210
31:0 |
CBC_AES_IV_0 |
AES CBC mode IV. Bit 31 down to bit 0 |
CBC_AES_IV_1
Name: AES CBC IV 1 Register
Description: This register is a 32-bit buffer for the Initialization Vector (IV) [63:32] for AES CBC mode.
Offset: 0x214
31:0 |
CBC_AES_IV_1 |
AES CBC mode IV. Bit 63 down to bit 32 |
CBC_AES_IV_2
Name: AES CBC IV 2 Register
Description: This register is a 32-bit buffer for the Initialization Vector(IV) [95:64] for AES CBC mode.
Offset: 0x218
31:0 |
CBC_AES_IV_2 |
AES CBC mode IV. Bit 95 down to bit 64 |
CBC_AES_IV_3
Name: AES CBC IV 3 Register
Description: This register is a 32-bit buffer for the Initialization Vector (IV) [127:96] for AES CBC mode.
Offset: 0x21C
31:0 |
CBC_AES_IV_3 |
AES CBC mode IV. Bit 127 down to bit 96 |
