文档中心 > GR5405 Datasheet/ Peripherals/ Security Interfaces/ True Random Number Generator (TRNG) Copy URL
The True Random Number Generator (TRNG) generates random numbers used in encryption and decryption. Post-processing is added to the TRNG module to ensure the quality of random number and amend the bias of TRNG.
The goal of true random data generated by TRNG is to pass the NIST SP 800-22 standard test suite.
  • Supports true and pseudo random number generation.
  • Random number quality can pass the NIST SP 800-22 standard test suite.
  • Supports multiple post-processing mechanisms, including bit-skipping, bit-counting, and von-Neumann.
  • Supports multiple combinations of random numbers.
  • Supports both interrupt and query modes.
Standard
Table 464 TRNG module standard
NIST SP 800-22
A Statistical Test Suite for Random and Pseudorandom Number Generators for Cryptographic Applications
Module Overview
The location of RNG module in the system is shown in figure below. Digital_FRO is the digital true random number generator, based on the FRO scheme. Post-process logic is added in RNG module to ensure the quality of random number and amend the bias of true random number generator (TRNG).
Figure 73 RNG module in the system
Figure 74 RNG post-process module
The TRNG module supports pseudo random number generation and true random number generation. Pseudo random numbers are generated by a linear feedback shift register (LFSR). True random numbers are generated by using a feedforward ring oscillator(FRO) as the entropy source.
The work mode of the LFSR can be configured as 128 or 59 polynomial which is implemented by Galois structure. The LFSR seed can be configured from the FRO or in parallel be written in user-configured seed by using the USER_SEED register.
The TRNG module supports multiple output modes, including LFSR direct output, LFSR XOR TRNG, LFSR and TRNG cyclic sampling, LFSR and TRNG cyclic sampling and parity generation, and the FRO direct output. Since only the FRO is used as the true random number source, the results of LFSR direct output, LFSR XOR TRNG, as well as LFSR and TRNG cyclic sampling will be the same when the LFSR seed is configured by users.
The TRNG module supports multiple post-processing mechanisms, including bit-skipping, bit-counting and Von-Neumann corrector.
  • bit-skipping: Select 1-bit for every 5-bit as the final output.
  • bit-counting: XOR every 5-bit into 1-bit as the final output.
  • Von-Neumann corrector: Judge two consecutive bits and output 1-bit with the rules that skipping if the 2-bit is 00B or 11B, output as 0B if the 2-bit is 01B, output as 1B if the 2-bit is 10B.
Usage
The CONFIG register can be used to configure relevant parameters for the TRNG module. CONFIG.OUT_MODE can be used to configure the output mode. CONFIG.POST_MODE can be used to configure the post-process mode. CONFIG. LFSR_MODE can be used to configure the 59-bit or 128-bit LFSR operation mode. CONFIG.LFSR_SEED_SEL can be used to configure the LFSR seed source. CONFIG.IRQ_EN can set the TRNG module into interrupt mode.
The FRO acts as the entropy source so that CONFIG.FRO_EN should be enabled in order to generate true random numbers. It can directly output or be set as the LFSR seed.
The TRNG module also supports user-defined LFSR seeds. In the 59-bit LFSR operation mode, the USER_SEED register needs to be written 4 consecutive times to configure the seed. In the 128-bit LFSR operation mode, the USER_SEED register needs to be written 8 consecutive times to configure the seed. If the output mode is set to LFSR directly output, the random number will be pseudo random number.
he TRNG module can be started by using the CTRL register. The STAT register is used to indicate the current status of the TRNG module. The generated random number can be read out from the DATA register.
CTRL
  • Name: TRNG Controller Register
  • Description: This register acts as a global enable/disable for TRNG.
  • Base Address: 0x40019000
  • Offset: 0x0
Table 465 TRNG Controller Register
Bits Field Name Access Reset Value Description
31:1
RUN_EN
TRNG working enable signal, valid at HIGH
  • 0x0: Disable TRNG module.
  • 0x1: TRNG starts working to execute an operation of reading random number.
STAT
  • Name: TRNG Status Register
  • Description: This is a read-only register used to indicate the current status of TRNG.
  • Offset: 0x4
Table 466 TRNG Status Register
31:1
READY
WC
TRNG status flag bit, queried by CPU.
  • 0x0: TRNG output data is not valid.
  • 0x1: TRNG output data is valid.
This register is automatically cleared by hardware after READY is set HIGH.
This register is automatically cleared by hardware after data reads.
DATA
  • Name: TRNG Data Register
  • Description: This register is a 32-bit read buffer for the random numbers.
  • Offset: 0x8
Table 467 TRNG Data Register
31:0
VALUE
TRNG data.
LLR_STATUS
  • Name: TRNG Long Run Status Register
  • Description: This is a read-only register used to indicate the current status of long run mode.
  • Offset: 0x10
Table 468 TRNG Long Run Status Register
31:9
8:1
CNT
Counts of TRNG long run test.
This value is incremented by 1 for every long run detected by TRNG.
After TRNG is disabled or reset, the register is cleared.
LFLAG
Flag of TRNG long run test
  • 0x0: Long run never occurs.
  • 0x1: Long run was occurred in random number sequence
After TRNG is disabled or reset, this register is cleared.
CONFIG
  • Name: TRNG Configuration Register
  • Description: This register acts as a configuration for TRNG.
  • Offset: 0x14
  • Reset Value: 0x0000B246
Table 469 TRNG Configuration Register
31:16
15
FRO_EN
0x1
Ring oscillator TRNG enable signal
  • 0x0: Disabled
  • 0x1: Enabled
14
LFS_EN
Low frequency sampling TRNG enable signal
  • 0x0: Disabled
  • 0x1: Enabled
Reserved.
13
IRQ_EN
0x1
TRNG hardware interrupt enable bit.
Active high.
12:10
LFSR_SEED_SEL
0x4
LFSR seed configuration mode. Select a source for LFSR seed.
  • 0x0: LFSR seed is from the switching current s0
  • 0x1: LFSR seed is from the switching current s1
  • 0x2: LFSR seed is from the switching current s2
  • 0x3: LFSR seed is from the switching current s3
  • 0x4: LFSR seed is from the oscillator s0
  • 0x5: LFSR seed is from the Low Frequency Sampling s0
  • 0x6: LFSR seed is configured by users
  • 0x7: Random numbers do not use LFSR and completely use true random mode.
Value is limited to 0x4 or 0x6 in the device.
9
LFSR_MODE
0x1
LFSR configuration mode:
  • 0x0: 59-bit LFSR
  • 0x1: 128-bit LFSR
8:7
POST_MODE
TRNG post-process configuration
  • 0x0: No post-process
  • 0x1: Bit skipping
  • 0x2: Bit counting
  • 0x3: Von-Neumann
6:4
LFSR_XOR_SEL
0x4
In Output mode 8, select TRNG with LFSR XOR
0x4: LFSR Ring Oscillator s0
means XOR.
Value is limited to 0x4 in the device.
3:0
OUT_MODE
0x6
Select a TRNG output mode
  • 0x4: Digital TRNG direct output, ring oscillator s0
  • 0x6: LFSR and TRNG cyclic sampling and parity generation
  • 0x7: LFSR and TRNG cyclic sampling
  • 0x8: LFSR TRNG
  • 0x9: LFSR direct output
means XOR.
Value is limited to 0x4, 0x6, 0x7, 0x8, or 0x9 in the device.
STSCON
  • Name: TRNG Source Configuration Register
  • Description: This register acts as a configuration for source of TRNG.
  • Offset: 0x18
  • Reset Value: 0x00007864
Table 470 TRNG Source Configuration Register
31:15
14:11
FRO_CHAIN
0xF
Selection of Chain4–Chain7 for FRO
  • 0x0: Select long ring.
  • 0x1: Select short ring.
10:8
7:0
TRDY_TIME
0x64
The waiting time during which the TRNG input reaches stable.
Default value is 100 time cycles.
FROCFG
  • Name: TRNG FRO Configuration Register
  • Description: This register acts as a configuration for FRO.
  • Offset: 0x1C
  • Reset Value: 0x0000FFFF
Table 471 TRNG FRO Configuration Register
31:16
15:8
TEST_IN
0xFF
Test input signal of each chain for FRO.
The default value is 1.
7:0
CHAIN_EN
0xFF
Enable signal of each chain in ring oscillator module.
It is valid when FROEN is high.
USER_SEED
  • Name: TRNG User Seed Register
  • Description: This register acts as a user seed value for TRNG.
  • Offset: 0x20
Table 472 TRNG User Seed Register
Bits Name Access Reset Value Description
31:16
15:0
USER_SEED
W
RNG seed configured by users.
Write four times to user_seed[58:0] to configure a 59-bit random number.
Write eight times to user_seed[127:0] to configure a 128-bit random number.
LLRCON
  • Name: TRNG Long Run Configuration Register
  • Description: This register acts as a configuration for long run mode.
  • Offset: 0x24
  • Reset Value: 0x00000035
Table 473 TRNG Long Run Configuration Register
31:6
5:1
TEST_LIMIT
0x1A
Threshold configuration of RNG long run test. The run which lasts in a longer or an equal period than this value will be detected.
Default value is 26 and the maximum value is 31.
TEST_EN
0x1
RNG long run test enable bit
  • 0x0: Disabled
  • 0x1: Enabled
