Features
- Bluetooth Low Energy (LE) 5.1 transceiver integrates Controller and Host layers
- Supported data rates: 1 Mbps, 2 Mbps, Long Range 500 kbps, Long Range 125 kbps
- TX power: -20 dBm to +7 dBm
- -97 dBm sensitivity (in 1 Mbps mode)
- -93 dBm sensitivity (in 2 Mbps mode)
- -99.5 dBm sensitivity (in Long Range 500 kbps mode)
- -103 dBm sensitivity (in Long Range 125 kbps mode)
- TX current: 3.05 mA @ 0 dBm, 1 Mbps
- RX current: 3.9 mA @ 1 Mbps
- ARM® Cortex®-M4F 32-bit micro-processor with floating point support
- Maximum frequency: 64 MHz
- Power consumption: 30 µA/MHz
- Memory
- 256 KB RAM with retention (four 8 KB banks and seven 32 KB banks) for GR5515 series SoCs, and 128 KB RAM with retention (four 8 KB banks and three 32 KB banks) for the GR5513 SoC.
- 1 MB Flash for GR5515 series SoCs (The GR5515I0ND SoC uses external QSPI Flash with various model options.) and 512 KB Flash for the GR5513 SoC.
- Power management
- On-chip DC-DC Converter
- Supply voltage: 1.7 V to 3.8 V (The supply voltage of GR5515I0ND SoC is equal to the working voltage of external SPI Flash.)
- I/O voltage: 1.8 V to 3.3 V (Typical) (On GR5515I0ND, VDDIO0 is bonded to I/O LDO internally which is fixed in bypass mode, so VDDIO0 and VIO_LDO_OUT follow VBATL voltage.)
- OFF mode: 0.15 µA (Typical); nothing is on except VBAT, chip in reset mode
- Ultra deep sleep mode: 0.65 µA (Typical); IO LDO off, no memory retention. Wake up by an external GPIO or an internal Timer.
- Sleep mode: 1.3 µA (Typical); Bluetooth LE link alive, I/O LDO off, supporting AON_RTC, AON GPIO and Bluetooth LE Event, memory retention and wake up by an external GPIO or an internal Timer.
- Peripherals
- 2 x QSPI interfaces, up to 32 MHz
- 2 x SPI interfaces (1 SPI Master Interface with 2 slave CS pins + 1 SPI Slave Interface), up to 32 MHz
- 2 x I2C interfaces at 100 kHz, 400 kHz, 1 MHz, 2 MHz
- 2 x I2S interfaces (1 I2S Master Interface + 1 I2S Slave Interface)
- 2 x UART interfaces, one with DMA channel.
- 13-bit ADC, up to 1 Msps, 8 channels (5 external test channels and 3 internal signal channels), supporting both single-ended and differential inputs
- ISO 7816 interface
- 6-channel PWM
- Built-in temperature and voltage sensors
- 4 x Hardware timers
- 1 x AON hardware timer
- 2 x Watchdog timers(1 System Watchdog Timer and 1 Always-on watchdog timer)
- Calendar timer
- Wake-up comparator
- Up to 39 multiplexed GPIO pins
- Security
- Complete secure computing engine:
- AES 128-bit/192-bit/256-bit symmetric encryption (ECB, CBC)
- Keyed Hash Message Authentication Code (HMAC)
- PKC
- TRNG
- Comprehensive security operation mechanism:
- Secure boot
- Encrypted firmware runs directly from Flash
- Packages
- QFN56: 7 mm * 7 mm
- BGA68: 5.3 mm * 5.3 mm
- BGA55: 3.5 mm * 3.5 mm
- QFN40: 5 mm * 5 mm
- Operating temperature range: -40°C to +85°C
