文档中心 > GR551x Datasheet/ Peripherals / PWM/ Registers Copy URL
MODE
  • Name: Mode Register
  • Description: This register sets PWM operation mode
  • Base Address: 0xA000C900 + x*0x300
  • Offset: 0x0
x* is used to identify which PWM Module is x0, or x1.
表 288 Mode Register
31:6
5
PD_C_EN
PWMC positive-drive mode enable.
  • 0x0: negative-drive mode
  • 0x1: positive-drive mode
4
PD_B_EN
PWMB positive-drive mode enable.
3
PD_A_EN
PWMA positive-drive mode enable.
2
BREATH_EN
Breath mode enable.
  • 0x0: flicker mode
  • 0x1: breath mode
PAUSE
PWM pause signal.
  • 0x0: Ongoing
  • 0x1: Pause
EN
Enable PWM.
  • 0x0: Disable
  • 0x1: Enable
UPDATE
  • Name: Update Register
  • Description: Synchronous update enable register
  • Offset: 0x4
表 289 Update Register
30x1:19
18
UPDATE_SYNC_SAQCTRL
Separate update enable of AQCTRL
  • 0x0: Disable
  • 0x1: Enable
17
UPDATE_SYNC_SHOLD
Separate update enable of HOLD
  • 0x0: Disable
  • 0x1: Enable
16
UPDATE_SYNC_SBRPRD
Separate update enable of BRPRD
  • 0x0: Disable
  • 0x1: Enable
15
UPDATE_SYNC_SPAUSE
Separate update enable of PAUSE
  • 0x0: Disable
  • 0x1: Enable
14
UPDATE_SYNC_SCMPC1
Separate update enable of CMPC1
  • 0x0: Disable
  • 0x1: Enable
13
UPDATE_SYNC_SCMPC0
Separate update enable of CMPC0
  • 0x0: Disable
  • 0x1: Enable
12
UPDATE_SYNC_SCMPB1
Separate update enable of CMPB1
  • 0x0: Disable
  • 0x1: Enable
11
UPDATE_SYNC_SCMPB0
Separate update enable of CMPB0
  • 0x0: Disable
  • 0x1: Enable
10
UPDATE_SYNC_SCMPA1
Separate update enable of CMPA1
  • 0x0: Disable
  • 0x1: Enable
9
UPDATE_SYNC_SCMPA0
Separate update enable of CMPA0
  • 0x0: Disable
  • 0x1: Enable
8
UPDATE_SYNC_SPRD
Separate update enable of PRD
  • 0x0: Disable
  • 0x1: Enable
7:2
UPDATE_SYNC_AE
  • 0x0: Disable
  • 0x1: Enable
UPDATE_SYNC_AG
Synchronous update ongoing
  • 0x0: Not ongoing
  • 0x1: Ongoing
PRD
  • Name: Period Register
  • Description: This register is used to set the PWM cycle
  • Offset: 0x8
表 290 Period Register
31:0
PRD
The period of PWM output, PRD=fCLK/fPWM
CMPA0
  • Name: Compare A0 Register
  • Description: Compare register 0 of channel A
  • Offset: 0xC
表 291 Compare A0 Register
31:0
CMPA0
PWMA duty control register0
CMPA1
  • Name: Compare A1 Register
  • Description: Compare register 1 of channel A
  • Offset: 0x10
表 292 Compare A1 Register
31:0
CMPA1
PWMA duty control register1
CMPB0
  • Name: Compare B0 Register
  • Description: Compare register 0 of channel B
  • Offset: 0x14
表 293 Compare B0 Register
31:0
CMPB0
PWMB duty control register0
CMPB1
  • Name: Compare B1 Register
  • Description: Compare register 1 of channel B
  • Offset: 0x18
表 294 Compare B1 Register
31:0
CMPB1
PWMB duty control register1
CMPC0
  • Name: Compare C0 Register
  • Description: Compare register 0 of channel C
  • Offset: 0x1C
表 295 Compare C0 Register
31:0
CMPC0
PWMC duty control register0
CMPC1
  • Name: Compare C1 Register
  • Description: Compare register 1 of channel C
  • Offset: 0x20
表 296 Compare C1 Register
31:0
CMPC1
PWMC duty control register1
AQCTRL
  • Name: Action Qualifier Control Register
  • Description: This register is used to set actions when counter reaches the compare value.
  • Offset: 0x24
表 297 Action Qualifier Control Register
31:12
11:10
AQ_CTRL_C1
Action of event CNT_CMPC1 control register;
  • 0x0: do nothing
  • 0x1: clear
  • 0x2: set
  • 0x3: toggle
9:8
AQ_CTRL_C0
Action of event CNT_CMPC0 control register;
  • 0x0: do nothing
  • 0x1: clear
  • 0x2: set
  • 0x3: toggle
7:6
AQ_CTRL_B1
Action of event CNT_CMPB1 control register;
  • 0x0: do nothing
  • 0x1: clear
  • 0x2: set
  • 0x3: toggle
5:4
AQ_CTRL_B0
Action of event CNT_CMPB0 control register;
  • 0x0: do nothing
  • 0x1: clear
  • 0x2: set
  • 0x3: toggle
3:2
AQ_CTRL_A1
Action of event CNT_CMPA1 control register;
  • 0x0: do nothing
  • 0x1: clear
  • 0x2: set
  • 0x3: toggle
1:0
AQ_CTRL_A0
Action of event CNT_CMPA0 control register;
  • 0x0: do nothing
  • 0x1: clear
  • 0x2: set
  • 0x3: toggle
BRPRD
  • Name: Breath Period Register
  • Description: This register configures the period of breath mode.
  • Offset: 0x28
表 298 Breath Period Register
31:0
BRPRD
Breath period register, i.e. the required time (number of clock) that the duty changes from 0% to 100% in breath mode.
HOLD
  • Name: Hold Register
  • Description: This register configures the hold period on breath mode.
  • Offset: 0x2C
表 299 Hold Register
31:24
23:0
HOLD
Breath hold control register. The value should be the required number of clock in breath hold state.
