XIP_Cache Registers
CACHE_CTRL0
  • Name: XQSPI cache Control 0 Register
  • Description: This register performs the main control of XIP cache.
  • Base Address: 0xA000D000
  • Offset: 0x00
  • Reset Value: 0x00000011
表 199 Control 0 Register
31:5
4
HIT_MISS_CLR
0x1
Clear Hit/Miss Counters
  • 0x0: Hit/Miss Counters in Normal Mode
  • 0x1: Hit/Miss Counters in Clear Mode
3
FIFO_CLR
Clear LFU FIFO
  • 0x0: FIFO in Normal Mode
  • 0x1: FIFO in Clear Mode
2
Reserved
TAG_FLUSH_EN
Enable Tag Memory Flush
Tag memory will get flushed unless tag_ret is enabled (Tag_ret signal lives in CPU register space).
  • 0x0: Tag memory Flush is disabled.
  • 0x1: Tag memory Flush is enabled.
CACHE_EN
0x1
  • 0x0: Cache enabled.
  • 0x1: Cache disabled.
CACHE_CRTL1
  • Name: XQSPI cache Control 1 Register
  • Description: This register is used to configure Bus Write/Read.
  • Offset: 0x04
  • Reset Value: 0x00000110
表 200 Control 1 Register
31:12
11
BUS_MUX_EN
  • 0x0: enable
  • 0x1: disable
10:8
BUS_MUX_SRC
0x1
Select 1 of 8 debug-bus configurations.
Debug-bus is 8-bit bus.
7:4
BIAS_TRIM
0x1
Bias TRIM signal
3:2
RW_MARGIN_CTRL
Read and write margin control
WR_MARGIN
Write margin
RD_MARGIN
Read margin
CACHE_HIT_COUNT
  • Name: XQSPI cache Hits Counter Register
  • Description: Cache Hits counter
  • Offset: 0x08
表 201 Hits Counter Register
31:0
HIT_COUNT
Cache hit counter
CACHE_MISS_COUNT
  • Name: XQSPI cache Miss Counter Register
  • Description: Cache Miss counter
  • Offset: 0x0C
表 202 Miss Counter Register
31:0
MISS_COUNT
Cache miss counter
CACHE_STAT
  • Name: XQSPI cache Status Register
  • Description: This is a read-only register used to indicate the current tag flush status.
  • Offset: 0x10
表 203 Status Register
31:1
STAT
Tag_flush_busy status.
  • 0x0: Idle
  • 0x1: Busy
