文档中心 > GR551x Datasheet/ Peripherals / I2C/ Registers Copy URL
CTRL
  • Name: I2C Control Register
  • Description: This register can be written only when the I2C is disabled, which corresponds to the EN[0] register being set to 0. Writes at other times have no effect.
  • Base Address: 0xA000C300 + x*0x100
  • Offset: 0x00
  • Reset Value: 0x0000007F
表 77 I2C Control Register
31:11 RSVD R Reserved bits
10 STOP_DET_M_ACTIVE RW 0x0
In Master mode
  • 0x1: issues the STOP_DET interrupt only when master is active.
  • 0x0: issues the STOP_DET irrespective of whether master is active or not.
9 RSVD R
8 TX_EMPTY_CTRL RW 0x0
This bit controls the generation of the TX_EMPTY interrupt, as described in the RAW_INT_STAT register.
  • 0x0 (DISABLED): Default behavior of TX_EMPTY interrupt
  • 0x1 (ENABLED): Controlled generation of TX_EMPTY interrupt
7 STOP_DET_INT RW 0x0
In slave mode
  • 0x0: issues the STOP_DET irrespective of whether it's addressed or not
When it is addressed
  • 0x0 (DISABLED): Slave issues STOP_DET interrupt always.
  • 0x1 (ENABLED): Slave issues STOP_DET interrupt only if addressed.
During a general call address, the slave does not issue the STOP_DET interrupt if STOP_DET_INT = 1, even if the slave responds to the general call address by generating ACK. The STOP_DET interrupt is generated only when the transmitted address matches the slave address (S_ADDR).
6 S_DIS RW 0x1
This bit controls whether I2C has its slave disabled. By default, the slave is always disabled (in reset state as well). If you need to enable it after reset, set this bit to 0.
If this bit is set (slave is disabled), I2C functions only as a master and does not perform any action that requires a slave.
Software should ensure that if this bit is written with 0, then bit 0 should also be written with 0.
  • 0x0 (S_EN): Slave mode is enabled.
  • 0x1 (S_DIS): Slave mode is disabled.
5 RESTART_EN RW 0x1
Determine whether RESTART conditions may be sent when I2C acting as a master. Some older slaves do not support handling RESTART conditions; however, RESTART conditions are used in several I2C operations. When RESTART is disabled, the master is prohibited from performing the following functions:
  • Sending a START BYTE
  • Performing any high-speed mode operation
  • Performing direction changes in combined format mode
  • Performing a read operation with a 10-bit address
By replacing RESTART condition followed by a STOP and a subsequent START condition, split operations are broken down into multiple I2C transfers. If the above operations are performed, it will result in setting bit 6 (TX_ABORT) of the RAW_INT_STAT register.
  • 0x0 (DISABLED): Master restart disabled
  • 0x1 (ENABLED): Master restart enabled
4 ADDR_BIT_M RW 0x1
This bit controls whether the I2C starts its transfers in 7-bit or 10-bit addressing mode when I2C acting as a master.
  • 0x0 (ADDR_7BITS): Master 7-bit addressing mode
  • 0x1 (ADDR_10BITS): Master 10-bit addressing mode
3 ADDR_BIT_S RW 0x1
When acting as a slave, this bit controls whether the I2C responds to 7- or 10-bit addresses.
  • 0x0 (ADDR_7BITS): Slave 7-Bit addressing
  • 0x1 (ADDR_10BITS): Slave 10-Bit addressing
2:1 SPEED RW 0x3
These bits control at which speed the I2C operates; its setting is relevant only if one is operating the I2C in master mode. Hardware protects against illegal values being programmed by software. These bits must be programmed appropriately for slave mode also, as it is used to capture correct value of spike filter as per the speed mode.
This register should be programmed only with a value in the range of 1 to 3.
  • 0x1: standard mode (100 kbit/s)
  • 0x2: fast mode ( ≤400 kbit/s) or fast plus mode (≤1000 kbit/s)
  • 0x3: high-speed mode (2 Mbit/s)
  • 0x1 (STANDARD): Standard Speed mode of operation
  • 0x2 (FAST): Fast or Fast Plus mode of operation
  • 0x3 (HIGH): High-speed mode of operation
0 M_MODE RW 0x1
This bit controls whether the I2C master is enabled.
Software should ensure that if this bit is written with '1', then bit 6 should also be written with '1'.
  • 0x0 (DISABLED): Master mode is disabled
  • 0x1 (ENABLED): Master mode is enabled
TARGET_ADDR
  • Name: I2C Target Address Register
  • Description: This register can be written to only when EN[0] is set to 0. You cannot change the TARGET_ADDR address dynamically.
  • If the software or application is aware that the I2C is not using the TARGET_ADDR address for the pending commands in the TX FIFO, then it is possible to update the TARGET_ADDR address even while the TX FIFO has entries (STAT[2]= 0).
  • It is not necessary to perform any write to this register if the I2C is enabled as an I2C slave only.
  • Offset: 0x04
  • Reset Value: 0x00000055
表 78 I2C Target Address Register
31:12 RSVD R Reserved bits
11 SPECIAL RW 0x0
This bit indicates whether software performs a Device-ID or General Call or START BYTE command.
  • 0x0 (DISABLED): Disable programming of GENERAL_CALL or START_BYTE transmission
  • 0x1 (ENABLED): Enable programming of GENERAL_CALL or START_BYTE transmission
10 TX_CTRL RW 0x0
If bit 11 (SPECIAL) is set to 1, then this bit indicates whether a General Call or START BYTE command is to be performed by the I2C.
  • 0x0 (GENERAL_CALL): GENERAL_CALL byte transmission
  • 0x1 (START_BYTE): START BYTE transmission
9:0 TARGET RW 0x55
This is the target address for any master transaction. When transmitting a General Call, these bits are ignored. To generate a START BYTE, the CPU needs to write only once into these bits.
If the TARGET_ADDR and S_ADDR are the same, loopback exists but the FIFOs are shared between master and slave, so full loopback is not feasible. Only one direction loopback mode is supported (simplex), not duplex. A master cannot transmit to itself; it can transmit to only a slave.
S_ADDR
  • Name: I2C Slave Address Register
  • Description: I2C Slave Address Register
  • Base Address:0xA000C300 + x*0x100
  • Offset: 0x08
表 79 I2C Slave Address Register
31:10 RSVD R Reserved bits
9:0 S_ADDR RW 0x55
The S_ADDR holds the slave address when the I2C is operating as a slave. For 7-bit addressing, only S_ADDR[6:0] is used.
This register can be written only when the I2C interface is disabled, which corresponds to the EN[0] register being set to 0. Writes at other times have no effect.
The default values cannot be any of the reserved address locations: 0x00 to 0x07, or 0x78 to 0x7F. The correct operation of the device is not guaranteed if you program the S_ADDR or TARGET_ADDR to a reserved value. Refer to 表 76 for a complete list of these reserved values.
M_HS_ADDR
  • Name: I2C High-Speed Master Mode Code Address Register
  • Description: I2C High-Speed Master Mode Code Address Register
  • Offset: 0x0C
  • Reset Value: 0x00000001
表 80 I2C High-Speed Master Mode Code Address Register
31:3 RSVD R Reserved bits
2:0 M_HS_ADDR RW 0x1
This bit field holds the value of the I2C HS mode master code. HS-mode master codes are reserved 8-bit codes (00001xxx) that are not used for slave addressing or other purposes. Each master has its unique master code; up to eight high-speed mode masters can be present on the same I2C bus system. Valid values are from 0 to 7.
DATA_CMD
  • Name: I2C RX/TX Data Buffer and Command Register
  • Description: This is the register the CPU writes to when filling the TX FIFO and the CPU reads from when retrieving bytes from RX FIFO.
In order to continue acknowledging reads, a read command should be written for every byte that is to be received; otherwise the I2C will stop acknowledging.
  • Offset: 0x10
表 81 I2C RX/TX Data Buffer and Command Register
31:9 RSVD R Reserved bits
8 CMD W 0x0
This bit controls whether a read or a write is performed. This bit does not control the direction when the I2C acts as a slave. It controls only the direction when it acts as a master.
  • 0x0 (WRITE): Master Write command
  • 0x1 (READ): Master Read command
7:0 DATA RW 0x0 This register contains the data to be transmitted or received on the I2C bus. If you are writing to this register and want to perform a read, bits 7:0 (DATA) are ignored by the I2C. However, when you read this register, these bits return the value of data received on the I2C interface.
SS_CLK_HCOUNT
  • Name: Standard Speed I2C Clock SCL High Count Register
  • Description: Standard Speed I2C Clock SCL High Count Register
  • Offset:0x14
  • Reset Value:0x00000190
表 82 Standard Speed I2C Clock SCL High Count Register
31:16 RSVD R Reserved bits
15:0 COUNT RW 0x0190
This register must be set before any I2C bus transaction can take place to ensure proper I/O timing.
This register can be written only when the I2C interface is disabled which corresponds to the EN[0] register being set to 0. Writes at other times have no effect.
The minimum valid value is 6; hardware prevents values less than this being written, and if attempted, the value will be set to 6.
This register must not be programmed to a value higher than 65525, because I2C uses a 16-bit counter to flag an I2C bus idle condition when this counter reaches a value of COUNT + 10.
SS_CLK_LCOUNT
  • Name: Standard Speed I2C Clock SCL Low Count Register
  • Description: Standard Speed I2C Clock SCL Low Count Register
  • Offset:0x18
  • Reset Value: 0x000001D6
表 83 Standard Speed I2C Clock SCL Low Count Register
15:0 COUNT RW 0x01D6
The minimum valid value is 8; hardware prevents values less than this being written, and if attempted, the value will be set to 8.
FS_CLK_HCOUNT
  • Name: Fast Mode or Fast Mode Plus I2C Clock SCL High Count Register
  • Description:Fast Mode or Fast Mode Plus I2C Clock SCL High Count Register
  • Offset: 0x1C
  • Reset Value:0x0000003C
表 84 Fast Mode or Fast Mode Plus I2C Clock SCL High Count Register
15:0 COUNT RW 0x003C
FS_CLK_LCOUNT
  • Name: Fast Mode or Fast Mode Plus I2C Clock SCL Low Count Register
  • Description:Fast Mode or Fast Mode Plus I2C Clock SCL Low Count Register
  • Offset: 0x20
  • Reset Value:0x00000082
表 85 Fast Mode or Fast Mode Plus I2C Clock SCL Low Count Register
15:0 COUNT RW 0x0082
HS_CLK_HCOUNT
  • Name: High Speed I2C Clock SCL High Count Register
  • Description: High Speed I2C Clock SCL High Count Register
  • Offset:0x24
  • Reset Value: 0x00000006
表 86 High Speed I2C Clock SCL High Count Register
15:0 COUNT RW 0x0006
The SCL High time depends on the loading of the bus. For 100 pF loading, the SCL High time is 60 ns; for 400 pF loading, the SCL High time is 120 ns.
HS_CLK_LCOUNT
  • Name: High Speed I2C Clock SCL Low Count Register
  • Description: High Speed I2C Clock SCL Low Count Register
  • Offset: 0x28
  • Reset Value: 0x00000010
表 87 High Speed I2C Clock SCL Low Count Register
15:0 COUNT RW 0x0010
The SCL low time depends on the loading of the bus. For 100pF loading, the SCL low time is 160 ns; For 400 pF loading, the SCL low time is 320 ns.
INT_STAT
  • Name: I2C Interrupt Status Register
  • Description: Each bit in this register has a corresponding mask bit in the INT_MASK register. These bits are cleared by reading the matching interrupt clear register. The unmasked raw versions of these bits are available in the RAW_INT_STAT register.
  • Offset: 0x2C
表 88 I2C Interrupt Status Register
31:14 RSVD R Reserved bits
13 RAW_M_HOLD R 0x0
See RAW_INT_STAT for a detailed description of RAW_M_HOLD bit.
  • 0x0 (INACTIVE): RAW_M_HOLD interrupt is inactive
  • 0x1 (ACTIVE): RAW_M_HOLD interrupt is active
12 RAW_RESTART_DET R 0x0
See RAW_INT_STAT for a detailed description of RAW_RESTART_DET bit.
  • 0x0 (INACTIVE): RAW_RESTART_DET interrupt is inactive
  • 0x1 (ACTIVE): RAW_RESTART_DET interrupt is active
11 RAW_GEN_CALL R 0x0
See RAW_INT_STAT for a detailed description of RAW_GEN_CALL bit.
  • 0x0 (INACTIVE): RAW_GEN_CALL interrupt is inactive
  • 0x1 (ACTIVE): RAW_GEN_CALL interrupt is active
10 RAW_START_DET R 0x0
See RAW_INT_STAT for a detailed description of RAW_START_DET bit.
  • 0x0 (INACTIVE): RAW_START_DET interrupt is inactive
  • 0x1 (ACTIVE): RAW_START_DET interrupt is active
9 RAW_STOP_DET R 0x0
See RAW_INT_STAT for a detailed description of RAW_STOP_DET bit.
  • 0x0 (INACTIVE): RAW_STOP_DET interrupt is inactive
  • 0x1 (ACTIVE): RAW_STOP_DET interrupt is active
8 RAW_ACTIVITY R 0x0
See RAW_INT_STAT for a detailed description of RAW_ACTIVITY bit.
  • 0x0 (INACTIVE): RAW_ACTIVITY interrupt is inactive
  • 0x1 (ACTIVE): RAW_ACTIVITY interrupt is active
7 RAW_RX_DONE R 0x0
See RAW_INT_STAT for a detailed description of RAW_RX_DONE bit.
  • 0x0 (INACTIVE): RAW_RX_DONE interrupt is inactive
  • 0x1 (ACTIVE): RAW_RX_DONE interrupt is active
6 RAW_TX_ABORT R 0x0
RAW_TX_ABORT bit.
  • 0x0 (INACTIVE): RAW_TX_ABORT interrupt is inactive
  • 0x1 (ACTIVE): RAW_TX_ABORT interrupt is active
5 RAW_RD_REQ R 0x0
See RAW_INT_STAT for a detailed description of RAW_RD_REQ bit.
  • 0x0 (INACTIVE): RAW_RD_REQ interrupt is inactive
  • 0x1 (ACTIVE): RAW_RD_REQ interrupt is active
4 RAW_TX_EMPTY R 0x0
See RAW_INT_STAT for a detailed description of RAW_TX_EMPTY bit.
  • 0x0 (INACTIVE): RAW_TX_EMPTY interrupt is inactive
  • 0x1 (ACTIVE): RAW_TX_EMPTY interrupt is active
3 RAW_TX_OVER R 0x0
See RAW_INT_STAT for a detailed description of RAW_TX_OVER bit.
  • 0x0 (INACTIVE): RAW_TX_OVER interrupt is inactive
  • 0x1 (ACTIVE): RAW_TX_OVER interrupt is active
2 RAW_RX_FULL R 0x0
See RAW_INT_STAT for a detailed description of RAW_RX_FULL bit.
  • 0x0 (INACTIVE): RAW_RX_FULL interrupt is inactive
  • 0x1 (ACTIVE): RAW_RX_FULL interrupt is active
1 RAW_RX_OVER R 0x0
See RAW_INT_STAT for a detailed description of RAW_RX_OVER bit.
  • 0x0 (INACTIVE): RAW_RX_OVER interrupt is inactive
  • 0x1 (ACTIVE): RAW_RX_OVER interrupt is active
0 RAW_RX_UNDER R 0x0
See RAW_INT_STAT for a detailed description of RAW_RX_UNDER bit.
  • 0x0 (INACTIVE): RX_UNDER interrupt is inactive
  • 0x1 (ACTIVE): RX_UNDER interrupt is active
INT_MASK
  • Name: I2C Interrupt Mask Register
  • Description: These bits mask their corresponding interrupt status bits. This register is active low; a value of 0 masks the interrupt, whereas a value of 1 unmasks the interrupt.
  • Offset: 0x30
  • Reset Value: 0x000008FF
表 89 I2C Interrupt Mask Register
11 MASK_GEN_CALL RW 0x1
This bit masks the RAW_GEN_CALL interrupt in INT_STAT register.
  • 0x0 (ENABLED): GEN_CALL interrupt is masked
  • 0x1 (DISABLED): GEN_CALL interrupt is unmasked
10 MASK_START_DET RW 0x0
This bit masks the RAW_START_DET interrupt in INT_STAT register.
  • 0x0 (ENABLED): START_DET interrupt is masked
  • 0x1 (DISABLED): START_DET interrupt is unmasked
9 MASK_STOP_DET RW 0x0
This bit masks the RAW_STOP_DET interrupt in INT_STAT register.
  • 0x0 (ENABLED): STOP_DET interrupt is masked
  • 0x1 (DISABLED): STOP_DET interrupt is unmasked
8 MASK_ACTIVITY RW 0x0
This bit masks the RAW_ACTIVITY interrupt in INT_STAT register.
  • 0x0 (ENABLED): ACTIVITY interrupt is masked
  • 0x1 (DISABLED): ACTIVITY interrupt is unmasked
7 MASK_RX_DONE RW 0x1
This bit masks the RAW_RX_DONE interrupt in INT_STAT register.
  • 0x0 (ENABLED): RX_DONE interrupt is masked
  • 0x1 (DISABLED): RX_DONE interrupt is unmasked
6 MASK_TX_ABORT RW 0x1
This bit masks the RAW_TX_ABORT interrupt in INT_STAT register.
  • 0x0 (ENABLED): TX_ABORT interrupt is masked
  • 0x1 (DISABLED): TX_ABORT interrupt is unmasked
5 MASK_RD_REQ RW 0x1
This bit masks the RAW_RD_REQ interrupt in INT_STAT register.
  • 0x0 (ENABLED): RD_REQ interrupt is masked
  • 0x1 (DISABLED): RD_REQ interrupt is unmasked
4 MASK_TX_EMPTY RW 0x1
This bit masks the RAW_TX_EMPTY interrupt in INT_STAT register.
  • 0x0 (ENABLED): TX_EMPTY interrupt is masked
  • 0x1 (DISABLED): TX_EMPTY interrupt is unmasked
3 MASK_TX_OVER RW 0x1
This bit masks the RAW_TX_OVER interrupt in INT_STAT register.
  • 0x0 (ENABLED): TX_OVER interrupt is masked
  • 0x1 (DISABLED): TX_OVER interrupt is unmasked
2 MASK_RX_FULL RW 0x1
This bit masks the RAW_RX_FULL interrupt in INT_STAT register.
  • 0x0 (ENABLED): RX_FULL interrupt is masked
  • 0x1 (DISABLED): RX_FULL interrupt is unmasked
1 MASK_RX_OVER RW 0x1
This bit masks the RAW_RX_OVER interrupt in INT_STAT register.
  • 0x0 (ENABLED): RX_OVER interrupt is masked
  • 0x1 (DISABLED): RX_OVER interrupt is unmasked
0 MASK_RX_UNDER RW 0x1
This bit masks the RAW_RX_UNDER interrupt in INT_STAT register.
  • 0x0 (ENABLED): RX_UNDER interrupt is masked
  • 0x1 (DISABLED): RX_UNDER interrupt is unmasked
RAW_INT_STAT
  • Name: I2C Raw Interrupt Status Register
  • Description: Unlike the INT_STAT register, these bits are not masked so they always show the true status of the I2C.
  • Offset: 0x34
表 90 I2C Raw Interrupt Status Register
13 M_HOLD R 0x0
Indicate whether the master is holding the bus and TX FIFO is empty.
  • 0x0 (INACTIVE): M_HOLD interrupt is inactive
  • 0x1 (ACTIVE): M_HOLD interrupt is active
12 RESTART_DET R 0x0
Indicate whether a RESTART condition has occurred on the I2C interface when I2C is operating in Slave mode and the slave is being addressed.
However, in high-speed mode or during a START BYTE transfer, the RESTART comes before the address field as per the I2C protocol. In this case, the slave is not the addressed slave when the RESTART is issued, therefore I2C does not generate the RESTART_DET interrupt.
  • 0x0 (INACTIVE): RESTART_DET interrupt is inactive
  • 0x1 (ACTIVE): RESTART_DET interrupt is active
11 GEN_CALL R 0x0
Set only when a General Call address is received and it is acknowledged. It stays set until it is cleared either by disabling I2C or when the CPU reads bit 0 of the CLR_GEN_CALL register. I2C stores the received data in the RX buffer.
  • 0x0 (INACTIVE): GEN_CALL interrupt is inactive
  • 0x1 (ACTIVE): GEN_CALL interrupt is active
10 START_DET R 0x0
Indicate whether a START or RESTART condition has occurred on the I2C interface regardless of whether I2C is operating in slave or master mode.
  • 0x0 (INACTIVE): START_DET interrupt is inactive
  • 0x1 (ACTIVE): START_DET interrupt is active
9 STOP_DET R 0x0
Indicate whether a STOP condition has occurred on the I2C interface regardless of whether I2C is operating in slave or master mode.
In Slave Mode:
  • If CTRL[7] = 0x1 (STOP_DET_INT), the STOP_DET interrupt will be issued only if slave is addressed.
During a general call address, this slave does not issue a STOP_DET interrupt if STOP_DET_INT = 0x1, even if the slave responds to the general call address by generating ACK. The STOP_DET interrupt is generated only when the transmitted address matches the slave address (S_ADDR).
  • If CTRL[7] = 0x0 (STOP_DET_INT), the STOP_DET interrupt is issued irrespective of whether it is being addressed.
In Master Mode:
  • If CTRL[10] = 0x1 (STOP_DET_IF_MASTER_ACTIVE), the STOP_DET interrupt will be issued only if Master is active.
  • If CTRL[10] = 0x0 (STOP_DET_INT), the STOP_DET interrupt will be issued irrespective of whether master is active or not.
  • 0x0 (INACTIVE): STOP_DET interrupt is inactive
  • 0x1 (ACTIVE): STOP_DET interrupt is active
8 ACTIVITY R 0x0
This bit captures I2C activity and stays set until it is cleared. There are four ways to clear it:
  • Disabling the I2C
  • Reading the CLR_ACTIVITY register
  • Reading the CLR_INT register
  • System reset
Once this bit is set, it stays set unless one of the four methods is used to clear it. Even if the I2C module is idle, this bit remains set until cleared, indicating that there was activity on the bus.
  • 0x0 (INACTIVE): ACTIVITY interrupt is inactive
  • 0x1 (ACTIVE): ACTIVITY interrupt is active
7 RX_DONE R 0x0
When the I2C is acting as a slave-transmitter, this bit is set to 1 if the master does not acknowledge a transmitted byte. This occurs on the last byte of the transmission, indicating that the transmission is done.
  • 0x0 (INACTIVE): RX_DONE interrupt is inactive
  • 0x1 (ACTIVE): RX_DONE interrupt is active
6 TX_ABORT R 0x0
This bit indicates if I2C, as an I2C transmitter, is unable to complete the intended actions on the contents of the transmit FIFO. This situation can occur both as an I2C master or an I2C slave, and is referred to as a 'transmit abort'. When this bit is set to 1, the TX_ABORT_SRC register indicates the reason why the transmit abort takes place.
The I2C flushes/resets/empties only the TX_FIFO whenever there is a transmit abort caused by any of the events tracked by the TX_ABORT_SRC register. The TX FIFO remains in this flushed state until the register CLR_TX_ABORT is read. Once this read is performed, the TX FIFO is then ready to accept more data bytes from the APB interface.
  • 0x0 (INACTIVE): TX_ABORT interrupt is inactive
  • 0x1 (ACTIVE): TX_ABORT interrupt is active
5 RD_REQ R 0x0
This bit is set to 1 when I2C is acting as a slave and another I2C master is attempting to read data from I2C. The I2C holds the I2C bus in a wait state (SCL=0) until this interrupt is serviced, which means that the slave has been addressed by a remote master that is asking for data to be transferred. The processor must respond to this interrupt and then write the requested data to the DATA_CMD register. This bit is set to 0 just after the processor reads the CLR_RD_REQ register.
  • 0x0 (INACTIVE): RD_REQ interrupt is inactive
  • 0x1 (ACTIVE): RD_REQ interrupt is active
4 TX_EMPTY R 0x0
The behavior of the TX_EMPTY interrupt status differs based on the TX_EMPTY_CTRL selection in the CTRL register.
  • When TX_EMPTY_CTRL = 0:
    This bit is set to 1 when the transmit buffer is at or below the threshold value set in the TX_FIFO_THD register.
  • When TX_EMPTY_CTRL = 1:
    This bit is set to 1 when the transmit buffer is at or below the threshold value set in the TX_FIFO_THD register and the transmission of the address/data from the internal shift register for the most recently popped command is completed.
    It is automatically cleared by hardware when the buffer level goes above the threshold. When EN[0] is set to 0, the TX FIFO is flushed and held in reset. There the TX FIFO looks like it has no data within it, so this bit is set to 1, provided there is activity in the master or slave state machines. When there is no longer any activity, then with EN[0] = 0, this bit is set to 0.
  • 0x0 (INACTIVE): TX_EMPTY interrupt is inactive
  • 0x1 (ACTIVE): TX_EMPTY interrupt is active
3 TX_OVER R 0x0
Set during transmit if the transmit buffer is filled to 8 and the processor attempts to issue another I2C command by writing to the DATA_CMD register. When I2C module is disabled, this bit keeps its level until the master or slave state machines go into idle, and when EN[0] goes to 0, this interrupt is cleared.
  • 0x0 (INACTIVE): TX_OVER interrupt is inactive
  • 0x1 (ACTIVE): TX_OVER interrupt is active
2 RX_FULL R 0x0
Set when the receive buffer reaches or goes above the RX_FIFO_THD threshold in the RX_FIFO_THD register. It is automatically cleared by hardware when buffer level goes below the threshold. If I2C module is disabled (EN[0] = 0), the RX FIFO is flushed and held in reset; therefore the RX FIFO is not full. So this bit is cleared once the EN bit 0 is programmed with a 0, regardless of the activity that continues.
  • 0x0 (INACTIVE): RX_FULL interrupt is inactive
  • 0x1 (ACTIVE): RX_FULL interrupt is active
1 RX_OVER R 0x0
Set if the receive buffer is completely filled to 8 and an additional byte is received from an external I2C device. The I2C acknowledges this, but any data bytes received after the FIFO is full are lost. If I2C module is disabled (EN[0]=0), this bit keeps its level until the master or slave state machines go into idle, and when EN[0] goes to 0, this interrupt is cleared.
  • 0x0 (INACTIVE): RX_OVER interrupt is inactive
  • 0x1 (ACTIVE): RX_OVER interrupt is active
0 RX_UNDER R 0x0
Set if the processor attempts to read the receive buffer when it is empty by reading from the DATA_CMD register. If the module is disabled (EN[0]=0), this bit keeps its level until the master or slave state machines go into idle, and when EN[0] goes to 0, this interrupt is cleared.
RX_FIFO_THD
  • Name:I2C Receive FIFO Threshold Register
  • Description: I2C Receive FIFO Threshold Register
  • Offset: 0x38
表 91 I2C Receive FIFO Threshold Register
31:8 RSVD R Reserved bits
7:0 THD RW 0x00
Receive FIFO Threshold Level.
Control the level of entries (or above) that triggers the RX_FULL interrupt (bit 2 in RAW_INT_STAT register). The valid range is 0-255, with the additional restriction that hardware does not allow this value to be set to a value larger than the depth of the buffer. If an attempt is made to do that, the actual value set will be the maximum depth of the buffer.
A value of 0 sets the threshold for 1 entry, and a value of 255 sets the threshold for 256 entries.
TX_FIFO_THD
  • Name: I2C Transmit FIFO Threshold Register
  • Description: I2C Transmit FIFO Threshold Register
  • Offset: 0x3C
表 92 I2C Transmit FIFO Threshold Register
7:0 THD RW 0x00
Transmit FIFO Threshold Level.
Control the level of entries (or below) that trigger the TX_EMPTY interrupt (bit 4 in RAW_INT_STAT register).
The valid range is 0 – 255, with the additional restriction that it may not be set to value larger than the depth of the buffer. If an attempt is made to do that, the actual value set will be the maximum depth of the buffer. A value of 0 sets the threshold for 0 entries, and a value of 255 sets the threshold for 255 entries.
CLR_INT
  • Name: Clear Combined and Individual Interrupt Register
  • Description: Clear Combined and Individual Interrupt Register
  • Offset: 0x40
表 93 Clear Combined and Individual Interrupt Register
31:1 RSVD R Reserved bits
0 CLR_INT R 0x0 Read this register to clear the combined interrupt, all individual interrupts, and the TX_ABORT_SRC register. This bit does not clear hardware clearable interrupts but software clearable interrupts.
CLR_RX_UNDER
  • Name: Clear RX_UNDER Interrupt Register
  • Description: Clear RX_UNDER Interrupt Register
  • Offset:0x44
  • Reset Value:0x00000000
表 94 Clear RX_UNDER Interrupt Register
0 CLR_RX_UNDER R 0x0 Read this register to clear the RX_UNDER interrupt (bit 0) of the RAW_INT_STAT register.
CLR_RX_OVER
  • Name: Clear RX_OVER Interrupt Register
  • Description: Clear RX_OVER Interrupt Register
  • Offset: 0x48
表 95 Clear RX_OVER Interrupt Register
0 CLR_RX_OVER R 0x0 Read this register to clear the RX_OVER interrupt (bit 1) of the RAW_INT_STAT register.
CLR_TX_OVER
  • Name: Clear TX_OVER Interrupt Register
  • Description: Clear TX_OVER Interrupt Register
  • Offset:0x4C
表 96 Clear TX_OVER Interrupt Register
0 CLR_TX_OVER R 0x0 Read this register to clear the TX_OVER interrupt (bit 3) of the RAW_INT_STAT register.
CLR_RD_REQ
  • Name: Clear RD_REQ Interrupt Register
  • Description: Clear RD_REQ Interrupt Register
  • Offset: 0x50
表 97 Clear RD_REQ Interrupt Register
0 CLR_RD_REQ R 0x0 Read this register to clear the RD_REQ interrupt (bit 5) of the RAW_INT_STAT register.
CLR_TX_ABORT
  • Name: Clear TX_ABORT Interrupt Register
  • Description: Clear TX_ABORT Interrupt Register
  • Offset:0x54
表 98 Clear TX_ABORT Interrupt Register
0 CLR_TX_ABORT R 0x0 Read this register to clear the TX_ABORT interrupt (bit 6) of the RAW_INT_STAT register, and the TX_ABORT_SRC register.
CLR_RX_DONE
  • Name: Clear RX_DONE Interrupt Register
  • Description: Clear RX_DONE Interrupt Register
  • Offset: 0x58
表 99 Clear RX_DONE Interrupt Register
0 CLR_RX_DONE R 0x0 Read this register to clear the RX_DONE interrupt (bit 7) of the RAW_INT_STAT register.
CLR_ACTIVITY
  • Name: Clear ACTIVITY Interrupt Register
  • Description: Clear ACTIVITY Interrupt Register
  • Offset: 0x5C
表 100 Clear ACTIVITY Interrupt Register
0 CLR_ACTIVITY R 0x0 Reading this register clears the ACTIVITY interrupt if the I2C is not active anymore. If the I2C module is still active on the bus, the ACTIVITY interrupt bit continues to be set. It is automatically cleared by hardware if the module is disabled and if there is no further activity on the bus. The value read from this register to get status of the ACTIVITY interrupt (bit 8) of the RAW_INT_STAT register.
CLR_STOP_DET
  • Name: Clear STOP_DET Interrupt Register
  • Description: Clear STOP_DET Interrupt Register
  • Offset: 0x60
表 101 Clear STOP_DET Interrupt Register
0 CLR_STOP_DET R 0x0 Read this register to clear the STOP_DET interrupt (bit 9) of the RAW_INT_STAT register.
CLR_START_DET
  • Name: Clear START_DET Interrupt Register
  • Description: Clear START_DET Interrupt Register
  • Offset: 0x64
表 102 Clear START_DET Interrupt Register
0 CLR_START_DET R 0x0 Read this register to clear the START_DET interrupt (bit 10) of the RAW_INT_STAT register.
CLR_GEN_CALL
  • Name: Clear GEN_CALL Interrupt Register
  • Description: Clear GEN_CALL Interrupt Register
  • Offset: 0x68
表 103 Clear GEN_CALL Interrupt Register
0 CLR_GEN_CALL R 0x0 Read this register to clear the GEN_CALL interrupt (bit 11) of RAW_INT_STAT register.
EN
  • Name: I2C ENABLE Register
  • Description: I2C enable register
  • Offset: 0x6C
表 104 I2C ENABLE Register
2 TX_CMD_BLOCK RW 0x0
In Master mode:
  • 0x0 (NOT_BLOCKED): TX Command execution not blocked
  • 0x1 (BLOCKED): TX Command execution blocked
1 ABORT RW
When set, the controller initiates the transfer abort.
The software can abort the I2C transfer in master mode by setting this bit. The software can set this bit only when EN is already set; otherwise, the controller ignores any write to ABORT bit. The software cannot clear the ABORT bit once set. In response to an ABORT, the controller issues a STOP and flushes the TX FIFO after completing the current transfer, then sets the TX_ABORT interrupt after the abort operation. The ABORT bit is cleared automatically after the abort operation.
  • 0x0 (DISABLED): ABORT operation not in progress
  • 0x1 (ENABLED): ABORT operation in progress
0 ACTIVITY RW 0x0
Control whether the I2C is enabled.
Software can disable I2C while it is active. However, it is important that care should be taken to ensure that I2C is disabled properly.
When I2C is disabled, the following occurs:
The TX FIFO and RX FIFO get flushed.
Status bits in the INT_STAT register are still active until I2C goes into IDLE state.
If the I2C module is transmitting, it stops as well as deletes the contents of the transmit buffer after the current transfer is completed. If the module is receiving, the I2C stops the current transfer at the end of the current byte and does not acknowledge the transfer.
  • 0x0 (DISABLED): I2C is disabled
  • 0x1 (ENABLED): I2C is enabled
STAT
  • Name: I2C STATUS Register
  • Description: This is a read-only register used to indicate the current transfer status and FIFO status. The status register may be read at any time. None of the bits in this register requests an interrupt.
    When the I2C is disabled by writing 0 in bit 0 of the EN register:
    • Bits 1 and 2 are set to 1
    • Bits 3 and 6 are set to 0
    When the master or slave state machine goes to idle and EN[0]=0:
    • Bits 5 and 6 are set to 0
  • Offset: 0x70
表 105 I2C STATUS Register
31:7 RSVD R Reserved bits
6 S_ACTIVITY R
Slave Activity Status. When the Slave is not in the IDLE state, this bit is set.
  • 0x0 (INACTIVE): Slave is idle
  • 0x1 (ACTIVE): Slave is not idle
5 M_ACTIVITY R
Master Activity Status. When the Master is not in the IDLE state, this bit is set.
STAT[0], ACTIVITY bit, is the OR of S_ACTIVITY and M_ACTIVITY Y bits.
  • 0x0 (INACTIVE): Master is idle
  • 0x1 (ACTIVE): Master not idle
4 RX_FIFO_CF R
Receive FIFO Completely Full. When the receive FIFO is completely full, this bit is set. When the receive FIFO contains one or more empty location, this bit is cleared.
  • 0x0 (NOT_FULL): RX FIFO is not full
  • 0x1 (FULL): RX FIFO is full
3 RX_FIFO_NE R
Receive FIFO Not Empty. This bit is set when the receive FIFO contains one or more entries; it is cleared when the receive FIFO is empty.
  • 0x0 (EMPTY): RX FIFO is empty
  • 0x1 (NOT_EMPTY): RX FIFO not empty
2 TX_FIFO_CE R
0x1
Transmit FIFO Completely Empty. When the transmit FIFO is completely empty, this bit is set. When it contains one or more valid entries, this bit is cleared. This bit field does not request an interrupt.
  • 0x0 (NOT_EMPTY): TX FIFO not empty
  • 0x1 (EMPTY): TX FIFO is empty
1 TX_FIFO_NF R
0x1
Transmit FIFO Not Full. Set when the transmit FIFO contains one or more empty locations, and is cleared when the FIFO is full.
  • 0x0 (FULL): TX FIFO is full
  • 0x1 (NOT_FULL): TX FIFO not full
0 ACTIVITY R 0x0
I2C Activity Status
  • 0x0 (INACTIVE): I2C is idle
  • 0x1 (ACTIVE): I2C is active
TX_FIFO_LEVEL
  • Name: I2C Transmit FIFO Level Register
  • Description: This register contains the number of valid data entries in the transmit FIFO buffer. It is cleared whenever:
    • The I2C is disabled.
    • If TX_ABORT bit is set in the RAW_INT_STAT register, the slave bulk transmit mode is aborted.
    • The register increments whenever data is placed into the transmit FIFO and decrements when data is taken from the transmit FIFO.
  • Offset: 0x74
表 106 I2C Transmit FIFO Level Register
31:4 RSVD R Reserved bits
3:0 TLEVEL R 0x0 Transmit FIFO Level. It contains the number of valid data entries in the transmit FIFO.
RX_FIFO_LEVEL
  • Name: I2C Receive FIFO Level Register
  • Description: This register contains the number of valid data entries in the receive FIFO buffer. It is cleared whenever:
    • There is a transmit abort caused by any of the events tracked in TX_ABORT_SRC.
    • The register increments whenever data is placed into the receive FIFO and decrements when data is taken from the receive FIFO.
  • Offset: 0x78
表 107 I2C Receive FIFO Level Register
3:0 LEVEL R 0x0 Receive FIFO Level. It contains the number of valid data entries in the receive FIFO.
SDA_HOLD
  • Name: I2C SDA Hold Time Length Register
  • Description: I2C SDA Hold Time Length Register
    • The bits [15:0] of this register are used to control the hold time of SDA during transmit in both slave and master mode (after SCL goes from HIGH to LOW).
    • The bits [23:16] of this register are used to extend the SDA transition (if any) whenever SCL is HIGH in the receiver in either master or slave mode.
    • Writes to this register succeed only when EN[0]=0.
    • The values in this register are in units of clock period. The value programmed in TX_HOLD must be greater than the minimum hold time in each mode one cycle in master mode, seven cycles in slave mode for the value to be implemented.
    • The programmed SDA hold time during transmit (TX_HOLD) cannot exceed at any time the duration of the low part of SCL. Therefore the programmed value cannot be larger than N_SCL_LOW-2, where N_SCL_LOW is the duration of the low part of the SCL period measured in clock cycles.
  • Offset: 0x7C
表 108 I2C SDA Hold Time Length Register
31:24 RSVD R Reserved bits
23:16 RX_HOLD RW 0x0 Set the required SDA hold time in units of clock period, when I2C acts as a receiver.
15:0 TX_HOLD RW 0x1 Set the required SDA hold time in units of clock period, when I2C acts as a transmitter.
TX_ABORT_SRC
  • Name: I2C Transmit Abort Source Register
  • Description: I2C Transmit Abort Source Register
    • This register has 32 bits that indicates the source of the TX_ABORT bit. Except for Bit 9, this register is cleared whenever the CLR_TX_ABORT register or the CLR_INT register is read. To clear Bit 9, the source of the ABORT_SBYTE_NORSTRT must be fixed first; RESTART must be enabled (CTRL[5] = 1), the SPECIAL bit must be cleared (TARGET_ADDR[11]), or the TX_CTRL bit must be cleared (TARGET_ADDR[10]).
    • Once the source of the ABORT_SBYTE_NORSTRT is fixed, then this bit can be cleared in the same manner as other bits in this register. If the source of the ABORT_SBYTE_NORSTRT is not fixed before attempting to clear this bit, Bit 9 clears for one cycle and is then re-asserted.
  • Offset: 0x80
表 109 I2C Transmit Abort Source Register
31:23 TX_FLUSH_CNT R 0x0
This field indicates the number of TX FIFO Data Commands which are flushed due to TX_ABORT interrupt. It is cleared whenever I2C is disabled.
Role of I2C: Master-Transmitter or Slave-Transmitter
22:17 RSVD R Reserved bits
16 ABORT_USER_ABORT R 0x0
This is a master-mode-only bit. Master has detected the transfer abort (EN[1])
  • 0x0 (ABORT_USER_ABORT_VOID): Transfer abort detected by master- scenario not present
  • 0x1 (ABORT_USER_ABORT_GENERATED): Transfer abort detected by master
15 ABORT_SLVRD_INTX R 0x0
When the processor side responds to a slave mode request for data to be transmitted to a remote master and user writes a 1 in CMD (bit 8) of DATA_CMD register.
Role of I2C: Slave-Transmitter
  • 0x0 (ABORT_SLVRD_INTX_VOID): Slave trying to transmit to remote master in read mode- scenario not present
  • 0x1 (ABORT_SLVRD_INTX_GENERATED): Slave trying to transmit to remote master in read mode
14 ABORT_S_ARBLOST R 0x0
This field indicates that a Slave has lost the bus while transmitting data to a remote master. TX_ABORT_SRC[12] is set at the same time.
Even though the slave never 'owns' the bus, something could go wrong on the bus. This is a fail safe check. For instance, during a data transmission at the low-to-high transition of SCL, if what is on the data bus is not what is supposed to be transmitted, then I2C no longer owns the bus.
  • 0x0 (ABORT_S_ARBLOST_VOID): Slave lost arbitration to remote master- scenario not present
  • 0x1 (ABORT_S_ARBLOST_GENERATED): Slave lost arbitration to remote master
13 ABORT_SLVFLUSH_TXFIFO R 0x0
This field specifies that the Slave has received a read command and some data exists in the TX FIFO, so the slave issues a TX_ABORT interrupt to flush old data in TX FIFO.
  • 0x0 (ABORT_SLVFLUSH_TXFIFO_VOID): Slave flushes existing data in TX-FIFO upon getting read command- scenario not present
  • 0x1 (ABORT_SLVFLUSH_TXFIFO_GENERATED): Slave flushes existing data in TX-FIFO upon getting read command
12 ABORT_LOST R 0x0
This field specifies that the Master has lost arbitration, or if TX_ABORT_SRC[14] is also set, then the slave transmitter has lost arbitration.
  • 0x0 (ABORT_LOST_VOID): Master or Slave-Transmitter lost arbitration- scenario not present
  • 0x1 (ABORT_LOST_GENERATED): Master or Slave-Transmitter lost arbitration
11 ABORT_MASTER_DIS R 0x0
This field indicates that the User tries to initiate a Master operation with the Master mode disabled.
Role of I2C: Master-Transmitter or Master-Receiver
  • 0x0 (ABORT_MASTER_DIS_VOID): User initiating master operation when Master disabled- scenario not present
  • 0x1 (ABORT_MASTER_DIS_GENERATED): User initiating master operation when Master disabled
10 ABORT_10B_RD_NORSTR R 0x0
This field indicates that the restart is disabled (RESTART_EN bit (CTRL[5]) =0) and the master sends a read command in 10-bit addressing mode.
Role of I2C: Master-Receiver
  • 0x0 (ABRT_10B_RD_VOID): Master not trying to read in 10-bit addressing mode when RESTART disabled
  • 0x1 (ABRT_10B_RD_GENERATED): Master trying to read in 10-bit addressing mode when RESTART disabled
9 ABORT_SBYTE_NORSTRT R 0x0
To clear Bit 9, the source of the ABORT_SBYTE_NORSTRT must be fixed first; restart must be enabled (CTRL[5]=1), the SPECIAL bit must be cleared (TARGET_ADDR[11]), or the TX_CTRL bit must be cleared (TARGET_ADDR[10]). Once the source of the ABORT_SBYTE_NORSTRT is fixed, then this bit can be cleared in the same manner as other bits in this register. If the source of the ABORT_SBYTE_NORSTRT is not fixed before attempting to clear this bit, bit 9 clears for one cycle and then gets reasserted. When this field is set to 1, the restart is disabled (RESTART_EN bit (CTRL[5]) =0) and the user is trying to send a START BYTE.
Role of I2C: Master
  • 0x0 (ABORT_SBYTE_NORSTRT_VOID): User trying to send START BYTE when RESTART disabled- scenario not present
  • 0x1 (ABORT_SBYTE_NORSTRT_GENERATED): User trying to send START BYTE when RESTART disabled
8 ABORT_HS_NORSTRT R 0x0
This field indicates that the restart is disabled (RESTART_EN bit (CTRL[5]) =0) and the user is trying to use the master to transfer data in High Speed mode.
  • 0x0 (ABORT_HS_NORSTRT_VOID): User trying to switch Master to HS mode when RESTART disabled- scenario not present
  • 0x1 (ABORT_HS_NORSTRT_GENERATED): User trying to switch Master to HS mode when RESTART disabled
7 ABORT_SBYTE_ACKDET R 0x0
This field indicates that the Master has sent a START Byte and the START Byte was acknowledged (wrong behavior).
Role of I2C: Master
  • 0x0 (ABORT_SBYTE_ACKDET_VOID): ACK detected for START byte- scenario not present
  • 0x1 (ABORT_SBYTE_ACKDET_GENERATED): ACK detected for START byte
6 ABORT_HS_ACKDET R 0x0
This field indicates that the Master is in High Speed mode and the High Speed Master code was acknowledged (wrong behavior).
Role of I2C: Master
  • 0x0 (ABRT_HS_ACK_VOID): HS Master code ACKed in HS Mode- scenario not present
  • 0x1 (ABRT_HS_ACK_GENERATED): HS Master code ACKed in HS Mode
5 ABORT_GCALL_RD R 0x0
This field indicates that I2C in the master mode has sent a General Call but the user programmed the byte following the General Call to be a read from the bus (DATA_CMD[9] is set to 1).
  • 0x0 (ABORT_GCALL_RD_VOID): GCALL is followed by read from bus-scenario not present
  • 0x1 (ABORT_GCALL_RD_GENERATED): GCALL is followed by read from bus
4 ABORT_GCALL_NOACK R 0x0
This field indicates that I2C in master mode has sent a General Call and no slave on the bus acknowledged the General Call.
  • 0x0 (ABORT_GCALL_NOACK_VOID): GCALL not ACKed by any slave-scenario not present
  • 0x1 (ABORT_GCALL_NOACK_GENERATED): GCALL not ACKed by any slave
3 ABORT_TX_NOACK R 0x0
This field indicates the master-mode only bit. When the master receives an acknowledgement for the address, but when it sends data byte(s) following the address, it did not receive an acknowledge from the remote slave(s).
Role of I2C:Master-Transmitter
  • 0x0 (ABORT_TX_NOACK_VOID): Transmitted data non-ACKed by addressed slave-scenario not present
  • 0x1 (ABORT_TX_NOACK_GENERATED): Transmitted data not ACKed by addressed slave
2 ABORT_10B2_NOACK R 0x0
This field indicates that the Master is in 10-bit address mode and that the second address byte of the 10-bit address was not acknowledged by any slave.
  • 0x0 (INACTIVE): This abort is not generated
  • 0x1 (ACTIVE): Byte 2 of 10-bit Address not ACKed by any slave
1 ABORT_10B1_NOACK R 0x0
This field indicates that the Master is in 10-bit address mode and the first 10-bit address byte was not acknowledged by any slave.
  • 0x1 (ACTIVE): Byte 1 of 10-bit Address not ACKed by any slave
0 ABORT_7B_NOACK R 0x0
This field indicates that the Master is in 7-bit address mode and the address sent was not acknowledged by any slave.
  • 0x1 (ACTIVE): This abort is generated because of NACK for 7-bit address
DMA_CTRL
  • Name: DMA Control Register
  • Description: This register is only valid when I2C is configured with a set of DMA Controller interface signals. When I2C is not configured for DMA operation, this register does not exist and writing to the register's address has no effect and reading from this register address will return zero. The register is used to enable the DMA Controller interface operation. There is a separate bit for transmitting and receiving. This can be programmed regardless of the state of EN.
  • Offset: 0x88
表 110 DMA Control Register
31:2 RSVD R Reserved bits
1 TX_EN RW 0x0
Transmit DMA Enable. This bit enables/disables the transmit FIFO DMA channel.
  • 0x0 (DISABLED): Transmit FIFO DMA channel disabled
  • 0x1 (ENABLED): Transmit FIFO DMA channel enabled
0 RX_EN RW 0x0
Receive DMA Enable. This bit enables/disables the receive FIFO DMA channel.
  • 0x0 (DISABLED): Receive FIFO DMA channel disabled
  • 0x1 (ENABLED): Receive FIFO DMA channel enabled
DMA_TX_LEVEL
  • Name: DMA Transmit Data Level Register
  • Description: This register is only valid when the I2C is configured with a set of DMA interface signals. When I2C is not configured for DMA operation, this register does not exist; writing to its address has no effect; reading from its address returns zero.
  • Offset: 0x8C
表 111 DMA Transmit Data Level Register
2:0 LEVEL RW 0x0 Transmit Data Level. This bit field controls the level at which a DMA request is made by the transmit logic.
DMA_RX_LEVEL
  • Name: DMA Receive Data Level Register
  • Description: This register is only valid when I2C is configured with a set of DMA interface signals (HAS_DMA = 1). When I2C is not configured for DMA operation, this register does not exist; writing to its address has no effect; reading from its address returns zero.
  • Offset: 0x90
表 112 DMA Receive Data Level Register
2:0 LEVEL RW 0x0 Receive Data Level. This bit field controls the level at which a DMA request is made by the receive logic.
SDA_SETUP
  • Name: I2C SDA Setup Register
  • Description: This register controls the amount of time delay (in terms of number of clock periods) introduced in the rising edge of SCL - relative to SDA changing - when I2C services a read request in a slave-transmitter operation. The relevant I2C requirement is tSU_STO as detailed in the 图 29. This register must be programmed with a value equal to or greater than 2.
    Writes to this register succeed only when EN[0] = 0.
The length of setup time is calculated using [(SDA_SETUP - 1) * (clk_period)], so if the user requires 10 clock periods of setup time, they should program a value of 11. The SDA_SETUP register is only used by the I2C when operating as a slave transmitter.
  • Offset: 0x94
  • Reset Value: 0x00000064
表 113 I2C SDA Setup Register
7:0 SETUP RW 0x64 SDA Setup. It is recommended that if the required delay is 1000 ns, then for a clock frequency of 10 MHz, SETUP should be programmed to a value of 11. SETUP must be programmed with a minimum value of 2.
ACK_GEN_CALL
  • Name: I2C ACK General Call Register
  • Description: The register controls whether I2C responds with an ACK or NACK when it receives an I2C General Call address. This register is applicable only when the I2C is in slave mode.
  • Offset: 0x98
表 114 I2C ACK General Call Register
0 ACK_GEN_CALL RW 0x1
ACK General Call. When set to 1, I2C responds with an ACK (by asserting data_oe) when it receives a General Call. Otherwise, I2C responds with a NACK (by negating data_oe).
  • 0x0 (DISABLED): Generate NACK for General Call
  • 0x1 (ENABLED): Generate ACK for a General Call
EN_STAT
  • Name: I2C Enable Status Register
  • Description: The register is used to report the I2C hardware status when the EN[0] register is set from 1 to 0; that is, when I2C is disabled.
    • If EN[0] has been set to 1, bits 2:1 are forced to 0, and bit 0 is forced to '1'.
    • If EN[0] has been set to 0, bits 2:1 is only be valid as soon as bit 0 is read as '0'.
When EN[0] has been set to 0, a delay occurs for bit 0 to be read as 0 because disabling the I2C depends on I2C bus activities.
  • Offset: 0x9C
表 115 I2C Enable Status Register
2 S_RX_DATA_LOST R 0x0
Slave Received Data Lost. This bit indicates if a Slave-Receiver operation has been aborted with at least one data byte received from an I2C transfer due to the setting bit 0 of EN from 1 to 0. When read as 1, I2C is deemed to have been actively engaged in an aborted I2C transfer (with matching address) and the data phase of the I2C transfer has been entered, even though a data byte has been responded with a NACK.
  • If the remote I2C master terminates the transfer with a STOP condition before the I2C has a chance to NACK transfer, and EN[0] has been set to 0, then this bit is also set to 1.
  • When read as 0, I2C is deemed to have been disabled without being actively involved in the data phase of a Slave-Receiver transfer.
  • The CPU can safely read this bit when EN (bit 0) is read as 0.
  • 0x0 (INACTIVE): Slave RX Data is not lost
  • 0x1 (ACTIVE): Slave RX Data is lost
1 S_DIS_BUSY R 0x0
Slave Disabled While Busy (Transmit, Receive). This bit indicates if a potential or active Slave operation has been aborted due to the setting bit 0 of the ENABLE register from 1 to 0. This bit is set when the CPU writes a 0 to the ENABLE register while:
  • I2C is receiving the address byte of the Slave-Transmitter operation from a remote master.
  • Address and data bytes of the Slave-Receiver operation from a remote master.
When read as 1, I2C is deemed to have forced a NACK during any part of an I2C transfer, irrespective of whether the I2C address matches the slave address set in I2C (S_ADDR register) or if the transfer is completed before EN is set to 0 but has not taken effect.
  • If the remote I2C master terminates the transfer with a STOP condition before the I2C has a chance to NACK a transfer, and EN[0] has been set to 0, then this bit will also be set to 1.
  • When read as 0, I2C is deemed to have been disabled when there is master activity, or when the I2C bus is idle.
  • 0x0 (INACTIVE): Slave is disabled when it is idle
  • 0x1 (ACTIVE): Slave is disabled when it is active
0 EN R 0x0
EN Status. This bit always reflects the value driven on the output port EN.
When read as 1, I2C is deemed to be in an enabled state.
When read as 0, I2C is deemed completely inactive.
The CPU can safely read this bit anytime. When this bit is read as 0, the CPU can safely read S_RX_DATA_LOST (bit 2) and S_DIS_BUSY (bit 1).
  • 0x0 (DISABLED): I2C disabled
  • 0x1 (ENABLED): I2C enabled
FS_SPKLEN
  • Name: I2C SS, FS or FM+ spike suppression limit
  • Description: This register is used to store the duration, measured in clock cycles, of the longest spike that is filtered out by the spike suppression logic when the component is operating in SS, FS or FM+ mode. The relevant I2C requirement is tSP as detailed in the I2C Bus Specification. This register must be programmed with a minimum value of 1.
  • Offset: 0xA0
  • Reset Value: 0x00000005
表 116 I2C SS, FS or FM+ spike suppression limit
7:0 FS_SPKLEN RW 0x5
This register must be set before any I2C bus transaction can take place to ensure stable operation. This register sets the duration, measured in clock cycles, of the longest spike in the SCL or SDA lines that will be filtered out by the spike suppression logic.
This register can be written only when the I2C interface is disabled which corresponds to the EN[0] register being set to 0. Writes at other times have no effect. The minimum valid value is 1; hardware prevents values less than this being written, and if attempted results in 1 being set.
HS_SPKLEN
  • Name: I2C HS spike suppression limit register
  • Description: This register is used to store the duration, measured in clock cycles, of the longest spike that is filtered out by the spike suppression logic when the component is operating in HS mode. The relevant I2C requirement is tSP as detailed in the I2C Bus Specification. This register must be programmed with a minimum value of 1 and is implemented only if the component is configured to support HS mode.
  • Offset: 0xA4
表 117 I2C HS spike suppression limit register
7:0 HS_SPKLEN RW 0x1
