CTRL
  • Name: Control Register
  • Description: This register is only to write.
  • Base Address: 0xA000F200
  • Offset: 0x0
表 241 Control Register
31
IRQ_TEST_SET
W
Interrupt Test Set.
This register sets test interrupt
  • 0x0: No effect
  • 0x1: Set
30
IRQ_TEST_CLR
W
Interrupt Test Clear.
This register clears test interrupt (has higher priority than ‘IRQ_TEST_SET’)
  • 0x0: No effect
  • 0x1: Clear
29:26
W
25
IRQ_PRESENCE_CLR
W
Interrupt source presence clear.
This register clears interrupt source ‘STAT.IRQ_PRESENCE’.
  • 0x0: No effect
  • 0x1: Clear
24
IRQ_STAT_EC
W
Interrupt source state_err clear.
This register clears interrupt source ‘STAT.IRQ_STAT_ERR’.
  • 0x0: No effect
  • 0x1: Clear
23
IRQ_DMA_EC
W
Interrupt source dma_err clear.
This register clears interrupt source ‘STAT.IRQ_DMA_ERR’.
  • 0x0: No effect
  • 0x1: Clear
22
IRQ_RETYR_EC
W
Interrupt source retry_err clear.
This register clears interrupt source ‘STAT.IRQ_RETYR_ERR’.
  • 0x0: No effect
  • 0x1: Clear
21
IRQ_RX_EC
W
Interrupt source rx_err clear.
This register clears interrupt source ‘STAT.IRQ_RX_ERR’.
  • 0x0: No effect
  • 0x1: Clear
20
IRQ_DONE_CLR
W
Interrupt source done clear.
This register clears interrupt source ‘STAT.IRQ_DONE’.
  • 0x0: No effect
  • 0x1: Clear
19:13
W
12
TX_RETYR_MC
W
Transmit Retries Maximum Clear.
This register clears ‘STAT.TX_RETRY_MAX’.
  • 0x0: No effect
  • 0x1: Clear
11:9
W
8
RX_RETYR_MC
W
Receive Retries Maximum Clear.
This register clears ‘STAT.RX_RETRY_MAX’.
  • 0x0: No effect
  • 0x1: Clear
7:3
W
2:0
ACTION
W
  • 0x0: Do Nothing.
  • 0x1: Switch off.
  • 0x2: Stop the clock.
  • 0x3: Switch on and receive ATR. Re-enable clock if clock is stopped.
  • 0x4: Trigger warm reset and receive ATR.
  • 0x5: Receive.
  • 0x6: Transmit.
  • 0x7: Transmit, followed by RX.
STAT
  • Name: Status Register
  • Description: This register record interrupt, IO and power status.
  • Offset: 0x04
  • Reset Value: 0x00020000
表 242 Status Register
31
30
IRQ_TEST
Interrupt Test.
Test interrupt for connection check.
  • 0x0: No interrupt
  • 0x1: Active
29:26
25
IRQ_PRESENCE
Interrupt Presence.
SIM card presence changed. Inserted or removed.
  • 0x0: No interrupt
  • 0x1: Active
24
IRQ_STAT_ERR
Interrupt State Error.
Action requested while busy or unsupported transition.
  • 0x0: No interrupt
  • 0x1: Active
23
IRQ_DMA_ERR
Interrupt DMA Error.
DMA read/write operation could not be issued.
  • 0x0: No interrupt
  • 0x1: Active
22
IRQ_RETRY_ERR
Interrupt Retry Error.
Maximum number of retries exceeded.
  • 0x0: No interrupt
  • 0x1: Active
21
IRQ_RX_ERR
Interrupt RX Error.
No or incomplete or unexpected data.
  • 0x0: No interrupt
  • 0x1: Active
20
IRQ_DONE
Interrupt Done.
Requested operation has been completed.
  • 0x0: No interrupt
  • 0x1: Active
19:18
17
PRESENCE_STAT
0x1
Status of presence IO.
  • 0x0: Absent
  • 0x1: Presence
16
BUSY
Status of SIM interface.
  • 0x0: Idle
  • 0x1: Busy
15
14:12
TX_RETRY_MAX
Transmit Retries Maximum.
Maximum number of seen transmit retries after error signaling by SIM.
11
10:8
RX_RETRY_MAX
Receive Retries Maximum.
Maximum number of seen receive retries after parity error.
7
6:4
IO_STAT
IO States.
  • 0x0: IO pin is driven low.
  • 0x1: IO pin is high impedance and driven high by the pull-up.
  • 0x4: Wait for start bit.
  • 0x5: Receive.
  • 0x6: Transmit.
  • 0x7: Wait until next character to ensure configured guard time.
3:0
PWR_STAT
Power States.
  • 0x0: SIM is unpowered.
  • 0x1: Power up SIM. RST asserted (low). Clock stopped. IO is tristate.
  • 0x2: Power up SIM. RST asserted (low). Clock is running. IO is high.
  • 0x3: Power up SIM. RST asserted (low). Clock is running. IO is tristate.
  • 0x4: Power up SIM. RST asserted (low). Clock stopped. IO is low.
  • 0x5: Preparing clock stop.
  • 0x6: Clock stopped.
  • 0x7: Exiting clock stop
  • 0x8: SIM is idle, no communication is ongoing.
  • 0x9: RX TS0 Character.
  • 0xA: RX TS1 Character.
  • 0XB: Receive.
  • 0xC: Transmit.
  • 0xD: Transmit and Receive.
CLK_CFG
  • Name: Clock Configuration Register
  • Description: This register configure clock.
  • Offset: 0x08
  • Reset Value: 0x002F0173
表 243 Clock Configuration Register
31
CLK_STOP_SEL
Clock Stop Select.
Value of the clock output during stopped clock.
  • 0x0: Low
  • 0x1: High
30:24
23:16
CLK_DIV
0x2F
Clock Division.
Divide system clock by this value + 1.
15:10
9:0
ETU_DIV
0x173
Divide SIM clock by this value+1 to define ETU length. The reset value is the one, needed for the ATR.
TIMES_CFG
  • Name: Times Configuration Register
  • Description: This register configures the timing
  • Offset: 0x10
  • Reset Value: 0x006B0000
表 244 Times Configuration Register
31:30
29:12
WAIT_TIME
0x6B
Wait time in [ETU].
Maximum card response time (leading edge to leading edge).
11:10
9:0
GUARD_TIME
Guard time in [ETU].
Time between the leading edges of two consecutive characters.
DATA_CFG
  • Name: Data Configuration Register
  • Description: This register configures the communication
  • Offset: 0x14
  • Reset Value: 0x00000002
表 245 Data Configuration Register
31:7
6:4
RETRY_LIMIT
Retries Limit.
Maximum number of issued retries before giving up.
3:2
DETECT_CODING
0x1
Detect Coding Convention.
Automatically detect coding convention during ATR reception.
  • 0x0: Disable
  • 0x1: Enable
CODING
Coding Convention.
  • 0x0: Default. High = 1, LSB first.
  • 0x1: Inverse. High = 0, MSB first.
ADDR
  • Name: Address Register
  • Description: This register records current address relative to base_addr.
  • Offset: 0x18
表 246 Address Register
31:20
19:2
ADDR
Address.
Current address relative to base_addr.
1:0
ADDR_FRAC
Address Fraction.
Byte selection.
START_ADDR
  • Name: Start Address Register
  • Description: This register configures read/write memory address. RX and TX buffer has to be aligned to 4 bytes, and buffer address [31:2] = START_ADDR[31:2]
  • Offset: 0x1c
表 247 Start Address Register
31:20
BASE_ADDR
Base Address.
Base Address for RX and TX Buffer.
19:2
START_ADDR
Start Address.
Start address of RX and TX buffer, relative to base_addr.
1:0
RX_END_ADDR
  • Name: RX End Register
  • Description: This register configures RX data end address
  • Offset: 0x20
表 248 RX End Register
31:20 RSVD R Reserved bits
19:2 RX_END_ADDR RW 0x0
RX End Address.
End address of receive buffer, relative to base_addr.
1:0 RX_END_AF RW 0x0
RX End Address Fraction.
Byte selection.
TX_END_ADDR
  • Name: TX End Register
  • Description: This register configures TX data end address
  • Offset: 0x24
表 249 TX End Register
31:20
19:2
TX_END_ADDR
TX End Address.
End address of transmit buffer, relative to base_addr.
1:0
TX_END_AF
TX End Address Fraction.
Byte selection.
