FIFO_RD
  • Name: Sense ADC FIFO Register
  • Description: Reading this register will pop an entry from the sense ADC FIFO.
  • Base Address: 0xA000E000
  • Offset: 0x00
表 204 Sense ADC FIFO Register
31:0
DATA
When the register is read, data in the FIFO buffer is accessed.
FIFO_THD
  • Name: Sense ADC FIFO Threshold Register
  • Description: This register is used to set the threshold at which the DMA request is made to the hardware handshake mechanism.
  • Offset: 0x100
表 205 Sense ADC FIFO Threshold Register
31:6
5:0
THD
This is used to set the threshold at which the DMA request is made to the hardware handshake mechanism.
FIFO_STAT
  • Name: Sense ADC Status Register
  • Description: This register contains the number of valid data entries in the ADC FIFO memory.
  • Offset: 0x104
表 206 Sense ADC Status Register
31:9
8
VAL
Identify whether FIFO is empty
  • 0x0: FIFO is empty
  • 0x1: FIFO is not empty
7
6:0
COUNT
Sense ADC FIFO Count, number of 32-bit words in the FIFO. Maximum value is 0x40 or decimal 64.
CFG
  • Name: Sense ADC Configuration Register
  • Description: This register is used to configure reference, channels and input mode of ADC.
  • Base Address: 0xA000C500
  • Offset: 0x08
  • Reset Value: 0x0708070A
表 207 Sense ADC Configuration Register
31
RST
Reset ADC
  • 0x0: None
  • 0x1: Reset
30
EN
Enable ADC
  • 0x0: Disable ADC
  • 0x1: Enable ADC
29:27
REF_SEL
Reference Voltage Select
  • 0x0: Buffered internal reference
  • 0x1: Reserved
  • 0x2: Reserved
  • 0x3: Using MSIO0 as a reference
  • 0x4: Using MSIO1 as a reference
  • 0x5: Using MSIO2 as a reference
  • 0x6: Using MSIO3 as a reference
  • 0x7: Reserved
Because the maximum input for any MSIO is supposed to be VBATT. So in this case, there is no benefit from using an external input higher than VBATT/2.
26:24
REF_HP_MODE
0x7
Used to define current in the reference circuit :Default-<0x0> at 100 Ksps and <0x7> at 1 Msps
23:22
Reserved
21:19
CH_P
0x1
Used to define input for channel P
  • 0x0: MSIO0 as input
  • 0x1: MSIO1 as input
  • 0x2: MSIO2 as input
  • 0x3: MSIO3 as input
  • 0x4: MSIO4 as input
18:16
CH_N
Used to define input for channel N
  • 0x5: Temperature sensor as input
  • 0x6: Battery sensor as input
  • 0x7: Internal reference as input
15
EN_TMP
Enable temperature sensor
  • 0x0: Disable
  • 0x1: Enable
14
EN_VBAT
Enable battery sensor
  • 0x0: Disable
  • 0x1: Enable
13
MODE
Used to define operation either single ended or differential.
  • 0x0: Differential
  • 0x1: Single ended
12
EN_CAL
Used to swap inputs of comparator for offset calibration.
  • 0x0: Disable
  • 0x1: Enable
11
10:8
CODE_IN
0x7
Used to define dynamic range of ADC. Default set to <0x7>, for higher input signal frequencies close to Nyquist rate use <0x1>
7:4
3:0
BIAS_RES_CTRL
0xA
  • 0x3: 0.85 V
  • 0x7: 1.28 V
  • 0xA: 1.6 V
For any specific reference value (Vref), the maximum ADC input is supposed to be 2 x Vref.
CLK
  • Name: Sense ADC Clock Register
  • Description: This register selects ADC clock.
  • Offset: 0x40
表 208 Sense ADC Clock Register
31
CLK_EN
Enable ADC clock
  • 0x0: Disable
  • 0x1: Enable
30:28
CLK_SEL
ADC clock select
  • 0x0: 16 MHz
  • 0x1: 8 MHz
  • 0x2: 4 MHz
  • 0x3: 2 MHz
  • 0x4: 1.6 MHz
  • 0x5: 1 MHz
27:0
