GPIO Electrical Specifications
The electrical parameters for the GPIO_0 – GPIO_31 and AON_GPIO_0 – AON_GPIO_7 are as follows:
| VIH | Input high voltage | VDDIO x 0.7 | VDDIO | V | |
| VIL | Input low voltage | VSSIO | VDDIO x 0.3 | V | |
| VOH,L | Output high voltage, 2 mA, VDD ≥1.7 V | VDD - 0.4 | VDD | V | |
| VOH,M | Output high voltage, 2.5 mA, VDD ≥ 2.5 V | VDD - 0.4 | VDD | V | |
| VOH,H | Output high voltage, 2.5 mA, VDD ≥ 3 V | VDD - 0.4 | VDD | V | |
| VOL,L | Output low voltage, 2 mA, VDD ≥1.7 V | VSS | VSS + 0.4 | V | |
| VOL,M | Output low voltage, 2.5 mA, VDD ≥ 2.5 V | VSS | VSS + 0.4 | V | |
| VOL,H | Output low voltage, 2.5 mA, VDD ≥ 3 V | VSS | VSS + 0.4 | V | |
| IOL,L | Current at VSS+0.4 V, output set low, VDD ≥ 1.7 V | 2 | 2.5 | mA | |
| IOL,M | Current at VSS+0.4 V, output set low, VDD ≥ 2.5 V | 2.5 | 3 | mA | |
| IOH,L | Current at VDD-0.4 V, output set high, VDD ≥ 1.7 V | 2 | 2.5 | mA | |
| IOH,M | Current at VDD-0.4 V, output set high, VDD ≥ 2.5 V | 2.5 | 2.8 | mA | |
| tRF,15pF | Rise/Fall time, 10% - 90%, 15 pF load | 8 | ns | ||
| tRF,25pF | Rise/Fall time, 10% - 90%, 25 pF load | 13 | ns | ||
| RPU | Pull-up resistance | 70 | 120 | 150 | kΩ |
| RPD | Pull-down resistance | 70 | 120 | 150 | kΩ |
| CPAD | Pad capacitance | 5 | pF |
