文档中心 > GR551x Datasheet/ Peripherals / I2S/ Registers Copy URL
EN
  • Name: I2S Enable Register
  • Description: This register acts as a global enable/disable for I2S.
  • Base Address: 0xA000CA00(master) and 0xA000F000(slave)
  • Offset: 0x0
表 211 I2S Enable Register
31:1
I2S_EN
I2S enable.
This bit enables or disables I2S. A disable on this bit overrides any other block or channel enables and flushes all FIFOs.
  • 0x0: I2S disabled.
  • 0x1: I2S enabled
RX_EN
  • Name: I2S Receiver Block Enable Register
  • Description: This register acts as an enable/disable for the I2S Receiver block.
  • Offset: 0x4
表 212 I2S Receiver Block Enable Register
31:1
RX_EN
Receiver block enable.
This bit enables or disables the receiver. A disable on this bit overrides any individual receive channel enables.
  • 0x0: Receiver disabled
  • 0x1: Receiver enabled
TX_EN
  • Name: I2S Transmitter Block Enable Register
  • Description: This register acts as an enable/disable for the I2S Transmitter block.
  • Offset: 0x8
表 213 I2S Transmitter Block Enable Register
31:1
TX_EN
Transmitter block enable.
This bit enables or disables the transmitter. A disable on this bit overrides any individual transmit channel enables.
  • 0x0: Transmitter disabled
  • 0x1: Transmitter enabled
CLK_EN
  • Name: Clock Enable Register
  • Description: This register acts as an enable/disable for the I2S clock generation block.
  • Offset: 0xC
表 214 Clock Enable Register
31:1
CLK_EN
Clock Generation enable/disable.
This bit enables or disables the clock generation signals when I2S is a master.
  • 0x0: Clock generation disabled
  • 0x1: Clock generation enabled
When the I2S is configured as a slave, this register serves no purpose.
SCLK_CFG
  • Name: Clock Configuration Register
  • Description: This register configures the WS when I2S is a master.
  • Offset: 0x10
表 215 Clock Configuration Register
31:5
4:3
WS_SCLK
These bits are used to program the number of SCLK cycles for which the word select line (ws_out) stays in the left or right sample mode. The I2S Clock Generation block must be disabled (CLK_EN [0] = 0) prior to any changes in this value.
  • 0x0: 16 SCLK cycles
  • 0x1: 24 SCLK cycles
  • 0x2: 32 SCLK cycles
2:0
SCLK_GAT
These bits are used to program the gating of SCLK. The programmed gating value must be less than or equal to the largest configured/programmed audio resolution to prevent the truncating of RX/TX data. The I2S Clock Generation block must be disabled (CLK_EN[0] = 0) before making any changes in this value.
Values:
  • 0x0 (NO_CLOCK_GATING): Clock gating is disabled
  • 0x1 (CLOCK_CYCLES_12): Gating after 12 SCLK cycles
  • 0x2 (CLOCK_CYCLES_16): Gating after 16 SCLK cycles
  • 0x3 (CLOCK_CYCLES_20): Gating after 20 SCLK cycles
  • 0x4 (CLOCK_CYCLES_24): Gating after 24 SCLK cycles
This register is only relevant when component is configured to be a master (I2S_MODE_EN = 1).
RX_FIFO_RST
  • Name: Receiver Block FIFO Reset Register
  • Description: This register specifies the Receiver Block FIFO Reset Register.
  • Offset: 0x14
表 216 Receiver Block FIFO Reset Register
31:1
W
RX_FIFO_RST
W
Receiver FIFO Reset.
Writing a 1 to this register flushes all the RX FIFOs (this is a self-clear bit). The Receiver Block must be disabled before writing to this bit.
  • 0x0: Do not flush the RX FIFO
  • 0x1: Flush the RX FIFO
TX_FIFO_RST
  • Name: Transmitter Block FIFO Reset Register
  • Description: This register specifies the Transmitter Block FIFO Reset Register.
  • Offset: 0x18
表 217 Transmitter Block FIFO Reset Register
31:1
W
TX_FIFO_RST
W
Transmitter FIFO Reset.
Writing a 1 to this register flushes all the TX FIFOs (this is a self-clear bit). The Transmitter Block must be disabled prior to writing this bit.
  • 0x0: Do not flush the TX FIFO
  • 0x1: Flush the TX FIFO
LEFT_RX_BUF
  • Name: Left Receive Buffer Register
  • Description: This specifies the Left Receive Buffer Register.
  • Offset: 0x20
表 218 Left Receive Buffer Register
31:0
LEFT_RX_BUF
The left stereo data received serially from the receive channel input (sdi). If the RX FIFO is full and the two-stage read operation (for instance, a read from LEFT_RX_BUF followed by a read from RIGHT_RX_BUF) is not performed before the start of the next stereo pair, then the new data is lost and an overrun interrupt occurs. (Data already in the RX FIFO is preserved.)
Before reading this register again, the right stereo data must be read from RIGHT_RX_BUFx or the status/interrupts will not be valid.
LEFT_TX_HDG
  • Name: Left Transmit Holding Register
  • Description: This specifies the Left Transmit Holding Register
  • Offset: 0x20
表 219 Left Transmit Holding Register
31:0
LEFT_TX_HDG
W
The left stereo data to be transmitted serially through the transmit channel output (sdo) is written through this register.
Writing is a two-stage process:
  • A write to this register passes the left stereo sample to the transmitter
  • This MUST be followed by writing the right stereo sample to the RIGHT_TX_HDG register
Data must only be written to the FIFO when it is not full. Any attempt to write to a full FIFO results in that data being lost and an overrun interrupt being generated.
RIGHT_RX_BUF
  • Name: Right Receive Buffer Register
  • Description: This specifies the Right Receive Buffer Register
  • Offset: 0x24
表 220 Right Receive Buffer Register
31:0
RIGHT_RX_BUF
The right stereo data received serially from the receive channel input (SDI) is read through this register. If the RX FIFO is full and the two-stage read operation (for instance, read from LEFT_RX_BUF followed by a read from RIGHT_RX_BUF) is not performed before the start of the next stereo pair, then the new data is lost and an overrun interrupt occurs. (Data already in the RX FIFO is preserved.)
Prior to reading this register, the left stereo data must be read from LEFT_RX_BUF, or the status/interrupts will not be valid.
RIGHT_TX_HDG
  • Name: Right Transmit Holding Register
  • Description: This specifies the Right Transmit Holding Register.
  • Offset: 0x24
表 221 Right Transmit Holding Register
31:0
RIGHT_TX_HDG
W
The right stereo data to be transmitted serially through the transmit channel output (SDO) is written through this register.
  • A left stereo sample must be written to the LEFT_TX_HDG register
  • A write to this register passes the right stereo sample to the transmitter
Data should only be written to the FIFO when it is not full. Any attempt to write to a full FIFO results in that data being lost and an overrun interrupt being generated.
RX_CH_EN
  • Name: Receive Enable Register
  • Description: This specifies the Receive Enable Register.
  • Offset: 0x28
  • Reset Value: 0x00000001
表 222 Receive Enable Register
31:1
RX_CH_EN
0x1
Receive channel enable. This bit enables/disables a receive channel.
On enable, the channel begins receiving on the next left stereo cycle.
A global disable of I2S (EN[0] = 0) or the Receiver block (RX_EN[0] = 0) overrides this value.
  • 0x0: Receive Channel Disable
  • 0x1: Receive Channel Enable
TX_CH_EN
  • Name: Transmit Enable Register
  • Description: This specifies the Transmit Enable Register.
  • Offset: 0x2c
表 223 Transmit Enable Register
31:1
TX_CH_EN
0x1
Transmit channel enable. This bit enables/disables a transmit channel.
On enable, the channel begins transmitting on the next left stereo cycle.
A global disable of I2S (EN[0] = 0) or Transmitter block (TX_EN[0] = 0) overrides this value.
  • 0x0: Transmit Channel Disable
  • 0x1: Transmit Channel Enable
RX_CFG
  • Name: Receive Configuration Register
  • Description: This specifies the Receive Configuration Register
  • Offset: 0x30
  • Reset Value: 0x00000005
表 224 Receive Configuration Register
31:3
2:0
WORD_LEN
0x5
These bits are used to program the desired data resolution of the receiver and enables the LSB of the incoming left (or right) word to be placed in the LSB of the LEFT_RX_BUF (or RIGHT_RX_BUF) register.
Programmed data resolution must be less than or equal to 0x5. If the selected resolution is greater than the 0x5, the receive channel defaults back to 0x5.
The channel must be disabled prior to any changes in this value (RX_EN0[0] = 0).
  • 0x0: Ignore the word length
  • 0x1: 12-bit data resolution of the receiver.
  • 0x2: 16-bit data resolution of the receiver.
  • 0x3: 20-bit data resolution of the receiver.
  • 0x4: 24-bit data resolution of the receiver.
  • 0x5: 32-bit data resolution of the receiver.
TX_CFG
  • Name: Transmit Configuration Register
  • Description: This specifies the Transmit Configuration Register.
  • Offset: 0x34
表 225 Transmit Configuration Register
31:3
2:0
WORD_LEN
0x5
These bits are used to program the data resolution of the transmitter and ensures the MSB of the data is transmitted first.
Programmed resolution must be less than or equal to 0x5. If the selected resolution is greater than 0x5, the transmit channel defaults back to 0x5.
The channel must be disabled prior to any changes in this value (TX_EN [0] = 0).
  • 0x1: 12-bit data resolution of the transmitter.
  • 0x2: 16-bit data resolution of the transmitter.
  • 0x3: 20-bit data resolution of the transmitter.
  • 0x4: 24-bit data resolution of the transmitter.
  • 0x5: 32-bit data resolution of the transmitter.
INT_STAT
  • Name: Interrupt status Register
  • Description: This specifies the Interrupt Status Register.
  • Offset: 0x38
  • Reset Value: 0x00000010
表 226 Interrupt status Register
31:6
5
TX_FIFO_OVER
Status of Data Overrun interrupt for the TX channel.
This bit specifies whether the TX FIFO write is valid or an overrun. Attempt to write to full TX FIFO.
  • 0x0: TX FIFO write valid
  • 0x1: TX FIFO write overrun
4
TX_FIFO_EMPTY
0x1
Status of Transmit Empty Trigger interrupt.
This bit specifies whether the TX FIFO trigger level has reached or not. TX FIFO is empty.
  • 0x0: TX FIFO trigger level is reached
  • 0x1: TX FIFO trigger level is not reached
3:2
RX_FIFO_OVER
Status of Data Overrun interrupt for the RX channel. Incoming data lost due to a full RX FIFO.
  • 0x0: RX FIFO write valid
  • 0x1: RX FIFO write overrun
RX_DATA_AVL
Status of Receive Data Available interrupt. This bit denotes the status of the RX FIFO trigger level.
  • 0x0: RX FIFO trigger level is not reached
  • 0x1: RX FIFO trigger level is reached
INT_MASK
  • Name: Interrupt Mask Register
  • Description: This specifies the Interrupt Mask Register
  • Offset: 0x3c
  • Reset Value: 0x00000033
表 227 Interrupt Mask Register
31:6
5
TX_FOM
0x1
Mask TX FIFO Overrun interrupt.
This bit masks or unmasks a TX FIFO overrun interrupt.
  • 0x0: Enable TX FIFO Overrun interrupt
  • 0x1: Disable TX FIFO Overrun interrupt
4
TX_FEM
0x1
Mask TX FIFO Empty interrupt.
This bit masks or unmasks a TX FIFO Empty interrupt.
  • 0x0: Enable TX FIFO Empty interrupt
  • 0x1: Disable TX FIFO Empty interrupt
3:2
RX_FOM
0x1
Mask RX FIFO Overrun interrupt.
This bit masks or unmasks an RX FIFO Overrun interrupt.
  • 0x0: Enable RX FIFO Overrun interrupt
  • 0x1: Disable RX FIFO Overrun interrupt
RX_DAM
0x1
Mask RX FIFO Data Available interrupt.
This bit masks or unmasks an RX FIFO Data Available interrupt.
  • 0x0: Enable RX FIFO data available interrupt
  • 0x1: Disable RX FIFO data available interrupt
RX_OVER
  • Name: Receive Overrun Register
  • Description: This specifies the Receive Overrun Register
  • Offset: 0x40
表 228 Receive Overrun Register
31:1
RX_CLR_FDO
Read this bit to clear the RX FIFO Data Overrun interrupt.
TX_OVER
  • Name: Transmit Overrun Register
  • Description: This specifies the Transmit Overrun Register.
  • Offset: 0x44
表 229 Transmit Overrun Register
31:1
TX_CLR_FDO
0X0
Read this bit to clear the TX FIFO Data Overrun interrupt.
RX_FIFO_CFG
  • Name: Receive FIFO Configuration Register
  • Description: This specifies the Receive FIFO Configuration Register
  • Offset: 0x48
  • Reset Value: 0x00000008
表 230 Receive FIFO Configuration Register
31:4
3:0
RX_FIFO_TL
0x8
These bits program the trigger level in the RX FIFO at which the Received Data Available interrupt is generated.
Trigger Level = Programmed Value + 1
  • 0x0: Interrupt trigger when FIFO level is 1.
  • 0x1: Interrupt trigger when FIFO level is 2.
  • 0x2: Interrupt trigger when FIFO level is 3.
  • 0x3: Interrupt trigger when FIFO level is 4.
  • 0x4: Interrupt trigger when FIFO level is 5.
  • 0x5: Interrupt trigger when FIFO level is 6.
  • 0x6: Interrupt trigger when FIFO level is 7.
  • 0x7: Interrupt trigger when FIFO level is 8.
  • 0x8: Interrupt trigger when FIFO level is 9.
  • 0x9: Interrupt trigger when FIFO level is 10.
  • 0xA: Interrupt trigger when FIFO level is 11.
  • 0xB: Interrupt trigger when FIFO level is 12.
  • 0xC: Interrupt trigger when FIFO level is 13.
  • 0xD: Interrupt trigger when FIFO level is 14.
  • 0xE: Interrupt trigger when FIFO level is 15.
  • 0xF: Interrupt trigger when FIFO level is 16.
TX_FIFO_CFG
  • Name: Transmit FIFO Configuration Register
  • Description: This specifies the Transmit FIFO Configuration Register.
  • Offset: 0x4C
表 231 Transmit FIFO Configuration Register
31:4
3:0
TX_FIFO_TL
0x8
These bits program the trigger level in the TX FIFO at which the Empty Threshold Reached Interrupt is generated.
Trigger Level = TX_FIFO_TL
RX_FIFO_FLUSH
  • Name: Receive FIFO Flush Register
  • Description: This specifies the Receive FIFO Flush Register.
  • Offset: 0x50
表 232 Receive FIFO Flush Register
31:1
W
RX_FIFO_RST
W
Receive Channel FIFO Reset.
Writing a 1 to this register flushes an individual RX FIFO (This is a self-clear bit.). A RX channel or block must be disabled prior to writing to this bit.
  • 0x0: Do not flush an individual RX FIFO.
  • 0x1: Flush an individual RX FIFO.
TX_FIFO_FLUSH
  • Name: Transmit FIFO Flush Register
  • Description: This specifies the Transmit FIFO Flush Register.
  • Offset: 0x54
表 233 Transmit FIFO Flush Register
31:1
W
TX_FIFO_RST
W
Transmit Channel FIFO Reset.
Writing a 1 to this register flushes an individual TX FIFO (This is a self-clear bit.). A TX channel or block must be disabled prior to writing to this bit.
  • 0x0: Do not flush an individual TX FIFO.
  • 0x1: Flush an individual TX FIFO.
RX_DMA
  • Name: Receiver Block DMA Register
  • Description: The RX_DMA register allows access to receive channel via a single point rather than through the LEFT_RX_BUF and RIGHT_RX_BUF registers. The receive channel is targeted in a cyclical fashion (starting at the lowest numbered enabled channel) and takes two reads (left and right stereo data) before the component points to the next channel.
  • Offset: 0x1c0
表 234 Receiver Block DMA Register
31:1
RX_DMA
Receiver Block DMA Register.
These bits are used to cycle repeatedly through the enabled receive channel, reading stereo data pairs.
RST_RX_DMA
  • Name: Reset Receiver Block DMA Register
  • Description: The RX_DMA can be reset to the enabled Channel via the RST_RX_DMA register. The RST_RX_DMA register can be written to at any stage of the RX_DMA's read cycle, however, it has no effect when the component is in the middle of a stereo pair read.
  • Base Address: 0xA000CA00 (master) and 0xA000F000 (slave)
  • Offset: 0x1C4
表 235 Reset Receiver Block DMA Register
31:1
W
RST_RX_DMA
W
Reset Receiver Block DMA Register.
Writing a 1 to this self-clearing register resets the RX_DMA register mid-cycle to point to the enabled Receive channel.
  • 0x0: No effect.
  • 0x1: Reset receiver block DMA register.
TX_DMA
  • Name: Transmitter Block DMA Register
  • Description: The TX_DMA register functions similar to the RX_DMA register and allows write access to all of the enabled Transmit channel via a single point rather than through the LEFT_TX_HDG and RIGHT_TX_HDG registers.
  • Offset: 0x1c8
表 236 Transmitter Block DMA Register
31:1
TX_DMA
Transmitter Block DMA Register.
These bits are used to cycle repeatedly through the enabled transmit channel to allow writing of stereo data pairs.
RST_TX_DMA
  • Name: Reset Transmitter Block DMA Register
  • Description: This register provides the same functionality as the RST_RX_DMA register but targets TX_DMA instead.
  • Offset: 0x1cc
表 237 Reset Transmitter Block DMA Register
31:1
W
RST_TX_DMA
W
Reset Transmitter Block DMA Register.
Writing a 1 to this self-clearing register resets the TX_DMA register mid-cycle to point to the enabled Transmit channel.
  • 0x0: No effect.
  • 0x1: Reset transmitter block DMA register.
CLK_CFG
  • Name: I2S Clock Configure Register
  • Description: This register is used to configure I2S master clock.
  • Offset: 0x268
  • Reset Value: 0x00040008
表 238 I2S Clock Configure Register
31:19
18
CLK_SRC_SEL
0x1
clock divider source select 0:96 M, 1:32 M
17
16
DIV_EN
Enable I2S clock divider
15:12
11:0
DIV
0x8
ratio = 1/(div + 2). Duty cycle is not 50 when the number is odd.
For example:
div = 0, ratio = 1/2
