文档中心 > GR551x Datasheet/ Peripherals / GPIO/ Electrical Specifications Copy URL
GPIO Electrical Specifications
The electrical parameters for the GPIO_0 – GPIO_31 and AON_GPIO_0 – AON_GPIO_7 are as follows:
表 58 GPIO electrical specifications
VIH Input high voltage VDDIO x 0.7 VDDIO V
VIL Input low voltage VSSIO VDDIO x 0.3 V
VOH,L Output high voltage, 2 mA, VDD ≥1.7 V VDD - 0.4 VDD V
VOH,M Output high voltage, 2.5 mA, VDD ≥ 2.5 V VDD - 0.4 VDD V
VOH,H Output high voltage, 2.5 mA, VDD ≥ 3 V VDD - 0.4 VDD V
VOL,L Output low voltage, 2 mA, VDD ≥1.7 V VSS VSS + 0.4 V
VOL,M Output low voltage, 2.5 mA, VDD ≥ 2.5 V VSS VSS + 0.4 V
VOL,H Output low voltage, 2.5 mA, VDD ≥ 3 V VSS VSS + 0.4 V
IOL,L Current at VSS+0.4 V, output set low, VDD ≥ 1.7 V 2 2.5 mA
IOL,M Current at VSS+0.4 V, output set low, VDD ≥ 2.5 V 2.5 3 mA
IOH,L Current at VDD-0.4 V, output set high, VDD ≥ 1.7 V 2 2.5 mA
IOH,M Current at VDD-0.4 V, output set high, VDD ≥ 2.5 V 2.5 2.8 mA
tRF,15pF Rise/Fall time, 10% - 90%, 15 pF load 8 ns
tRF,25pF Rise/Fall time, 10% - 90%, 25 pF load 13 ns
RPU Pull-up resistance 70 120 150
RPD Pull-down resistance 70 120 150
CPAD Pad capacitance 5 pF
