CTRL
  • Name: Timer Control Register
  • Description: The CTRL register enables the software to control the Timer unit.
  • Base Address: 0xA0000000 + x*0x1000
  • Offset: 0x0000
  • Reset Value: 0x00
表 59 Timer Control Register
31:4 RSVD R Reserved bits
3 INT_EN RW 0x0
Timer interrupt enable
  • 0x0: Disable the timer interrupt
  • 0x1: Enable the timer interrupt
2:1 RSVD R Reserved bits
0 EN RW 0x0
VAL
  • Name: Timer Value Register
  • Description: The VAL register indicates the current value of the decrementing counter.
  • Offset: 0x04
  • Reset Value: 0x00
表 60 Timer Value Register
31:0 COUNT RW 0x0 Current value
RELOAD
  • Name:Timer Reload Register
  • Description: When this register is written to, the count is immediately restarted from the new value.
  • Offset: 0x08
  • Reset Value: 0x00
表 61 Timer Reload Register
31:0 COUNT RW 0x0 Reload value. Write the current value to this register.
INT_STAT
  • Name: Timer Interrupt Status Register
  • Description: The INT_STAT register indicates the interrupt status from the counter. Write 1 to this register to clear the timer interrupt flag.
  • Offset: 0x0C
表 62 Timer Interrupt Status Register
31:1 RSVD R Reserved bits
0 STAT RW 0x0 Timer interrupt. Write one to clear.
