LOAD
  • Name: System Watchdog Load Register
  • Description: The LOAD register contains the value from which the counter is to decrease. When this register is written to, the count is immediately restarted from the new value. The minimum valid value for LOAD register is 1.
  • Base Address: 0xA0008000
  • Offset: 0x0000
  • Reset Value: 0xFFFFFFFF
表 69 System Watchdog Load Register
31:0 COUNT RW 0xFFFFFFFF Reload value. A write to this register sets the current value.
VAL
  • Name: System Watchdog Value Register
  • Description: This is a read-only register used to indicate the current value of the decrementing counter.
  • Offset: 0x04
表 70 System Watchdog Value Register
31:0 COUNT RO 0xFFFFFFFF Current value of the watchdog counter
CTRL
  • Name: System Watchdog Control Register
  • Description: The CTRL register enables the software to control the watchdog unit.
  • Offset: 0x0008
  • Reset Value: 0x00
表 71 System Watchdog Control Register
31:2 RSVD R Reserved bits
1 RST_EN RW 0x0
Enable watchdog reset output.
  • 0x0: Disable the reset.
  • 0x1: Enable the reset.
0 INT_EN RW 0x0
Enable the interrupt event. Reload the counter from the value in LOAD register when the interrupt is enabled, after previously being disabled.
  • 0x0: Disable the counter and the interrupt.
  • 0x1: Enable the counter and the interrupt.
INT_CLR
  • Name: System Watchdog Clear Interrupt Register
  • Description: A write of any value to the INT_CLR register clears the watchdog interrupt, and reloads the counter from the value in LOAD register.
  • Offset: 0x0C
  • Reset Value:0x00000000
表 72 System Watchdog Clear Interrupt Register
31:0 CLR WO 0x0 Clear the watchdog interrupt event.
INT_RAW_STAT
  • Name: System Watchdog Raw Interrupt Status Register
  • Description: The INT_RAW_STAT register indicates the raw interrupt status from the counter.
  • Offset: 0x10
表 73 System Watchdog Raw Interrupt Status Register
31:1 RSVD R Reserved bits
0 RAW_STAT RO 0x0 Raw interrupt status from the counter
INT_STAT
  • Name: System Watchdog Interrupt Status Register
  • Description: The INT_STAT register indicates the masked interrupt status from the counter.
  • Offset: 0x14
表 74 System Watchdog Interrupt Status Register
0 STAT RO 0x0 Enable interrupt status from the counter.
LOCK
  • Name: System Watchdog Lock Register
  • Description: The LOCK register disables write access to all other registers. This is to prevent rogue software from disabling the watchdog functionality. Writing a value of 0x1ACCE551 enables write access to all other registers. Write any other value disables write access.
  • Offset: 0x0C00
表 75 System Watchdog Lock Register
31:1 WR_EN RW 0x0 Enable write access to all other registers by writing 0x1ACCE551. Disable write access by writing any other value.
0 WR_EN_STAT RW 0x0
Register write enable status
  • 0x0: Write access to all other registers is enabled. This is the default.
  • 0x1: Write access to all other registers is disabled.
