DPAD_RE_N
  • Name: GPIO pull up/down resistor enable register
  • Description: This register decides whether to use a pull up/down resistor.
  • Base Address: 0xA000E000
  • Offset: 0x208
表 40 DPAD_RE_N
31:0 DPAD_RE_N RW 0x0
Enable a pull up/down resistor to the RETENTION PAD.
  • 0x0: Enable resistor inputs to pad (GPIO_0 - GPIO_31)
  • 0x1: Disable resistor inputs to pad (GPIO_0 - GPIO_31)
DPAD_RTYPE
  • Name: GPIO pull resistor type control register
  • Description: This register chooses the pull resistor type.
  • Offset: 0x210
表 41 DPAD_RTYPE
31:0 DPAD_RTYPE RW 0x0
Resistor type inputs to the RETENTION PAD.
  • 0x0: Pull down (when DPAD_RE_N = 0)
  • 0x1: Pull up (when DPAD_RE_N = 0)
GPIOx_DATA
  • Name: GPIO data value register
  • Description: This register contains the input data and can write data output register.
  • Base Address: 0xA0010000 + x*0x1000
  • Offset: 0x0000
  • Reset Value:0x00000000
表 42 GPIO data value register
31:16 RSVD R Reserved bits
15:0 DATA RW 0x0
Data value [15:0]
Read: The input level state(high or low) at pin
Write: To data output register
GPIOx_DATA_OUT
  • Name: GPIO data output register
  • Description: This register contains the output data.
  • Offset: 0x0004
表 43 GPIO data output register
15:0 DATA_OUT RW 0x0
Data output register value [15:0]
Read: Current value of data output register
GPIOx_OUT_EN
  • Name: GPIO output enable register
  • Description: This register is used to enable output.
  • Offset: 0x0010
表 44 GPIO output enable register
15:0 EN RW 0x0
Output enable set [15:0]
Read:
  • 0x0: As input
  • 0x1: As output
Write:
  • 0x0:No effect.
  • 0x1:Set the output enable bit
GPIOx_OUT_CLR
  • Name: GPIO output clear register
  • Description: This register is used to disable output.
  • Offset: 0x0014
表 45 GPIO output clear register
15:0 CLR RW 0x0
Output enable clear [15:0]
Read:
  • 0x0: As input
  • 0x1:As output
Write:
  • 0x0:No effect
  • 0x1:Clear the output enable bit
GPIOx_INT_EN
  • Name: GPIO interrupt enable register
  • Description: This register is used to enable GPIO interrupt.
  • Offset: 0x0020
表 46 GPIO interrupt enable register
15:0 EN RW 0x0
Interrupt enable set [15:0]
Read:
  • 0x0: Interrupt disabled
  • 0x1: Interrupt enabled
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt enable bit
GPIOx_INT_CLR
  • Name: GPIO interrupt clear register
  • Description: This register is used to disable GPIO interrupt.
  • Offset: 0x0024
表 47 GPIO interrupt clear register
15:0 CLR RW 0x0
Interrupt enable clear [15:0]
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt enable bit
GPIOx_INT_TYPE_EN
  • Name: GPIO interrupt type enable register
  • Description: This register is used to set GPIO interrupt type. If interrupt type is 0 and interrupt polarity is 0, Low-level trigger interrupt. If interrupt type is 0 and interrupt polarity is 1, High-level trigger interrupt. If interrupt type is 1 and interrupt polarity is 0, Falling edge trigger interrupt. If interrupt type is 1 and interrupt polarity is 1, Rising edge trigger interrupt.
  • Offset: 0x0028
表 48 GPIO interrupt type enable register
15:0 EN RW 0x0
Interrupt type set [15:0]
Read:
  • 0x0: LOW or HIGH level
  • 0x1: Falling edge or rising edge
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt type bit
GPIOx_INT_TYPE_CLR
  • Name: GPIO interrupt type clear register
  • Description: This register is used to disable GPIO interrupt type.
  • Offset: 0x002C
表 49 GPIO interrupt type clear register
15:0 CLR RW 0h 0
Interrupt type clear [15:0]
Read:
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt type bit
GPIOx_INT_POL_EN
  • Name: GPIO interrupt polarity enable register
  • Description: This register is used to enable GPIO interrupt polarity.
  • Offset: 0x0030
表 50 GPIO interrupt polarity enable register
15:0 EN RW 0h 0
Polarity-level, edge IRQ configuration [15:0]
Read:
  • 0x0: LOW level or falling edge
  • 0x1: HIGH level or rising edge
Write:
  • 0x0: No effect
  • 0x1: Set the interrupt polarity bit
GPIOx_INT_POL_CLR
  • Name: GPIO interrupt polarity disable register
  • Description: This register is used to disable GPIO interrupt polarity.
  • Offset: 0x0034
表 51 GPIO interrupt polarity disable register
15:0 CLR RW 0x0
Read:
  • 0x1:HIGH level or rising edge
Write:
  • 0x0: No effect
  • 0x1: Clear the interrupt polarity bit
GPIOx_INT_STAT
  • Name: GPIO IRQ status register
  • Description: This register contains GPIO interrupt status, and used to clear the interrupt request.
  • Offset: 0x0038
表 52 GPIO IRQ status register
15:0 STAT_CLR RW 0x0
Write one to clear interrupt request
Read:
[15:0] IRQ status Register
Write:
  • 0x0: No effect
  • 0x1: To clear the interrupt request.
MSIO_VAL
  • Name: MSIO digital input value register
  • Description: This register contains MSIO digital input value.
  • Offset: 0x220
表 53 MSIO_VAL
31:5 RSVD R Reserved bits
4:0 MSIO_VAL RO N/A MSIO digital value (when MSIO_PAD_CFG1.MSIO_A_EN = 1)
MSIO_PAD_CFG0
  • Name: MSIO pad control register 0
  • Description: This register controls MSIO pad.
  • Base Address: 0xA000C500
  • Offset: 0x3C
表 54 MSIO_PAD_CFG0
31:29 RSVD R Reserved bits
28:24 MSIO_OUT_EN RW 0x0
MSIO output enable (active low)
  • 0x0: Enable MSIOx output
  • 0x1: Disable MSIOx output
23:21 RSVD R Reserved bits
20:16 MSIO_IN_EN RW 0x0
MSIO input enable (active low)
  • 0x0: Enable MSIOx input
  • 0x1: Disable MSIOx input
15:13 RSVD R Reserved bits
12:8 MSIO_OUT RW 0x0
MSIO Drive level value (valid in output mode)
  • 0x0: Drive MSIOx low
  • 0x1: Drive MSIOx high
7:5 RSVD R Reserved bits
4:0 MSIO_R_EN RW 0x0
MSIO resistor enable (active low)
  • 0x0: Enable MSIOx resistor
  • 0x1: Disable MSIOx resistor
MSIO_PAD_CFG1
  • Name: MSIO pad control register 1
  • Offset: 0x40
表 55 MSIO_PAD_CFG1
31 *SADC_CLK_EN RW 0x0 ADC clock enable
  • 0x0: Disable ADC clock
  • 0x1: Enable ADC clock
30:28 *SADC_CLK_SEL RW 0x0 ADC clock select
  • 0x0: 16 M
  • 0x1: 8 M
  • 0x2: 4 M
  • 0x3: 2 M
  • 0x4, 0x6: 1.6 M
  • 0x5, 0x7: 1 M
27 *RSVD R Reserved bits
26:22 *MSIO_MCU_OVE RW 0x0 Use the setting from MCU domain, only valid when MCU domain is ON.
  • 0x0: Disable MSIOx digital setting
  • 0x1: Enable MSIOx digital setting
21:16 *DEP_CTRL_WR RW 0x0 Comm timer register
Deep sleep control comm timer register write bit
15 *DEP_CTRL_RD RO 0x0 Comm timer register
Deep sleep control comm timer register read bit
14:13 RSVD R Reserved bits
12:8 MSIO_R_TYPE RW 0x0
MSIO resistor type
  • 0x0: Pull down
  • 0x1: Pull up
4:0 MSIO_A_EN RW 0x0
Analog enable control for MSIO Pad
  • 0x0: Analog mode
  • 0x1: Digital mode
MSIO_PAD_CFG1 does not support fields marked with an asterisk (*).
AON_PAD_CTRL0
  • Name: AON GPIO pad control register 0
  • Description: This register controls AON GPIO pad.
  • Offset: 0x50
  • Reset value: 0x00000000
表 56 AON_PAD_CTRL_0
31:30 *RSVD R Reserved bits
29:28 *TIMER_CLK_SEL RW 0x0 Comm timer clock select
  • 0x0: rng_osc_clk
  • 0x1: rtc_osc_clk
  • 0x2, 0x3: rng_2_osc_clk (an RNG clock with better ppm)
27:24 *RSVD R Reserved bits
23:16 *AON_MCU_OVE RW 0x0 Use the setting from MCU domain, only valid when MCU domain is ON
  • 0x0: Disable AONx digital setting
  • 0x1: Enable AONx digital setting
15:8 AON_R_TYPE RW 0x0 Always on PAD resistor type
  • 0x0: Pull down
  • 0x1: Pull up
7:0 AON_R_EN RW 0x0
Always on PAD resister enable
  • 0x0: Enable AONx resistor
  • 0x1: Disable AONx resistor
AON_PAD_CTRL0 does not support fields marked with an asterisk (*).
AON_PAD_CTRL1
  • Name: AON GPIO pad control register 1
  • Offset: 0x5C
  • Reset value: 0x000000FF
表 57 AON_PAD_CTRL_1
31:30 *TIMER_RD_SEL RW 0x0 Select which timer value to read
  • 0x0: calendar timer
  • 0x1: always on watchdog timer
  • 0x2: sleep timer
  • 0x3: Calendar timer alarm value
29:26 *RSVD R Reserved bits
25 *OVR_EN RW 0x0 Enable override for all stdby_n and vdd_iso_n values
24:16 *RSVD R Reserved bits
15:8 AON_OUT_VAL RW 0x0
AON PAD output value (valid when oe_n = 0):
  • 0x0: Drive AONx low
  • 0x1: Drive AONx high
7:0 AON_OUT_EN RW 0xFF
Always on PAD output enable (active low)
  • 0x0: Enable AONx output
  • 0x1: Disable AONx output
AON_PAD_CTRL1 does not support fields marked with an asterisk (*).
