文档中心 > GR551x Datasheet/ Peripherals / SPI/ Registers Copy URL
CTRL0
  • Name: Control Register 0
  • Description: This register controls the serial data transfer. It is impossible to write to this register when the SPI is enabled.
  • Base Address: 0xA000C000 + x*0x100
  • Offset: 0x00
  • Reset Value: 0x01070000
表 148 Control Register 0
31:25
24
S_ST_EN
0x1
Slave Select Toggle Enable.
When operating in SPI mode with clock phase (SERIAL_CLK_PHASE) set to 0, this register controls the behavior of the slave select line (CS) between data frames.
If this register field is set to 1, the CS line will toggle between consecutive data frames, with the serial clock (SCLK) being held to its default value while CS is high; if this register field is set to 0, the CS will stay low and SCLK will run continuously for the duration of the transfer.
When the SPI is configured as a slave, this register serves no purpose.
23:21
20:16
DATA_FRAME_SIZE
0x7
Data Frame Size in 32-bit transfer size mode. Used to select the data frame size in 32-bit transfer mode. When the data frame size is programmed to be less than 32 bits, the receive data is automatically right-justified by the receive logic, with the upper bits of the receive FIFO zero-padded. You are responsible for making sure that transmit data is right-justified before writing into the transmit FIFO. The transmit logic ignores the upper unused bits when transmitting the data.
  • 0x3 (FRAME_04BITS): 4-bit serial data transfer
  • 0x4 (FRAME_05BITS): 5-bit serial data transfer
  • 0x5 (FRAME_06BITS): 6-bit serial data transfer
  • 0x6 (FRAME_07BITS): 7-bit serial data transfer
  • 0x7 (FRAME_08BITS): 8-bit serial data transfer
  • 0x8 (FRAME_09BITS): 9-bit serial data transfer
  • 0x9 (FRAME_10BITS): 10-bit serial data transfer
  • 0xa (FRAME_11BITS): 11-bit serial data transfer
  • 0xb (FRAME_12BITS): 12-bit serial data transfer
  • 0xc (FRAME_13BITS): 13-bit serial data transfer
  • 0xd (FRAME_14BITS): 14-bit serial data transfer
  • 0xe (FRAME_15BITS): 15-bit serial data transfer
  • 0xf (FRAME_16BITS): 16-bit serial data transfer
  • 0x10 (FRAME_17BITS): 17-bit serial data transfer
  • 0x11 (FRAME_18BITS): 18-bit serial data transfer
  • 0x12 (FRAME_19BITS): 19-bit serial data transfer
  • 0x13 (FRAME_20BITS): 20-bit serial data transfer
  • 0x14 (FRAME_21BITS): 21-bit serial data transfer
  • 0x15 (FRAME_22BITS): 22-bit serial data transfer
  • 0x16 (FRAME_23BITS): 23-bit serial data transfer
  • 0x17 (FRAME_24BITS): 24-bit serial data transfer
  • 0x18 (FRAME_25BITS): 25-bit serial data transfer
  • 0x19 (FRAME_26BITS): 26-bit serial data transfer
  • 0x1a (FRAME_27BITS): 27-bit serial data transfer
  • 0x1b (FRAME_28BITS): 28-bit serial data transfer
  • 0x1c (FRAME_29BITS): 29-bit serial data transfer
  • 0x1d (FRAME_30BITS): 30-bit serial data transfer
  • 0x1e (FRAME_31BITS): 31-bit serial data transfer
  • 0x1f (FRAME_32BITS): 32-bit serial data transfer
15:12
CTRL_FRAME_SIZE
Control Frame Size. Selects the length of the control word for the Microwire frame format.
  • 0x0 (SIZE_01_BIT): 1-bit Control Word
  • 0x1 (SIZE_02_BIT): 2-bit Control Word
  • 0x2 (SIZE_03_BIT): 3-bit Co ntrol Word
  • 0x3 (SIZE_04_BIT): 4-bit Control Word
  • 0x4 (SIZE_05_BIT): 5-bit Control Word
  • 0x5 (SIZE_06_BIT): 6-bit Control Word
  • 0x6 (SIZE_07_BIT): 7-bit Control Word
  • 0x7 (SIZE_08_BIT): 8-bit Control Word
  • 0x8 (SIZE_09_BIT): 9-bit Control Word
  • 0x9 (SIZE_10_BIT): 10-bit Control Word
  • 0xa (SIZE_11_BIT): 11-bit Control Word
  • 0xb (SIZE_12_BIT): 12-bit Control Word
  • 0xc (SIZE_13_BIT): 13-bit Control Word
  • 0xd (SIZE_14_BIT): 14-bit Control Word
  • 0xe (SIZE_15_BIT): 15-bit Control Word
  • 0xf (SIZE_16_BIT): 16-bit Control Word
11
SHIFT_REG_LOOP
Shift Register Loop.
Used for testing purposes only. When internally active, connect the transmit shift register output to the receive shift register input.
  • 0x0 (NORMAL_MODE): Normal mode operation
  • 0x1 (TESTING_MODE): Test mode: TX & RX shift register connected
10
S_OUT_EN
Slave Output Enable. Relevant only when the SPI is configured as a serial-slave device. When configured as a serial-master, this bit field has no functionality.
  • 0x0 (ENABLED): Slave Output is enabled
  • 0x1 (DISABLED): Slave Output is disabled
When the SPI is configured as a master, this register serves no purpose.
9:8
XFE_MODE
Transfer Mode.
This transfer mode is only valid when the SPI is configured as master device.
  • 0x0 - Transmit & Receive
  • 0x1 - Transmit Only
  • 0x2 - Receive Only
  • 0x3 - EEPROM Read
7
SERIAL_CLK_POL
Serial Clock Polarity.
Valid when the frame format (FRAME_FORMAT) is set to Motorola SPI. Used to select the polarity of the inactive serial clock, which is held inactive when the SPI master is not actively transferring data on the serial bus.
  • 0x0 (SCLK_LOW): Inactive state of serial clock is low
  • 0x1 (SCLK_HIGH): Inactive state of serial clock is high
6
SERIAL_CLK_PHASE
Serial Clock Phase.
Valid when the frame format (FRAME_FORMAT) is set to Motorola SPI. The serial clock phase selects the relationship of the serial clock with the slave select signal.
When SERIAL_CLK_PHASE = 0, data is captured on the first edge of the serial clock. When SERIAL_CLK_ PHASE = 1, the serial clock starts toggling one cycle after the slave select line is activated, and data is captured on the second edge of the serial clock.
  • 0x0 (SERIAL_CLK_PHASE_MIDDLE): Serial clock toggles in middle of first data bit
  • 0x1 (SERIAL_CLK_PHASE_START): Serial clock toggles at start of first data bit
5:4
FRAME_FORMAT
Frame Format. Select which serial protocol transfers the data.
  • 0x0 (MOTOROLA_SPI): Motorola SPI Frame Format
  • 0x1 (TEXAS_SSP): Texas Instruments SSP Frame Format
  • 0x2 (NS_MICROWIRE): National Microwire Frame Format
  • 0x3 (RESERVED): Reserved value
3:0
CTRL1
  • Name: Control Register 1
  • Description: This register exists only when the SPI is configured as a master device. Control register 1 controls the end of serial transfers when in receive-only mode. It is impossible to write to this register when the SPI is enabled.
  • Offset: 0x04
表 149 Control Register 1
31:16
15:0
NUM_DATA_FRAME
Number of Data Frames.
When XFE_MODE = 10 or XFE_MODE = 11, this register field sets the number of data frames to be continuously received by the SPI. The SPI continues to receive serial data until the number of data frames received is equal to this register value plus 1, which enables you to receive up to 64 KB of data in a continuous transfer.
SSI_EN
  • Name: SSI Enable Register
  • Description: This register enables and disables the SPI.
  • Offset: 0x08
表 150 SSI Enable Register
31:1
SSI_EN
SSI Enable.
Enable and disable all SPI operations. When disabled, all serial transfers are halted immediately. Transmit and receive FIFO buffers are cleared when all serial transfers are disabled.
  • 0x0 (DISABLE): Disables Serial Transfer
  • 0x1 (ENABLED): Enables Serial Transfer
MW_CTRL
  • Name: Microwire Control Register
  • Description: This register controls the direction of the data word for the half-duplex Microwire serial protocol. It is impossible to write to this register when the SPI is enabled.
  • Offset: 0x0C
表 151 Microwire Control Register
31:3
2
MW_HSG
Microwire Handshaking.
Used to enable and disable the busy/ready handshaking interface for the Microwire protocol. When enabled, the SPI checks for a ready status from the target slave, after the transfer of the last data/control bit, before clearing the SSI_BUSY status in the STAT register.
  • 0x0 (DISABLE): Handshaking interface is disabled
  • 0x1 (ENABLED): Handshaking interface is enabled
MW_DIR_DW
Microwire Control.
Define the direction of the data word when the Microwire serial protocol is used.
  • 0x0 (RECEIVE): SPI receives data
  • 0x1 (TRANSMIT): SPI transmits data
MW_XFE_MODE
Microwire Transfer Mode.
Define whether the Microwire transfer is sequential or non-sequential. When sequential mode is used, only one control word is needed to transmit or receive a block of data words. When non-sequential mode is used, there must be a control word for each data word that is transmitted or received.
  • 0x0 (NON_SEQUENTIAL): Non-Sequential Microwire Transfer
  • 0x1 (SEQUENTIAL): Sequential Microwire Transfer
S_EN
  • Name: Slave Enable Register
  • Description: This register exists only when the SPI is configured as a master device. The register enables the individual slave select output lines from the SPI master.
  • Offset: 0x10
表 152 Slave Enable Register
31:2
1:0
S_EN
Slave Select Enable.
Each bit in this register corresponds to a slave select line (CSn) from the SPI master.
  • 0x0 (NOT_SELECTED): No slave selected
  • 0x1 (SELECTED): Slave is selected
BAUD
  • Name: Baud Rate Register
  • Description: This register exists only when the SPI is configured as a master device. The register derives the frequency of the serial clock that regulates the data transfer. It is impossible to write to this register when the SPI is enabled.
  • Offset: 0x14
表 153 Baud Rate Register
31:16
15:0
SSI_CLK_DIV
SSI Clock Divider.
The LSB for this field is always set to 0 and is unaffected by a write operation, which ensures an even value is held in this register. If the value is 0, the serial output clock (sclk_out) is disabled. The frequency of the sclk_out is derived from the following equation:
Fsclk_out = Fssi_clk/ SSI_CLK_DIV
TX_FIFO_TL
  • Name: Transmit FIFO Threshold Level
  • Description: This register controls the threshold value for the transmit FIFO memory.
  • Offset: 0x18
表 154 Transmit FIFO Threshold Level
31:3
2:0
TX_FIFO_THD
Transmit FIFO Threshold.
Control the level of entries (or below) at which the transmit FIFO controller triggers an interrupt. The FIFO depth is configurable in the range 2-256; this register is sized to the number of address bits needed to access the FIFO. If you attempt to set this value greater than or equal to the depth of the FIFO, this field is not written and retains its current value. When the number of transmit FIFO entries is less than or equal to this value, the transmit FIFO empty interrupt is triggered.
RX_FIFO_TL
  • Name: Receive FIFO Threshold Level
  • Description: This register controls the threshold value for the receive FIFO memory.
  • Offset: 0x1C
表 155 Receive FIFO Threshold Level
31:3
2:0
RX_FIFO_THD
Receive FIFO Threshold.
Control the level of entries (or above) at which the receive FIFO controller triggers an interrupt. The FIFO depth is configurable in the range 2 – 256. This register is sized to the number of address bits needed to access the FIFO. If you attempt to set this value greater than the depth of the FIFO, this field is not written and retains its current value. When the number of receive FIFO entries is greater than or equal to this value + 1, the receive FIFO full interrupt is triggered.
TX_FIFO_LEVEL
  • Name: Transmit FIFO Level Register
  • Description: This register contains the number of valid data entries in the transmit FIFO memory.
  • Offset: 0x20
表 156 Transmit FIFO Level Register
31:4
3:0
TX_FIFO_LEVEL
Transmit FIFO Level.
Contain the number of valid data entries in the transmit FIFO.
RX_FIFO_LEVEL
  • Name: Receive FIFO Level Register
  • Description: This register contains the number of valid data entries in the receive FIFO memory. This register can be ready at any time.
  • Offset: 0x24
表 157 Receive FIFO Level Register
31:4
3:0
RX_FIFO_LEVEL
Receive FIFO Level.
Contain the number of valid data entries in the receive FIFO.
STAT
  • Name: Status Register
  • Description: This is a read-only register used to indicate the current transfer status, FIFO status, and any transmission/reception errors that may have occurred. The status register may be read at any time.
  • Offset: 0x28
  • Reset Value: 0x00000006
表 158 Status Register
31:7
6
DATA_COLN_ERR
Data Collision Error.
This bit will be set if MISO input is asserted by other master, when the SPI master is in the middle of the transfer. This informs the processor that the last data transfer was halted before completion. This bit is cleared when read.
5
TX_ERR
Transmission Error.
Set if the transmit FIFO is empty when a transfer is started. Data from the previous transmission is resent on the txd line. This bit is cleared when read.
  • 0x0 (NO_ERROR): No Error
  • 0x1 (TX_ERROR): Transmission Error
4
RX_FIFO_FULL
Receive FIFO Full.
When the receive FIFO is completely full, this bit is set. When the receive FIFO contains one or more empty location, this bit is cleared.
  • 0x0 (NOT_FULL): Receive FIFO is not full
  • 0x1 (FULL): Receive FIFO is full
3
RX_FIFO_NE
Receive FIFO Not Empty.
Set when the receive FIFO contains one or more entries and is cleared when the receive FIFO is empty. This bit can be polled by software to completely empty the receive FIFO.
  • 0x0 (EMPTY): Receive FIFO is empty
  • 0x1 (NOT_EMPTY): Receive FIFO is not empty
2
TX_FIFO_EMPTY
0x1
Transmit FIFO Empty.
When the transmit FIFO is completely empty, this bit is set. When the transmit FIFO contains one or more valid entries, this bit is cleared. This bit field does not request an interrupt.
  • 0x0 (NOT_EMPTY): Transmit FIFO is not empty
  • 0x1 (EMPTY): Transmit FIFO is empty
TX_FIFO_NF
0x1
Transmit FIFO Not Full.
Set when the transmit FIFO contains one or more empty locations, and is cleared when the FIFO is full.
  • 0x0 (FULL): Transmit FIFO is full
  • 0x1 (NOT_FULL): Transmit FIFO is not Full
SSI_BUSY
SSI Busy Flag.
When set, indicates that a serial transfer is in progress; when cleared indicates that the SPI is idle or disabled.
  • 0x0 (INACTIVE): SPI is idle or disabled
  • 0x1 (ACTIVE): SPI is actively transferring data
INT_MASK
  • Name: Interrupt Mask Register
  • Description: This read/write register masks or enables all interrupts generated by the SPI. When the SPI is configured as a slave device, the MULTI_M_CIM bit field is not present. This changes the reset value from 0x3F for serial-master configurations to 0x1F for serial-slave configurations.
  • Offset: 0x2C
  • Reset Value: master ? 0x0000003F: 0x0000001F
表 159 Interrupt Mask Register
31:6
5
MULTI_M_CIM
0x1
Multi-Master Contention Interrupt Mask.
  • 0x0 (MASKED): Disable mst_intr interrupt
  • 0x1 (UNMASKED): Enable mst_intr interrupt
4
RX_FIFO_FIS
0x1
Receive FIFO Full Interrupt Mask
  • 0x0 (MASKED): Disable rxf_intr interrupt
  • 0x1 (UNMASKED): Enable rxf_intr interrupt
3
RX_FIFO_OIS
0x1
Receive FIFO Overflow Interrupt Mask
  • 0x0 (MASKED): Disable rxo_intr interrupt
  • 0x1 (UNMASKED): Enable rxo_intr interrupt
2
RX_FIFO_UIS
0x1
Receive FIFO Underflow Interrupt Mask
  • 0x0 (MASKED): Disable rxu_intr interrupt
  • 0x1 (UNMASKED): Enable rxu_intr interrupt
TX_FIFO_OIS
0x1
Transmit FIFO Overflow Interrupt Mask
  • 0x0 (MASKED): Disable txo_intr interrupt
  • 0x1 (UNMASKED): Enable txo_intr interrupt
TX_FIFO_EIS
0x1
Transmit FIFO Empty Interrupt Mask
  • 0x0 (MASKED): Disable txe_intr interrupt
  • 0x1 (UNMASKED): Enable txe_intr interrupt
INT_STAT
  • Name: Interrupt Status Register
  • Description: This register reports the status of the SPI interrupts after they have been enabled.
  • Offset: 0x30
表 160 Interrupt Status Register
31:6
5
MULTI_M_CIS
Multi-Master Contention Interrupt Status
  • 0x0 (INACTIVE): mst_intr interrupt is not active after being enabled
  • 0x1 (ACTIVE): mst_intr interrupt is active after being enabled
4
RX_FIFO_FIS
Receive FIFO Full Interrupt Status
  • 0x0 (INACTIVE): rxf_intr interrupt is not active after being enabled
  • 0x1 (ACTIVE): rxf_intr interrupt is active after being enabled
3
RX_FIFO_OIS
Receive FIFO Overflow Interrupt Status
  • 0x0 (INACTIVE): rxo_intr interrupt is not active after being enabled
  • 0x1 (ACTIVE): rxo_intr interrupt is active after being enabled
2
RX_FIFO_UIS
Receive FIFO Underflow Interrupt Status
  • 0x0 (INACTIVE): rxu_intr interrupt is not active after being enabled
  • 0x1 (ACTIVE): rxu_intr interrupt is active after being enabled
TX_FIFO_OIS
Transmit FIFO Overflow Interrupt Status
  • 0x0 (INACTIVE): txo_intr interrupt is not active after being enabled
  • 0x1 (ACTIVE): txo_intr interrupt is active after being enabled
TX_FIFO_EIS
Transmit FIFO Empty Interrupt Status
  • 0x0 (INACTIVE): txe_intr interrupt is not active after being enabled
  • 0x1 (ACTIVE): txe_intr interrupt is active after being enabled
RAW_INT_STAT
  • Name: Raw Interrupt Status Register
  • Description: This read-only register reports the status of the SPI interrupts prior to be enabled.
  • Offset: 0x34
表 161 Raw Interrupt Status Register
31:6
5
MULTI_M_CRIS
Multi-Master Contention Raw Interrupt Status
  • 0x0 (INACTIVE): mst_intr interrupt is not active prior to be enabled
  • 0x1 (ACTIVE): mst_intr interrupt is active prior to be enabled
4
RX_FIFO_FRIS
Receive FIFO Full Raw Interrupt Status
  • 0x0 (INACTIVE): rxf_intr interrupt is not active prior to be enabled
  • 0x1 (ACTIVE): rxf_intr interrupt is active prior to be enabled
3
RX_FIFO_ORIS
Receive FIFO Overflow Raw Interrupt Status
  • 0x0 (INACTIVE): rxo_intr interrupt is not active prior be enabled
  • 0x1 (ACTIVE): rxo_intr interrupt is active prior to be enabled
2
RX_FIFO_URIS
Receive FIFO Underflow Raw Interrupt Status
  • 0x0 (INACTIVE): rxu_intr interrupt is not active prior to be enabled
  • 0x1 (ACTIVE): rxu_intr interrupt is active prior to be enabled
TX_FIFO_ORIS
Transmit FIFO Overflow Raw Interrupt Status
  • 0x0 (INACTIVE): txo_intr interrupt is not active prior to be enabled
  • 0x1 (ACTIVE): txo_intr interrupt is active prior be enabled
TX_FIFO_ERIS
Transmit FIFO Empty Raw Interrupt Status
  • 0x0 (INACTIVE): txe_intr interrupt is not active prior to be enabled
  • 0x1 (ACTIVE): txe_intr interrupt is active prior be enabled
TX_FIFO_OIC
  • Name: Transmit FIFO Overflow Interrupt Clear Register
  • Description: Transmit FIFO Overflow Interrupt Clear Register
  • Offset: 0x38
表 162 Transmit FIFO Overflow Interrupt Clear Register
31:1
TX_FIFO_OIC
Clear Transmit FIFO Overflow Interrupt.
This register reflects the status of the interrupt. A read from this register clears the txo_intr interrupt; writing has no effect.
RX_FIFO_OIC
  • Name: Receive FIFO Overflow Interrupt Clear Register
  • Description: Receive FIFO Overflow Interrupt Clear Register
  • Offset: 0x3C
表 163 Receive FIFO Overflow Interrupt Clear Register
31:1
RX_FIFO_OIC
Clear Receive FIFO Overflow Interrupt.
This register reflects the status of the interrupt. A read from this register clears the rxo_intr interrupt; writing has no effect.
RX_FIFO_UIC
  • Name: Receive FIFO Underflow Interrupt Clear Register
  • Description: Receive FIFO Underflow Interrupt Clear Register
  • Offset: 0x40
表 164 Receive FIFO Underflow Interrupt Clear Register
31:1
MULTI_M_IC
Clear Receive FIFO Underflow Interrupt.
This register reflects the status of the interrupt. A read from this register clears the rxu_intr interrupt; writing has no effect.
MULTI_M_IC
  • Name: Multi-Master Interrupt Clear Register
  • Description: Multi-Master Interrupt Clear Register
  • Offset: 0x44
表 165 Multi-Master Interrupt Clear Register
31:1
MULTI_M_IC
Clear Multi-Master Contention Interrupt.
This register reflects the status of the interrupt. A read from this register clears the mst_intr interrupt; writing has no effect.
INT_CLR
  • Name: Interrupt Clear Register
  • Description: Interrupt Clear Register
  • Offset: 0x48
表 166 Interrupt Clear Register
31:1
INT_CLR
Clear Interrupts.
This register is set if any of the interrupts below are active. A read clears the txo_intr, rxu_intr, rxo_intr, and the mst_intr interrupts. Writing to this register has no effect.
DMA_CTRL
  • Name: DMA Control Register
  • Description: The register is used to enable the DMA Controller interface operation.
  • Offset: 0x4C
表 167 DMA Control Register
31:2
TX_DMA_EN
Transmit DMA Enable.
This bit enables/disables the transmit FIFO DMA channel.
  • 0x0 (DISABLED): Transmit DMA disabled
  • 0x1 (ENABLED): Transmit DMA enabled
RX_DMA_EN
Receive DMA Enable.
This bit enables/disables the receive FIFO DMA channel.
  • 0x0 (DISABLED): Receive DMA disabled
  • 0x1 (ENABLED): Receive DMA enabled
DMA_TX_DL
  • Name: DMA Transmit Data Level
  • Offset: 0x50
表 168 DMA Transmit Data Level
31:3
2:0
DMA_TX_DL
Transmit Data Level.
This bit field controls the level at which a DMA request is made by the transmit logic. It is equal to the watermark level; that is, the dma_tx_req signal is generated when the number of valid data entries in the transmit FIFO is equal to or below this field value, and TX_EN = 1.
DMA_RX_DL
  • Name: DMA Receive Data Level
  • Offset: 0x54
表 169 DMA Receive Data Level
31:3
2:0
DMA_RX_DL
Receive Data Level.
This bit field controls the level at which a DMA request is made by the receive logic. The watermark level = DMARDL+1; that is, dma_rx_req is generated when the number of valid data entries in the receive FIFO is equal to or above this field value + 1, and RX_EN=1.
DATA
  • Name: Data Register
  • Description: The SPI data register is a 32-bit read/write buffer for the transmit/receive FIFOs. When the register is read, data in the receive FIFO buffer is accessed. When it is written to, data is moved into the transmit FIFO buffer; a write can occur only when SSI_EN = 1. FIFOs are reset when SSI_EN = 0
  • Offset: 0x60
表 170 Data Register
31:0
DATA
Data Register. When writing to this register, you must right-justify the data. Read data is automatically right-justified.
