FIFO_RD
- Name: Sense ADC FIFO Register
- Description: Reading this register will pop an entry from the sense ADC FIFO.
- Base Address: 0xA000E000
- Offset: 0x00
31:0 |
DATA |
When the register is read, data in the FIFO buffer is accessed. |
FIFO_THD
- Name: Sense ADC FIFO Threshold Register
- Description: This register is used to set the threshold at which the DMA request is made to the hardware handshake mechanism.
- Offset: 0x100
31:6 |
Reserved bits |
5:0 |
THD |
This is used to set the threshold at which the DMA request is made to the hardware handshake mechanism. |
FIFO_STAT
- Name: Sense ADC Status Register
- Description: This register contains the number of valid data entries in the ADC FIFO memory.
- Offset: 0x104
31:9 |
Reserved bits |
8 |
VAL |
Identify whether FIFO is empty Value:
7 |
Reserved bits |
6:0 |
COUNT |
Sense ADC FIFO Count, number of 32-bit words in the FIFO. Maximum value is 0x40 or decimal 64. |
CFG
- Name: Sense ADC Configuration Register
- Description: This register is used to configure reference, channels and input mode of ADC.
- Base Address: 0xA000C500
- Offset: 0x08
- Reset Value: 0x0708070A
31 |
RST |
Reset ADC Value:
30 |
EN |
Enable ADC Value:
29:27 |
REF_SEL |
Reference Voltage Select Value:
Note: Because the maximum input for any MSIO is supposed to be VBATT. So in this case, there is no benefit from using an external input higher than VBATT/2. |
26:24 |
REF_HP_MODE |
0x7 |
Used to define current in the reference circuit :Default-<0x0> at 100 Ksps and <0x7> at 1 Msps |
23:22 |
Reserved |
Reserved bits |
21:19 |
CH_P |
0x1 |
Used to define input for channel P Value:
18:16 |
CH_N |
Used to define input for channel N Value:
15 |
EN_TMP |
Enable temperature sensor Value:
14 |
EN_VBAT |
Enable battery sensor Value:
13 |
MODE |
Used to define operation either single ended or differential. Value:
12 |
EN_CAL |
Used to swap inputs of comparator for offset calibration. Value:
11 |
Reserved bits |
10:8 |
CODE_IN |
0x7 |
Used to define dynamic range of ADC. Default set to <0x7>, for higher input signal frequencies close to Nyquist rate use <0x1> |
7:4 |
Reserved bits |
3:0 |
BIAS_RES_CTRL |
0xA |
Buffered internal reference Value:
Note: For any specific reference value (Vref), the maximum ADC input is supposed to be 2 x Vref. |
CLK
- Name: Sense ADC Clock Register
- Description: This register selects ADC clock.
- Offset: 0x40
31 |
CLK_EN |
Enable ADC clock Value:
30:28 |
CLK_SEL |
ADC clock select Value:
27:0 |
Reserved bits |
