MODE
- Name: Mode Register
- Description: This register sets PWM operation mode
- Base Address: 0xA000C900 + x*0x300
- Offset: 0x0
x* is used to identify which PWM Module is x0, or x1.
31:6 |
Reserved bits |
5 |
PD_C_EN |
PWMC positive-drive mode enable. Value:
4 |
PD_B_EN |
PWMB positive-drive mode enable. Value:
3 |
PD_A_EN |
PWMA positive-drive mode enable. Value:
2 |
BREATH_EN |
Breath mode enable. Value:
1 |
PAUSE |
PWM pause signal. Value:
0 |
EN |
Enable PWM. Value:
UPDATE
- Name: Update Register
- Description: Synchronous update enable register
- Offset: 0x4
30x1:19 |
Reserved bits |
18 |
UPDATE_SYNC_SAQCTRL |
Separate update enable of AQCTRL Value:
17 |
UPDATE_SYNC_SHOLD |
Separate update enable of HOLD Value:
16 |
UPDATE_SYNC_SBRPRD |
Separate update enable of BRPRD Value:
15 |
UPDATE_SYNC_SPAUSE |
Separate update enable of PAUSE Value:
14 |
UPDATE_SYNC_SCMPC1 |
Separate update enable of CMPC1 Value:
13 |
UPDATE_SYNC_SCMPC0 |
Separate update enable of CMPC0 Value:
12 |
UPDATE_SYNC_SCMPB1 |
Separate update enable of CMPB1 Value:
11 |
UPDATE_SYNC_SCMPB0 |
Separate update enable of CMPB0 Value:
10 |
UPDATE_SYNC_SCMPA1 |
Separate update enable of CMPA1 Value:
9 |
UPDATE_SYNC_SCMPA0 |
Separate update enable of CMPA0 Value:
8 |
UPDATE_SYNC_SPRD |
Separate update enable of PRD Value:
7:2 |
Reserved bits |
1 |
UPDATE_SYNC_AE |
Synchronous update enable Value:
0 |
UPDATE_SYNC_AG |
Synchronous update ongoing Value:
PRD
- Name: Period Register
- Description: This register is used to set the PWM cycle
- Offset: 0x8
31:0 |
PRD |
The period of PWM output, PRD=fCLK/fPWM |
CMPA0
- Name: Compare A0 Register
- Description: Compare register 0 of channel A
- Offset: 0xC
31:0 |
CMPA0 |
PWMA duty control register0 |
CMPA1
- Name: Compare A1 Register
- Description: Compare register 1 of channel A
- Offset: 0x10
31:0 |
CMPA1 |
PWMA duty control register1 |
CMPB0
- Name: Compare B0 Register
- Description: Compare register 0 of channel B
- Offset: 0x14
31:0 |
CMPB0 |
PWMB duty control register0 |
CMPB1
- Name: Compare B1 Register
- Description: Compare register 1 of channel B
- Offset: 0x18
31:0 |
CMPB1 |
PWMB duty control register1 |
CMPC0
- Name: Compare C0 Register
- Description: Compare register 0 of channel C
- Offset: 0x1C
31:0 |
CMPC0 |
PWMC duty control register0 |
CMPC1
- Name: Compare C1 Register
- Description: Compare register 1 of channel C
- Offset: 0x20
31:0 |
CMPC1 |
PWMC duty control register1 |
AQCTRL
- Name: Action Qualifier Control Register
- Description: This register is used to set actions when counter reaches the compare value.
- Offset: 0x24
31:12 |
Reserved bits |
11:10 |
AQ_CTRL_C1 |
Action of event CNT_CMPC1 control register;
9:8 |
AQ_CTRL_C0 |
Action of event CNT_CMPC0 control register;
7:6 |
AQ_CTRL_B1 |
Action of event CNT_CMPB1 control register;
5:4 |
AQ_CTRL_B0 |
Action of event CNT_CMPB0 control register;
3:2 |
AQ_CTRL_A1 |
Action of event CNT_CMPA1 control register;
1:0 |
AQ_CTRL_A0 |
Action of event CNT_CMPA0 control register;
BRPRD
- Name: Breath Period Register
- Description: This register configures the period of breath mode.
- Offset: 0x28
31:0 |
BRPRD |
Breath period register, i.e. the required time (number of clock) that the duty changes from 0% to 100% in breath mode. |
HOLD
- Name: Hold Register
- Description: This register configures the hold period on breath mode.
- Offset: 0x2C
31:24 |
Reserved bits |
23:0 |
HOLD |
Breath hold control register. The value should be the required number of clock in breath hold state. |
