LOADx
- Name: Dual-Timer Load Register
- Description: This register contains the value from which the counter is to decrease. This is the value used to reload the counter when periodic mode is enabled, and the current count reaches 0.
- Base Address: 0xA0002000
- Offset: 0x00 + x*0x20
- Reset Value: 0x00
| 31:0 | COUNT | RW | 0x0 | Reload value. Write to this register sets the current value. |
VALx
- Name: Dual-Timer Current Value Register
- Description: This register provides the current value of the decrementing counter.
- Offset: 0x04 + x*0x20
- Reset Value: 0xFFFFFFFF
| 31:0 | COUNT | RO | 0xFFFFFFFF | Current value |
CTRLx
- Name: Dual-Timer Control Register
- Description: The CTRL register enables the software to control the Dual-Timer unit.
- Offset: 0x08 + x*0x20
- Reset Value: 0x20
| 31:8 | RSVD | R | Reserved bits | |
| 7 | EN | RW | 0x0 |
Timer enable Value:
| 6 | MODE | RW | 0x0 |
Timer mode Value:
| 5 | INT_EN | RW | 0x1 |
Interrupt enable Value:
| 4 | RSVD | R | Reserved bits | |
| 3:2 | PRE | RW | 0x0 |
Prescale bits Value:
| 1 | SIZE | RW | 0x0 |
Select 16-bit or 32-bit counter operation Value:
| 0 | COUNT_MODE | RW | 0x0 |
Select Free-running or One-shot mode. Value:
INT_CLRx
- Name: Dual-Timer Interrupt Clear Register
- Description: Any write to the INT_CLRx register clears the interrupt output from the counter.
- Offset: 0x0C + x*0x20
- Reset Value:0x00
| 31:0 | STAT | WO | 0x0 | Clear the Dual-Timer interrupt event. |
INT_RSTATx
- Name: Dual-Timer Raw Interrupt Status Register
- Description: The INT_RSTATx register indicates the raw interrupt status from the counter.
- Offset: 0x10 + x*0x20
- Reset Value:0x00
| 31:1 | RSVD | R | Reserved bits | |
| 0 | STAT | RW | 0x0 | Raw interrupt status from the counter |
INT_STATx
- Name: Dual-Timer Interrupt Status Register
- Description: The INT_STATx register indicates the masked interrupt status from the counter.
- Offset: 0x14 + x*0x20
- Reset Value: 0x00
| 0 | STAT | RW | 0x0 | Enable interrupt status from the counter. |
