DPAD_RE_N
- Name: GPIO pull up/down resistor enable register
- Description: This register decides whether to use a pull up/down resistor.
- Base Address: 0xA000E000
- Offset: 0x208
| 31:0 | DPAD_RE_N | RW | 0x0 |
Enable a pull up/down resistor to the RETENTION PAD. Value:
DPAD_RTYPE
- Name: GPIO pull resistor type control register
- Description: This register chooses the pull resistor type.
- Offset: 0x210
| 31:0 | DPAD_RTYPE | RW | 0x0 |
Resistor type inputs to the RETENTION PAD. Value:
GPIOx_DATA
- Name: GPIO data value register
- Description: This register contains the input data and can write data output register.
- Base Address: 0xA0010000 + x*0x1000
- Offset: 0x0000
- Reset Value:0x00000000
| 31:16 | RSVD | R | Reserved bits | |
| 15:0 | DATA | RW | 0x0 |
Data value [15:0] Read: The input level state(high or low) at pin Write: To data output register |
GPIOx_DATA_OUT
- Name: GPIO data output register
- Description: This register contains the output data.
- Offset: 0x0004
| 15:0 | DATA_OUT | RW | 0x0 |
Data output register value [15:0] Read: Current value of data output register Write: To data output register |
GPIOx_OUT_EN
- Name: GPIO output enable register
- Description: This register is used to enable output.
- Offset: 0x0010
| 15:0 | EN | RW | 0x0 |
Output enable set [15:0] Read:
Write:
GPIOx_OUT_CLR
- Name: GPIO output clear register
- Description: This register is used to disable output.
- Offset: 0x0014
| 15:0 | CLR | RW | 0x0 |
Output enable clear [15:0] Read:
Write:
GPIOx_INT_EN
- Name: GPIO interrupt enable register
- Description: This register is used to enable GPIO interrupt.
- Offset: 0x0020
Interrupt enable set [15:0] Read:
Write:
GPIOx_INT_CLR
- Name: GPIO interrupt clear register
- Description: This register is used to disable GPIO interrupt.
- Offset: 0x0024
Interrupt enable clear [15:0] Read:
Write:
GPIOx_INT_TYPE_EN
- Name: GPIO interrupt type enable register
- Description: This register is used to set GPIO interrupt type. If interrupt type is 0 and interrupt polarity is 0, Low-level trigger interrupt. If interrupt type is 0 and interrupt polarity is 1, High-level trigger interrupt. If interrupt type is 1 and interrupt polarity is 0, Falling edge trigger interrupt. If interrupt type is 1 and interrupt polarity is 1, Rising edge trigger interrupt.
- Offset: 0x0028
Interrupt type set [15:0] Read:
Write:
GPIOx_INT_TYPE_CLR
- Name: GPIO interrupt type clear register
- Description: This register is used to disable GPIO interrupt type.
- Offset: 0x002C
| 15:0 | CLR | RW | 0h 0 |
Interrupt type clear [15:0] Read:
Write:
GPIOx_INT_POL_EN
- Name: GPIO interrupt polarity enable register
- Description: This register is used to enable GPIO interrupt polarity.
- Offset: 0x0030
| 15:0 | EN | RW | 0h 0 |
Polarity-level, edge IRQ configuration [15:0] Read:
Write:
GPIOx_INT_POL_CLR
- Name: GPIO interrupt polarity disable register
- Description: This register is used to disable GPIO interrupt polarity.
- Offset: 0x0034
Write:
GPIOx_INT_STAT
- Name: GPIO IRQ status register
- Description: This register contains GPIO interrupt status, and used to clear the interrupt request.
- Offset: 0x0038
| 15:0 | STAT_CLR | RW | 0x0 |
Write one to clear interrupt request Read: [15:0] IRQ status Register Write:
MSIO_VAL
- Name: MSIO digital input value register
- Description: This register contains MSIO digital input value.
- Offset: 0x220
| 31:5 | RSVD | R | Reserved bits | |
| 4:0 | MSIO_VAL | RO | N/A | MSIO digital value (when MSIO_PAD_CFG1.MSIO_A_EN = 1) |
MSIO_PAD_CFG0
- Name: MSIO pad control register 0
- Description: This register controls MSIO pad.
- Base Address: 0xA000C500
- Offset: 0x3C
| 31:29 | RSVD | R | Reserved bits | |
| 28:24 | MSIO_OUT_EN | RW | 0x0 |
MSIO output enable (active low) Value:
| 23:21 | RSVD | R | Reserved bits | |
| 20:16 | MSIO_IN_EN | RW | 0x0 |
MSIO input enable (active low) Value:
| 15:13 | RSVD | R | Reserved bits | |
| 12:8 | MSIO_OUT | RW | 0x0 |
MSIO Drive level value (valid in output mode) Value:
| 7:5 | RSVD | R | Reserved bits | |
| 4:0 | MSIO_R_EN | RW | 0x0 |
MSIO resistor enable (active low) Value:
MSIO_PAD_CFG1
- Name: MSIO pad control register 1
- Offset: 0x40
| 31 | *SADC_CLK_EN | RW | 0x0 | ADC clock enable Value:
| 30:28 | *SADC_CLK_SEL | RW | 0x0 | ADC clock select Value:
| 27 | *RSVD | R | Reserved bits | |
| 26:22 | *MSIO_MCU_OVE | RW | 0x0 | Use the setting from MCU domain, only valid when MCU domain is
ON. Value:
| 21:16 | *DEP_CTRL_WR | RW | 0x0 | Comm timer register Deep sleep control comm timer register write bit |
| 15 | *DEP_CTRL_RD | RO | 0x0 | Comm timer register Deep sleep control comm timer register read bit |
| 14:13 | RSVD | R | Reserved bits | |
| 12:8 | MSIO_R_TYPE | RW | 0x0 |
MSIO resistor type Value:
| 4:0 | MSIO_A_EN | RW | 0x0 |
Analog enable control for MSIO Pad Value:
MSIO_PAD_CFG1 does not support fields marked with an asterisk (*).
AON_PAD_CTRL0
- Name: AON GPIO pad control register 0
- Description: This register controls AON GPIO pad.
- Offset: 0x50
- Reset value: 0x00000000
| 31:30 | *RSVD | R | Reserved bits | |
| 29:28 | *TIMER_CLK_SEL | RW | 0x0 | Comm timer clock
select Value:
| 27:24 | *RSVD | R | Reserved bits | |
| 23:16 | *AON_MCU_OVE | RW | 0x0 | Use the setting from MCU domain, only valid when MCU domain is
ON Value:
| 15:8 | AON_R_TYPE | RW | 0x0 | Always on PAD resistor type Value:
| 7:0 | AON_R_EN | RW | 0x0 |
Always on PAD resister enable Value:
AON_PAD_CTRL0 does not support fields marked with an asterisk (*).
AON_PAD_CTRL1
- Name: AON GPIO pad control register 1
- Offset: 0x5C
- Reset value: 0x000000FF
| 31:30 | *TIMER_RD_SEL | RW | 0x0 | Select which timer value to read Value:
| 29:26 | *RSVD | R | Reserved bits | |
| 25 | *OVR_EN | RW | 0x0 | Enable override for all stdby_n and vdd_iso_n values |
| 24:16 | *RSVD | R | Reserved bits | |
| 15:8 | AON_OUT_VAL | RW | 0x0 |
AON PAD output value (valid when oe_n = 0):
| 7:0 | AON_OUT_EN | RW | 0xFF |
Always on PAD output enable (active low) Value:
AON_PAD_CTRL1 does not support fields marked with an asterisk (*).
