LOAD
- Name: System Watchdog Load Register
- Description: The LOAD register contains the value from which the counter is to decrease. When this register is written to, the count is immediately restarted from the new value. The minimum valid value for LOAD register is 1.
- Base Address: 0xA0008000
- Offset: 0x0000
- Reset Value: 0xFFFFFFFF
| 31:0 | COUNT | RW | 0xFFFFFFFF | Reload value. A write to this register sets the current value. |
VAL
- Name: System Watchdog Value Register
- Description: This is a read-only register used to indicate the current value of the decrementing counter.
- Offset: 0x04
| 31:0 | COUNT | RO | 0xFFFFFFFF | Current value of the watchdog counter |
CTRL
- Name: System Watchdog Control Register
- Description: The CTRL register enables the software to control the watchdog unit.
- Offset: 0x0008
- Reset Value: 0x00
| 31:2 | RSVD | R | Reserved bits | |
| 1 | RST_EN | RW | 0x0 |
Enable watchdog reset output. Value:
| 0 | INT_EN | RW | 0x0 |
Enable the interrupt event. Reload the counter from the value in LOAD register when the interrupt is enabled, after previously being disabled. Value:
INT_CLR
- Name: System Watchdog Clear Interrupt Register
- Description: A write of any value to the INT_CLR register clears the watchdog interrupt, and reloads the counter from the value in LOAD register.
- Offset: 0x0C
- Reset Value:0x00000000
| 31:0 | CLR | WO | 0x0 | Clear the watchdog interrupt event. |
INT_RAW_STAT
- Name: System Watchdog Raw Interrupt Status Register
- Description: The INT_RAW_STAT register indicates the raw interrupt status from the counter.
- Offset: 0x10
| 31:1 | RSVD | R | Reserved bits | |
| 0 | RAW_STAT | RO | 0x0 | Raw interrupt status from the counter |
INT_STAT
- Name: System Watchdog Interrupt Status Register
- Description: The INT_STAT register indicates the masked interrupt status from the counter.
- Offset: 0x14
| 0 | STAT | RO | 0x0 | Enable interrupt status from the counter. |
LOCK
- Name: System Watchdog Lock Register
- Description: The LOCK register disables write access to all other registers. This is to prevent rogue software from disabling the watchdog functionality. Writing a value of 0x1ACCE551 enables write access to all other registers. Write any other value disables write access.
- Offset: 0x0C00
| 31:1 | WR_EN | RW | 0x0 | Enable write access to all other registers by writing 0x1ACCE551. Disable write access by writing any other value. |
| 0 | WR_EN_STAT | RW | 0x0 |
Register write enable status Value:
